Snow Attachments 2320 Front Axle Tire Chains
/ 2320 Front Axle Tire Chains #1
Johnbaich
Golden
John Deere
Any suggestions on tire chains for the front axle. Living in the mountains in Colorado steep inclines are routine. Rear axle tire chains help but the front axle is doing little more than spinning. I tried standard tire chains; however, they do not clear the front drive mechanism. Has anyone found a solution to provide additional bite? Working 100% dirt/gravel.
/ 2320 Front Axle Tire Chains #2
Try Quality Chain - they have some close clearance ones and are great to work wit.
/ 2320 Front Axle Tire Chains #3
Tirechains.com has 'cable' chains that will fit the front tires of your 2320..
I would worry about chain chains not having enough clearance..
brian
/ 2320 Front Axle Tire Chains #4
Pretty sure JD has some 1" spacers that will fit for the front wheels to add the clearance you'd need. There are a couple threads I know on the GTT forum but I can't link them here unfortunately.
/ 2320 Front Axle Tire Chains #5
I use 2 link vbars on my L3400, they work great.
