2320 3-5th SCVs?
/ 2320 3-5th SCVs? #1
scrappy isb67
princeton nc.
JD 2320
in the future I want to add a grapple and rear couplers to my 2320. I intend to use the current SCVs for the rear couplers.
The problem I am running into is finding a valve that will work. I want a 3 spool valve with float on 1 spool, regen on another and l I don't care on the 3rd. this valve is going to be for the loader/grapple. the valve also has to either be electronic or cable operated, I plan to mount the valve on the RH loader subframe and either have the controls mounted to the current joystick(if it is electronic) or have a 2nd joystick if it is cable operated. But I am having no luck finding the 3 function valve with the float and regen. Any one have any ideas where to find one?
/ 2320 3-5th SCVs? #2
/ 2320 3-5th SCVs?
This valve has everything you need except regen.
What is it about regen that you really need, the fast dump function?
Surplus Center - 3 SPOOL 25 GPM JOYSTICK LOADER VALVE W/GRAPPLE
A lot of the loader valves have float and regen, and you can add a single spool valve third valve with PB for whatever.
Two of these would give you two floats, two regens.
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Thanks for the input!
I do like the fast dump that regen gives me.
I have run loaders w/o regen and it seems like regen on the current scv/loader is a good thing!
and all in a 3 spool valve.
/ 2320 3-5th SCVs? #4
Check ebay. A three function JD loader valve with float, regen, (cable operated) and electric operated third fuction just sold for under $200 shipped. Same valve from JD would have been $2200. You just have to research if it's open or closed center before you buy.
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2224CFL (A61572)
2224CFL (A61572)
2010 Dodge Grand Caravan Van (A61574)
2010 Dodge Grand...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
