2320 3-5th SCVs?
/ 2320 3-5th SCVs? #1
scrappy isb67
Gold Member
princeton nc.
JD 2320
in the future I want to add a grapple and rear couplers to my 2320. I intend to use the current SCVs for the rear couplers.
The problem I am running into is finding a valve that will work. I want a 3 spool valve with float on 1 spool, regen on another and l I don't care on the 3rd. this valve is going to be for the loader/grapple. the valve also has to either be electronic or cable operated, I plan to mount the valve on the RH loader subframe and either have the controls mounted to the current joystick(if it is electronic) or have a 2nd joystick if it is cable operated. But I am having no luck finding the 3 function valve with the float and regen. Any one have any ideas where to find one?
/ 2320 3-5th SCVs? #2
/ 2320 3-5th SCVs?
This valve has everything you need except regen.
What is it about regen that you really need, the fast dump function?
Surplus Center - 3 SPOOL 25 GPM JOYSTICK LOADER VALVE W/GRAPPLE
A lot of the loader valves have float and regen, and you can add a single spool valve third valve with PB for whatever.
Two of these would give you two floats, two regens.
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Thanks for the input!
I do like the fast dump that regen gives me.
I have run loaders w/o regen and it seems like regen on the current scv/loader is a good thing!
and all in a 3 spool valve.
/ 2320 3-5th SCVs? #4
Check ebay. A three function JD loader valve with float, regen, (cable operated) and electric operated third fuction just sold for under $200 shipped. Same valve from JD would have been $2200. You just have to research if it's open or closed center before you buy.
