2310 DASH
/ 2310 DASH #1
THUNTING
I recently bought a 2310 (Gear) on ebay and really like the tractor. When I bought the tractor it was missing one of the four bolts that hold the instrument cluster to the dash. I attempted to replace the bolt but it appears that there isn't a nut plate. I don't want to lossen one of the other bolts to see if this is true because if there is just a nut on the back I might not be able to get it tight again. Am I missing the nut plate or is there a nut on the back that I'll have to relace by taking the whole @#%$& dash off? Any help would be greatly appreciated. Also the advertisments for this model tractor state that here is a tool bag under the floor mat. I took a peek and don't see anything, where is this thing hiding. I have been reading many of the posts in tractorbynet and have learned a great deal and have found eveyones comments very interesting.
Thanks
THUNTING
/ 2310 DASH #2
Congrats! Wish it were mine! Where's the loader?
/ 2310 DASH #3
On my 3510 it's on the left of the floorboard. It's a recessed well with a hinged lid and it's covered by the rubber floormat.
/ 2310 DASH #4
Go ahead and take the other screws out. There is what is called a U nut on the dash and the instrument cluster screws screw into it. Pull the cluster out and you will see what I mean. You should be able to find a U nut at any body shop as they are used commonly in autobody applications. As for the tool box it is on the 3510 & 4110 tractors only. The 2310 & 2810 didn't have it. Good luck with your 2310! (One Tough little tractor)
Galen LaWall
Your Mahindra Tractor Dealer
Batavia NY 14020
585-343-0770
/ 2310 DASH
Thanks for all the comments. I'll take your advice about the dash, I knew someone would have the right answer. I'm getting the tractor ready to clear 3+ acres of brush and recently purchased a 5' Lowery brush cutter and a Lowery 5' fully adjustable blade. Looks good on the tractor (red) and is built strong. I would have bought a tractor with FEL but I'm on a tight budget. Again, thanks from a new Arkansas Mahindra owner.
THUNTING
/ 2310 DASH #6
A good hardware store should also have the U-nuts Galen mentioned.
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
