2310 back hoe problems
/ 2310 back hoe problems #1
Rob2310
West Virginia
GC 2610
After I run the back hoe on my 2310 and the hydrualic oil gets hot, when the hoe is stessed, I get a severe whinning sounding from the tractor. I'm not sure where exactly it's coming from, but sounds like the rear end. The hoe seems not to have as much power after it runs for twenty minutes in 90 degree weather and starts the whinning when it's worked hard.
My assessment is that when the fluid bypass's a valve due to to much strain on the hoe, the whinning starts. It does not due this when you first start digging and works fine, but after it warms up the problem starts. I believe that either the pump is bad or the fluid is breaking down.
I called my dealer, which is along ways away and talked to the mechanic, who recommended checking to make sure all the lines were tight and call him back if it happens again. I did this before I called them.
Anyone else experience this?
1987 FORD F-8000 ROLLBACK TRUCK (A64277)
1987 FORD F-8000...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
1994 John Deere 8300 (A64126)
1994 John Deere...
