2305 Power loss?
/ 2305 Power loss? #1
Curly69
Henderson County, NC.
2006 JD 2305
Try to make this short but a long story.
LOANED my tractor out and didn't get it back for over a month. It was left outside longer than it's ever been in the 10.5 yrs I've owned it.
Anyhow hydro fan broke and they used in for 30-40 hours with it broke I figure. Fluid is fried to dark brown or black. dampening control is bent, drive shaft bent. Had that fixed and put in new U-joints. to my surprise with 900 hours they were fine but I replaced them anyway since it was apart. Change the fluid, filter and cleaned the screen all nasty. Just did my annual maintenance not long ago and changed the oil, filter, air filter and greased her up. Keep in mind the hydro fluid was just changed last yr as part of the reg maintenance.
After all this the power is at about 60-70%, tried to cut the grass yesterday and it was like pulling teeth from a bear. I've been cutting the same 3.5 acres for 10.5 years and it rarely ever bogs down and it did it all day. Just no power is all. I've been told to do the full throttle in reverse then hit the forward pedal and no change. This thing would spin tires in 4WD but never ever bogged down, now the slightest obstruction it bogs.
I've read where the pressure relief valve could be bad but that's over 600.00? Has anyone ever just taken one apart to see if there was a problem?
Pictures for the weary and I am embarrassed to have let someone borrow it! Never again will it leave my property.
The pile of crud was just what I could reach to pull out on top of the hydro pump by all the linkage. I blow it out or hose it out every few times I use it and spray the linkage with lithium grease and it's worked for me more than 10 years now, others just don't respect things I figure.
Any suggestions would be great!
/ 2305 Power loss? #2
Trade the unit as fast as you can. You loaned out a tractor and now have a money pit. I am afraid your tractor is ruined, a very expensive lesson to learn. I hope you at least learned to never loan your tractor again.
People will destroy borrowed equipment and then cuss you if you ask them to pay for repairs.
/ 2305 Power loss? #3
Trade the unit as fast as you can. You loaned out a tractor and now have a money pit. I am afraid your tractor is ruined, a very expensive lesson to learn. I hope you at least learned to never loan your tractor again. People will destroy borrowed equipment and then cuss you if you ask them to pay for repairs.
Originally Posted by Wvanatti
I would drain all fuel and replace fuel filter. Never know what has been poured into the tank, or how clean the container was. I remember reading something very similar on here a couple years ago. Guy finally took the filter assembly off and found a spider at the outlet was the issue. Might be a cheap fix- or peace of mind at the very least.
Outlet
/ 2305 Power loss? #4
DITTO on being sure you have good fuel flow from fuel tank to injector pump.Is fuel tank venting??
/ 2305 Power loss?
I took the filter off and changed it a few days ago. I took every fuel line off I could and sprayed it out with gumout then air, they were pretty clean. Turned on the petcock and the fuel to the filter flowed just as always. What else would there be to clean?
/ 2305 Power loss? #6
Check to be sure fuel return lines(key 20 & 22)are not blocked IE is excess fuel being returned to tank?
/ 2305 Power loss?
Another question about JD pricing? I've been looking for part# LVA801209 and understand it's been replaced by LVA 803403. But I can still find the original on line in several places for as little as $250.00. Yet the new number over $600.00.
What's the difference and which do I have in a 2006 2305?
/ 2305 Power loss?
Per the tech manual:
Wheels rotate in one direction only.
a. Forward or reverse relief valve malfunction. Swap forward and reverse relief valves to diagnose and isolate problem.
b. Pedal linkage damaged or broken.
Now to figure the difference in the new part numbers and price.
/ 2305 Power loss? #9
I don't have good news for you. First, I'm surprised the fan lasted as long as it did. Heat, age, and debris cause them to break. Down here in the heat they don't last but maybe 3 - 4 years.
Looking at the oil on your finger, and the screen filter, there are problems. If if were mine, I'd start dis assembling the transmission to find out what is going out. Long ago I had started a thread on the 2305 we had at work. I remember that the tranny castings were up revved to include a beefier bearing support for one of the shafts. The one at work ended up with a major tranny malfunction and the boss traded it in after it was torn down at the dealership. Ultimately, I believe your problem exists within the tranny.
If you have the model with the later improved tranny casting, you might be able to rebuild it, if not too much internal damage exists.
/ 2305 Power loss? #10
Upon further reading, you might have a bearing that is failing in the transmission.
I believe the tranny is a Tuff Torq K92. If so, you can get parts directly from TT.
/ 2305 Power loss?
OK I do think I have figured out the problem.
After switching out the forward and reverse valves I now have ground speed again, Hard to tell but I would figure 90%, ran around the yard twice with the mower cutting and where it's been bogging down it barely bogged but the grass was wet so. I asked around about the new part number and the old and was told if I could find the old go for it so I did from a JD parts store on line. $250.00 compared to $608.00. We'll see.
Before I put the new valve in I will be changing the fluid, filter and cleaning the screen again!
Anyway since I have it all apart I'm going to give it a like new detail which I haven't done in two years. For ten+ yrs old she still looks like new!!!!
/ 2305 Power loss?
IMG_20160910_110252.jpgIMG_20160910_112245.jpgOK All back together and back to normal. The on-line JD Parts store was a scam bait and switch. Two days after putting in the order and paying I received an E-Mail saying the part was no longer available and replaced with the new part for 3x's as much of course. I got a refund and went to the JD store here in SC and he cut me a good deal I guess $489.50 instead of $560.00.
I changed the fluid and filter and cleaned the screen again and was surprised it was still dirty, I guess that's from what I couldn't get out from draining it because it says 3.4 gallons but only took 3 gallons and about a pint.
As far as the part there is a physical difference as you can see but the only difference I could see was the O-Ring was beefy on the new one and the old one it was flat and used up?
I figure before winter sets in I will change the fluid again and clean the screen.
Total was $1127.00 parts only, 300 miles in driving to JD three times, and I figure about hours 10 labor and three driving hours.
Just a few more pictures.
/ 2305 Power loss? #13
View attachment 480438View attachment 480439OK All back together and back to normal. The on-line JD Parts store was a scam bait and switch. Two days after putting in the order and paying I received an E-Mail saying the part was no longer available and replaced with the new part for 3x's as much of course. I got a refund and went to the JD store here in SC and he cut me a good deal I guess $489.50 instead of $560.00.
Are you telling us that just 1 of the parts on the left costs $489.50 ???
/ 2305 Power loss?
Yes and that was a good price! The JD website has it at $609.51 plus tax. I kind of had to tell the guy how much I spent there and that I traveled there three times from an hour away. The one on the left is the new one.
1997 JCB  436B WHEEL LOADER (A63569)
1997 JCB 436B...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
WHITE 2-60 TRACTOR (A63291)
WHITE 2-60 TRACTOR...
HUSKY AIR COMPRESSOR (A63569)
HUSKY AIR...
TEREX LIGHT TOWER (A63569)
TEREX LIGHT TOWER...
Case 580 Super M Backhoe (A64047)
Case 580 Super M...
