2305 Caution Light Problem
/ 2305 Caution Light Problem #1
EasyE
North Carolina
JD 2305
For the last three times I have cranked up my tractor the yellow caution lights come on and stay on? I have looked for any wiring problems that I could see from just looking around but nothing out of the ordinary. Anyone else have this issue with their 2305 or any JD tractor for that matter?
/ 2305 Caution Light Problem #2
Sounds like a light switch is in your future
/ 2305 Caution Light Problem #3
Try spraying some WD40 in the ignition key switch.
/ 2305 Caution Light Problem #4
you probably already checked but just wondering have you checked oil,transmission and antifreeze levels.
/ 2305 Caution Light Problem #5
Hope this helps.
/ 2305 Caution Light Problem #6
Be very careful with WD40 and electrical connections.
I drive truck, the satellite system quit working, so I pulled the plug on the 'globe'. It was slightly corroded. So I got out the only thing I had with me.....WD40.......and proceeded to spray the connectors, reconnected them several times to clean them, and all was well.........till the next day when I was in our shop.
The WD40 apparently caused a bridge between two elecrical ports and caught fire.
/ 2305 Caution Light Problem #7
I would try electric contact cleaner (Auto parts stores). Try in the switch connector and the pigtails for the lights.
/ 2305 Caution Light Problem #8
There are 2 diodes under the dash that can cause problems similar to what you are describing.
Thanks folks for your help, I'm working on it.
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
2017 International HX620 Quint Dump (A62613)
2017 International...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
