2305 Caution Light Problem
/ 2305 Caution Light Problem #1
EasyE
North Carolina
JD 2305
For the last three times I have cranked up my tractor the yellow caution lights come on and stay on? I have looked for any wiring problems that I could see from just looking around but nothing out of the ordinary. Anyone else have this issue with their 2305 or any JD tractor for that matter?
/ 2305 Caution Light Problem #2
Sounds like a light switch is in your future
/ 2305 Caution Light Problem #3
Try spraying some WD40 in the ignition key switch.
/ 2305 Caution Light Problem #4
you probably already checked but just wondering have you checked oil,transmission and antifreeze levels.
/ 2305 Caution Light Problem #5
Hope this helps.
/ 2305 Caution Light Problem #6
Be very careful with WD40 and electrical connections.
I drive truck, the satellite system quit working, so I pulled the plug on the 'globe'. It was slightly corroded. So I got out the only thing I had with me.....WD40.......and proceeded to spray the connectors, reconnected them several times to clean them, and all was well.........till the next day when I was in our shop.
The WD40 apparently caused a bridge between two elecrical ports and caught fire.
/ 2305 Caution Light Problem #7
I would try electric contact cleaner (Auto parts stores). Try in the switch connector and the pigtails for the lights.
/ 2305 Caution Light Problem #8
There are 2 diodes under the dash that can cause problems similar to what you are describing.
Thanks folks for your help, I'm working on it.
(1) UNUSED 12-16.5 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12-16.5...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A61572)
2018 Roadtec...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
POWELL (4) ROW FERTIZER DISTRIBUTOR (A64280)
POWELL (4) ROW...
2018 Isuzu FTR Landscape Dump Truck (A61573)
2018 Isuzu FTR...
