2040 Starter removal
/ 2040 Starter removal #1
Royce Fink
I have a 70 something model 2040 with a JD 145 front end loader. I need to remove the starter, it's dragging real bad. I can't figure out how to remove it. I can get to the top bolt easy but the bottom one is a real bugger. Does the front end loader have to be removed to get to it?
/ 2040 Starter removal #2
I have the 830 which is the same tractor, previous generation.
I also have the same loader and had to remove the starter.
I removed the loader, then the right side mount and 'plate'. Not sure what it's called. Using another tractor with a loader and chain hoist made it easier to remove the loader mount.
Then I could access the starter. Sounds hard but it's just heavy parts with large bolts. My loader is a quick attach tho.
Hope this helps.
/ 2040 Starter removal #3
The "plate" behind the loader mount is called a side frame.
/ 2040 Starter removal #4
Right, side plate.
I actually didn't remove it to access the starter.
The lower bolt on the starter can be reached w/o removing the side plate. It is tight though.
New/Unused Electric Golf Cart (A61166)
New/Unused...
208320 (A58375)
208320 (A58375)
2012 Range Rover SUV (A61569)
2012 Range Rover...
CAT 953 Crawler Loader (A61166)
CAT 953 Crawler...
John Deere 750C Dozer (A64047)
John Deere 750C...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
