2040 Starter removal
/ 2040 Starter removal #1
Royce Fink
I have a 70 something model 2040 with a JD 145 front end loader. I need to remove the starter, it's dragging real bad. I can't figure out how to remove it. I can get to the top bolt easy but the bottom one is a real bugger. Does the front end loader have to be removed to get to it?
/ 2040 Starter removal #2
I have the 830 which is the same tractor, previous generation.
I also have the same loader and had to remove the starter.
I removed the loader, then the right side mount and 'plate'. Not sure what it's called. Using another tractor with a loader and chain hoist made it easier to remove the loader mount.
Then I could access the starter. Sounds hard but it's just heavy parts with large bolts. My loader is a quick attach tho.
Hope this helps.
/ 2040 Starter removal #3
The "plate" behind the loader mount is called a side frame.
/ 2040 Starter removal #4
Right, side plate.
I actually didn't remove it to access the starter.
The lower bolt on the starter can be reached w/o removing the side plate. It is tight though.
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
UNUSED JOHN DEERE STRIP-TILL WHEEL ASSIST (A62131)
UNUSED JOHN DEERE...
207275 (A52708)
207275 (A52708)
2013 International WorkStar 7400 Bucket Truck, VIN # 1HTWGAAR2DJ222471 (A61165)
2013 International...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
