2040 Starter removal
/ 2040 Starter removal #1
Royce Fink
I have a 70 something model 2040 with a JD 145 front end loader. I need to remove the starter, it's dragging real bad. I can't figure out how to remove it. I can get to the top bolt easy but the bottom one is a real bugger. Does the front end loader have to be removed to get to it?
/ 2040 Starter removal #2
I have the 830 which is the same tractor, previous generation.
I also have the same loader and had to remove the starter.
I removed the loader, then the right side mount and 'plate'. Not sure what it's called. Using another tractor with a loader and chain hoist made it easier to remove the loader mount.
Then I could access the starter. Sounds hard but it's just heavy parts with large bolts. My loader is a quick attach tho.
Hope this helps.
/ 2040 Starter removal #3
The "plate" behind the loader mount is called a side frame.
/ 2040 Starter removal #4
Right, side plate.
I actually didn't remove it to access the starter.
The lower bolt on the starter can be reached w/o removing the side plate. It is tight though.
2024 Scag Cheetah 61in. Zero Turn Commercial Mower (A61567)
2024 Scag Cheetah...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
