2040 Starter removal
/ 2040 Starter removal #1
Royce Fink
I have a 70 something model 2040 with a JD 145 front end loader. I need to remove the starter, it's dragging real bad. I can't figure out how to remove it. I can get to the top bolt easy but the bottom one is a real bugger. Does the front end loader have to be removed to get to it?
/ 2040 Starter removal #2
I have the 830 which is the same tractor, previous generation.
I also have the same loader and had to remove the starter.
I removed the loader, then the right side mount and 'plate'. Not sure what it's called. Using another tractor with a loader and chain hoist made it easier to remove the loader mount.
Then I could access the starter. Sounds hard but it's just heavy parts with large bolts. My loader is a quick attach tho.
Hope this helps.
/ 2040 Starter removal #3
The "plate" behind the loader mount is called a side frame.
/ 2040 Starter removal #4
Right, side plate.
I actually didn't remove it to access the starter.
The lower bolt on the starter can be reached w/o removing the side plate. It is tight though.
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
John Deere 6120M (A57148)
John Deere 6120M...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2004 John Deere 4720 (A60462)
2004 John Deere...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
