2022 Polaris Ranger EV - picked up today!
   / 2022 Polaris Ranger EV - picked up today!
I haven't been by in a while!
EV is over 2 years old now. I do notice the batteries not lasting quite as long, but still completely fine for me.
In November 2022 I bought a ground drive manure spreader, just a 25 bushel size, and I use my FEL to fill it, then tow it with EV to spread the manure.
It's a small one, but I spent $1000 on it . The guy who was spreading for me charged $650 the last time he did it, which sent me shopping for a used one. I figure I've paid for the spreader by now. It is more time, but when the grandkids come, they love watching the loader and spreader work.
I should be better at keeping the batteries topped off, but now that my back is fixed (surgery in Jan 2023) I actually use a wheelbarrow more often, and don't jump in EV as often for quick stuff.
Currently it needs a bath and I need to top off the distilled water in the batteries. I've noticed if you overfill, I end up with battery acid on the rubber mats under EV.
That Amazon replacement dump hydraulic lift is still going strong and I never did get around to getting a restrictor cable. I figure it will be great for 3 years since I spent the extra $6.99 on the 3 year warranty (which I rarely do) from Amazon.
   / 2022 Polaris Ranger EV - picked up today! #42
I've had a Polaris EV since it was new about 5 years ago. The lead acid batteries died a little over a year ago, probably one or two really weak batteries with the rest not much better. I decided to replace them with LiFePo lithium batteries, which cost more than the lead acid replacements would have, but they should last a lot longer, never need watering and actually provide more range because they can be more deeply drained without damage.
Having said that, I made sure to flush the battery trays with the garden hose frequently to prevent battery acid from rotting the metal, and when I pulled the old batteries out the metal was only lightly rusted. I watered the batteries one cell at a time for a few times, then realized I was not keeping on top of that due to the difficulty and time it to to water them, so I installed one of those watering systems that you just pump distilled water into a hose and it fills all the cells, but with a valve on each one to keep from overflowing. One hose attachment to pump into per side, I believe it worked well but did not bother to check each cell after installing it. Those batteries are thirsty! They took gallons of distilled water to top both banks up, sometimes. Now that watering system is surplus, PM me if you are interested in buying it. It's complete, but not all prettily sorted as I had meant to do before selling it.
FYI, I used two 48v Falcon Elite batteries in parallel from BigBattery.com for the replacements, together they can supply at least 650 amps for a few seconds, as I believe that is the max current draw under full load. I've never had them cut out as long as they have sufficient charge. I put one on each side where the lead acid batteries were, mounted the new charger on to of the old one, leaving it wired to the controller and it all work quite well. Not as elegant as completely removing the original lead acid battery charger, which I plan to do someday, but it all works. Only real issue is installing a "coulomb counting" state of charge meter, as measuring voltage of the lithium batteries is not a useful "gas gauge" as it is with lead acid.
Oh, and the EV is now 500 pounds lighter šŸ˜„.
   / 2022 Polaris Ranger EV - picked up today! #43
Batteries. Yuk. I'm happy you guys like those EVs. I detest messing with batteries. That reminds me of the golf cart days and fooling with degrading batteries, acid and corrosion, distilled water and battery cables.
   / 2022 Polaris Ranger EV - picked up today! #44
I'm waiting for some you-tuber to come out with a good conversion from DeWalt Flexvolt to a small utv. Like the Greenworks UTV.
I only NEED to go about 1,000 yards most of the time, not miles. There's no corrosion, acid, or distilled water and I have the batteries already for my blower, trimmer and lawnmower.
   / 2022 Polaris Ranger EV - picked up today! #45
I've had my Polaris Ranger since 2007 when I bought it new. I've had the usual suspension bushing replacement, CV axle, fuel pump issues that I finally resolved and of course several batteries. It's easy to work on and parts are readily available. I guess there's a tradeoff for everything.
   / 2022 Polaris Ranger EV - picked up today! #46
Yes, they all need some repairs. That's what happens when you use your machine and things spin. I can't see a battery powered atv or utv in our future but did purchase a zero steer. Thanks for your thoughtful posts on your ranger.
   / 2022 Polaris Ranger EV - picked up today! #47
I can see EV UTVs but not with lead acid batteries. I would rather gas up than deal with the hassle of lead acid battery maintenance.
But "one size" does not fit all. It they work for golf carts they should work for a lot of people with UTVs.
   / 2022 Polaris Ranger EV - picked up today! #48
Let's just forget about using the problems of lead acid batteries as an excuse to not like battery powered machines. That's an old, soon to be considered an ancient way of powering things. The only advantage the lead acid batteries had in my Polaris EV was that being mounted so low in the chassis, I never once felt unstable no matter what slope I was on. Now that it is 500 pounds lighter, it rides higher up and does not have the massive ballast of the lead acid batteries. I imagine that if it was designed for lithium batteries, that would be taken into account when designing the suspension. Sure, I could lower the EV, but i don't really need to, so won't go to the effort or expense. This EV gets used for frequent very short trips and to pull a mower at slow speeds for hours. No clutch, belts filters or stink to worry about. Since we installed solar panels, it's truly powered by the sun. Just like my electric zero turn. I love powering these things for darn near free. I'm not trying to save the Earth by going electric, just the hassle of petrol powered machines. I also realize that i am probably spending more money for electric powered toys, but the convenience and ease of use is a joy. Plus they always just start right up.
Could you post pictures of the new charger and batteries?
I also make sure to hose out around my battery compartment fairly often, when we fill the batteries, I make sure it's cleaned up first, because I don't want hay and manure bits falling into the batteries.
I will admit that we don't top them off monthly, but it also is because after the initial time I filled them and they took 2 gallons of distilled water, now it's usually right around a gallon for all 8 and our method of topping them off is a bit sloppy, so it could be less. We use a giant syringe with an old plumbing hose wedged onto the end to direct it into each compartment. I pour, husband moves the hose end from cell to cell.
So when we added water to the batteries, I realized several connector cables had corroded completely through! Clearly I need to be more diligent about rinsing the battery acid off/out. I saw one recommendation to spray baking soda water on the batteries at some interval, but I didn't note the interval. I was looking for parts diagram mostly and the specs on the wires.
The Polaris branded cables are $50 each and there are 6 total. The same 4AWG wire and small (not the big battery terminal size, a bolt) connectors for golf carts are $5.95 each. I'm going to give those a try, since it's a battery cable. My hubby was just going to buy a coil of wire and make new ones, but then I found these.
XFaxman - I saw you posted a response on the Polaris Ranger EV forum about a small wire and I need to go find that post again, as I think the same wire also another that corroded through, some sort of fuse line, pretty delicate wire.
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
2013 Nissan Sentra Sedan (A53424)
2013 Nissan Sentra...
2014 CAT CT6 (A55745)
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
2014 International ProStar Truck, VIN # 3HSDHSJR1EN768255 (A54865)
2014 International...
2017 TRAVIS BODY & TRAILER END DUMP (A55745)
2017 TRAVIS BODY &...
