2022 L3302
/ 2022 L3302 #41
If your backhoe is Kubota, it will be a frame mounted, not a 3 point mount. I have install more Kubota backhoes than I care to remember. If everything is correct you should be able to lift the rear of the tractor when the BH dipper is 1/2 half way extended and the boom down. Should even be able to move the tractor sideways. Tractor has more than enough hydraulic power to do so.
/ 2022 L3302 #42
Can’t afford 90 or 120k.
Not rich!
It doesn’t attach to the 3 point it has a subframe.
Tractor manufacturers should make certain add-ons like this get proper hydraulic flow to them.
Right, instead of a 3pt you get a little tractor with a wanna be backhoe.
I am not rich either-I suppose, but I found a great used bh for under 30k that will do everything a bh is supposed to do, and leave my tractor for tractor stuff.
No hard feelings; just busting your balls; hope you get it worked out.
/ 2022 L3302 #43
38k for a brand new tractor with a leaky hose, yeah I’m rich I don’t care, b nope, not me!
Stop acting like it rolled off the delivery truck and caught on fire. A hose is like $50 and the dealer will take care of it although maybe not in the next 5 minutes. Put on your big boy pants and quit whining. If you’re that unhappy get your money back and do something else.
/ 2022 L3302
Right, instead of a 3pt you get a little tractor with a wanna be backhoe. View attachment 759825
Trust me, has I found one like that I would’ve bought it, but these times are hard to find things and they want new prices for used stuff!
I’m just not a very lucky person!😁
/ 2022 L3302
Glad you’re rich and can shrug off crappy stuff like it was nothing!
Personally I’m not rich and struggle to buy a machine, like someone else said this should have been caught both times by the dealer.
Do you think Kuhota would like dealers to tarnish their reputation with bad prep work?
Oh, besides the inability of the machine to do simple task with the backhoe.
/ 2022 L3302
That’s whati was thinking it should be able to do and expected from it.
Not being able to even sweep a pile of loose dirt back into the ditch with the bucket is wrong.
/ 2022 L3302 #47
Suggestion: Have your sales person come out and observe you operating the unit and then inform you if you are doing anything incorrectly And yes, you should be able to "sweep" dirt back into a hole.
/ 2022 L3302 #48
I have a 1960 international 404 with loader and chloride filled rear tires. Recently bought a 1970’s bush hog backhoe with subframe. Made mounts on tractor for it and a pto power unit. I can pick up the tractor with the backhoe, the loader down, and still move it sideways. All at an idle. You should be able to do more with new.
/ 2022 L3302 #49
Swing is the weakest function. When I cover a ditch with my mini x I’ll put my 3 foot bucket on and drive beside the ditch and pull the dirt back in. It’s way faster than taking tiny bits at a time swinging it in. It’s also less stressful on the equipment. If you were using a hand rake you wouldn’t swing it sideways. Your arms are much stronger to push and pull compared to sideways. The backhoe is the same way. Do you have any experience on other similar sized tractors to compare to?
/ 2022 L3302 #50
Dude you’re really annoying, in relationship to other cheaper brands Kubota is considered a more premium brand.
Dude.... you're even more annoying.
Coming on here whining and crying about a minor problem.....that your dealer is working on....
And giving us little bits of information and not the whole story.
People on this forum are here to help. But you appear to not want help and only want to whine and cry about a small issue with your machine and how poor you are. Take that BS elsewhere.
I told you early in this post....get your money back. Get another brand so you can cry and bash them everytime something doesn't go your way.
/ 2022 L3302
And this post helped how?
Others are chiming in with suggestions, you, you’re just spewing words.
Get a life, and stop trolling here.
/ 2022 L3302
Swing should be no weaker than any other function.
And I do backfill sometimes like you described, but at times it’s handy to just sweep the dirt back in without moving the tractor, it should be able to do it easily.
/ 2022 L3302
I used the word “sweep” as a descriptive word to easily convey an image, sorry it upsets you.
I will gladly show anyone, I have a video I took that day but this site doesn’t allow video uploads here.
/ 2022 L3302 #54
Swing is weaker than any other function. Tractor backhoes, real construction backhoes, mini excavators, big excavators, and cranes have virtually no power on the swing. It’s not meant to move material that way. If you’re expecting the Kubota to do that or any other brand machine you’re going to be disappointed.
/ 2022 L3302 #55
Doesn't upset me. Was just trying to say that you should be able to move some dirt with the bucket. And yes, the swing is not as strong as you would think.
/ 2022 L3302 #56
I understand your frustration. When you say premium, you mean overpriced. For some people the reassurance of buying a more expensive brand or with a name familiar to more people is reassuring, too. The expectation is that your chances of problems will be much lower.
Any brand will have some that are just lemons. Every brand has some dealerships with issues. Maybe it was a new guy assembling. Maybe just someone distracted. The fact remains that your brand new tractor does not do that for which you purchased it. If it is me, I push the dealership to take it back and return my money. Likely you will never trust it and it will gnaw at you for years.
Sorry for your luck.
/ 2022 L3302 #57
I have made several posts asking questions that go unanswered, and making suggestions of things you should to to troubleshoot or help you out. I can tell at this point you obviously have no clue about your machine, and for someone claiming to come here for help....you do a terrible job of explaining things, and leaving out key details. Then you go on the defensive and start attacking the very people you seek help from.....all I can do is shake my head.
/ 2022 L3302 #58
This shows your lack of understanding as well. As already mentioned....swing IS the weakest function and not made to move material under resistance.
Look at the size/stroke of the cylinders in relation to how far the boom swings. Simple physics and geometry.
Weld you up a bucket rotated 90 degrees so the dig path is inline with the swing arc. See how well it digs compared to the dipper and bucket cylinders. I told you WAY BACK on post #8 that you need to put a pressure gauge on the system and see what PSI you are getting. You ever do that? or have your dealer do that? Or do you think thats just me trolling and spewing words :ROFLMAO:
/ 2022 L3302 #59
It won’t, it creeps backwards when I tried to just roll it with the FEL off the ground, heck with the FEL bucket flat on the ground you should be able to push it backwards with the backhoe.
My tractor backhoe has pretty decent power IMO (has dug everything I have needed over the years), but I can't push my tractor ahead with the FEL bucket on the ground.
I need to raise the FEL bucket off the ground and have the tractor in neutral to shove the tractor ahead.
/ 2022 L3302 #60
The Kubota tractor backhoes are the best in industry. That doesn’t change the fact it’s still a tractor backhoe, not a 50,000 pound excavator. The controls are the smoothest, the tractor subframe mounts are the best, and the backhoe buckets are the best. One minor dealer prep problem doesn’t make it junk. And ever manufacturer has a few problems. That’s why warranty exists.
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
John Deere 1025R (A62177)
John Deere 1025R...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
