Oil & Fuel 2020 Hydraulic Pump Filter?
   / 2020 Hydraulic Pump Filter? #1
bodin1968
Montgomery, AL
1968 John Deere 2020
recently changed all of the fluids on the 2020 (hydraulic oil/filter, engine oil/filter, coolant etc.).... i'm having no hydraulic issues w tractor.
should i pull this hyd. pump filter and clean it or leave it alone? thanks in advance....
   / 2020 Hydraulic Pump Filter? #2
I would first pull and check/clean the internal sump screen that is in the transmission case. 27 in the drawing
thanks zebra... will i lose much hyd. oil when i pull this screen to clean?
   / 2020 Hydraulic Pump Filter? #4
Only about 8 gallons. In lieu of draining the oil one can insert the nozzle on hose of an operating shop vac in hyd filler hole with excess of hole blocked off with a shop towel to create a vacuum.
no thanks. 2020 manual says change Hyd. oil every 1k hours. is this right?
...and the manual says there are 2 hyd. drain plugs? i see one drain plug. is the other hidden by my draw bar?
   / 2020 Hydraulic Pump Filter? #6
Yes IIRC 1 drain plug is hidden by drwawbar.
EZ-GO Freedom TXT Electric Golf Cart (A57149)
EZ-GO Freedom TXT...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250208 (A57453)
2000 Volvo VNL...
KUBOTA RTV 1100 (A58214)
KUBOTA RTV 1100...
Pickup Truck (A59230)
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
