Oil & Fuel 2020 Hydraulic Pump Filter?
/ 2020 Hydraulic Pump Filter? #1
bodin1968
Montgomery, AL
1968 John Deere 2020
recently changed all of the fluids on the 2020 (hydraulic oil/filter, engine oil/filter, coolant etc.).... i'm having no hydraulic issues w tractor.
should i pull this hyd. pump filter and clean it or leave it alone? thanks in advance....
/ 2020 Hydraulic Pump Filter? #2
I would first pull and check/clean the internal sump screen that is in the transmission case. 27 in the drawing
thanks zebra... will i lose much hyd. oil when i pull this screen to clean?
/ 2020 Hydraulic Pump Filter? #4
Only about 8 gallons. In lieu of draining the oil one can insert the nozzle on hose of an operating shop vac in hyd filler hole with excess of hole blocked off with a shop towel to create a vacuum.
no thanks. 2020 manual says change Hyd. oil every 1k hours. is this right?
...and the manual says there are 2 hyd. drain plugs? i see one drain plug. is the other hidden by my draw bar?
/ 2020 Hydraulic Pump Filter? #6
Yes IIRC 1 drain plug is hidden by drwawbar.
