Looking for some ideas as to what could be wrong with it. Dealer will have to pick up after the weekend, but in the meantime any help would be appreciated.
Has 220 hours on it, no trouble until today.
Started it up and in the 10 minutes of warm up at idle, the engine sounded just a little different. Almost like there was something extra running with a slightly higher pitch. Also it had slightly different smell.
Warmed up as usual and when I put it in gear and then moved the shift into Forward the extra sound went away but it made a sound like a truck's air brakes just for a second - it usually doesn't do this. I drove it out of the shed, and put it in Neutral and the same air brake sound. Normal temp on gauge.
I hopped off for a second, it then stalled out and a bunch of white smoke came out of the rear part of the engine compartment. When I opened the hood the smoke was gone, and I couldn't tell where it had come from.
Haven't tried to restart it. All fluids are at appropriate levels, all service up to date. Worked fine two days ago.
Any thoughts much appreciated.
