2017 Kubota M7060 with engine problem - diagnosis help please
   / 2017 Kubota M7060 with engine problem - diagnosis help please #11
I don't think it's a regen or DEF issue.
The pic you posted, how about holding the other end and take a pic exposing the end that you were holding.
Update:
1. ovrszd is correct - it was not a DEF issue. I apologize for not posting another photo. Somehow I missed your post. The piece was from the starter.
2. I called the dealer last Monday. He sent his mobile crew out. They identified the problem as the starter. Apparently there is a service bulletin out about the key switch sticking and burning out the starter.
3. It was under warranty, and they had the new starter and key switch installed on Friday. They ended up leaving the headlights on by accident and draining the battery, but once I figured that out and charged the battery the tractor is running perfectly again.
4. Thanks to everyone for their input on this.
Bob
   / 2017 Kubota M7060 with engine problem - diagnosis help please #13
Thank you for the update. Glad it got repaired reasonably. Now back to work!! :)
   / 2017 Kubota M7060 with engine problem - diagnosis help please #14
Good to hear it was nothing serious and you’re back to work
2013 Freightliner M2 106 Stellar 12621 6-Ton Mechanics Crane Truck (A55852)
2013 Freightliner...
golf cart (A55787)
golf cart (A55787)
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2018 Ford Escape (A56859)
2018 Ford Escape...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
