2016 TYM 1003 Transmission
/ 2016 TYM 1003 Transmission #1
john FunnellTMY
Taupo New Zealand
TMY 1003
Hi, I have a 2016 TYM 1003. Works well until the I work it mowing or bailing and if I take the shuttle from the forward position to neutral or revers, it then wont move forward until I let it cool down for around 5 minutes. It will go backwards but not forwards. Any one have any suggestions as it has only done 1984 hours total.
/ 2016 TYM 1003 Transmission #2
To let it cool do you just pull it down to idle or do you shut it off?
Is it low on hydraulic fluid?
Does it have a hydraulic oil cooler? If so, has it been cleaned?
I just let it idle for around 5 minutes and it is then OK to move forward again. The oil level is OK. It does have a separate oil cooler and I have cleaned the screen (which had very little grass stuck to it) and it has made no change.
/ 2016 TYM 1003 Transmission #4
I would look closely at the cooler fins and maybe do a good cleaning. It sounds like the fluid is getting too hot. I can not think of any other reason for it to work once it has cooled down some. Hopefully someone that knows more about the system will give better advice.
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2018 CATERPILLAR D11T HIGH TRACK CRAWLER DOZER (A65056)
2018 CATERPILLAR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
2012 CHEVROLET IMPALA CAR (A66091)
2012 CHEVROLET...
