2016 Mahindra 2538 engine emissions
/ 2016 Mahindra 2538 engine emissions #1
Tractor Jack
N.E Lower Michigan
2016 Mahindra 2538, 1966 MF 165 & 1977 Ford 1600
I was told that this 4cyl diesel has less emissions equipment that other makes in this class ( less that 40hp ).
Is there a certain number of years that this applies to the Mahindra diesel ( ie 2012-2017 etc ).
That don't require DEF & afterburners, etc..
And is there any of those years that are better / worse than others..?
I appreciate any advise.
Jack
989.471.8255
/ 2016 Mahindra 2538 engine emissions #2
No tractors under 75hp use DEF. The limits are easier under 75hp and easier again under 25.5hp.
Your Mahindra has a DOC and EFI. The DOC does not do regens like the usual DOC+DPF systems. But it's not really "less" emissions gear: it is designed to meet the same requirements.
/ 2016 Mahindra 2538 engine emissions #3
The mahindra does not have a dpf filter but i doubt the emissions are any less than other tier 4t tractors.I do like the 4 cyl engine it just sounds better than my other 3 cyl ones do.
