2016 Mahindra 2538 engine emissions
   / 2016 Mahindra 2538 engine emissions #1
Tractor Jack
N.E Lower Michigan
2016 Mahindra 2538, 1966 MF 165 & 1977 Ford 1600
I was told that this 4cyl diesel has less emissions equipment that other makes in this class ( less that 40hp ).
Is there a certain number of years that this applies to the Mahindra diesel ( ie 2012-2017 etc ).
That don't require DEF & afterburners, etc..
And is there any of those years that are better / worse than others..?
I appreciate any advise.
Jack
989.471.8255
   / 2016 Mahindra 2538 engine emissions #2
No tractors under 75hp use DEF. The limits are easier under 75hp and easier again under 25.5hp.
Your Mahindra has a DOC and EFI. The DOC does not do regens like the usual DOC+DPF systems. But it's not really "less" emissions gear: it is designed to meet the same requirements.
   / 2016 Mahindra 2538 engine emissions #3
The mahindra does not have a dpf filter but i doubt the emissions are any less than other tier 4t tractors.I do like the 4 cyl engine it just sounds better than my other 3 cyl ones do.
Chevy caprice (A55758)
John Deere 4510 (A53317)
John Deere 4510...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
MISC TIRES (A54757)
MISC TIRES (A54757)
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
