2016 Hay season started for me.
/ 2016 Hay season started for me. #121
Got back from vacation yesterday and cut the neighbor's 12 AC today. I started with the drum mower, then decided to switch to the 9' sickle mower with Brian's hydraulic top link. What a huge difference - I was able to dial in the tilt to cut and cut and cut with no issues. It's 95 out with about a 5 mph wind - perfect drying conditions. I'll ted the lumps put tomorrow and keep checking. I dont want the big sweat like I got my first cutting.
/ 2016 Hay season started for me. #122
Well the spring hay season is over. Finished yesterday. First time in almost 5 years we've been done before Father's Day. Last year was middle of July.
351 4x5 rolls. About 225-250 will be split between me and dad. The rest is landowners shares. Need about 100 more to go through the winter. Should be a fall cutting. As long as we keep getting a few rains.
/ 2016 Hay season started for me. #123
First field done...7 acres of Timothy/bluegrass mix. 480 or so bales, about 65 lbs give or take.. Swather and rake worked great. Fought the baler and accumulator for days. One new wiper arm, one new billhook, one new piece of all thread and several adjustments to the old farmhand accumulator and I finally got stuff working right. Or so I hope. About 70 acres to go yet..glad the first patch is in the barn.
You need to get a bale grapple like I have :thumbsup: Its small and I can work in the barn too. - Save the back
I will be investigating my options over the winter. But something has to give, my back will not keep up with those 90 pounder's for very many years.
/ 2016 Hay season started for me. #125
May I ask why you make 90# sq bales instead of 50#-60# sq bales?
/ 2016 Hay season started for me. #126
Used the old farmhand grapple to stack hay in my barn for the first time. After some learning, it went pretty well. Much easier and cleaner than throwing the bales down and stacking them manually. I need to get some more hooks for it so I don't have to pay so much attention when lining things up.
many, many bales and acres to go yet... ugh.
/ 2016 Hay season started for me. #127
I haft to agree - back the tension off on the baler and shoot for 55 lbs.
But after picking up 298 bales yesterday and today with my grapple (twice - to load and unload) I am sold on what I got - perfect size for my use and not that expensive if you buy from the right place. :D:thumbsup:. Next toy is the accumulator that goes with it to speed the field pickup. I only touched one bale by hand and that was to retie it after the grapple brook the string - first time that has happened. So far moisture is good at about 10%. The bales did get a bit of rain for about 20 minutes, but no effect after a day of drying except for some surface bleaching. Now I cant rest until I have it all sold and go for the second cutting. This 298 cam off of about 12 acres the neighbor has - native grass no fertilizer. I am thinking of working a deal for him to fertilize and split costs, but then I would have 3 times the hay to deal with. Doing what I did whipped my butt - but it was 95+ outside while I worked. I was lucky and got the hay out of the field just in time for the neighbor to water.
Not on purpose for sure.
I adjusted twice for lighter bales during the first 10 or so bales. Thought I had it down to 60 pounders. I will not make that mistake again.
However, have any of you seen the "Rocky Mountain Bale Sweep". Mounts right on the SSQA, sure looks simple. I might invest in that, then the weight won't matter as much.
/ 2016 Hay season started for me. #129
I've seen several different brands of bale grapple/accumulators that mount on FEL. IMHO any type of mechanical bale handling is better than hay hauler's BACK.
/ 2016 Hay season started for me. #130
I remember hauling hay for various farmers as a teenager and one of them would ratchet his up for 100 lb bales. He was a big, big guy and could carry two in one hand but I was at my fighting weight of 175 lb so I got my workout in. But he paid $0.10 more an hour and sent me home with a six pack. Seemed like a good deal.
/ 2016 Hay season started for me. #131
I looked at it and quickly discovered you cant stack with it and definitely not pull out of a stack to unload the trailer, or get hay out of the barn. Look at how it unloads on a trailer, then think about the limitations of stacking higher and then getting the hay off of the trailer -it cant cross stack either for stability . The unit I have from Kuhns Mfg LLC | Innovation in small square bale handling. will do the same thing. You dont need the separator bars like this one and others have (grapolator, etc). With all the space between bales they leave you cant get a tight fit on you trailer or in the barn. A true grapple can also cross stack - you just build a square and pick it up from the other side. All of the other grapples are SSQA too. Also look at the cost and compare - a bit pricey for my book.
Hope this helps.
Hope this helps.
I hear ya. My biggest issue is getting the bale off the ground and on the trailer. I can't fit my tractor in the barn where I keep the hay, so unloading doesn't matter. I can back the trailer in and unload easy enough.
See my limited height.
My building engineer/designer (me) screwed that up big time.
Agree 100%.
For about the last 15-18 years I have been buying hay from a local grower. He bales 100-120 pound bales. I'm glad the price also included loading the hay on my trailer. He has the hay grapple and can load 10 at a time.
All I can say is next year I'll have more bales but they WILL be lighter. :)
/ 2016 Hay season started for me. #135
I would think that people buying hay would not want such a heavy bale either.
Ya really, but he's been doing it the same way for a very long time. His family has owned the farm for over 125 years. Grows really good hay. (alfalfa)
I'm just glad to be growing my own - - - - finally!
/ 2016 Hay season started for me. #137
For about the last 15-18 years I have been buying hay from a local grower. He bales 100-120 pound bales. I'm glad the price also included loading the hay on my trailer. He has the hay grapple and can load 10 at a time. All I can say is next year I'll have more bales but they WILL be lighter. :)
Those are heavy bales. I agree with you that a little lighter is better.
/ 2016 Hay season started for me. #138
The grapple I have would work well in your barn as I have the same limitations. When I set the top row I just dont lift up as far and slide out slowly. My unit is more compact than some.
BTW - do you have room to install a taller door? Neighbor down the road just raised his 4 feet by cutting his posts and having it jacked up and adding extensions. Looks a bit funny now with the gap in the sheeting, but I heard he did it for better ventilation.
/ 2016 Hay season started for me. #139
The grapple I have would work well in your barn as I have the same limitations. When I set the top row I just dont lift up as far and slide out slowly. My grapple unit is more compact than some. Then again I noticed my tractor is a bit more compact than your beauty. Maybe you can talk the Miss's into a Bobcat skid steer and grapple that can work in that space - think of the time savings and your health. Then you would have time for more honey does :D:eek::thumbsup:
BTW - do you have room to install a taller door or have you thought about raising the structure? With a pole barn its not that hard to do.
It would take some work but I'm sure I could raise the barn. Since I have the new barn I just didn't think I would mess with raising the little one. Plus I will only have 2-3 mother cows and calf's to deal with. So how it sits will be fine. As a last resort I can store lots of hay in the big barn. If I move to a round baler that would be my plan.
You can see the difference in the two barns. The little one has water, power and plenty of storage for just a few cows. Plus a good feeding manger. I built it for the exact purpose of feeding just a few cows. Although in my head it was taller.:confused3:
2017 KUBOTA SVL75-2 SKID STEER (A60429)
2017 KUBOTA...
2024 CUB CADET ULTIMA ZT1-54 ZERO TURN LAWNMOWER (A60430)
2024 CUB CADET...
2020 JLG SKYTRACK 12054 TELESCOPIC FORKLIFT (A60429)
2020 JLG SKYTRACK...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
