2015 String Trimmers
/ 2015 String Trimmers #1
grasschopper
Floresville
none
I have to buy a corded string trimmer for my spry but aging mother to use. Gas powered is out of the question, she hates things with engines. What is looking good on the market right now?
I was thinking about the GreenWorks 21142
Does any one know if it's string head can be replaced?
/ 2015 String Trimmers #2
I've been using a Ryobi straight shaft corded trimmer for many years, around the house. I would replace it with the same thing if I needed to. The only complaint is that I forget how to re-string it every few years.
Bruce
/ 2015 String Trimmers #3
My daughter recently bought a rechargable trimmer with cheap replaceable plastic blades instead of string. I havent seen it but she tells me she loves it. Sounds a lot easier to easier use. Would be ideal for an elderly woman I think.
I've seen those plastic blades, I was wondering how long they lasted.
/ 2015 String Trimmers #5
They make battery powered trimmers now with the smaller rechargeables that are pretty powerful and last a good amount of time. DeWalt makes one.
They are extremely convenient (no electric cords to move around or deal with).
But, they are pricey --- in the mid $200's range. They use the same batteries as your tools.
MoKelly
/ 2015 String Trimmers #6
Depending on what she needs to trim and how much, I second the rechargeable trimmer instead of a plug in version. I used an 18v Black and Decker version for 3-4 years on a 1/2 acre fenced lot with ~500' of wood fence and 20 - 5' tree circles to trim around, plus sidewalk, driveway, house. Doing the fence & tree circles used 1 battery, the driveway and everything else used the 2nd battery with plenty to spare to do other things if I wanted. If you weren't handy it had prefilled spools you could buy and drop in as needed although 1 spool lasted me a MN summer using it every week. You can also just rewind the spools with bulk string. If I just needed to trim grass on a normal city lot I'd definitely get one again vs a gas or plug in version. Especially since that was 3 years ago, the ones I've seen now have even better batteries and longer run times. We moved to the woods so now I use a brush trimmer instead otherwise I'd still be using the little battery one.
Battery powered would be fine, but I was hoping to put a brush cutter on it when I helped her out.
/ 2015 String Trimmers #8
My cheap ryobi battery powered one works great for trimming grass and small weeds. But you can forget about the brush cutting. I use it about 90% of the time instead of firing up the big heavy gas unit. But the battery powered one won't cut any brush or even really tough big heavy stalked growth.
/ 2015 String Trimmers #9
It seemed like the Ryobi one was $39. I already had batteries for it. It is all the same 18 Volt.
/ 2015 String Trimmers #10
I've used 3 or 4 corded electric string trimmers over the years. I'm currently using a 10 year old gasoline Stihl string trimmer, and it still works just fine. BUT . . . if or when it ever dies, I intend to replace it with a battery powered string trimmer.
/ 2015 String Trimmers #11
I'm slowly changing over my Stihl stuff to the 36V line.Have the trimmer and blower and just bought the bigger battery this week( the blower sucks power like crazy), so I'll have a spare.When I get the chain saw I'll be able to get rid of the mixed gas can for good.NOT CHEAP,but very convenient.The trimmer has plenty of power for the heavier stuff.
Bobcat 72SDR Seeder (A66285)
Bobcat 72SDR...
Brent 320 Grain Cart (A65640)
Brent 320 Grain...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
Speed Trailer (A64194)
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
