2015 hydraulic issues
/ 2015 hydraulic issues #1
SamatGA
I have had problems with the hydraulics since changing fluid and replacing filter for the second time. First time, no problems at all. But this time there is a performance issue. 3 point operates verrry slowly, and FEL is jerky, especially while engaging transmission at the same time. It is a 2015 4wd with gear drive. Is there a way to bleed the system? There seems to be whining from the hydraulics on operation also. There is no reference to this in the owners manual that I can find. Any help would be greatly appreciated.
Thanks,
Sam
/ 2015 hydraulic issues #2
They will self bleed by raising the loader to full height and tipping bucket back and forth with no load then lowering all the way. Do this several times and it should bleed the air out. Same for the 3pt. raise and lower several times. When you get it running smothly recheck your fluid levels.
Thanks for the help. There was quite a bit of air in there, and I got a lot of it out today, but will do it some more tomorrow to try to get the rest out. Appreciate the help.
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
1998 Freightliner MT45 Chassis Truck (A66736)
1998 Freightliner...
2011 CATERPILLAR CB434D DOUBLE DRUM ROLLER (A65056)
2011 CATERPILLAR...
2008 CHEVROLET SILVERADO 3500 4X2 S/A SERVICE TRUCK (A69167)
2008 CHEVROLET...
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
JOHN DEERE 325G SKIDSTEER (A67714)
JOHN DEERE 325G...
