2015 hydraulic issues
/ 2015 hydraulic issues #1
SamatGA
I have had problems with the hydraulics since changing fluid and replacing filter for the second time. First time, no problems at all. But this time there is a performance issue. 3 point operates verrry slowly, and FEL is jerky, especially while engaging transmission at the same time. It is a 2015 4wd with gear drive. Is there a way to bleed the system? There seems to be whining from the hydraulics on operation also. There is no reference to this in the owners manual that I can find. Any help would be greatly appreciated.
Thanks,
Sam
/ 2015 hydraulic issues #2
They will self bleed by raising the loader to full height and tipping bucket back and forth with no load then lowering all the way. Do this several times and it should bleed the air out. Same for the 3pt. raise and lower several times. When you get it running smothly recheck your fluid levels.
Thanks for the help. There was quite a bit of air in there, and I got a lot of it out today, but will do it some more tomorrow to try to get the rest out. Appreciate the help.
CAT 621B Transmission (A68134)
CAT 621B...
GAYLEAN  130BBL VACUUM TRAILER (A67714)
GAYLEAN 130BBL...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
2007 Chevrolet C7500 Auto Crane 8406H 8,400 lb. Crane Mechanics Truck (A66736)
2007 Chevrolet...
TAG 35" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 35" QUICK...
