2013 Branson 2400H question.
/ 2013 Branson 2400H question. #1
gamatt27
Kukje 2400H
Hello!
I hope this is the forum for Branson tractors now that TYM bought us!
Does anyone know if the mid PTO on a Branson 2400H is supposed to hook up to anything? I was just doing a service on it and noticed some damage to the front drive shaft. At the same time I saw an exposed, short, drive shaft poking out of the transmission in the back. I looked it up in my service manual and it said it is the mid PTO.
Everything is currently working on my 2400H. Just wondering what the mid PTO is for??
G
/ 2013 Branson 2400H question. #2
Mid mount mower is what I use mine for. Not sure if Branson offered front mount snow blower but that is another possible option.
/ 2013 Branson 2400H question. #3
Berco-Mac in Canada makes a front mount snow blower that also uses that mid pto.
Otherwise you dont really need to worry about it. Just don't run it when going through tall grass, I've seen people get grass wrapped around it and take out the oil seal there.
Thanks!
/ 2013 Branson 2400H question. #5
I just got one and didn't look to see if mine has one.
It has the lever for it. Do all of the 2400H comes with mid pto or is it an option and have the level just as standard set up?
/ 2013 Branson 2400H question. #6
Do all 2400H have mid pto, mine has the level but never checked to see underneath. Delivery is Monday. If so, what deck does it take? Thanks
/ 2013 Branson 2400H question. #7
I believe the mid PTO was a standard feature on all of them.
Suspect requires a Branson or TYM mid mount mower so that mounting and PTO are correct.
Not sure on the front mount snow blower option. I am old school and have a 3 point blower since I have front blade or loader.
/ 2013 Branson 2400H question. #8
What deck are u using I see some on Market Place for sale and might pick one up just for kicks.
/ 2013 Branson 2400H question. #9
Manual I have for mower says it is an MB60A. Note this requires a mounting kit that includes brackets that bolt to front on tractor, side rails under floor board and arms that hook on lower 3 point. Without this the deck is useless. Will head out to shed and try to get some pictures of these items.
/ 2013 Branson 2400H question. #10
Some pictures of the different mounting components.
Front hanger brackets.
3 point lift brackets
linkage that connects between tractor and mower.
the round pin on the road attaches to the 3 point brackets and under floor boards. didn't take a picture of those attachment points.
Piece that looks like sled runners is the front bracket that goes from deck to the front hangers
Hope these pics are helpful.
NOTE: This on a 2012 model so not positive the mounting is identical for a 202* model. I believe the deck shape changed but again not certain on mounting brackets.
/ 2013 Branson 2400H question. #11
I have the T254 which I believe is the TYM version of your tractor. Mine is a 2014 model and has the MM60 mower. I believe they also had a 54" for the T254 also. Oldnslo is correct that you will need the mounting kit which is fairly easy to install. I also have the Bercomac 56" snowblower that runs off the mid-pto. I do wish sometimes it could either be moved back about 6" or forward about 6". I have to take my mower off periodically and it is a pain to get the pto shaft hooked up. (push the ring in one direction while trying to slide the shaft in the opposite direction.) Taking it off is a piece of cake.
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
Caterpillar D6H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D6H...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
Year: 2022 Make: Ford Model: Expedition Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 52,907 (A61574)
Year: 2022 Make...
