2010 DK40 SE Won't Start
   / 2010 DK40 SE Won't Start
Thanks to all for your responses and I'll try to respond. The tractor is gear drive with ROPS and the solenoid has 3 terminals. Unfortunately I do not have a multimeter but I can get one and probably stumble through some electrical checks although I don't know about relays and contacts. Thanks to all.
   / 2010 DK40 SE Won't Start #12
Let us know when you are ready to proceed. I take it you want to try, correct?.. do you have a friend who is experienced that could work with you.?
   / 2010 DK40 SE Won't Start #13
Warranty IS transferable to a subsequent owner, the OP, through Kioti. If the tractor was originally purchased after August 1st, 2010 here is the coverage in brief: *The engine includes the crankcase, cylinder head, front gear case, valve cover pans, and all parts contained therein. Does NOT include fuel, electrical, cooling, intake, and exhaust components.
http://www.kioti.com/wp-content/uploads/2012/10/2010-2012_KIOTI_Warranty_TRACTOR-ENGLISH.pdf
   / 2010 DK40 SE Won't Start #14
Well we haven't heard back from him..he was going to buy a multimeter. I have been keeping the schematic up on the PC hoping he would return. Unfortunately he has no electronic experience. We shall see.
I'm sorry for the delay in responding but my regular job has kept me very busy the last couple of days. Yes, I definitely want to work through the problem and will try to find someone who can assist me. I assume I will need to purchase a multimeter so I will do that today and will be ready to start tomorrow PM. Many thanks to all the helpful people on this board.
   / 2010 DK40 SE Won't Start #17
Just about any cheapie multimeter (often called a voltmeter) will do the job. If you have a Harbor Freight nearby, they usually have a couple for under $10. Otherwise just about any meter you find at Walmart, a car parts place, Tractor Supply, Radio Shack, etc will do the job. Make sure it has a DC volts scale greater than 12v. Also an ampere capability (200 milliamp and 10 amp scales are typical) is useful for finding small current leaks. You do want a meter with leads (wires) and preferably leads with alligator clips (clip them on to free up a hand).
The main caution using a meter involves the ampere scale. If you were, for example to connect the meter across the battery in current mode (amp scale) you WILL damage the meter. If you are lucky it will only blow an internal fuse inside the meter. So be sure you are in a Volt scale when you try to measure volts.
   / 2010 DK40 SE Won't Start #18
For that matter a tail light bulb with 2 alligator clips soldered on it and a paper clip for a probe would work for what we need to test. But I am betting he does not have a soldering iron.
   / 2010 DK40 SE Won't Start #19
Don't forget checking voltage sources when on the resistance scale.... poof!:shocked: You will let out the smoke, and as you know they run on smoke, once you let out the smoke, well they don't work so well after that.
I purchased an analog multimeter over the weekend which I think meets requirements and I will grab a friend to assist me whenever it is convenient for someone to walk us through the system test/check. thanks again for all who have been so helpful.
Toro (A56857)
Toro (A56857)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
Zero Turn Mower (A59231)
Zero Turn Mower...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
*Selling at Royal Auction Zephyrhills, FL Location* 7 (A59228)
*Selling at Royal...
