200CX Question
/ 200CX Question #1
larry8818
John Deere 2520
I am trying to find out if you guys can help me figure out how much this set-up weighs. In the picture you'll find a JD2520, 72" MMM, 200CX loader with 61" Bucket & Ballast Box filled with concrete.
1. The JD Manual for the 2520 gives a listed weight of 1865lb.
2. 72" MMM - The Operator's manual states - Weight (Approximate).....183 kg (406 lb). The 2008 John Deere Governmet Equipment Purchasing Guides states 448lb.
3. 200CX Loader in the operators manual or The 2008 John Deere Governmet Equipment Purchasing Guide, neither states a given weight. It does show however that the ballast box, filled with concrete (which it is) is 824lb.
4. I cannot find a given weight anywhere for the 61" bucket. However it The 2008 John Deere Governmet Equipment Purchasing Guide, it states weight for the 49" bucket at 154 lb and the 53" bucket @ 183 lb.
If anyone get the correct specs that would be great.
Because I do not know, I'm guessing:
1865 lb tractor
685 lb 200CX (approximately estimted)
210 lb 61" Bucket (approximately estimted)
824 lb Ballast Box filled with concrete
406 lb MMM (approximately estimted)
3990 lb TOTAL
What do you guys think?
/ 200CX Question #2
This lists the 200CX as about 477, the 53" bucket as 170, and the 61" bucket as 190lbs.
But a lot of it depends on why you need to know the weight. If you're looking to buy a trailer I'd recommend estimating very high, in which case 5000 or even 6000lbs should cover you plus allow you to get a new toy in the future.
/ 200CX Question #3
I agree 100%. If your purpose for this post is about what trailer you will need, then let us know please. And also what your towing with...
At the very MINIMUM, I think you'd need a 16' 7,000 pound rated trailer with brakes on both axles for your tractor.
/ 200CX Question #4
I just looked at your picture again... Have you checked the air in those front tires?;)
/ 200CX Question #5
If it is the trailer, then don't forget to add in the weight of fuel, water, other implements, dirt, sod... Whatever you think might possibly get on that trailer along with the tractor. You won't ever want to make two trips if you can avoid it.
/ 200CX Question #6
Turf tires!
/ 200CX Question
Thanks for the link. I wonder where John Deere 2210 got this information.
/ 200CX Question
Hi KennyD,
The sole purpose is to find what this stuff weighs. I am very surprised that a company like John Deere, which has to know the weights both crated & uncrated for shipment from their plants, does not make these weights standard accurate materials listed under specifications in every tractor and implement owners manual. Why they like to keep us guessing is beyond me. In case I would ever want to trailer it, I'd like to know down to the + or - 100lb whats going on the trailer as it is the drivers responsibility to know. State Police love the guys who guess!
/ 200CX Question
Hi KennyD,
What I love about this site is how everyone looks our for everyone! Safety especially!
I had just done my 2nd service about a week before I had these 4 yards of T-pack dropped in my driveway. Tire pressure in all 4 was deadnuts to specifications. The reason they look so low are a few factors.
1. Weight of the heaping mound of T-pack in the bucket.
2. Being on pavement does not absorb any pressure.
3. Probably the turf tires vs the industrial tread.
That stuff is heavy let me tell you. My first scoop I didn't use my ballast box. The tractor drove in and picked up a full scoop with no problem at all, however transporting that load to my boat launch 1200ft away down a slight slope made me cautious as the tractor was a little "light in the seat". I put the ballast box on for the final 8 or 9 loads.
/ 200CX Question
larry8818 said:
1865 lb tractor
3990 lb TOTAL
Would you guys say this is more accurate?
1865 lb tractor
477 lb 200CX (from John Deeres 2210's post here)
190 lb 61" Bucket (from John Deeres 2210's post here)
3762 lb TOTAL
What number would you believe is more accurate for the 72"mmm?
- The 2008 John Deere Governmet Equipment Purchasing Guides states 448lb.
/ 200CX Question #11
Is one the shipping weight and the other perhaps the equipment weight? Or including the mounting hardware? The conservative in me says always go with the larger value.
I doubt you'll get to within +/-100lbs without a scale, there are a lot of variables in fluid weights, making sure mounting brackets are accounted for, filled tires, heck I think I've got more than 100lbs of mub on my tractor now :)
However I do agree that a common spec sheet for physical dimensions of all implements would be a great improvement in the manuals.
/ 200CX Question #13
It seems like you've already found it, but for those who haven't the government sales purchasing guide is a bit more uniform in how they present the specs.
Some more weights of my stuff in case anyone is interested:
53" bucket for the 200CX is 183lbs according to the guide, this is different than the post on TBN (but also may include the pallet weight, for example).
46 Backhoe is 896lbs (but this may not include the weight of the hydraulic fluids which can be substantial in a backhoe - ironically the government site didn't have the weight but the normal Deere site did)
9" bucket for the backhoe is 43lbs.
62D mower is 422lbs but it looks like a later version is a bit heavier?
The rear bagger attachment (including the impeller) is 103lbs.
Still looking for the weight of my Frontier pallet forks, maybe I'll have to (*gasp!*) check the manual. :eek:
Edit: FYI, found the fork weight in the manual. The Frontier AL1240F with 42" forks is 380lbs, shipping weight on these is a consistent 40lbs more.
Deutz DX140 Tractor (A66285)
Deutz DX140...
EZ Trail 672 Head Cart (A66285)
EZ Trail 672 Head...
2014 John Deere 8345R (A64126)
2014 John Deere...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
