2008 BX24 HOUR METER NOT WORKING
/ 2008 BX24 HOUR METER NOT WORKING #1
Sams Bx
KUBOTA BX24
I have a 2008 KUBOTA BX24 that I recently had serviced. The hour meter worked when I took it in. They delivered it back and now the hour meter is all a bunch of numbers not giving a true reading? Like just a bunch of random numbers. So I told them take it back. I had checked out on line that the whole dash has to be replaced when the hour meter goes bad. Is the hour meter bad now? It worked when I took it in? I checked with a couple of dealerships and found out the dash for my tractor is now not available anymore. But there is a replacement dash that has to be used with a special adapter. Total parts is almost $600!!! Is there a better solution that's not so rough on the pocket book? Or a differant hour that can be used? Please help here. This is frustrating.
/ 2008 BX24 HOUR METER NOT WORKING #2
Maybe try disconnecting the battery for 5 min to allow it to reset? :unsure:
The dealership did put in a new battery in as part of my service I had done. Shouldn't they suposedly know that if that is the answer?
/ 2008 BX24 HOUR METER NOT WORKING #4
I’d would guess unless they were messing with the dash it’s just a coincidence it went bad. I’m sure there is a way to add an hour meter as a separate gauge but I don’t know how exactly to wire it up.
/ 2008 BX24 HOUR METER NOT WORKING #5
An option is to Wire a 12 vdc hour meter to a power source that only has power when engine is running like fuel shut off solenoid.
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
7021 (A55851)
7021 (A55851)
Mahindra 6065PST (A53317)
Mahindra 6065PST...
16' 5" METAL STORAGE RACK (A60432)
16' 5" METAL...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
