2007 MF 3645 - Won't Shift
   / 2007 MF 3645 - Won't Shift #1
Yeti
2007 MF 3645 with 360 hours. Tractor has sat for a week without being used. Started tractor and shifted into high, 1st, and tried to move the synchroshift lever to forward and it would not go. It would not go into reverse. Let the tractor run in neutral for 15 minutes thinking the fluids needed to be circulated. Still not able to move the lever. Turned the tractor off and tried again. Nothing.
Test #1
Started tractor in neutral. Shifted the synchroshift lever in forward. Then shifted in high, then tried to shift to 1st but wouldn't go into gear.
Test #2
Started tractor in neutral. Shifted into low. Then shifted into 1st. Then forced synchroshift lever into forward. The tractor moved forward. However, when I tried to use the clutch it would not kick the tractor into neutral. I had to pull the synchroshift lever into neutral.
Test #3
Shifted the synchroshift lever into forward with the other gears in neutral. Tried to start tractor. It would not start. (my thinking was I needed to test the neutral switch)
All fluids look good. No warning lights on the dash are on. Could this be a clutch adjustment issue or is the clutch frozen?
Thanks,
Ryan
Spoke to the local dealer. Suggested that the clutch may be frozen/stuck. So we decided to take the tractor and shift into Low, 1st, lower the RPMs, shift the synchroshifter into drive. Then once the tractor started moving, push in the clutch, and slam on the brakes.
First try and the clutch is free. Guess I need to use the tractor more.
   / 2007 MF 3645 - Won't Shift #3
My Massey-Ferguson got stuck in reverse, when I tried to shift it out of reverse the shifter seemed to disconnect internally. How can I fix the problem?
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
LMC G300JD LOT IDENTIFIER 47 (A53084)
LMC G300JD LOT...
Polaris ATV (A50324)
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
2007 Mack Granite CT713 Day Cab Truck Tractor (A53117)
2007 Mack Granite...
