2007 Kioti CK30 shifting problem
/ 2007 Kioti CK30 shifting problem #1
cdknight
2007 Kioti ck30
I have manual shift 2007 Kioti CK30 with main shift lever stuck in 3 gear. Fwd and reverse work on steering wheel and low\ hi work. Can anyone tell me how to resolve the problem?
/ 2007 Kioti CK30 shifting problem #2
When I first got my CK30 it was really hard to shift, got underneath and sprayed all the shift linkage with PB Blaster and it loosened up, seemed to be caused by the paint they laid on. If that doesn't work, it may be an internal problem (shift fork).
/ 2007 Kioti CK30 shifting problem #3
If you havnt tried, I would put it in low range.Hold back on shifter steady with left hand while running back and forth using right hand on shuttle.Change loads and pressure on clutch and tractor,dont force too hard on the shifter.If you are lucky it may slide out of third.Good luck.
2007 International School Bus (A64194)
2007 International...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
2013 International WorkStar 7500 Side Loader Garbage Truck (A64194)
2013 International...
2000 Hino (A64194)
2000 Hino (A64194)
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
Applegate Creep Feeder (A66408)
Applegate Creep...
