2005 JD 5103 CSS replacement
/ 2005 JD 5103 CSS replacement #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
I had a problem with my 5103 today and thru research here on TBN was able to solve the issue. The 20A fuse for the fuel shutoff solenoid blew when I turned the key on. After one replacement with the same result, I came to TBN and was able to dig up a solution that worked. I disconnected the cold start solenoid @ the thermostat housing, replaced the fuse and the tractor fired up. I purchased a new one for $35 at the local JD dealer. Is there anything I need to watch for when replacing this, such as thread sealant, o-ring etc.? It looks very simple and straight forward, but those are the ones that usually have a little hidden gremlin that turns a 20 minute job into an all day job.
WHEEL LOADER FORK ATTACHMENT (A67714)
WHEEL LOADER FORK...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
2017 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A69167)
2017 FREIGHTLINER...
2021 Forest River Salem FSX 280RTX 30ft Toy Hauler T/A Travel Trailer (A66738)
2021 Forest River...
AG Tires - 11.00-16SL (A68134)
AG Tires -...
2021 CATERPILLAR 259D3 SKID STEER (A65056)
2021 CATERPILLAR...
