2002 DK50C
/ 2002 DK50C #1
Sierraau
Truckee, CA
2019 Rx7320
Gave my old DK50C to my niece and her husband, had 1400 hours on it and it never had a serious problem. After they got it home, they went to hook up the backhoe and noticed that a detent hydraulic line from the hydraulic block on the right side in front of the door to the quick connects behind the seat was leaking (the one that runs the backhoe), so he replaced the line, fired up the tractor and now neither the rear arms lift nor the backhoe seems to be getting flow. I looked and looked and couldn't figure out why the hydraulics aren't working. I pushed the detent lever on the right both forward and backward with no results. Is there some sort of burping process you need to go through when replacing a line like that? The two quick connects on the rear.... are the hydraulic hoses for each attachment mounted horizontally or vertically? I'm pretty sure each valve has the quick connects are aligned vertically, right?
