2000 shift boot
/ 2000 shift boot #1
FL_Jerry
FL, Bay County
YM 2000
I looked at some old posts about this, and found the problem I have, but I'm unsure of the fix. I have some hydro fluid that leaks out from under the boot. Previous posts say replace the O-ring there.
When I looked at the parts breakdown, I'm wondering if this will do the trick. I guess I'm second guessing how fluid is being forced up that far. I'm not really to concerned about it at this point, and I do realize it is 20+ years old.
I just replaced my front left knuckle seal (thanks everyone for all the info), and I think I now have restore fever.
Thanks,
Jerry
2000BD, Koyker 120, Box Blade, 5' Brush cutter
/ 2000 shift boot #2
Your vent is likely blocked.
/ 2000 shift boot
Thanks, I suspected that, but looking at it I didn't see any crud. This is the piple that comes out and makes a bend under the seat from the 3ph isn't it? Is it advisable to clean it out by running somthing down it?
Jerry
/ 2000 shift boot #4
</font><font color="blue" class="small">( This is the piple that comes out and makes a bend under the seat from the 3ph isn't it? )</font>
Yes. I'd take it off first. You don't want whatever is in there to get into your transmission. It just unscrews.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ 2000 shift boot #5
I'm having the same problem. I did put a piece of screen around the vent and it isn't clogged. Will replace the boot... the next time I service.
/ 2000 shift boot #6
I didn't replace the boot on my 1700, just used a ty-wrap on it after removing the springy thing used originally. Quit leaking after that.
/ 2000 shift boot
It was plugged! Way down by where it screws in.
Thanks once again for dead on advice all.
Jerry
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A65643)
2014 RETESA 210BBL...
2000 International 4900 Tandem Truck (A66285)
2000 International...
(3) Corral Panels (A66408)
(3) Corral Panels...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2011 TROXELL...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
