2000 shift boot
/ 2000 shift boot #1
FL_Jerry
FL, Bay County
YM 2000
I looked at some old posts about this, and found the problem I have, but I'm unsure of the fix. I have some hydro fluid that leaks out from under the boot. Previous posts say replace the O-ring there.
When I looked at the parts breakdown, I'm wondering if this will do the trick. I guess I'm second guessing how fluid is being forced up that far. I'm not really to concerned about it at this point, and I do realize it is 20+ years old.
I just replaced my front left knuckle seal (thanks everyone for all the info), and I think I now have restore fever.
Thanks,
Jerry
2000BD, Koyker 120, Box Blade, 5' Brush cutter
/ 2000 shift boot #2
Your vent is likely blocked.
/ 2000 shift boot
Thanks, I suspected that, but looking at it I didn't see any crud. This is the piple that comes out and makes a bend under the seat from the 3ph isn't it? Is it advisable to clean it out by running somthing down it?
Jerry
/ 2000 shift boot #4
</font><font color="blue" class="small">( This is the piple that comes out and makes a bend under the seat from the 3ph isn't it? )</font>
Yes. I'd take it off first. You don't want whatever is in there to get into your transmission. It just unscrews.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ 2000 shift boot #5
I'm having the same problem. I did put a piece of screen around the vent and it isn't clogged. Will replace the boot... the next time I service.
/ 2000 shift boot #6
I didn't replace the boot on my 1700, just used a ty-wrap on it after removing the springy thing used originally. Quit leaking after that.
/ 2000 shift boot
It was plugged! Way down by where it screws in.
Thanks once again for dead on advice all.
Jerry
(2) 27x32 CIH Rims (A65640)
(2) 27x32 CIH Rims...
John Deere Tractor Fenders (A65640)
John Deere Tractor...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
Trimble True Count Clutch Wiring (A65640)
Trimble True Count...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
