20 inch chainsaw recommendation
   / 20 inch chainsaw recommendation #71
It seems that my Stihl is not the only one that is hard to start. I am thinking about adding a bulb to it and not just depend on the choke. Did anyone do this and did that improve the starting?
They are picky about the start procedure. Never had any saw that would start on the first pull. My 261 and the 400 start on the third pull just like my old 044. When both these new saws were brand new, I almost threw them both in the dumpster because I pulled and pulled. I was trying to start them like my old 044 and that doesn't work too well. Most any saw you have to get them broken in before they start right and make max power. After I cut 3 or 4 cords of firewood both start easy enough and they both make good power. Cutting firewood is about the hardest thing you can do to a saw because the bar is pretty much in a cut all the time. One cut after another over and over again will put any saw to the test. Use good bar lube, I always use Stihl oil and Stihl chains and touch up the chain every time you fill the tank. Cutting clean wood always helps too if you can ever find clean wood. :confused:
   / 20 inch chainsaw recommendation #72
When I decided to buy my chainsaw, I talked to the pro who was taking down a couple of damaged large trees well beyond what I was was comfortable tackling. I was down to choosing between Echo and Stihl. He said, I own both, but this is the one I use the most and he pulled out his Stihl. I’ve never regretted it. I did opt for the EZ-start system.
   / 20 inch chainsaw recommendation #74
I went thru a similar decision a couple years ago when I got tired of fighting to start my Stihl ms290. I went with the Echo 4910 (501p- basically the same saw ). Great saw. After running 6-8 thanks is had thru it to break it in, open up the exhaust (very simple), pull the tuning limiting tabs and reset.
I run it with a 20" bar and it just cuts. I mostly use mine on live oak (very hard wood) and juniper trees. It's lightweight and pulls the chain well.
Echo replaced the 4910 with the 4920. Find a NOS 4910 or one slightly used on marketplace. It's a great saw at a very good price.
   / 20 inch chainsaw recommendation #75
All good options,-- But I'm a Husky fan ~~ 450 Rancher 20" 50.2cc .
   / 20 inch chainsaw recommendation #76
Do you want a 20" bar for reach or will you be burying it quite often? If you're burying the bar a lot, you want a 60cc saw or larger.
^^Agree. (y)
   / 20 inch chainsaw recommendation #77
Hi All,
I need to buy a new chain saw. I have a Husky 18 inch that is around 22 years old or so and the trees I need to cut up are too big for it. I figure a Husky or Stihl but open to other ideas as well. I would like to go with either brand's middle line, not home or professional but I think it is called Rancher series.
Secondly are there good online discount sites to buy or is buying local at a box store, hardware store TSC etc better?
Thanks so much,
Glenn
I have a Husqvarna 455 Rancher 20" that's provided firewood for my home and shop for longer than I can accurately recall. 20+ years. It has NEVER let me down. Maintain your bar, use good oil and gas, change the air filter, too. I have a half dozen chains I pay to have professionally sharpened. Laugh at the ice storms.
   / 20 inch chainsaw recommendation #78
So I had a Stihl 261 for a few years, ran a 20” bar on it the whole time but I recently upgraded to a Husky 562 XP, Husky is running a spring promo and I got it for less than I payed for my 261 and it runs a 20” bar like a mad man, better than the 261 could ever hope to. If you can find a deal like I did go for the husky. Otherwise the 261 is a great saw and is lighter than the 562 Xp.
My logger has settled on the 562XP as his go-to saw. He really likes it.
I guess the whole 20" bar thing is what made me assume the 261 was 61cc saw. I think a typical bar on a 45cc saw is 16" or 18". I run 18" on mine. 20" I think is pushing it, and is a better fit for perhaps a 50 to 60 cc saw. But it also depends on how much of the time you are actually using all 20" of it. I have an 18" bar on my 346xp for the occasional times I have to cut something that requires the whole bar, but it's really infrequent. It just saves me from breaking our another saw for a cut or two. If I'm regularly cutting something that size I use a 62cc. With my 45cc saw I'm typically limbing or cutting 10-12" longs.
   / 20 inch chainsaw recommendation #79
Own a 20" bar Stihl 311 great power and saw when it starts. Next 20" saw will probably be an echo really like my 400 with 18" bar though very underpowered for larger rounds though but always starts easy in any condition or temp.
I have a 036 PRO.Have had it since 2000, never fails to start.
   / 20 inch chainsaw recommendation #80
I have owned a Stihl MS290 (called 029 Farm Boss back then) and it has been a great reliable saw since I bought it in 1998 or so. I also "had" a MS 390 saw with a 24" bar but it would easily bog in big rounds of Red Oak, which is mostly what I cut for firewood. I upgraded to a MS360 pro saw and very glad I did. I don't notice the lighter weight really, but there is night and day more power and it hardly ever bogs down! I have my eye on a MS261 next to replace the 290, expecting the similar upgrade in power. I also had a small MS170 which was fine, but it essentially rattled itself apart. The MS210 I have now is fine until it gets hot, then it doesn't like to restart until it cools back off.
I have a small Husky I got from a neighbor, right out of the box it stalls as soon as you let off the trigger and won't start at all unless you hold the trigger 1/2 way or more. Neighbor bought it at Tractor Supply so they won't do anything since fuel was put in it, and his wife works there!
So my point is the big three saw companies are just like the 3 big US automakers, everyone has had good luck and are mostly loyal to their favorite brand. Buy at a dealer get the support after the sale. Buy at box store and save a few $$ but you're on your own if things go south. Run clean non ethanol fuel and that will solve 80% of your issues right there. You can not have too much power, so if you're torn between models, go pro if not too cost prohibitive.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2007 MACK  CTP 713 DAY CAB (A58214)
2007 MACK CTP 713...
202480 (A54757)
202480 (A54757)
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2009 Ford F450 XL Utility Bucket Truck (A55272)
2009 Ford F450 XL...
