Buying Advice 2 speed rear PTO
   / 2 speed rear PTO #11
The new Kioti LK 30 (was the LK3054, I think) has 540/1000 PTO standard (per Kioti's web page). As mentioned, my Dad's 3054 has 2 speed PTO and this is also a pretty common tractor on the fairly new/used market.
Good luck.
   / 2 speed rear PTO #12
You may want to check out the LS line of tractors. I think some of them have the option for multi-speed PTO's. My R3039 is only a single speed PTO, but it has a shift gate with multiple speeds on it.
   / 2 speed rear PTO #13
Kubota B2920 (29 hp with 21 pto hp) has two speed rear pto as well as the its siblings the B2620 and B2320 which Stihl22 mentioned
   / 2 speed rear PTO #14
very likely can find a chinese tractor or two with a multi speed pto setup.
soundguy
   / 2 speed rear PTO #15
My Kioti CK25 came with 540/1000. It's now the CK27.
   / 2 speed rear PTO
Thanks for all the help. I purchased a Kioti CK35 with 2 speed rear PTO.
   / 2 speed rear PTO #18
I really recommend 2 speed pto! I have a kubota b2320 with the 540 and the 960 and i basicaly use the 540 when i need power otherwise i am always on the 960 at around 1400 rpm that give me about 540. I blow snow when its powder snow i cut grass always on 960. With the blower i go to 540 when its heavy snow or when i blow the bank of the snow truck.
Yeah! I just wish they made the bigger HST tractors with multi speed PTO.:(
larry
   / 2 speed rear PTO #19
Its just that i have never seen a 1000pto speed empliment. ?? can you just run a bush hog normaly rated at 540 and then turn it up to 1000?
   / 2 speed rear PTO #20
IIRC, the Wallenstein chippers say 500-1000 rpm. Finer chips at 1000, but I don't have the power to run it like that for bigger stuff.
Kubota L4701 (A53317)
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2016 FREIGHTLINER...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
