Buying Advice 2 speed rear PTO
   / 2 speed rear PTO #11
The new Kioti LK 30 (was the LK3054, I think) has 540/1000 PTO standard (per Kioti's web page). As mentioned, my Dad's 3054 has 2 speed PTO and this is also a pretty common tractor on the fairly new/used market.
Good luck.
   / 2 speed rear PTO #12
You may want to check out the LS line of tractors. I think some of them have the option for multi-speed PTO's. My R3039 is only a single speed PTO, but it has a shift gate with multiple speeds on it.
   / 2 speed rear PTO #13
Kubota B2920 (29 hp with 21 pto hp) has two speed rear pto as well as the its siblings the B2620 and B2320 which Stihl22 mentioned
   / 2 speed rear PTO #14
very likely can find a chinese tractor or two with a multi speed pto setup.
soundguy
   / 2 speed rear PTO #15
My Kioti CK25 came with 540/1000. It's now the CK27.
   / 2 speed rear PTO
Thanks for all the help. I purchased a Kioti CK35 with 2 speed rear PTO.
   / 2 speed rear PTO #18
I really recommend 2 speed pto! I have a kubota b2320 with the 540 and the 960 and i basicaly use the 540 when i need power otherwise i am always on the 960 at around 1400 rpm that give me about 540. I blow snow when its powder snow i cut grass always on 960. With the blower i go to 540 when its heavy snow or when i blow the bank of the snow truck.
Yeah! I just wish they made the bigger HST tractors with multi speed PTO.:(
larry
   / 2 speed rear PTO #19
Its just that i have never seen a 1000pto speed empliment. ?? can you just run a bush hog normaly rated at 540 and then turn it up to 1000?
   / 2 speed rear PTO #20
IIRC, the Wallenstein chippers say 500-1000 rpm. Finer chips at 1000, but I don't have the power to run it like that for bigger stuff.
2 BOTTOM PLOW (A57192)
UNUSED FUTURE FT-M48 48" HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
UNUSED (2) 3500# AXLES W/ BRAKES (A57192)
UNUSED (2) 3500#...
PALLET OF HYD HOSES (A57192)
PALLET OF HYD...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
