2" I-beam
/ 2" I-beam #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
I'd like to make an adapter to put a quick hitch on my loader arms. I think it should be made of 1 x 3 or 2 x 4 steel tube that I don't have, however I do have some 2" I-beam. Is this strong enough?
Thanx
M.D.
/ 2" I-beam #2
How about some pics of what your talking about. Do you mean a quick attach hitch or a receiver hitch?
/ 2" I-beam
I want to put a 3 point quick hitch on the loader arms so I can attach my boom pole and carry all to the front of the tractor.
/ 2" I-beam #4
There is not enough info given to answer your question accurately:
What thickness is the steel on the I-Beam material?
What will the overall span be?
How much will the FEL lift?
How heavy are the implements you intend to lift?
But it "sounds" to me, if I have an accurate mental picture of what your trying make that it will not be strong enough. 2x3 box would be best, and I think you already know that:D
/ 2" I-beam #5
MD;
I just made a 3 point hitch adapter (non quick hitch) for my Kubota B7100. I used 1/4" thick steel throughout. The main frame is 4"x 3" x 1/4" angle and the cross members are 3" x 3" angle and 3" x 3" x 1/4" tube. The whole thing weighs about 80lbs and is rigid enough that when you pull on the adapter the tractor itself moves and only then as a result of the "bounce" factor of the turf tires. If you are going to be lifting anything heavy at the end of your boom pole, it's going to make a lot of demand on the attachment point. I ended up using 1/4" because that was the thicness of the mounting flanges on the back of my bucket.
Cheers, Erik
/ 2" I-beam
The I-beam is 2" wide, 2-1/4 high and 3/16 thick. I want to make something like Eric made but it would attach to the quick tach mounting points on the loader arms. I have some 4 x 4 x 1/4 angle but only short pieces. It's a JD 420 loader so I can't pick up too much weight, probably around 800 lbs max...if that. There's an auction this Saturday that has some square steel tube, I'll check that out.
2012 BRENNER TANK PUP TRAILER (A67714)
2012 BRENNER TANK...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2021 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A66736)
2021 Ram 1500...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
1984 ROLL OFF TRAILER (A67714)
1984 ROLL OFF...
2000 Ford F-250 4x4 Service Truck (A66736)
2000 Ford F-250...
