2 cylinders together?
/ 2 cylinders together? #1
sos1
Can I connect 2 cylinders to the same control valve if they are moving the same lever?
/ 2 cylinders together? #3
You can in a parallel arrangement such as a left and right fel cylinder.
/ 2 cylinders together? #4
It depends on how they are mounted and connected to the lever.
Do you have any pictures or drawings that you can post?
/ 2 cylinders together? #6
Each cylinder (in parallel) would then operate half as fast.
You could also have them operate separate levers, since you mention it. Just can't imagine it functioning properly due to unbalanced loads.;)
Using to open and close 4 in 1 bucket.
Reading Service Body (A64911)
Reading Service...
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
7ft Fork Extensions (A66734)
7ft Fork...
2012 Deere 318D (A64911)
2012 Deere 318D...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
