2 cylinders together?
/ 2 cylinders together? #1
sos1
Can I connect 2 cylinders to the same control valve if they are moving the same lever?
/ 2 cylinders together? #3
You can in a parallel arrangement such as a left and right fel cylinder.
/ 2 cylinders together? #4
It depends on how they are mounted and connected to the lever.
Do you have any pictures or drawings that you can post?
/ 2 cylinders together? #6
Each cylinder (in parallel) would then operate half as fast.
You could also have them operate separate levers, since you mention it. Just can't imagine it functioning properly due to unbalanced loads.;)
Using to open and close 4 in 1 bucket.
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
3146 (A63117)
3146 (A63117)
Street Sweeper (A60352)
Street Sweeper...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
