Aug 24, 2014 / 2 cylinders together? #1 S sos1 Bronze Member Joined May 24, 2009 Messages 65 Can I connect 2 cylinders to the same control valve if they are moving the same lever?
Aug 24, 2014 / 2 cylinders together? #2 RickB Super Star Member Joined Sep 18, 2000 Messages 15,190 Location Up the road from Dollar General WNC Tractor Just a Scag That's how loaders work.
Aug 24, 2014 / 2 cylinders together? #3 J jenkinsph Super Star Member Joined Feb 27, 2008 Messages 12,577 Location somewhere usa Tractor Deere 110tlb, 4520, x749, L130 You can in a parallel arrangement such as a left and right fel cylinder.
Aug 24, 2014 / 2 cylinders together? #4 Xfaxman Super Star Member Joined Feb 8, 2013 Messages 13,334 Location Guthrie, OK Tractor Toolcat 5610 G - Bobcat V417 - TORO+Loader sos1 said: Can I connect 2 cylinders to the same control valve if they are moving the same lever? Click to expand... It depends on how they are mounted and connected to the lever. Do you have any pictures or drawings that you can post?
Aug 25, 2014 / 2 cylinders together? #5 RickB Super Star Member Joined Sep 18, 2000 Messages 15,190 Location Up the road from Dollar General WNC Tractor Just a Scag jenkinsph said: You can in a parallel arrangement such as a left and right fel cylinder. Click to expand... Also they can be in series if the cylinders are set up and sized to be master & slave.
Aug 26, 2014 / 2 cylinders together? #6 D davrow Veteran Member Joined Sep 29, 2013 Messages 1,196 Location Riverside, CA Tractor Kioti CK27HST Each cylinder (in parallel) would then operate half as fast. You could also have them operate separate levers, since you mention it. Just can't imagine it functioning properly due to unbalanced loads.
Aug 26, 2014 / 2 cylinders together? Thread Starter #7 OP S sos1 Bronze Member Joined May 24, 2009 Messages 65 Using to open and close 4 in 1 bucket.
Aug 26, 2014 / 2 cylinders together? #8 J jenkinsph Super Star Member Joined Feb 27, 2008 Messages 12,577 Location somewhere usa Tractor Deere 110tlb, 4520, x749, L130 sos1 said: Using to open and close 4 in 1 bucket. Click to expand... Yes, no different than plumbing two bucket tilt cylinders together.
