2 cylinders together?
/ 2 cylinders together? #1
sos1
Can I connect 2 cylinders to the same control valve if they are moving the same lever?
/ 2 cylinders together? #3
You can in a parallel arrangement such as a left and right fel cylinder.
/ 2 cylinders together? #4
It depends on how they are mounted and connected to the lever.
Do you have any pictures or drawings that you can post?
/ 2 cylinders together? #6
Each cylinder (in parallel) would then operate half as fast.
You could also have them operate separate levers, since you mention it. Just can't imagine it functioning properly due to unbalanced loads.;)
Using to open and close 4 in 1 bucket.
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
New Holland BR7090 Round Baler  5x6 Bales (A63688)
New Holland BR7090...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
John Deere 4044R (A62177)
John Deere 4044R...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
Refurbished KBH Tender (A63688)
Refurbished KBH...
