2 cylinders together?
   / 2 cylinders together? #1
sos1
Bronze Member
Can I connect 2 cylinders to the same control valve if they are moving the same lever?
   / 2 cylinders together? #3
You can in a parallel arrangement such as a left and right fel cylinder.
   / 2 cylinders together? #4
It depends on how they are mounted and connected to the lever.
Do you have any pictures or drawings that you can post?
   / 2 cylinders together? #6
Each cylinder (in parallel) would then operate half as fast.
You could also have them operate separate levers, since you mention it. Just can't imagine it functioning properly due to unbalanced loads.;)
Using to open and close 4 in 1 bucket.
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
