2.7EB vs 3.5EB?
/ 2.7EB vs 3.5EB? #61
So wouldn't you end up losing boost pressure with a hole in the system? When you get a hole in the big truck it squeals like crazy, loses power and smokes.
/ 2.7EB vs 3.5EB? #62
A waste gate to blow off excess pressure at certain RPM's is a way different scenario than having a hole in the system.
Like I say.....I'm no engineer. I just don't see this because the slightest hole or even a loose clamp causes all kinds of issues on a class 8 truck.
Especially with my Cat that makes 50 PSI boost.
Am I missing something here that I am not understanding???
I've never seen a weep hole in a class 8 truck, because we pressure test them when a driver has a low power or smoke issue or a squealing sound.
/ 2.7EB vs 3.5EB? #63
Engineer Mike noted:
I know at least two people have drilled the hole, so per LastResort's request, I wanted to get some before/after observations and results from drilling the hole.
And before anybody says it...
-It won't pull in dirt because there is never negative pressure there.
-It won't create an issue due to unmetered air because its not a MAF engine.
-It won't cause a decrease in boost because boost is on feedback control by the ECM.
-And finally, it won't cause a loss of engine power due to a reduction in airflow because a .050" hole will only leak .5 cfm at 15 psi.
Source: https://www.f150forum.com/f70/ecobo...le-post-your-results-here-223824/#post2925337
/ 2.7EB vs 3.5EB? #64
It is a computer controlled turbo waste gate and will never loose boost between the intake and throttle plate because the ECU compensates for the tiny leak.
/ 2.7EB vs 3.5EB? #65
Well I'll chime out now. You and your followers drill away then. Like I said, I don't buy used and it won't affect me. But it reinforces the fact that I won't ever buy into Ford's flawed system.
Maybe you are right that at low boost like 15 PSI it don't matter. But on my trucks at 24 to 50 PSI it causes all kinds of havoc.
My 2.0L VW turbo's don't have weep holes and have no water ingestion issues. And my first class 8 truck was a 1978 and my newest is a 2013 with a new one on order, and the only ones in all those years that ever had a hole in an intercooler where in the shop to have them replaced, LOL.
Trust me....any time you have drivers and there is the SLIGHTEST power loss.....you hear about it right away! LOL.
/ 2.7EB vs 3.5EB? #66
It is a gas engine, not a diesel. I could have a giant hole in the intake runner before the throttle plate and so long as I have excessive pressure regulated by a computer controlled waste gate on the turbo, the ECU will keep pressure at where it is supposed to be throughout the engine map.
BTW, your VWs also have the same problem and you know what the solutions is? Yup, you got it: drilling a weep hole.
VW Common Rail TDI Intercooler Icing / hydrolock problem. - YouTube
/ 2.7EB vs 3.5EB? #67
My VW has never had an issue. My oldest, the Tiguan is a 2010 with 105,000 miles. According to the internet it should have blown up from a bad timing chain tensioner by now too, LOL. And be plugged up with carbon, which the dealer will clean out for you at nice hefty price with their snake oil, LOL.
/ 2.7EB vs 3.5EB? #68
Turbos have gate valves to blow off excess pressure. Weep holes are on every high performance turbo application because of the pressure drop intercoolers cause on the intake side. The EPA shut dow the best practice of OEMs providing a weep hole. Here is a Caddy forum discussing the practice. Intercooler Weep Hole
Here is the 2017 Raptor guys just discovering the fix for their woes is, you got it, a 1/16" weep hole. http://www.fordraptorforum.com/f261/just-fixed-full-race-intercooler-my-raptor-2017-a-53954/
Here is a volvo loosing power because of a lack of efficiency from their intercooler loading up with condensation and the solution again is, you got it, a weep hole. 85 T5 3Hp - Loss Of Power At High Boost (Rumbling Hesitation) - FWD/AWD 1998 and Prior - Volvospeed Forums
Some do, some don't. Most modern turbos are VG and don't use waste gates. Even many of the constant geometry turbos don't use waste gates. The BW 171702 turbo on my Detroit 12.7L doesn't have a waste gate. The factory one did, but I took that rancid piece of junk off and replaced it with the BW turbo early on. Waste gate turbo housings are considerably smaller so they need a waste gate. Non waste gated turbos are larger in diameter and there is better exhaust flow thru them which equates to more efficiency and lower EGT's.
Even if a waste gate turbo is used, that is the exhaust side of the equation. Creating a leak in the intake side just makes the turbo have to work harder to develop the proper boost. Irregardless of the engine being gas or diesel. The actuator will increase the geometry of the turbo to compensate for loss of boost pressure, but it has its limits. The demand on the turbo increases.
/ 2.7EB vs 3.5EB? #69
I've got 102k on my 2012 EB. Never an issue still drives and looks like new. Quiet, smooth, solid, good performance and mileage. I was planning to trade at 100k but it is such a good vehicle I decided to keep running it. No mods, although I have been reading internet stories that the engine will blow up since before I bought it.
/ 2.7EB vs 3.5EB? #70
So, the 1/16" hole leaks 0.5 cfm at 15 psi vs (at 3000RPM) the 741CFM that the 3.5L EcoBoost engine is pushing through air intake system (or the 572CFM that the 2.7L engine is pushing through its air intake system).
Is that enough of a difference to even be noticed by the MAF?
Aaron Z
/ 2.7EB vs 3.5EB? #71
Yeah I know drilling a hole in the inter cooler seems like knocking a hole in the bottom of a boat to let the water out. It does work though and the hole is small enough its not a problem.
/ 2.7EB vs 3.5EB? #72
After those videos of the water pouring out, why would anyone not drill the hole. Too small to make a performance issue to me.
/ 2.7EB vs 3.5EB? #73
Yes, because the gm i own will be my last one...msny friends out of pocket on gm afm engines with no help from gm. swapping to Ford.
I also refuse to buy a truck that is built in Mexico - and to support a company that bails and moves there after receiving bail out money from us.
Check gm forums, loads of afm issues.
as a fellow Canadian you should know better the truth about that , but I will leave you to your misinformed biases
/ 2.7EB vs 3.5EB? #74
A lot of VW diesels had hydrolocking issues, VW went to a air to water intercooler on the Passat TDI and this solved the problem. Ford and others could do the same. But VW’s have had this issue. You could just loosen the connection and drain it every 6 months or so.
/ 2.7EB vs 3.5EB? #75
/ 2.7EB vs 3.5EB? #77
Why did the EPA ban the weeps on inter coolers?
Crank case gasses are vented into the intake runner and sent back through to be burned in the combustion chamber. This wasn't a problem with port fuel injected engines as the income fuel charge would wash off baked on gook on the intake valves. However, when everybody switched over to direct injection, baked on gook piled up on the intake valves until engine efficiency decreased, starting became harder and rough idle became apparent. What many people have done is disconnect the case vent system from the intake and run a racing catch can for crank case vapors.
/ 2.7EB vs 3.5EB? #78
After all those videos of water pouring out would convince me not to purchase such a setup. It is flawed if that is happening. While not any Ecoboost thing, I have run turbo charged engines for several decades and never was this kind of thing an issue. It is poor engineering.
At least, as oppose to a shade tree "weep hole" solution, one should install some sort of petcock so that water/oil could be drained off manually periodically, thereby keeping the system closed when in operation to maximize efficiency of the setup.
/ 2.7EB vs 3.5EB? #79
Copperhead I’ve read where people have put some kind of fitting and valve on them but everything I’ve read says the little hole doesn’t hurt anything.
/ 2.7EB vs 3.5EB? #80
All the old turbo had a weep hole in them, and for this reason you never had this problem with turbos. You had other problems like the turbos coking up.
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2019 BIG TEX 20PH-20BK+5 HI-TENSILE DOVETAIL TRL (A64277)
2019 BIG TEX...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
2019 Mercedes Sprinter 2500 Cargo Van (A64556)
2019 Mercedes...
