2.7EB vs 3.5EB?
/ 2.7EB vs 3.5EB? #21
2011 Max Tow 3.5...plays with 6000 lb travel trailer. Never goes over 3000 RPM unless I want it to. Run in M mode you can tow in OD (5th or 6th) 99% of the time. Can cruise under 2000 RPM towing.
I would think a 2.7 with the 10 speed wouldn't flinch at 6000 lb with 3.73s
/ 2.7EB vs 3.5EB? #22
My 2.7 6AT 3.55 easily handles my tandem flatbed, usually around 5500-6000K, and gets 14-16 mpg doing it. :)
/ 2.7EB vs 3.5EB? #23
Well my 2 cents is the fuel economy is likely quite similar between the two in a truck application. However, most say a intercooled turbo basically doubles the performance of whatever the engine displacement is.
So let's do some math:
2.7 x 2 = 5.4 (does that engine size sound a little familiar in the Ford line and was never really anything to brag about).
3.5 x 2 = 7.0 (Now that sounds impressive to me).
/ 2.7EB vs 3.5EB?
Lets look at how they are built - the 2.7 is overbuilt with a CGI block and watercooled integrated exhaust manifolds just like the 6.7 PSD. I may learn to live with the short bed SCrew snd get a 2.7EB. It puts my 4.8 to shame, and the 5.3 too. The 3.5 may have higher numbers, but it is not built as stout as the 2.7EB.
I only tow heavy once or twice a year, after reading I know the 2.7EB will handle it. My truck is my daily driver, 25,000+ miles a year. Im well beyond the power crazed teenager years. Best deal on either SCrew 4x4 EB is what I will grab.
/ 2.7EB vs 3.5EB? #25
From everything I have read, the 2.7EB is an over performer in every way. However, I've never driven one.
I have driven many 3.5EBs and will likely buy one this weekend. The torque curve on the 3.5EB feels like it is similar in shape to a diesel torque curve. The RPMs are a little higher than Diesel but no where near as high as with naturally aspirated V8's. Plus the engine is quiet and low pitched so never sounds like it's really working the way a v8 does. I would be very surprised if the 2.7EB didn't share all of these characteristics.
I don't know who said they think of turbos needing high revs, but every turbo engine I've ever driven has had impressive low and mid range torque.
These EB's are running a little more than 15psi of boost. So the effect is equivalent to more than double displacement.
Whoever said the 5.0L is a close second to the 3.5EB for towing has never towed with a 3.5EB. Big difference in low end torque.
/ 2.7EB vs 3.5EB? #26
Lets look at how they are built - the 2.7 is overbuilt with a CGI block and watercooled integrated exhaust manifolds just like the 6.7 PSD. I may learn to live with the short bed SCrew snd get a 2.7EB. It puts my 4.8 to shame, and the 5.3 too. The 3.5 may have higher numbers, but it is not built as stout as the 2.7EB.......
When you say the 2.7 is built tougher than the 3.5: Are you comparing that to a Gen I 3.5 liter ecoboost or a Gen II 3.5 liter ecoboost. Ford totally redesigned the 3.5 ecoboost for 2017 and about the only thing the new motor shares with the past 3.5 ecoboost is the measurements of the bore and stroke. Everything else is all new. (And for what is worth I am not promoting Ford either as I highly doubt I will ever own Ford product as I simply hate Ford Motor Co whole heartedly. That said, I could live with an F150 with the 3.5 eco or 5.0 V8).
As for your lambasting the GM trucks you have: They both have well over 200K on them so they can not be all that bad. (not fanboying these either).
Lots of good choices in the truck market right now regardless of ones flavor of choice....if you can get past the outlandish prices from any brand.
/ 2.7EB vs 3.5EB?
The 3.5 does not use the CGI block, nor the watercooled manifolds - the 2.7 is a much stronger design.
I will not own a GM AFM oil guzzler, which is why my 11 (4.8 does not have it, nor did the 04 5.3) will be my last one. I have friends with afm trucks, all use insane amounts of oil. I also wont own another gm crew cab due to where they are built, cheap quality. My 04 was an Oshawa built truck, much higher quality.
Ford's are USA built.
The last straw for me is GM closing Ontario plants and moving to Mexico.
After test driving a 2015 F150, and my previous test drive of a 2014 Sierra, GM has a ton of catch up to do. Maybe thats why the 2019 Sierra/Silvy 1500 resemble the F150, and will also get an 'ecoboosted' 3.6. Hopefully these are as sucessful as the ecoboosts have been for Ford.
/ 2.7EB vs 3.5EB? #28
you keep flogging this idea about GM AFM being oil burners........but that is out right BS , I know many GM truck owners including my self (mine is 2014) and we have no oil usage problems whatsoever. ...........and quality has been excellent too, yes some recalls but that is GM being extra careful and EVERY brand is doing recalls these days to be extra safe. All three (four when you include Toyota) make great trucks , and our choices and brand loyalty tends to blind us to that fact.
/ 2.7EB vs 3.5EB?
Everyone I know has had it start at 100,000 miles... first the pcv system will plug up, then it starts. Wnd once it starts, its big money to fix. GM has been replacing csm snd lifters on 16's sdue to oil use... afm is garbage.
/ 2.7EB vs 3.5EB? #30
I was not under any idea that the exhaust manifolds are water-cooled. I knew the turbos were water-cooled. That is the case with all variable geometry turbos that are being used in both gasoline and diesel applications. It may also be possible that EGR is water cooled like the diesels are. Not sure what benefit it would be to cool exhaust manifolds, as it is advantageous to keep EGT's steady for maximum flow thru the exhaust system. Hotter exhaust gasses flow faster. That equates to maximum efficiency of the turbo spool up.
This why I even use turbo blankets on my turbos and heat wrap the down pipe from the turbo. Less heat loss thru the turbo housing and down pipe which keeps exhaust flowing more efficiently.
For anyone interested, PTP Turbo Blankets is taking pre-orders on F-150 ecoboost turbo blankets. This is the company I have gotten my turbo blankets from for a long time. Quality stuff.
PTP Ford F-15 Ecoboost Turbo Blankets - Pre-Order | PTP Turbo Blankets
/ 2.7EB vs 3.5EB? #31
........now thats funny, starts at 100,000 miles !!! and you bash GM at every chance you get about that as if it is imminent ! , obviously your bias is important to you to uphold. ......meanwhile we might have many 6 cyl turbo engines that might need expensive repairs at 100,000 miles too.
/ 2.7EB vs 3.5EB?
Well then explain why GM truck sales keep dropping month after momth? And Ford truck sales are still on the rise?
Unlike you, i am not blindly biased, I test drove a Ford and found out why they are a superior truck. Afm is garbage, the proof is in the pudding.
This is an eb thread, since you have nothing to contribute from buyers remorse, go find another thread to ruin.
/ 2.7EB vs 3.5EB?
2018 updates...
storybreak stars<\/title><path d="M5.146 9.1l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953L5.147 H3.76l.158 3.623L.893 1.67.2 2.867l3.214 1.638L.2 6.175l.693 1.197 3.25-1.985L3.76 9.1m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H23.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H43.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623" fill="%23CCC" fill-rule="evenodd"/><\/svg>');background-repeat:no-repeat;background-position:center}.editor .editor-inner div.legacy-raw-html,.post-content div.legacy-raw-html{border:3px solid #eeb544;padding:5px;margin-bottom:2px}.editor .editor-inner div.legacy-raw-html:before,.post-content div.legacy-raw-html:before{content:'Before this post can be saved, this block must be removed.';font-size:12px;display:inline-block}.editor .editor-inner div.legacy-raw-html table,.post-content div.legacy-raw-html table{margin-bottom:}.f_dap_tables_on .editor .editor-inner table,.f_dap_tables_on .post-content table,.f_use_dap .editor .editor-inner table,.f_use_dap .post-content table{font-family:"ProximaNovaCond",sans-serif;border:1px solid #e5e5e5;width:1%;margin-bottom:1.5rem;border-spacing:}.f_dap_tables_on .editor .editor-inner table td,.f_dap_tables_on .editor .editor-inner table th,.f_dap_tables_on .post-content table td,.f_dap_tables_on .post-content table th,.f_use_dap .editor .editor-inner table td,.f_use_dap .editor .editor-inner table th,.f_use_dap .post-content table td,.f_use_dap .post-content table th{padding:1px;text-align:left;border:;border-right:1px solid #fff}.f_dap_tables_on .editor .editor-inner table td:last-child,.f_dap_tables_on .editor .editor-inner table th:last-child,.f_dap_tables_on .post-content table td:last-child,.f_dap_tables_on .post-content table th:last-child,.f_use_dap .editor .editor-inner table td:last-child,.f_use_dap .editor .editor-inner table th:last-child,.f_use_dap .post-content table td:last-child,.f_use_dap .post-content table th:last-child{border-right:}.f_dap_tables_on .editor .editor-inner table tr:nth-child(2n) td,.f_dap_tables_on .post-content table tr:nth-child(2n) td,.f_use_dap .editor .editor-inner table tr:nth-child(2n) td,.f_use_dap .post-content table tr:nth-child(2n) td{background-color:#f5f5f5}.above-headline-image .featured-post__caption,.above-headline-image .video-embed__caption,.above-headline-image figcaption,.editor .editor-inner .featured-post__caption,.editor .editor-inner .video-embed__caption,.editor .editor-inner figcaption,.featured-post__asset .featured-post__caption,.featured-post__asset .video-embed__caption,.featured-post__asset figcaption,.post-content .featured-post__caption,.post-content .video-embed__caption,.post-content figcaption{position:relative;font-family:"ProximaNovaCond",sans-serif;color:#aaa;font-size:15px;line-height:21px;text-align:left;margin-top:.5rem;display:block}.above-headline-image .featured-post__caption:focus,.above-headline-image .video-embed__caption:focus,.above-headline-image figcaption:focus,.editor .editor-inner .featured-post__caption:focus,.editor .editor-inner .video-embed__caption:focus,.editor .editor-inner figcaption:focus,.featured-post__asset .featured-post__caption:focus,.featured-post__asset .video-embed__caption:focus,.featured-post__asset figcaption:focus,.post-content .featured-post__caption:focus,.post-content .video-embed__caption:focus,.post-content figcaption:focus{outline:none}.above-headline-image .video-embed__caption,.editor .editor-inner .video-embed__caption,.featured-post__asset .video-embed__caption,.post-content .video-embed__caption{margin-top:-.5rem}.above-headline-image .featured-post__caption,.editor .editor-inner .featured-post__caption,.featured-post__asset .featured-post__caption,.post-content .featured-post__caption{position:absolute;top:1%}.ad-unit--featured-recirculation{opacity:1;pointer-events:auto;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;z-index:97}.ad-unit--featured-recirculation .ad-container{background:#f5f5f5;width:3px;height:25px}.ad-unit--featured-recirculation .ad-container--hidden{opacity:;pointer-events:none;visibility:hidden}.ad-unit--fixed-bottom{position:fixed;bottom:3.5rem;right:1.125rem;height:auto;width:3px;opacity:1;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;pointer-events:auto}.ad-unit--fixed-bottom--invisible{opacity:;pointer-events:none}.ad-unit--fixed-bottom .ad-container{background:#f5f5f5;width:3px;height:25px}.editor .editor-inner .has-image.align--center.media-large{max-width:636px}.shared{margin-bottom:3.4rem}.shared .content-wrapper{background-color:#f5f5f5;padding-top:24px;border:1px #aaa solid}.shared .referenced-label{background-color:#f5f5f5}.shared .reframe-post{margin-bottom:1.875rem}.post .linked,.post .recommend{background-color:rgba(,,,.7);position:absolute;cursor:pointer;top:8px;right:8px;width:32px;height:32px;opacity:;-webkit-transition:all .15s ease-out;transition:all .15s ease-out;border-radius:5px;z-index:1}.post .linked{bottom:;border-top-left-radius:5px}.post .flex-video:hover .recommend,.post .has-image:hover .linked,.post .has-image:hover .recommend,.post figure:hover .linked,.post figure:hover .recommend{opacity:1}.post .has-image .recommend{right:8px}.post .movementventures,.post .qzzr{width:1%}.post a[x-inset=hidden]{display:none}.pullquote{margin-bottom:2rem;margin-top:2rem;text-align:center;padding:1px ;font-family:"ProximaNovaCond",sans-serif;font-weight:lighter;font-style:italic;font-size:25px;line-height:37px;clear:left}.pullquote:after,.pullquote:before{content:'';display:block;width:45px;height:;margin: auto;position:relative;border-top-width:1px;border-top-style:solid;border-color:#aaa}.pullquote:before{margin-bottom:2px}.pullquote:after{margin-top:2px}@media only screen and (min-width: 37.5em){.pullquote.align--left{width:4%;max-width:32px;float:left;margin-right:2.25rem;text-align:left;margin-bottom:.5em;margin-top:}.pullquote.align--left:after,.pullquote.align--left:before{margin-left:;margin-right:}}.pullquote__helper{display:none}.commentlist .pullquote,.quickreply .pullquote{margin-bottom:1em;margin-top:1em;text-align:left;padding: 1.125rem;font-size:22px;line-height:3px;position:relative}.commentlist .pullquote:before,.quickreply .pullquote:before{position:absolute;left:;top:3px;bottom:5px;width:;height:auto;border-top:;border-left-width:1px;border-left-style:solid;margin:}.commentlist .pullquote:after,.quickreply .pullquote:after{display:none}.post-content .inset--story{clear:both;margin:2rem auto;padding:1.125rem;border:#e5e5e5 1px solid;border-radius:5px;-webkit-box-shadow:#e5e5e5 2px 5px;box-shadow:#e5e5e5 2px 5px;max-width:636px}.post-content .inset--story p{font-size:15px;line-height:25px;margin-bottom:.6rem}@media only screen and (min-width: 37.5em){.post-content .inset--story{display:-webkit-box;display:-ms-flexbox;display:flex}}.post-content .inset--story__thumb{display:block;position:relative;margin:-1.125rem -1.125rem 1rem}@media only screen and (min-width: 37.5em){.post-content .inset--story__thumb{width:25%;min-width:25%;margin: 1.125rem ;float:left}}.post-content .inset--story__thumb figure{margin:;position:relative}.post-content .inset--story__thumb img{width:1%}.post-content .inset--story__headline{font-size:2px;line-height:24px;margin-bottom:1px}.post-content .inset--story__headline a,.post-content .inset--story__headline a:hover{color:#}.post-content .inset--story__readmore{font-family:"ProximaNovaCond",sans-serif;font-size:16px}.post-content .inset--story__readmore .hostname{font-weight:bold}.non-secure-iframe-embed{position:relative;padding-bottom:56.25%}.iframe-container{position:absolute;top:;left:;height:1%;width:1%}.iframe-container__external-source{height:92.5%;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;background-color:#e5e5e5}@media only screen and (max-width: 37.438em){.iframe-container__external-source{position:relative}}.iframe-container__external-source svg{opacity:.1}.iframe-container__external-source img{position:absolute;top:;left:;width:1%;opacity:.8}@media only screen and (max-width: 37.438em){.iframe-container__external-source img{position:relative}}.iframe-container__link-to-source{position:absolute;top:25px;right:25px}.iframe-container__link-to-source svg{opacity:.7;fill:#fff}.iframe-container__message{position:absolute;bottom:;height:7.5%;width:1%;background:#fff;color:#aaa;font-size:15px}@media only screen and (max-width: 37.438em){.iframe-container__message{position:absolute;height:auto}}.iframe-container__message p{position:absolute;font-family:"ProximaNovaCond", sans-serif;bottom:;margin:;font-size:15px;text-align:left}@media only screen and (max-width: 37.438em){.iframe-container__message p{position:relative}}.iframe-container__message a{text-decoration:none;color:#93ec}.google-adx .container{background-color:#f5f5f5;line-height:18px;padding:5px 1.125rem}.google-adx .by-google{color:#;font-size:14px}.google-adx .google-headline{color:#333}.post-bottom{margin: -1.125rem;max-width:none;width:auto}.post-bottom:after,.post-bottom:before{content:" ";display:table}.post-bottom:after{clear:both}@media only screen and (max-width: 37.438em){.post-bottom{margin:2rem 1rem}}@media only screen and (min-width: 37.5em){.post-bottom{margin:1.5rem }}.post-bottom .post-bottom__inner{max-width:636px;margin: auto}.post-bottom,.post-bottom a{color:#777}.post-bottom .fb-like{float:left;z-index:4;width:auto}.post-bottom .reply-to-post{color:#aaa}.post-bottom .reply-to-post .icon{margin-left:7px}.post-bottom .icon{opacity:.3;margin-left:5px;vertical-align:middle}.private-post-list{border-bottom:2px #aaa solid}.stream{padding-bottom:}.stream .meta .publish-time .icon{margin: 5px}.stream .post-dropdown-ct{display:none}.unshare-bloglist{position:absolute;top:;right:;z-index:1}.unshare-bloglist .unshare-bloglist-select,.unshare-bloglist .unshare-bloglist-title{display:inline-block;vertical-align:middle}.unshare-bloglist .unshare-bloglist-title{padding: 3px;background-color:#fff;margin: 1px }.unshare-bloglist .unshare-bloglist-select{margin-bottom:}.text-red{color:#eeb544}.post-tools-wrapper .reply-to-post__container .svg-icon{margin-left:;position:relative;top:2px}@media only screen and (max-width: 37.438em){.post-tools-wrapper .reply-to-post__container{display:none}}@media only screen and (max-width: 37.438em){.post-tools-wrapper{-webkit-box-flex:1;-moz-flex:1 1 1%;-ms-flex:1 1 1%;flex:1 1 1%;-webkit-box-ordinal-group:3;-moz-order:2;-ms-flex-order:2;order:2;margin:3px 14px}}@media only screen and (max-width: 37.438em){.post-tools-wrapper .button-recommend-post,.post-tools-wrapper .reply-count{display:none}}.newsletter-subscribe-post{display:block;font-family:"ElizabethSerif",Georgia,serif;border-top:#e5e5e5 1px solid;margin:1.5rem ;max-width:636px}.newsletter-subscribe-post__copy{color:#aaa;margin:1.5rem 1rem;line-height:29px}.newsletter-subscribe-post .button{font-size:1.1rem;padding: 1.2rem}.newsletter-subscribe-post .svg-icon{opacity:1;fill:#93ec}.center{margin: auto}ul.commerce-inset.fake-list{margin-bottom:;margin-top:-2px}.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:4px;margin:.5rem 1.125rem .5rem }.asset.has-media.has-image.align--left.media-large{width:1%}.asset.has-media.has-image.media-large.align--center{max-width:636px}@media only screen and (max-width: 27.25rem){.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:1%}}@media only screen and (min-width: 37.5em){.asset.has-media.has-image{margin-left:auto;margin-right:auto;max-width:636px}.asset.has-media.has-image.media-large{margin-left:-1.125rem;margin-right:-1.125rem;max-width:initial}.asset.has-media.has-image.media-large.align--center{margin-left:auto;margin-right:auto}.asset.media-small.has-media.has-image:not(.align--center){margin-bottom:.5rem;margin-right:1.125rem}}@media only screen and (min-width: 53.126em){.asset.has-media.has-image.media-large{margin-left:auto;margin-right:auto}}.post-content{font-family:"ElizabethSerif",Georgia,serif}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper{position:relative;background:#f5f5f5}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper img{background:none}.post-content .has-image.has-image.media-large .img-wrapper,.post-content .has-image.has-image.media-medium .img-wrapper,.post-content .has-image.has-image.media-small .img-wrapper{max-width:1%}.post-content .has-image.has-image.media-large .img-wrapper img,.post-content .has-image.has-image.media-medium .img-wrapper img,.post-content .has-image.has-image.media-small .img-wrapper img{position:absolute;height:auto;top:;left:;right:;bottom:}.post-content .has-image.has-image.media-large .lightbox-wrapper,.post-content .has-image.has-image.media-medium .lightbox-wrapper,.post-content .has-image.has-image.media-small .lightbox-wrapper{display:block}.img-wrapper{max-width:1%}.old-post-type-img{display:block;margin:1.125rem auto}.gmg-text-ad{margin:2rem auto;max-width:636px;font-family:"ProximaNovaCond", sans-serif}.gmg-text-ad .text-ad__inner{border:1px solid #e5e5e5;border-left-width:;border-right-width:;padding:3px 18px 1px;position:relative;background-color:#f5f5f5}.gmg-text-ad .text-ad__inner:before{content:'Advertisement';text-transform:uppercase;position:absolute;top:;width:1%;text-align:center;color:#ccc;font-size:13px}.gmg-text-ad a{display:block;color:#}.gmg-text-ad a:hover{text-decoration:none}.gmg-text-ad .text-ad__headline{font-size:2px;line-height:24px;margin-bottom:5px;color:#}.gmg-text-ad a:hover .text-ad__headline{text-decoration:underline}.gmg-text-ad .text-ad__excerpt{font-family:"ElizabethSerif", Georgia, serif;font-size:15px;color:#333;line-height:26px;margin: 3px}.gmg-text-ad .text-ad__more{color:#ccc;font-size:15px}@-webkit-keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}@keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}.discussion-status-badge-wrapper{display:block;margin-bottom:2px}.discussion-status-badge-wrapper .discussion-status-badge{color:#fff;background-color:rgba(,,,.7);display:inline;padding:5px 1px}.discussion-status-badge{color:#ef774;line-height:24px;margin-bottom:12px;text-transform:uppercase}.discussion-status-badge:before{display:inline-block;content:'';width:11px;height:11px;background-color:#ef774;border-radius:11px;margin-right:5px;-webkit-animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite;animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite}.meta__tools .f-dropdown{text-align:left}.commerce-disclaimer{margin-bottom:2px;display:-webkit-box;display:-ms-flexbox;display:flex}.commerce-disclaimer:before{content:"";border-left:2px solid #72ad75;margin:4px 6px}.commerce-disclaimer span{padding-left:1px}.customkinja-backlink{max-width:636px;margin:2em auto}.customkinja-backlink:after,.customkinja-backlink:before{content:'';display:block;height:;width:auto;border-top-width:1px;border-top-style:solid;border-color:#ccc}.customkinja-backlink a{display:inline-block;padding:1em }.post__misc{clear:both}.permalink.featured-post .main{left:;padding:}.permalink.featured-post .entry-title{color:white;font-size:8.5vw;font-weight:normal;line-height:1.1;text-align:center;margin: auto;max-width:118px;width:1%}.permalink.featured-post .entry-title a{color:white}.permalink.featured-post .row.content-wrapper,.permalink.featured-post .post-wrapper{margin:}.permalink.featured-post .post{padding:}.permalink.featured-post .post .meta--pe{margin-bottom:;margin-left:auto;margin-right:auto;max-width:636px}.permalink.featured-post .post__misc{padding: 1.125rem}.permalink.featured-post .post--empty .meta--pe{margin-top: !important;margin-bottom: !important;padding-bottom:;border-top:;border-bottom:}.permalink.featured-post .post-content:not(.reply__content){margin-top:3px;padding: 1.125rem}.permalink.featured-post .ad-unit--in-post .ad-container{height:25px}.permalink.featured-post .entry-content.fixed{position:fixed;right:1px;top:}.permalink.featured-post .entry-content.unfixed{position:absolute;right:}.featured-post__sponsored-label{color:#aaa;font-size:13px;text-transform:uppercase}.featured-post__header{background:black;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-align:center;-ms-flex-align:center;align-items:center;position:relative}.featured-post__header .discussion-status-badge{font-size:.42em;margin:18px ;text-align:center}.featured-post__header.magazine{-webkit-box-align:initial;-ms-flex-align:initial;align-items:initial;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__asset-group{width:1%}.featured-post__header.magazine .featured-post__asset-group:after{display:none}.featured-post__header.magazine .featured-post__asset{padding:}.featured-post__header.magazine .featured-post__asset .featured-post__caption,.featured-post__header.magazine .featured-post__asset figcaption{display:none}.featured-post__header.magazine .featured-post__alternate-image-caption{display:block}.featured-post__header.magazine .featured-post__meta-container{display:none}.featured-post__header.magazine .featured-post__headline-container{width:1%}.featured-post__header.magazine .featured-post__headline-container-author{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__headline-container-author .meta--pe.secondary-byline{margin:;max-width:1%}.featured-post__header.magazine .featured-post__headline-container-author .meta__label--sponsored{color:#aaa}.featured-post__headline-container-author{width:1%}.featured-post__headline-container-author .meta--pe{margin-bottom:;padding-top:3px;width:1%}.featured-post__headline-container-author .meta--pe .svg-icon{opacity:1;stroke:#aaa}.featured-post__headline-container-author .meta--pe .svg-icon.stroked{stroke:#aaa}.featured-post__headline-container-author .meta--pe .meta__byline,.featured-post__headline-container-author .meta--pe .meta__byline a,.featured-post__headline-container-author .post-tags-container .first-tag span{color:white}.featured-post__headline-container{padding:2px}.featured-post__headline-container,.featured-post__headline-container .featured-post__headline-container-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:center;-ms-flex-align:center;align-items:center}.featured-post__meta-container,.featured-post__meta-container-alt{display:none;-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:1%}.featured-post__meta-container-alt .meta--pe,.featured-post__meta-container .meta--pe{border-top:1px solid #e5e5e5;border-bottom:1px solid #e5e5e5;margin:4px !important;max-width:636px;padding:4px ;width:1%}.featured-post__asset-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-ordinal-group:;-ms-flex-order:-1;order:-1;position:relative;width:1%}.featured-post__asset-group:after{background:white;bottom:;content:'';display:none;left:;height:25%;position:absolute;right:;width:1%}.featured-post__asset-group .featured-post__cover{height:1%;max-height:1%}.featured-post__asset{padding:;position:relative;width:1%;z-index:1}.featured-post__asset,.featured-post__asset.pillarboxed{background:transparent}.featured-post__asset img,.featured-post__asset video{width:1%}.featured-post__asset .featured-post__caption,.featured-post__asset figcaption{display:none;margin:auto;max-width:636px;padding:1px }.featured-post__asset .img-wrapper{background-size:cover}.featured-post__asset__container{height:calc(1vw*9/16);margin: auto;max-height:calc(85vh);max-width:calc(85vh*16/9);width:1%}.featured-post__asset__container.video-type--JwPlayer,.featured-post__asset__container.video-type--Mcp,.featured-post__asset__container.video-type--OnionStudios,.featured-post__asset__container.video-type--YoutubeVideo{position:relative;height:1%;max-height:1%;max-width:1%;width:1%}.featured-post__asset__container.video-type--JwPlayer:after,.featured-post__asset__container.video-type--Mcp:after,.featured-post__asset__container.video-type--OnionStudios:after,.featured-post__asset__container.video-type--YoutubeVideo:after{content:"";display:block;padding-top:56.25%;width:1%}.featured-post__asset__container.video-type--JwPlayer>iframe,.featured-post__asset__container.video-type--Mcp>iframe,.featured-post__asset__container.video-type--OnionStudios>iframe,.featured-post__asset__container.video-type--YoutubeVideo>iframe{bottom:;left:;position:absolute;right:;top:}.featured-post__asset__container iframe{height:1%;width:1%}.featured-post__cover{background-position:center;background-repeat:no-repeat;background-size:contain;cursor:pointer;height:calc(1vw*9/16);left:;max-height:calc(85vh);position:absolute;top:;width:1%}.featured-post__cover .play-icon{background:rgba(,,,.6);border-radius:5px;display:block;height:6px;left:calc(5% - 18px);position:absolute;top:calc(5% - 3px);width:56px}.featured-post__cover .svg-icon{height:6px;margin-top:;opacity:.8;width:56px}.featured-post__cover:hover .svg-icon{opacity:1}.featured-post__alternate-image-caption{color:#aaa;display:block;padding:1px 1.25rem }.featured-post__alternate-image-caption>div{margin:auto;max-width:636px}.featured-post__alternate-image-caption.magazine{display:block}@media only screen and (min-width: 768px){.permalink.featured-post .entry-title{font-size:6vw}}@media only screen and (min-width: 124px){.permalink.featured-post .post .post-content{margin:auto;margin-top:;max-width:124px;width:1%}.permalink.featured-post .ad-unit--in-post{display:none}.permalink.featured-post .entry-title{font-size:4vw}.permalink.featured-post .featured-post__alternate-image-caption{display:none}.permalink.featured-post .featured-post__alternate-image-caption.magazine{display:block}.featured-post__headline-container{padding:4px}.featured-post__header{margin-bottom:}.featured-post__header .featured-post__headline-container-author,.featured-post__header .featured-post__meta-container .featured-post__headline-container-author,.featured-post__header.magazine .featured-post__headline-container-author{display:none}.featured-post__header .featured-post__asset .featured-post__caption,.featured-post__header .featured-post__asset figcaption{display:block}.featured-post__header.magazine{-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row}.featured-post__header.magazine .entry-title{font-size:3vw}.featured-post__header.magazine .featured-post__asset-group{width:75%}.featured-post__header.magazine .featured-post__headline-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;min-width:35px;width:25%}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:start;-ms-flex-align:start;align-items:flex-start}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group h1{text-align:left}.featured-post__header.magazine .meta--pe{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .meta__right{margin-top:15px;right:;width:1%}.featured-post__header.magazine .meta__data--comment{margin-left:auto}.featured-post__header.magazine .featured-post__category-label-wrapper{margin-bottom:}.featured-post__meta-container-alt,.featured-post__meta-container{display:-webkit-box;display:-ms-flexbox;display:flex}.featured-post__meta-container{background:white}.featured-post__asset-group{-webkit-box-ordinal-group:initial;-ms-flex-order:initial;order:initial}.featured-post__asset-group:after{display:block}.featured-post__asset{padding: 2.5%}}@media only screen and (min-width: 18px){.permalink.featured-post .entry-title{font-size:3vw}.featured-post__header.magazine .entry-title{font-size:2.5vw}}.sharingfooter{position:fixed;bottom:;left:;right:;background:#fff;z-index:98;-webkit-box-shadow: 1px rgba(,,,.4);box-shadow: 1px rgba(,,,.4);height:38px;line-height:38px;vertical-align:middle;font-size:13px}html.fallback-fonts .sharingfooter{font-family:"Arial Narrow",Arial,sans-serif;font-size:12.285px;line-height:39.444px;letter-spacing:.5px}.sharingfooter:active,.sharingfooter:hover{-webkit-box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);-webkit-transition:all 2ms ease-in-out;transition:all 2ms ease-in-out}.sharingfooter__wrapper{margin: auto;max-width:63rem;width:1%;max-width:1336px}.sharingfooter__wrapper:after,.sharingfooter__wrapper:before{content:" ";display:table}.sharingfooter__wrapper:after{clear:both}.sharingfooter__content{float:right;padding: 1.125rem}.sharingfooter__content a{display:inline-block;margin-left:1px}.sharingfooter__content .button--share{margin-top:5px}@media only screen and (max-width: 53.125em){.sharingfooter__content{float:none;text-align:center}.sharingfooter__content a{margin:}.sharingfooter__content .sharingfooter__facebook{text-align:right;padding-right:1px}.sharingfooter__content .sharingfooter__twitter{text-align:left;padding-left:1px}}.alert-bar{position:relative;padding:.5em;background-color:#eeb544;color:rgba(,,,.6)}.alert-bar.alert-bar__hero{margin:2em ;font-size:1.1em}.alert-bar.alert-bar__inline{width:1%}.alert-bar.alert-bar__control{padding-right:2em}.alert-bar .alert-bar__text{position:relative;top:1px}.alert-bar .alert-bar__icon{position:absolute;top:1px;right:1px}.reply__byline,a.reply__count span,a.reply__link span{font-family:"ProximaNovaCond",sans-serif;font-weight:5}.reply .unapproved-msg,.reply__pending-label,.reply__publish-time,.reply__to-author{font-family:"ProximaNovaCond",sans-serif;font-weight:4}@media only screen and (max-width: 37.438em){.reply--depth-{margin-left:}}.reply--depth->.reply__header>.avatar{margin-top:}.reply--depth->.reply__header>.avatar img{width:4px;height:4px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__header>.avatar{margin-top:2px}.reply--depth->.reply__header>.avatar img{width:32px;height:32px}}.reply--depth->.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;max-width:696px;padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply--depth->.reply__tools{padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__tools{padding-left:1.125rem}}.reply--depth-.anchor>.reply__content{max-width:666px}ul.commentlist{margin:}ul.commentlist--depth-{position:relative;left:-5px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-{left:}}ul.commentlist--depth- .unapproved-filter--thread{width:686px;margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth- .unapproved-filter--thread{width:auto;margin-left:}}ul.commentlist--depth-1{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1{margin-left:18px}}ul.commentlist--depth-1+.reply-footer-bar{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1+.reply-footer-bar{margin-left:}}.commentlist__item:after{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5;margin: 6px}@media only screen and (max-width: 37.438em){.commentlist__item:after{position:relative;width:12%;left:-2%;margin:}}.commentlist__item:last-child:after{display:none}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:after{width:auto;margin: 46px 5px}}@media screen and (min-width: 64em) and (max-width: 69.375em){.commentlist__item--depth-1:after{margin: 5px}}.commentlist__item--depth-1:first-child:before{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5}@media only screen and (max-width: 37.438em){.commentlist__item--depth-1:first-child:before{position:relative;width:12%;left:-2%}}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:first-child:before{margin-right:5px}}@media screen and (min-width: 124px) and (max-width: 111px){.commentlist__item--depth-1:first-child:before{margin:}}.commentlist__item:not(.commentlist__item--depth-) .editor{margin-left:}.commentlist__item--depth-.commentlist__item--expandable:after{display:none}.commentlist__item--depth-.commentlist__item--expandable .reply-footer-bar{display:block}.reply{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row wrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row wrap;max-width:8px;padding:2px ;position:relative}.reply:hover .post-dropdown-trigger .svg-icon{opacity:1}.reply p.media-64{padding-bottom:1rem}.reply .media-3{float:left;max-width:5%;margin: 2.25rem ;padding:5px 15px }.reply .post-tools{bottom:;margin:;position:absolute;right:}.reply .post-tools .post-bottom{margin:}.reply .unapproved-msg{color:#aaa;font-size:.875rem;padding-bottom:1rem;font-style:italic}.reply img{width:1%}.reply.anchor:before{content:'';display:inline-block;height:1%;width:3px;position:absolute;left:-16px;top:}@media only screen and (max-width: 37.438em){.reply.anchor:before{left:-1.125rem}}.reply__header{-webkit-box-ordinal-group:1;-moz-order:;-ms-flex-order:;order:;width:1%;color:#aaa;line-height:1.4;position:relative;padding-right:23px;padding-bottom:1px}@media only screen and (min-width: 66.3em){.reply__header{padding-right:}}.reply__header .icon{opacity:.3;margin-left:1px}@media only screen and (max-width: 124px){.reply__header .icon{margin-top:-5px;margin-left:3px}}.reply__header>.avatar{float:left;display:block;position:relative;margin-top:2px;margin-right:2px}@media only screen and (max-width: 37.438em){.reply__header>.avatar{margin-right:1px}}.reply__header>.avatar img{height:3px;width:3px;display:block}@media only screen and (max-width: 37.438em){.reply__header>.avatar img{width:32px;height:32px}}.reply__header>.avatar .svg-checkmark{right:-6px;bottom:-5px}.reply__header .avatar .svg-checkmark,.reply__header .avatar .svg-checkmark--small{display:none;position:absolute;fill:#93ec;opacity:.9}.reply__header .post-dropdown-trigger{position:absolute;right:}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-trigger{right:1px}}.reply__header .post-dropdown-ct{position:absolute;top:3px}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct{position:static}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct{right:-14px}}@media only screen and (min-width: 9px) and (max-width: 124px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 128px) and (max-width: 147px){.reply__header .post-dropdown-ct{right:-41px;min-width:3px;min-height:1px}}@media only screen and (min-width: 148px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:6px}}@media only screen and (min-width: 88em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:-169px}}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct .f-dropdown{width:9%;left:5%;right:5%}}.reply__header .post-dropdown-ct .f-dropdown .repostblock{background:inherit;cursor:default}.reply__header .post-dropdown-ct .f-dropdown .repostblock ul{margin:}.reply__header .post-dropdown-ct .f-dropdown .repostblock .repostheader{display:block;background:inherit;cursor:default;padding-left:.5rem}.reply__header.without-dropdown{padding-right:}.reply__header.without-dropdown .post-dropdown-ct{display:none}.reply__header.followed .avatar .svg-checkmark,.reply__header.followed .avatar .svg-checkmark--small{display:block}.featured-post .reply__header .post-dropdown-ct{right:-14px}.reply__byline{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row nowrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row nowrap;font-size:16px}@media only screen and (max-width: 37.438em){.reply__byline{font-size:14px}}.reply__byline a{overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;font-weight:bold;color:#}.reply__byline a:focus,.reply__byline a:hover{color:#}.reply__to-author{-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;font-weight:normal}@media only screen and (max-width: 124px){.reply__to-author .icon{margin-top:-3px}}.reply__publish-time{font-size:.812rem}.reply__publish-time a{color:#aaa}.reply__publish-time a:active,.reply__publish-time a:focus,.reply__publish-time a:hover{color:#aaa;text-decoration:underline}.reply__pending-label{color:#;text-transform:uppercase;font-size:14px;display:none;float:right;margin-right:5px}@media only screen and (max-width: 37.438em){.reply__pending-label{float:none;margin:;position:absolute;right:;top:22px}}.reply--unapproved .reply__publish-time .reply__pending-label{display:none}@media only screen and (max-width: 37.438em){.reply--unapproved .reply__publish-time .reply__pending-label{color:black;position:static;font-size:13px;margin-left:5px;display:inline-block}}.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;-webkit-box-ordinal-group:2;-moz-order:1;-ms-flex-order:1;order:1;max-width:636px;position:relative;padding-left:5px}@media only screen and (max-width: 37.438em){.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply__content blockquote,.reply__content ol,.reply__content p,.reply__content ul{font-size:15px;line-height:28px;padding-bottom:.625rem}.reply__content>:last-child{padding-bottom:}@media only screen and (max-width: 37.438em){.reply__content{width:1%}}@media only screen and (max-width: 53.125em){.reply__content .has-video.has-video.media-large{margin:}}a.reply__count,a.reply__link{line-height:1;color:#aaa}a.reply__count span,a.reply__link span{color:#}a.reply__count .icon,a.reply__link .icon{margin-left:5px}a.reply__count:active,a.reply__count:focus,a.reply__count:hover,a.reply__link:active,a.reply__link:focus,a.reply__link:hover{color:#aaa;text-decoration:none}.reply__link{margin-left:6.5px;position:relative}@media only screen and (max-width: 37.438em){.reply-disabled,.reply__content p,.reply__header{padding-left:1.125rem;padding-right:1.125rem}}@-webkit-keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}@keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}.kinja-slide{-webkit-transition-timing-function:cubic-bezier(.25, .1, .25, 1);transition-timing-function:cubic-bezier(.25, .1, .25, 1)}.kinja-slide__container{width:1%;padding-bottom:66.6666%;position:relative}.kinja-slide__container--wide{padding-bottom:56.25%}@media only screen and (max-width: 37.438em){.kinja-slide--ad .kinja-slide__container{padding-bottom:18px}}.kinja-slide__image-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;background:#;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}@media only screen and (max-width: 37.438em){.kinja-slide__image-container{background:#333}}.kinja-slide__image{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden}.kinja-slide__image,.kinja-slide__image img{-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}.kinja-slide__image img{max-width:1%;max-height:1%;-ms-flex-item-align:center;align-self:center;position:relative;-o-object-fit:contain;object-fit:contain}.kinja-slide__image.kinja-slide__image.kinja-slide__image.kinja-slide__image{width:auto}.kinja-slide__image--hidden{display:none}.kinja-slide__blur-background{background-size:cover;background-position:center center;-webkit-filter:blur(3px);filter:blur(3px);position:absolute;width:12%;height:12%;opacity:.6}.kinja-slide__blur-background--hidden{display:none}@media only screen and (max-width: 37.438em){.kinja-slide__blur-background{display:none}}.kinja-slide__caption{color:#333;font-size:16px;line-height:21px;margin: auto;padding:18px;max-width:636px}@media only screen and (min-width: 37.5em){.kinja-slide__caption{padding:18px ;margin: 82px}}.kinja-slide .loading .container{background:#f5f5f5}.kinja-slide__ad-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-sizing:border-box;box-sizing:border-box;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none;color:#aaa;font-size:14px;font-weight:bold;line-height:17px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-container{background:#333;position:absolute;left:;top:;right:;bottom:}}.kinja-slide__ad-container .ad-container{width:3px;height:25px;background-color:#fff}.kinja-slide__ad-label{margin-bottom:5px;margin-top:15px;text-transform:uppercase}.kinja-slide__ad-buttons{display:-webkit-box;display:-ms-flexbox;display:flex;margin-top:1px;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;width:3px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-buttons{display:none}}.kinja-slide.wiggle .kinja-slide__caption,.kinja-slide.wiggle .kinja-slide__container{-webkit-animation:kinja-slide-wiggle .6s ease-in-out both;animation:kinja-slide-wiggle .6s ease-in-out both}.kinja-slideshow{margin-bottom:2px;position:relative;overflow:hidden;background-color:#f5f5f5;font-family:"ProximaNovaCond",sans-serif}.kinja-slideshow__deck{display:-webkit-box;display:-ms-flexbox;display:flex}.kinja-slideshow .kinja-slide{width:1%;position:relative;-webkit-box-flex:;-ms-flex: 1%;flex: 1%}.kinja-slideshow__navigate-left.button{display:none;position:absolute;top:2px;margin-top:66.6666%;left:2px}.kinja-slideshow__navigate-left.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-left.button{display:inherit}}.kinja-slideshow__navigate-right.button{display:none;position:absolute;top:2px;margin-top:66.6666%;right:2px}.kinja-slideshow__navigate-right.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-right.button{display:inherit}}.kinja-slideshow--wide .kinja-slideshow__navigate-left,.kinja-slideshow--wide .kinja-slideshow__navigate-right{margin-top:56.25%}.kinja-slideshow__index{padding: 18px 15px;max-width:636px;margin: auto;font-size:16px;line-height:21px;font-weight:normal;color:#aaa}.kinja-slideshow__index .svg-icon{margin-right:3px}@media only screen and (min-width: 37.5em){.kinja-slideshow__index{padding: 15px;margin: 82px}}.reviewbox-inset{clear:left}.reviewbox-inset .review-box__head-content-wrapper{display:none}@media only screen and (min-width: 37.5em){.reviewbox-inset.align--left .review-box{width:32px;margin:}}.reviewbox-inset.align--left .review-box__head-content{display:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box{max-width:1%}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head{position:relative;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:left;-ms-flex-align:left;align-items:left;padding-left:64%}}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{position:relative;display:block;width:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:before{content:"";width:1px;margin-left:-1px;float:left;height:;padding-top:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:after{content:"";display:table;clear:both}@media only screen and (max-width: 53.125em){.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head-content{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-flex:1;-ms-flex-positive:1;flex-grow:1;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;max-width:1%;padding:15px}.reviewbox-inset.align--fullbleed .review-box__head-content .review-score{position:unset;margin: auto;background:#fff;border-color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content .review-box__title{color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content:not(.review-box__head-content--visually-hidden){position:absolute;top:;right:;bottom:;left:}.reviewbox-inset.align--fullbleed .review-box__head-content--visually-hidden{visibility:hidden}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image-wrapper{-ms-flex-preferred-size:64%;flex-basis:64%;padding-top:36%;padding:;position:absolute;width:64%;top:;left:;right:36%;bottom:;height:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image{position:absolute;top:-9999px;right:-9999px;bottom:-9999px;left:-9999px;min-height:1%;max-width:none;width:auto;margin:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__content .review-box__title,.reviewbox-inset.align--fullbleed .review-box__content .review-score,.reviewbox-inset.align--fullbleed .review-box__content--nodata{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__data-wrapper:not(.review-box__data-wrapper--single){-webkit-column-count:2;column-count:2;-webkit-column-gap:3px;column-gap:3px}}.reviewbox-inset.align--fullbleed .review-box__data-item{-webkit-column-break-inside:avoid;break-inside:avoid;page-break-inside:avoid}.reviewbox-inset.align--fullbleed .review-box__data-label,.reviewbox-inset.align--fullbleed .review-box__data-value{max-width:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .storytype-label-wrapper--top{display:none}}.reviewbox-inset.align--fullbleed .storytype-label-wrapper--head{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;margin-bottom:2px}.review-box{margin:3px auto;max-width:47px;width:1%}.review-inset-editor .review-box{width:32px}.review-box__tag-wrapper{max-width:1%;height:26px;margin-bottom:1px}.review-box__tag-wrapper,.review-box__tag{display:-webkit-box;display:-ms-flexbox;display:flex}.review-box__tag{height:1%;padding:5px 5px 5px 7px;-webkit-box-flex:;-ms-flex: auto;flex: auto;overflow:hidden;font-family:"ProximaNovaCond",sans-serif;font-size:15px;line-height:18px;background-color:#93ec;-webkit-transition:background-color .1s ease-out;transition:background-color .1s ease-out}.review-box__tag:first-child{-webkit-box-flex:;-ms-flex: 1 auto;flex: 1 auto}.review-box__tag:first-child .review-box__text{white-space:nowrap;overflow:hidden;text-overflow:ellipsis}.review-box__tag:hover{text-decoration:none;background-color:#73b9}.review-box__tag:not:)last-child){margin-right:1px}.review-box__tag .svg-icon.small{min-width:1px;height:1%;-ms-flex-item-align:end;align-self:flex-end;stroke:#fff;opacity:1}.review-box__text{margin-right:5px;color:#fff;text-transform:uppercase}.review-box__image-wrapper{position:relative;height:;padding-top:56.25%}.review-box__image-container{width:1%;overflow:hidden;position:absolute;top:;right:;bottom:;left:}.review-box__image-container .spinner.bounce{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;width:1%;height:1%;background-color:#e5e5e5}.review-box__image{width:1%}.review-box__head-content-wrapper{display:none}.review-box__content{position:relative;padding:15px 15px 15px;background-color:#f5f5f5}.review-box__content--nodata{padding:15px}.review-box__content--nodata .review-box__title{margin-bottom:}.review-box__content--nodata .review-box__data-wrapper{display:none}.review-box__title{margin-bottom:15px;font-size:24px;line-height:28px;text-align:center}.review-box__title:last-child{margin-bottom:}.review-box__data-item{padding-bottom:15px}.review-box__data-label{margin-bottom:;font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:normal;line-height:28px;color:#666;text-transform:uppercase}.review-box__data-value{font-family:"ElizabethSerif",Georgia,serif;color:#222;margin-bottom:}.post-content .review-box__data-value,.dui-modal .review-box__data-value{font-size:15px;line-height:28px}.review-score{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:48px;height:48px;margin: auto 15px;border:2px solid #f5f5f5;border-radius:5%;font-family:"ProximaNovaCond",sans-serif;font-size:24px;line-height:24px;color:#fff;background-color:#333}.review-score--img{margin:;position:absolute;top:-38px;left:calc(5% - 24px)}.review-score--small{font-size:19px;line-height:19px;height:36px;width:36px}@media only screen and (min-width: 37.5em){.review-score--small-on-medium-up{font-size:19px;line-height:19px;height:36px;width:36px}}.postlist__item--compact .asset,.postlist__item .asset,.storytype--section .item__image{position:relative}.postlist__item--compact .asset .review-score,.postlist__item .asset .review-score,.storytype--section .item__image .review-score{margin:;position:absolute;left:1px;top:1px;z-index:1}@media only screen and (min-width: 37.5em){.postlist__item .asset .review-score{left:28px}}.branded-item .headline a{color:# !important}.branded-item .inset--story__thumb figure,.branded-item.item .image__wrapper{border-bottom:5px solid transparent}.branded-item .gmg-avatar{width:2px;position:absolute;bottom:-5px;left:}.branded-item .inset--story__readmore{display:inline-block}.branded-item--deadspin .inset--story__thumb figure,.branded-item--deadspin.item .image__wrapper{border-bottom-color:#1b3a4d}.branded-item--deadspin .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #3d84af;box-shadow:inset -2px #3d84af;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--deadspin .inset--story__readmore:hover{color:#1b3a4d;text-decoration:none}.branded-item--earther .inset--story__thumb figure,.branded-item--earther.item .image__wrapper{border-bottom-color:#75b2}.branded-item--earther .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--earther .inset--story__readmore:hover{color:#75b2;text-decoration:none}.branded-item--fusion .inset--story__thumb figure,.branded-item--fusion.item .image__wrapper{border-bottom-color:#4e}.branded-item--fusion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #7ae8ff;box-shadow:inset -2px #7ae8ff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--fusion .inset--story__readmore:hover{color:#caf4;text-decoration:none}.branded-item--gizmodo .inset--story__thumb figure,.branded-item--gizmodo.item .image__wrapper{border-bottom-color:#18afed}.branded-item--gizmodo .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #93daf7;box-shadow:inset -2px #93daf7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--gizmodo .inset--story__readmore:hover{color:#18afed;text-decoration:none}.branded-item--jalopnik .inset--story__thumb figure,.branded-item--jalopnik.item .image__wrapper{border-bottom-color:#ff4d}.branded-item--jalopnik .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffaa85;box-shadow:inset -2px #ffaa85;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jalopnik .inset--story__readmore:hover{color:#ff4d;text-decoration:none}.branded-item--jezebel .inset--story__thumb figure,.branded-item--jezebel.item .image__wrapper{border-bottom-color:#ec1238}.branded-item--jezebel .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jezebel .inset--story__readmore:hover{color:#ec1238;text-decoration:none}.branded-item--kotaku .inset--story__thumb figure,.branded-item--kotaku.item .image__wrapper{border-bottom-color:#fbc}.branded-item--kotaku .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--kotaku .inset--story__readmore:hover{color:#fbc;text-decoration:none}.branded-item--lifehacker .inset--story__thumb figure,.branded-item--lifehacker.item .image__wrapper{border-bottom-color:#94b33}.branded-item--lifehacker .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #cbdf88;box-shadow:inset -2px #cbdf88;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--lifehacker .inset--story__readmore:hover{color:#94b33;text-decoration:none}.branded-item--theonion .inset--story__thumb figure,.branded-item--theonion.item .image__wrapper{border-bottom-color:#6b3a}.branded-item--theonion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f82;box-shadow:inset -2px #f82;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theonion .inset--story__readmore:hover{color:#6b3a;text-decoration:none}.branded-item--theroot .inset--story__thumb figure,.branded-item--theroot.item .image__wrapper{border-bottom-color:#59b22}.branded-item--theroot .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theroot .inset--story__readmore:hover{color:#59b22;text-decoration:none}.branded-item--splinter .inset--story__thumb figure,.branded-item--splinter.item .image__wrapper{border-bottom-color:#f85637}.branded-item--splinter .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--splinter .inset--story__readmore:hover{color:#f85637;text-decoration:none}.branded-item--avclub .inset--story__thumb figure,.branded-item--avclub.item .image__wrapper{border-bottom-color:#1c263c}.branded-item--avclub .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #465f96;box-shadow:inset -2px #465f96;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--avclub .inset--story__readmore:hover{color:#1c263c;text-decoration:none}.branded-item--thetakeout .inset--story__thumb figure,.branded-item--thetakeout.item .image__wrapper{border-bottom-color:#E5371A}.branded-item--thetakeout .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fef7dd;box-shadow:inset -2px #fef7dd;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--thetakeout .inset--story__readmore:hover{color:#F9DB5D;text-decoration:none}.f_branding_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on .post-content .quotable a,.f_branding_on .post-content footer a,.f_branding_on .post-content h1 a,.f_branding_on .post-content h2 a,.f_branding_on .post-content h3 a,.f_branding_on .post-content h4 a,.f_branding_on .post-content h5 a,.f_branding_on .post-content h6 a,.f_branding_on .post-content li a,.f_branding_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on .post-content .quotable a:hover,.f_branding_on .post-content footer a:hover,.f_branding_on .post-content h1 a:hover,.f_branding_on .post-content h2 a:hover,.f_branding_on .post-content h3 a:hover,.f_branding_on .post-content h4 a:hover,.f_branding_on .post-content h5 a:hover,.f_branding_on .post-content h6 a:hover,.f_branding_on .post-content li a:hover,.f_branding_on .post-content p a:hover,.f_branding_on figcaption a{color:#93ec}.f_branding_on figcaption a:hover{color:#73b9}.f_branding_on .editor-inner.post-content blockquote,.f_branding_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on .editor-inner.post-content .pullquote:before,.f_branding_on .entry-content .pullquote:before,.f_branding_on .editor-inner.post-content .pullquote:after,.f_branding_on .entry-content .pullquote:after{border:}.f_branding_on .editor-inner.post-content .pullquote__content,.f_branding_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on .storybreak-branded-a,.f_branding_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on .review-score,.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#333}.f_branding_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on .author-bio__name{color:#222}.f_branding_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_deadspin_on.f_article_split_on .scroll-list-break{border-top:3px solid #2d9d92}.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#1b3a4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-deadspin .post-content .quotable a,.f_branding_on .blog-group-deadspin .post-content .quotable a,.f_branding_on.blog-group-deadspin .post-content footer a,.f_branding_on .blog-group-deadspin .post-content footer a,.f_branding_on.blog-group-deadspin .post-content h1 a,.f_branding_on .blog-group-deadspin .post-content h1 a,.f_branding_on.blog-group-deadspin .post-content h2 a,.f_branding_on .blog-group-deadspin .post-content h2 a,.f_branding_on.blog-group-deadspin .post-content h3 a,.f_branding_on .blog-group-deadspin .post-content h3 a,.f_branding_on.blog-group-deadspin .post-content h4 a,.f_branding_on .blog-group-deadspin .post-content h4 a,.f_branding_on.blog-group-deadspin .post-content h5 a,.f_branding_on .blog-group-deadspin .post-content h5 a,.f_branding_on.blog-group-deadspin .post-content h6 a,.f_branding_on .blog-group-deadspin .post-content h6 a,.f_branding_on.blog-group-deadspin .post-content li a,.f_branding_on .blog-group-deadspin .post-content li a,.f_branding_on.blog-group-deadspin .post-content p a,.f_branding_on .blog-group-deadspin .post-content p a,.f_branding_on.f_branding_deadspin_on .post-content .quotable a,.f_branding_on.f_branding_deadspin_on .post-content footer a,.f_branding_on.f_branding_deadspin_on .post-content h1 a,.f_branding_on.f_branding_deadspin_on .post-content h2 a,.f_branding_on.f_branding_deadspin_on .post-content h3 a,.f_branding_on.f_branding_deadspin_on .post-content h4 a,.f_branding_on.f_branding_deadspin_on .post-content h5 a,.f_branding_on.f_branding_deadspin_on .post-content h6 a,.f_branding_on.f_branding_deadspin_on .post-content li a,.f_branding_on.f_branding_deadspin_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #77d8ce;box-shadow:inset -2px #77d8ce;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-deadspin .post-content .quotable a:hover,.f_branding_on .blog-group-deadspin .post-content .quotable a:hover,.f_branding_on.blog-group-deadspin .post-content footer a:hover,.f_branding_on .blog-group-deadspin .post-content footer a:hover,.f_branding_on.blog-group-deadspin .post-content h1 a:hover,.f_branding_on .blog-group-deadspin .post-content h1 a:hover,.f_branding_on.blog-group-deadspin .post-content h2 a:hover,.f_branding_on .blog-group-deadspin .post-content h2 a:hover,.f_branding_on.blog-group-deadspin .post-content h3 a:hover,.f_branding_on .blog-group-deadspin .post-content h3 a:hover,.f_branding_on.blog-group-deadspin .post-content h4 a:hover,.f_branding_on .blog-group-deadspin .post-content h4 a:hover,.f_branding_on.blog-group-deadspin .post-content h5 a:hover,.f_branding_on .blog-group-deadspin .post-content h5 a:hover,.f_branding_on.blog-group-deadspin .post-content h6 a:hover,.f_branding_on .blog-group-deadspin .post-content h6 a:hover,.f_branding_on.blog-group-deadspin .post-content li a:hover,.f_branding_on .blog-group-deadspin .post-content li a:hover,.f_branding_on.blog-group-deadspin .post-content p a:hover,.f_branding_on .blog-group-deadspin .post-content p a:hover,.f_branding_on.f_branding_deadspin_on .post-content .quotable a:hover,.f_branding_on.f_branding_deadspin_on .post-content footer a:hover,.f_branding_on.f_branding_deadspin_on .post-content h1 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h2 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h3 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h4 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h5 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h6 a:hover,.f_branding_on.f_branding_deadspin_on .post-content li a:hover,.f_branding_on.f_branding_deadspin_on .post-content p a:hover,.f_branding_on.blog-group-deadspin figcaption a,.f_branding_on .blog-group-deadspin figcaption a,.f_branding_on.f_branding_deadspin_on figcaption a{color:#2d9d92}.f_branding_on.blog-group-deadspin figcaption a:hover,.f_branding_on .blog-group-deadspin figcaption a:hover,.f_branding_on.f_branding_deadspin_on figcaption a:hover{color:#22756d}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on.blog-group-deadspin .entry-content blockquote,.f_branding_on .blog-group-deadspin .entry-content blockquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_deadspin_on .entry-content blockquote{border-radius:;border-left:5px solid #1b3a4d;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-deadspin .entry-content .pullquote__content,.f_branding_on .blog-group-deadspin .entry-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-deadspin .review-score,.f_branding_on .blog-group-deadspin .review-score,.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_deadspin_on .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1b3a4d}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white){color:#2d9d92;border-color:#2d9d92}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white):hover{color:#22756d;border-color:#22756d}.f_branding_on.blog-group-deadspin .author-bio__name,.f_branding_on .blog-group-deadspin .author-bio__name,.f_branding_on.f_branding_deadspin_on .author-bio__name{color:#222}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name){color:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover{color:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#22756d}.f_branding_on.blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_deadspin_on .sidebar-content .newsletter-subscribe{border-color:#1b3a4d}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on.blog-group-deadspin .entry-content .pullquote,.f_branding_on .blog-group-deadspin .entry-content .pullquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote{border-top:1px solid #1b3a4d;border-bottom:1px solid #1b3a4d;padding:3px ;position:relative;color:#1b3a4d;font-size:22px;line-height:32px;font-weight:bold;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{height:4px;width:26px;position:absolute;left:calc(5% - 13px);background-image:url('data:image/svg+xml;utf8,<svg xmlns="http://www.w3.org/2/svg" width="26" height="4" viewBox=" 26 4"><title>deadspin-quote-carrot-aligned-w-bgr-2<\/title><path d="M1,3.5l3-3,3,3Z" style="fill:%23fff;stroke:%23fff"/><path d="M,3.5H1l3-3,3,3H26" style="fill:none;stroke:%231b3a4d"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{top:-4px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{bottom:-4px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;width:1%}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child{top:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child{bottom:6px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{display:block;content:'';height:9px;width:18px;position:absolute;top:-1px;background-color:#fff}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{left:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after{right:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{top:-2px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{background-image:url('data:image/svg+xml;utf8,<svg width="19" height="9" viewBox=" 19 9" xmlns="http://www.w3.org/2/svg"><title>deadspin-quote-topleft<\/title><path d="M.5 8.5c-4.43 3.655-8.54 8-8h1" stroke="%231B3A4D" fill="none" stroke-linecap="square" stroke-linejoin="round"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after{-webkit-transform:scaleX(-1);transform:scaleX(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{-webkit-transform:scaleY(-1);transform:scaleY(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after{-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>diamond-blue<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%231B3A4D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>deadspin-diamond-teal<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%23249D9D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on.blog-group-earther .entry-content .pullquote,.f_branding_on .blog-group-earther .entry-content .pullquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_earther_on .entry-content .pullquote{border-top:none;border-bottom:none;padding:3px;position:relative;font-size:22px;line-height:32px;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-earther .entry-content .pullquote.align--left,.f_branding_on .blog-group-earther .entry-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{height:3px;width:3px;position:absolute;background-image:url('data:image/svg+xml;utf8,<svg width="3" height="3" viewBox=" 4 4" xmlns="http://www.w3.org/2/svg"><title>pq-earther<\/title><path d="M4 h36v8H8v32HVh4z" fill="%2375B2" fill-rule="evenodd"/><\/svg>');margin:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{top:;left:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{bottom:;right:;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-a{min-width:26px;height:26px;background-image:url('data:image/svg+xml;utf8,<svg width="26" height="26" viewBox=" 26 26" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-a<\/title><g stroke="%2375B2" fill="none" fill-rule="evenodd" stroke-linejoin="round"><path d="M21.292 21.292c-4.757 4.757-12.47 4.756-17.225 -4.756-4.757-4.756-12.47 -17.225 4.757-4.756 12.47-4.756 17.225 4.756 4.757 4.756 12.47 17.225z"/><path d="M21.69 2.988c-3.98 2.526-1.537 1.65-14.767-2.578C2.69 14.177 1.857 8.238 4.67 3.655"/><path d="M22.75 14.657c-2.53 2.5-7.226 1.83-1.55-1.494C8.88 9.84 8.215 5.117 1.718 2.617c2.54-2.5 7.227-1.83 1.55 1.494 3.323 3.33 3.987 8.5 1.484 1.55z" stroke-width="1.77"/><path d="M2.294 9.234c-.793.793-2.37.5-3.524-.654s-1.447-2.732-.654-3.525c.792-.793 2.37-.5 3.524.654 1.154 1.15 1.446 2.73.654 3.52zm-.2.17c2.69 4.38 1.677 1.43-1.856 13.964M2.14 6.963c3.567-3.566 9.973-5.35 13.926-2.225m4.456 2.548c1.473.93 2.75.523 3.745 1.32m-6.7-3.77c-.11-1.416-.534-2.646-1.31-3.61"/><path d="M18.852 9.85c-.55 2.345-2.5 6.53-4.95 8.998-2.427 2.428-4.818 3.666-6.967 4.52m-4.512-4.512c.846-2.16 1.646-4.94 4.98-7.39 2.95-2.945 6.66-3.93 9.1-4.478"/><\/g><\/svg>')}.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-b{min-width:25px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="25" height="25" viewBox=" 25 25" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path d="M24.398 12.438c 6.63-5.374 12.4-12.4 12.4S.39 19.68.39 12.438 5.765.434 12.394.434c6.63 12.4 5.375 12.4 12.4" fill="%2375B2"/><path d="M 12.32h24.64M12.32 v24.42m8.74-2.818L3.73 2.932M3.727 3.596l17.336 17.34m-1.358-8.67c 4.37-3.273 7.31-7.31 7.31-4.37 -7.31-3.273-7.31-7.31 -4.37 3.273-7.31 7.31-7.31 4.37 7.31 3.273 7.31 7.31z" stroke="%23FFF" stroke-width=".88"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_gizmodo_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-gizmodo .post-content .quotable a,.f_branding_on .blog-group-gizmodo .post-content .quotable a,.f_branding_on.blog-group-gizmodo .post-content footer a,.f_branding_on .blog-group-gizmodo .post-content footer a,.f_branding_on.blog-group-gizmodo .post-content h1 a,.f_branding_on .blog-group-gizmodo .post-content h1 a,.f_branding_on.blog-group-gizmodo .post-content h2 a,.f_branding_on .blog-group-gizmodo .post-content h2 a,.f_branding_on.blog-group-gizmodo .post-content h3 a,.f_branding_on .blog-group-gizmodo .post-content h3 a,.f_branding_on.blog-group-gizmodo .post-content h4 a,.f_branding_on .blog-group-gizmodo .post-content h4 a,.f_branding_on.blog-group-gizmodo .post-content h5 a,.f_branding_on .blog-group-gizmodo .post-content h5 a,.f_branding_on.blog-group-gizmodo .post-content h6 a,.f_branding_on .blog-group-gizmodo .post-content h6 a,.f_branding_on.blog-group-gizmodo .post-content li a,.f_branding_on .blog-group-gizmodo .post-content li a,.f_branding_on.blog-group-gizmodo .post-content p a,.f_branding_on .blog-group-gizmodo .post-content p a,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a,.f_branding_on.f_branding_gizmodo_on .post-content footer a,.f_branding_on.f_branding_gizmodo_on .post-content h1 a,.f_branding_on.f_branding_gizmodo_on .post-content h2 a,.f_branding_on.f_branding_gizmodo_on .post-content h3 a,.f_branding_on.f_branding_gizmodo_on .post-content h4 a,.f_branding_on.f_branding_gizmodo_on .post-content h5 a,.f_branding_on.f_branding_gizmodo_on .post-content h6 a,.f_branding_on.f_branding_gizmodo_on .post-content li a,.f_branding_on.f_branding_gizmodo_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on .blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on.blog-group-gizmodo .post-content footer a:hover,.f_branding_on .blog-group-gizmodo .post-content footer a:hover,.f_branding_on.blog-group-gizmodo .post-content h1 a:hover,.f_branding_on .blog-group-gizmodo .post-content h1 a:hover,.f_branding_on.blog-group-gizmodo .post-content h2 a:hover,.f_branding_on .blog-group-gizmodo .post-content h2 a:hover,.f_branding_on.blog-group-gizmodo .post-content h3 a:hover,.f_branding_on .blog-group-gizmodo .post-content h3 a:hover,.f_branding_on.blog-group-gizmodo .post-content h4 a:hover,.f_branding_on .blog-group-gizmodo .post-content h4 a:hover,.f_branding_on.blog-group-gizmodo .post-content h5 a:hover,.f_branding_on .blog-group-gizmodo .post-content h5 a:hover,.f_branding_on.blog-group-gizmodo .post-content h6 a:hover,.f_branding_on .blog-group-gizmodo .post-content h6 a:hover,.f_branding_on.blog-group-gizmodo .post-content li a:hover,.f_branding_on .blog-group-gizmodo .post-content li a:hover,.f_branding_on.blog-group-gizmodo .post-content p a:hover,.f_branding_on .blog-group-gizmodo .post-content p a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a:hover,.f_branding_on.f_branding_gizmodo_on .post-content footer a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h1 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h2 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h3 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h4 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h5 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h6 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content li a:hover,.f_branding_on.f_branding_gizmodo_on .post-content p a:hover,.f_branding_on.blog-group-gizmodo figcaption a,.f_branding_on .blog-group-gizmodo figcaption a,.f_branding_on.f_branding_gizmodo_on figcaption a{color:#93ec}.f_branding_on.blog-group-gizmodo figcaption a:hover,.f_branding_on .blog-group-gizmodo figcaption a:hover,.f_branding_on.f_branding_gizmodo_on figcaption a:hover{color:#73b9}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on.blog-group-gizmodo .entry-content blockquote,.f_branding_on .blog-group-gizmodo .entry-content blockquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before,.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on .blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-gizmodo .review-score,.f_branding_on .blog-group-gizmodo .review-score,.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_gizmodo_on .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio__name,.f_branding_on .blog-group-gizmodo .author-bio__name,.f_branding_on.f_branding_gizmodo_on .author-bio__name{color:#222}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on.blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_gizmodo_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on.blog-group-gizmodo .entry-content .pullquote,.f_branding_on .blog-group-gizmodo .entry-content .pullquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote{border-top:2px solid #18afed;border-bottom:2px solid #18afed;padding-top:3px;padding-bottom:3px;position:relative}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before{height:42px;width:42px;position:absolute;left:calc(5% - 21px);top:-21px;background-image:url('data:image/svg+xml;utf8,<svg width="42" height="42" viewBox=" 42 42" xmlns="http://www.w3.org/2/svg"><title>gizmodo-quote<\/title><g fill="none" fill-rule="evenodd"><path d="M41.95 2.974c 11.583-9.392 2.974-2.976 2.974S 32.558 2.974 9.39 2.974 41.95 9.39 41.95 2.974" fill="%2318AFED"/><path d="M21.8 21.422c-6.874 3.744-9.434 9.622-9.623l.76 3.46c-3.178.38-4.74 1.894-4.647 4.453h3.51l-.2 9.245H21.8v-7.54zm-12.562 c-6.874 3.697-9.434 9.622-9.623l.71 3.46c-3.175.38-4.74 1.894-4.597 4.453h3.58l.4 9.245H9.238v-7.54z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a{min-width:33px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="12" viewBox=" 33 12" xmlns="http://www.w3.org/2/svg"><title>gizmodo-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2318AFED" d="M11 12h11VH11"/><path fill="%23" d="M 12h11VHm22 12h11VH22"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{min-width:111px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="111" height="25" viewBox=" 111 25" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>gizmodo-plots<\/title><defs><path id="a" d="M 5V.324h4.676V5Hz"/><path id="c" d="M4.985.26v4.8H.977V.26h4.8z"/><path id="e" d="M.398.842H3.7v2.672H.398V.842z"/><\/defs><g fill="none" fill-rule="evenodd"><path stroke="%2318AFED" stroke-width=".445" d="M34.61 19.42L1.762 21.857l9.583-18.2 22.69 15.63L44.157 1.372l1.73 1.52 18.44 9.124 3.855-14.23"/><g transform="translate( 19.158)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M4.67 2.516c.84 1.29-.896 2.4-2.184 2.48-1.29.8-2.4-.9-2.48-2.188-.8-1.29.898-2.4 2.188-2.48C3.48.25 4.59 1.23 4.67 2.518" fill="%2318AFED" mask="url(%23b)"/><\/g><path d="M13.587 3.714c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m43.543 8.38c.6.92-.64 1.713-1.56 1.77-.922.6-1.715-.64-1.772-1.56-.58-.922.64-1.715 1.562-1.772.92-.58 1.713.64 1.77 1.562m42.882-7.84c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m-25.368 16.46c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562M79.36 6.625c.7 1.15-.77 2.56-1.874 2.125-1.15.7-2.56-.77-2.125-1.875-.66-1.14.77-2.56 1.878-2.125 1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED"/><g transform="translate(16 18.158)"><mask id="d" fill="%23fff"><use xlink-underline:href="%23c"/><\/mask><path d="M4.98 2.14c.7 1.14-.77 2.55-1.874 2.124C2 4.334 1.5 3.494.98 2.39.91 1.284 1.75.332 2.857.263c1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED" mask="url(%23d)"/><\/g><path d="M36.61 19.296c.7 1.15-.77 2.56-1.875 2.125-1.15.7-2.56-.77-2.125-1.872-.7-1.14.77-2.56 1.875-2.125 1.14-.68 2.56.77 2.125 1.876" fill="%2318AFED"/><g transform="translate(43 -.842)"><mask id="f" fill="%23fff"><use xlink-underline:href="%23e"/><\/mask><path d="M3.67 2.95c.46.735-.514 1.37-1.25 1.416C1.8 3.56.447 3 .4 2.265.354 1.524.914.89 1.65.844c.737-.46 1.37.514 1.417 1.25" fill="%2318AFED" mask="url(%23f)"/><\/g><path d="M55.464 11.856L34.61 19.42m-32.272 2.4L44.734 1.336 77.36 6.75l32.24 13.83L97.985 3.574 72.977 2.512" stroke="%2318AFED" stroke-width=".445"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jalopnik_on.f_article_split_on .scroll-list-break{border-top:3px solid #ff4d}.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ff4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jalopnik .post-content .quotable a,.f_branding_on .blog-group-jalopnik .post-content .quotable a,.f_branding_on.blog-group-jalopnik .post-content footer a,.f_branding_on .blog-group-jalopnik .post-content footer a,.f_branding_on.blog-group-jalopnik .post-content h1 a,.f_branding_on .blog-group-jalopnik .post-content h1 a,.f_branding_on.blog-group-jalopnik .post-content h2 a,.f_branding_on .blog-group-jalopnik .post-content h2 a,.f_branding_on.blog-group-jalopnik .post-content h3 a,.f_branding_on .blog-group-jalopnik .post-content h3 a,.f_branding_on.blog-group-jalopnik .post-content h4 a,.f_branding_on .blog-group-jalopnik .post-content h4 a,.f_branding_on.blog-group-jalopnik .post-content h5 a,.f_branding_on .blog-group-jalopnik .post-content h5 a,.f_branding_on.blog-group-jalopnik .post-content h6 a,.f_branding_on .blog-group-jalopnik .post-content h6 a,.f_branding_on.blog-group-jalopnik .post-content li a,.f_branding_on .blog-group-jalopnik .post-content li a,.f_branding_on.blog-group-jalopnik .post-content p a,.f_branding_on .blog-group-jalopnik .post-content p a,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a,.f_branding_on.f_branding_jalopnik_on .post-content footer a,.f_branding_on.f_branding_jalopnik_on .post-content h1 a,.f_branding_on.f_branding_jalopnik_on .post-content h2 a,.f_branding_on.f_branding_jalopnik_on .post-content h3 a,.f_branding_on.f_branding_jalopnik_on .post-content h4 a,.f_branding_on.f_branding_jalopnik_on .post-content h5 a,.f_branding_on.f_branding_jalopnik_on .post-content h6 a,.f_branding_on.f_branding_jalopnik_on .post-content li a,.f_branding_on.f_branding_jalopnik_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #a1cde;box-shadow:inset -2px #a1cde;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on .blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on.blog-group-jalopnik .post-content footer a:hover,.f_branding_on .blog-group-jalopnik .post-content footer a:hover,.f_branding_on.blog-group-jalopnik .post-content h1 a:hover,.f_branding_on .blog-group-jalopnik .post-content h1 a:hover,.f_branding_on.blog-group-jalopnik .post-content h2 a:hover,.f_branding_on .blog-group-jalopnik .post-content h2 a:hover,.f_branding_on.blog-group-jalopnik .post-content h3 a:hover,.f_branding_on .blog-group-jalopnik .post-content h3 a:hover,.f_branding_on.blog-group-jalopnik .post-content h4 a:hover,.f_branding_on .blog-group-jalopnik .post-content h4 a:hover,.f_branding_on.blog-group-jalopnik .post-content h5 a:hover,.f_branding_on .blog-group-jalopnik .post-content h5 a:hover,.f_branding_on.blog-group-jalopnik .post-content h6 a:hover,.f_branding_on .blog-group-jalopnik .post-content h6 a:hover,.f_branding_on.blog-group-jalopnik .post-content li a:hover,.f_branding_on .blog-group-jalopnik .post-content li a:hover,.f_branding_on.blog-group-jalopnik .post-content p a:hover,.f_branding_on .blog-group-jalopnik .post-content p a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a:hover,.f_branding_on.f_branding_jalopnik_on .post-content footer a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h1 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h2 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h3 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h4 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h5 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h6 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content li a:hover,.f_branding_on.f_branding_jalopnik_on .post-content p a:hover,.f_branding_on.blog-group-jalopnik figcaption a,.f_branding_on .blog-group-jalopnik figcaption a,.f_branding_on.f_branding_jalopnik_on figcaption a{color:#417eb9}.f_branding_on.blog-group-jalopnik figcaption a:hover,.f_branding_on .blog-group-jalopnik figcaption a:hover,.f_branding_on.f_branding_jalopnik_on figcaption a:hover{color:#346493}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on.blog-group-jalopnik .entry-content blockquote,.f_branding_on .blog-group-jalopnik .entry-content blockquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote{border-radius:;border-left:5px solid #417eb9;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before,.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on .blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jalopnik .review-score,.f_branding_on .blog-group-jalopnik .review-score,.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jalopnik_on .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ff4d}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white){color:#417eb9;border-color:#417eb9}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white):hover{color:#346493;border-color:#346493}.f_branding_on.blog-group-jalopnik .author-bio__name,.f_branding_on .blog-group-jalopnik .author-bio__name,.f_branding_on.f_branding_jalopnik_on .author-bio__name{color:#222}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name){color:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover{color:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#346493}.f_branding_on.blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jalopnik_on .sidebar-content .newsletter-subscribe{border-color:#417eb9}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jalopnik .entry-content .pullquote,.f_branding_on .blog-group-jalopnik .entry-content .pullquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before{height:8px;width:219px;background-image:url('data:image/svg+xml;utf8,<svg width="219" height="8" viewBox=" 219 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-top<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" transform="matrix(-1 1 265 )" d="M46 h17l3 4H49"/><path fill="%23FF4D" d="M116 4H2L 8h114"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{height:8px;width:116px;background-image:url('data:image/svg+xml;utf8,<svg width="116" height="8" viewBox=" 116 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-bottom<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="%23FF4D" d="M116 H48l-1 4h68"/><path fill="url(%23a)" transform="matrix(-1 1 84 )" d="M 4h83l1 4H1"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a{min-width:77px;height:1px;background-image:url('data:image/svg+xml;utf8,<svg width="77" height="1" viewBox=" 77 1" xmlns="http://www.w3.org/2/svg"><title>%23-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%23CCC" d="M12.423 4L1 1h64.577L77 4"/><path fill="%23FF4D" d="M2.423 L 6h64.577L67 "/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{min-width:8px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="8" height="12" viewBox=" 8 12" xmlns="http://www.w3.org/2/svg"><title>%23-gradient<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" d="M75.1 5.982L78.82 12H3L4.185 H8"/><path d="M3.517 11.977c-.194 -.696.23-.96.23Hl.5-5.86h2.585c.264 .5-.22.527-.49L4.242 H9l-.665 6.92c-.26.27-.15.75-.175.965 -.532 4.68-4.643 4.92z" fill="%23FF4D"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .pullquote__content,.f_branding_on .blog-group-jalopnik .pullquote__content,.f_branding_on.f_branding_jalopnik_on .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jezebel_on.f_article_split_on .scroll-list-break{border-top:3px solid #ec1238}.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ec1238;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jezebel .post-content .quotable a,.f_branding_on .blog-group-jezebel .post-content .quotable a,.f_branding_on.blog-group-jezebel .post-content footer a,.f_branding_on .blog-group-jezebel .post-content footer a,.f_branding_on.blog-group-jezebel .post-content h1 a,.f_branding_on .blog-group-jezebel .post-content h1 a,.f_branding_on.blog-group-jezebel .post-content h2 a,.f_branding_on .blog-group-jezebel .post-content h2 a,.f_branding_on.blog-group-jezebel .post-content h3 a,.f_branding_on .blog-group-jezebel .post-content h3 a,.f_branding_on.blog-group-jezebel .post-content h4 a,.f_branding_on .blog-group-jezebel .post-content h4 a,.f_branding_on.blog-group-jezebel .post-content h5 a,.f_branding_on .blog-group-jezebel .post-content h5 a,.f_branding_on.blog-group-jezebel .post-content h6 a,.f_branding_on .blog-group-jezebel .post-content h6 a,.f_branding_on.blog-group-jezebel .post-content li a,.f_branding_on .blog-group-jezebel .post-content li a,.f_branding_on.blog-group-jezebel .post-content p a,.f_branding_on .blog-group-jezebel .post-content p a,.f_branding_on.f_branding_jezebel_on .post-content .quotable a,.f_branding_on.f_branding_jezebel_on .post-content footer a,.f_branding_on.f_branding_jezebel_on .post-content h1 a,.f_branding_on.f_branding_jezebel_on .post-content h2 a,.f_branding_on.f_branding_jezebel_on .post-content h3 a,.f_branding_on.f_branding_jezebel_on .post-content h4 a,.f_branding_on.f_branding_jezebel_on .post-content h5 a,.f_branding_on.f_branding_jezebel_on .post-content h6 a,.f_branding_on.f_branding_jezebel_on .post-content li a,.f_branding_on.f_branding_jezebel_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jezebel .post-content .quotable a:hover,.f_branding_on .blog-group-jezebel .post-content .quotable a:hover,.f_branding_on.blog-group-jezebel .post-content footer a:hover,.f_branding_on .blog-group-jezebel .post-content footer a:hover,.f_branding_on.blog-group-jezebel .post-content h1 a:hover,.f_branding_on .blog-group-jezebel .post-content h1 a:hover,.f_branding_on.blog-group-jezebel .post-content h2 a:hover,.f_branding_on .blog-group-jezebel .post-content h2 a:hover,.f_branding_on.blog-group-jezebel .post-content h3 a:hover,.f_branding_on .blog-group-jezebel .post-content h3 a:hover,.f_branding_on.blog-group-jezebel .post-content h4 a:hover,.f_branding_on .blog-group-jezebel .post-content h4 a:hover,.f_branding_on.blog-group-jezebel .post-content h5 a:hover,.f_branding_on .blog-group-jezebel .post-content h5 a:hover,.f_branding_on.blog-group-jezebel .post-content h6 a:hover,.f_branding_on .blog-group-jezebel .post-content h6 a:hover,.f_branding_on.blog-group-jezebel .post-content li a:hover,.f_branding_on .blog-group-jezebel .post-content li a:hover,.f_branding_on.blog-group-jezebel .post-content p a:hover,.f_branding_on .blog-group-jezebel .post-content p a:hover,.f_branding_on.f_branding_jezebel_on .post-content .quotable a:hover,.f_branding_on.f_branding_jezebel_on .post-content footer a:hover,.f_branding_on.f_branding_jezebel_on .post-content h1 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h2 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h3 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h4 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h5 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h6 a:hover,.f_branding_on.f_branding_jezebel_on .post-content li a:hover,.f_branding_on.f_branding_jezebel_on .post-content p a:hover,.f_branding_on.blog-group-jezebel figcaption a,.f_branding_on .blog-group-jezebel figcaption a,.f_branding_on.f_branding_jezebel_on figcaption a{color:#ec1238}.f_branding_on.blog-group-jezebel figcaption a:hover,.f_branding_on .blog-group-jezebel figcaption a:hover,.f_branding_on.f_branding_jezebel_on figcaption a:hover{color:#bde2d}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on.blog-group-jezebel .entry-content blockquote,.f_branding_on .blog-group-jezebel .entry-content blockquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jezebel_on .entry-content blockquote{border-radius:;border-left:5px solid #ec1238;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jezebel .review-score,.f_branding_on .blog-group-jezebel .review-score,.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jezebel_on .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white){color:#ec1238;border-color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white):hover{color:#bde2d;border-color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio__name,.f_branding_on .blog-group-jezebel .author-bio__name,.f_branding_on.f_branding_jezebel_on .author-bio__name{color:#222}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name){color:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover{color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#bde2d}.f_branding_on.blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jezebel_on .sidebar-content .newsletter-subscribe{border-color:#ec1238}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jezebel .entry-content .pullquote,.f_branding_on .blog-group-jezebel .entry-content .pullquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold;position:relative;padding:36px ;text-transform:uppercase;font-weight:1;color:#ec1238;font-size:31px;line-height:33px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{display:block;content:'';position:absolute;width:23px;height:18px;left:calc(5% - 12px);background-image:url('data:image/svg+xml;utf8,<svg width="23" height="18" viewBox=" 23 18" xmlns="http://www.w3.org/2/svg"><title>jezbel-quote<\/title><path d="M23 13.46c 1.253-.45 2.323-1.345 3.21-.897.887-1.977 1.33-3.243 1.33-1.69 -2.968-.548-3.837-1.644-.87-1.95-1.36-2.426-1.36-3.99 -2.192.76-4.435 2.29-6.73C17.9 3.338 19.252 1.46 22.5 L23 1.41c-1.32 1.147-2.36 2.347-3.125 3.598-.765 1.253-1.358 2.48-1.78 3.68 1.53.14 2.73.613 3.6 1.525.87.913 1.35 1.995 1.35 3.248m-12.385 c 1.258-.457 2.328-1.373 3.21-.915.89-2 1.33-3.256 1.33-1.622 -2.878-.543-3.767-1.64-.89-1.1-1.34-2.43-1.34-3.99 -2.194.756-4.437 2.273-6.73C4.677 3.335 6.85 1.46 9.673 l.86 1.41c-1.35 1.147-2.34 2.347-3.1 3.598-.755 1.253-1.344 2.48-1.762 3.68 1.52.14 2.72.613 3.61 1.525.89.913 1.338 1.995 1.338 3.248" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{top:-6px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{bottom:-6px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;height:7px;width:calc(5% - 2px);background-color:#ec1238;-webkit-transform:skewX(-7deg);transform:skewX(-7deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:first-child{top:;left:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:last-child{bottom:;right:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left{padding:31px ;text-align:left;margin-bottom:1rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:before{display:none}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a{min-width:31px;height:31px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="31" viewBox=" 31 31" xmlns="http://www.w3.org/2/svg"><title>jezebel-wheel<\/title><path d="M18.53.852h2.96v7.85c 1-.852 2.643-1.91 3.39-.392.275-.855.582-1.42.738v-.613c.29-.284.425-1.11.425-1.762V.852zM8.46 2.337L1.684.5l5.13 6.14c.652.765 1.72 2.563.75 3.84-.12.46-.274.986-.67 1.465l-.398-.472c.3-.4-.41-1.11-.83-1.61L8.46 2.34M1.713 9.844L2.22 7.3l7.858 1.362c1 .173 2.497 1.285 3.6 2.44.27.427.434.928.492 1.54l-.613-.18c-.234-.33-1.4-.63-1.69-.716-.96-.157-6.215-1.8-9.612-1.668M1.453 19.86C.963 19.23.49 18.22 17.384l6.91-3.925c.88-.5 2.752-.6 3.938-.7.438.19.94.43 1.36.84-.63.3-.334.19-.54.3-.394-.16-1.19.193-1.763.52l-8.452 4.8m6.342 7.84l-2.73-.978 2.73-7.376c.347-.94 1.72-2.197 2.972-2.54.464-.13 1.6-.26 1.593-.218-.26.7-.135.354-.216.574-.37.17-.784.93-1.1 1.515l-3.34 9.3m9.98 1.99l-2.73.978-2.73-7.38c-.345-.94-.116-2.77.62-3.83.272-.39.6-.837 1.8-1.175.23.7.127.357.21.576-.175.364-.13 1.186.213 1.8.315.85 2.16 5.833 3.338 9.22m8.948-4.785c-.49.837-.962 1.64-1.453 2.476l-6.91-3.926c-.88-.5-1.9-2.48-2.27-3.32-.47-.474-.86-1.2.6-1.58l.537.36c.16.39.767.917 1.34 1.243l8.453 4.8m3.727-9.32l.55 2.815-7.858 1.36c-1 .175-2.792-.366-3.722-1.262-.345-.332-.732-.727-.987-1.25.73-.1.38-.62.614-.13.334.23 1.185.22 1.837.17l9.61-1.667m-3.24-9.5l2.222 1.84c-1.756 2.6-3.37 3.953-5.13 6.13-.652.765-2.38 1.485-3.676 1.387-.48-.37-1.35-.94-1.57-.33.46-.6.25-.29.4-.47.41-.36 1.52-.584 1.477-1.8l6.274-7.36" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;font-family:"ElizabethSerif",Georgia,serif;letter-spacing:7px;margin-top:4px;margin-bottom:6px;overflow:visible;text-align:center}.f_branding_on.blog-group-jezebel .storybreak-branded-b:before,.f_branding_on .blog-group-jezebel .storybreak-branded-b:before,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b:before{color:#ec1238;content:'***';display:inline-block;font-size:17px}.f_branding_on.blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on .blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b.storybreak-variant--branded{margin:;padding:4px}.f_branding_on.blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_kotaku_on.f_article_split_on .scroll-list-break{border-top:3px solid #fbc}.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#b1246;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-kotaku .post-content .quotable a,.f_branding_on .blog-group-kotaku .post-content .quotable a,.f_branding_on.blog-group-kotaku .post-content footer a,.f_branding_on .blog-group-kotaku .post-content footer a,.f_branding_on.blog-group-kotaku .post-content h1 a,.f_branding_on .blog-group-kotaku .post-content h1 a,.f_branding_on.blog-group-kotaku .post-content h2 a,.f_branding_on .blog-group-kotaku .post-content h2 a,.f_branding_on.blog-group-kotaku .post-content h3 a,.f_branding_on .blog-group-kotaku .post-content h3 a,.f_branding_on.blog-group-kotaku .post-content h4 a,.f_branding_on .blog-group-kotaku .post-content h4 a,.f_branding_on.blog-group-kotaku .post-content h5 a,.f_branding_on .blog-group-kotaku .post-content h5 a,.f_branding_on.blog-group-kotaku .post-content h6 a,.f_branding_on .blog-group-kotaku .post-content h6 a,.f_branding_on.blog-group-kotaku .post-content li a,.f_branding_on .blog-group-kotaku .post-content li a,.f_branding_on.blog-group-kotaku .post-content p a,.f_branding_on .blog-group-kotaku .post-content p a,.f_branding_on.f_branding_kotaku_on .post-content .quotable a,.f_branding_on.f_branding_kotaku_on .post-content footer a,.f_branding_on.f_branding_kotaku_on .post-content h1 a,.f_branding_on.f_branding_kotaku_on .post-content h2 a,.f_branding_on.f_branding_kotaku_on .post-content h3 a,.f_branding_on.f_branding_kotaku_on .post-content h4 a,.f_branding_on.f_branding_kotaku_on .post-content h5 a,.f_branding_on.f_branding_kotaku_on .post-content h6 a,.f_branding_on.f_branding_kotaku_on .post-content li a,.f_branding_on.f_branding_kotaku_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-kotaku .post-content .quotable a:hover,.f_branding_on .blog-group-kotaku .post-content .quotable a:hover,.f_branding_on.blog-group-kotaku .post-content footer a:hover,.f_branding_on .blog-group-kotaku .post-content footer a:hover,.f_branding_on.blog-group-kotaku .post-content h1 a:hover,.f_branding_on .blog-group-kotaku .post-content h1 a:hover,.f_branding_on.blog-group-kotaku .post-content h2 a:hover,.f_branding_on .blog-group-kotaku .post-content h2 a:hover,.f_branding_on.blog-group-kotaku .post-content h3 a:hover,.f_branding_on .blog-group-kotaku .post-content h3 a:hover,.f_branding_on.blog-group-kotaku .post-content h4 a:hover,.f_branding_on .blog-group-kotaku .post-content h4 a:hover,.f_branding_on.blog-group-kotaku .post-content h5 a:hover,.f_branding_on .blog-group-kotaku .post-content h5 a:hover,.f_branding_on.blog-group-kotaku .post-content h6 a:hover,.f_branding_on .blog-group-kotaku .post-content h6 a:hover,.f_branding_on.blog-group-kotaku .post-content li a:hover,.f_branding_on .blog-group-kotaku .post-content li a:hover,.f_branding_on.blog-group-kotaku .post-content p a:hover,.f_branding_on .blog-group-kotaku .post-content p a:hover,.f_branding_on.f_branding_kotaku_on .post-content .quotable a:hover,.f_branding_on.f_branding_kotaku_on .post-content footer a:hover,.f_branding_on.f_branding_kotaku_on .post-content h1 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h2 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h3 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h4 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h5 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h6 a:hover,.f_branding_on.f_branding_kotaku_on .post-content li a:hover,.f_branding_on.f_branding_kotaku_on .post-content p a:hover{color:#fbc}.f_branding_on.blog-group-kotaku figcaption a,.f_branding_on .blog-group-kotaku figcaption a,.f_branding_on.f_branding_kotaku_on figcaption a{color:#b1246}.f_branding_on.blog-group-kotaku figcaption a:hover,.f_branding_on .blog-group-kotaku figcaption a:hover,.f_branding_on.f_branding_kotaku_on figcaption a:hover{color:#871b49}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on.blog-group-kotaku .entry-content blockquote,.f_branding_on .blog-group-kotaku .entry-content blockquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_kotaku_on .entry-content blockquote{border-radius:;border-left:5px solid #fbc;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before,.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-kotaku .review-score,.f_branding_on .blog-group-kotaku .review-score,.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_kotaku_on .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white){color:#b1246;border-color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white):hover{color:#871b49;border-color:#871b49}.f_branding_on.blog-group-kotaku .author-bio__name,.f_branding_on .blog-group-kotaku .author-bio__name,.f_branding_on.f_branding_kotaku_on .author-bio__name{color:#222}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name){color:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover{color:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#871b49}.f_branding_on.blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_kotaku_on .sidebar-content .newsletter-subscribe{border-color:#fbc}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on.blog-group-kotaku .entry-content .pullquote,.f_branding_on .blog-group-kotaku .entry-content .pullquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before{height:7px;width:244px;background-image:url('data:image/svg+xml;utf8,<svg width="244" height="7" viewBox=" 244 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-top<\/title><g fill="none" fill-rule="evenodd"><path d="M243 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M177.167 6.972c2.622.13 5.38-1.883 6.14-4.54L184 .22 64.833.2v.4c-2.622-.13-5.38 1.884-6.14 4.54L58 6.956l.1.44 119.157-.28z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{height:7px;width:129px;background-image:url('data:image/svg+xml;utf8,<svg width="129" height="7" viewBox=" 129 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-bottom<\/title><g fill="none" fill-rule="evenodd"><path d="M128 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M81.75 6.972c2.657.13 5.452-1.883 6.224-4.54l.7-2.41-4.76-.2v.4c-2.657-.13-5.452 1.884-6.224 4.54l-.7 2.41.1.44 4.65-.28z" fill="%23FBC"/><\/g><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:before{background-image:url('data:image/svg+xml;utf8,<svg width="243" height="7" viewBox=" 243 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-lefttop<\/title><g fill="none" fill-rule="evenodd"><path d="M242.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M157.912 6.845c2.375.128 4.872-1.85 5.562-4.457L164.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 122.896-.27z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:after{background-image:url('data:image/svg+xml;utf8,<svg width="117" height="7" viewBox=" 117 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-leftbottom<\/title><g fill="none" fill-rule="evenodd"><path d="M116.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M74.912 6.845c2.375.128 4.872-1.85 5.562-4.457L81.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 39.896-.27z" fill="%23FBC"/><\/g><\/svg>')}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a{min-width:75px;height:16px;background-image:url('data:image/svg+xml;utf8,<svg width="75" height="16" viewBox=" 75 16" xmlns="http://www.w3.org/2/svg"><title>kotaku-bars<\/title><g fill="none" fill-rule="evenodd"><path fill="%23B1246" d="M 16h5VHm7 16h5VH7m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><path fill="%23FBC" d="M49 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_lifehacker_on.f_article_split_on .scroll-list-break{border-top:3px solid #94b33}.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94b33;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-lifehacker .post-content .quotable a,.f_branding_on .blog-group-lifehacker .post-content .quotable a,.f_branding_on.blog-group-lifehacker .post-content footer a,.f_branding_on .blog-group-lifehacker .post-content footer a,.f_branding_on.blog-group-lifehacker .post-content h1 a,.f_branding_on .blog-group-lifehacker .post-content h1 a,.f_branding_on.blog-group-lifehacker .post-content h2 a,.f_branding_on .blog-group-lifehacker .post-content h2 a,.f_branding_on.blog-group-lifehacker .post-content h3 a,.f_branding_on .blog-group-lifehacker .post-content h3 a,.f_branding_on.blog-group-lifehacker .post-content h4 a,.f_branding_on .blog-group-lifehacker .post-content h4 a,.f_branding_on.blog-group-lifehacker .post-content h5 a,.f_branding_on .blog-group-lifehacker .post-content h5 a,.f_branding_on.blog-group-lifehacker .post-content h6 a,.f_branding_on .blog-group-lifehacker .post-content h6 a,.f_branding_on.blog-group-lifehacker .post-content li a,.f_branding_on .blog-group-lifehacker .post-content li a,.f_branding_on.blog-group-lifehacker .post-content p a,.f_branding_on .blog-group-lifehacker .post-content p a,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a,.f_branding_on.f_branding_lifehacker_on .post-content footer a,.f_branding_on.f_branding_lifehacker_on .post-content h1 a,.f_branding_on.f_branding_lifehacker_on .post-content h2 a,.f_branding_on.f_branding_lifehacker_on .post-content h3 a,.f_branding_on.f_branding_lifehacker_on .post-content h4 a,.f_branding_on.f_branding_lifehacker_on .post-content h5 a,.f_branding_on.f_branding_lifehacker_on .post-content h6 a,.f_branding_on.f_branding_lifehacker_on .post-content li a,.f_branding_on.f_branding_lifehacker_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #9dcee7;box-shadow:inset -2px #9dcee7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on .blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on.blog-group-lifehacker .post-content footer a:hover,.f_branding_on .blog-group-lifehacker .post-content footer a:hover,.f_branding_on.blog-group-lifehacker .post-content h1 a:hover,.f_branding_on .blog-group-lifehacker .post-content h1 a:hover,.f_branding_on.blog-group-lifehacker .post-content h2 a:hover,.f_branding_on .blog-group-lifehacker .post-content h2 a:hover,.f_branding_on.blog-group-lifehacker .post-content h3 a:hover,.f_branding_on .blog-group-lifehacker .post-content h3 a:hover,.f_branding_on.blog-group-lifehacker .post-content h4 a:hover,.f_branding_on .blog-group-lifehacker .post-content h4 a:hover,.f_branding_on.blog-group-lifehacker .post-content h5 a:hover,.f_branding_on .blog-group-lifehacker .post-content h5 a:hover,.f_branding_on.blog-group-lifehacker .post-content h6 a:hover,.f_branding_on .blog-group-lifehacker .post-content h6 a:hover,.f_branding_on.blog-group-lifehacker .post-content li a:hover,.f_branding_on .blog-group-lifehacker .post-content li a:hover,.f_branding_on.blog-group-lifehacker .post-content p a:hover,.f_branding_on .blog-group-lifehacker .post-content p a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a:hover,.f_branding_on.f_branding_lifehacker_on .post-content footer a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h1 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h2 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h3 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h4 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h5 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h6 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content li a:hover,.f_branding_on.f_branding_lifehacker_on .post-content p a:hover,.f_branding_on.blog-group-lifehacker figcaption a,.f_branding_on .blog-group-lifehacker figcaption a,.f_branding_on.f_branding_lifehacker_on figcaption a{color:#39c}.f_branding_on.blog-group-lifehacker figcaption a:hover,.f_branding_on .blog-group-lifehacker figcaption a:hover,.f_branding_on.f_branding_lifehacker_on figcaption a:hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on.blog-group-lifehacker .entry-content blockquote,.f_branding_on .blog-group-lifehacker .entry-content blockquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote{border-radius:;border-left:5px solid #94b33;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-lifehacker .review-score,.f_branding_on .blog-group-lifehacker .review-score,.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_lifehacker_on .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#94b33}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white){color:#39c;border-color:#39c}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white):hover{color:#297aa3;border-color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio__name,.f_branding_on .blog-group-lifehacker .author-bio__name,.f_branding_on.f_branding_lifehacker_on .author-bio__name{color:#222}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name){color:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#297aa3}.f_branding_on.blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_lifehacker_on .sidebar-content .newsletter-subscribe{border-color:#94b33}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on.blog-group-lifehacker .entry-content .pullquote,.f_branding_on .blog-group-lifehacker .entry-content .pullquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote{padding: 23px 61px;text-align:left;max-width:4px}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#39c;-webkit-box-shadow:1px #39c,-1px #39c;box-shadow:1px #39c,-1px #39c;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:4px 3px;line-height:4px;position:relative}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{width:46px;height:36px;left:-61px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="36" viewBox=" 46 36" xmlns="http://www.w3.org/2/svg"><title>lifehacker-quote<\/title><path d="M36 L25 18v18h21V17h-8l8-17M11 L 18v18h21V17h-8l8-17" fill="%2394B33" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after{width:1px;height:36px;background-color:#94b33;right:-23px;bottom:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a{min-width:46px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="11" viewBox=" 46 11" xmlns="http://www.w3.org/2/svg"><title>lifehacker-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2394B33" d="M 11h11VH"/><path fill="%2339C" d="M18 11h11VH18"/><path fill="%2394B33" d="M35 11h11VH35"/><\/g><\/svg>')}.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{min-width:48px;height:47px;background-image:url('data:image/svg+xml;utf8,<svg width="48" height="47" viewBox=" 48 47" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>lifehacker-binder<\/title><defs><path id="a" d="M2.667 3.52H.77V.526h2.59v2.526z"/><\/defs><g fill="none" fill-rule="evenodd"><path d="M18.638 41.243c.347 .348-.568 -.568-.347 -.347.568 .568" fill="%2394B33"/><path d="M18.946 4.75c-1.36-1.347-2.153-2.62-3.35-3.824-.297-.297-.756.167-.46.466 1.2 1.22 2.315 2.477 3.352 3.824.256.334.712-.135.458-.465" fill="%2394B33"/><path d="M15.494 36.886c-1.74-.117-3.66.613-3.115 2.77.28 1.13 1.21 1.998 1.95 2.832.46.523.92 1.5 1.4 1.57.24.272.37.474.74.478.15 .26-.14.31-.24l.2-.75c.13-.4-.49-.57-.63-.17l-.3.8.31-.24c-.33 -1.16-1.26-1.4-1.54-.51-.57-1.5-1.12-1.5-1.74-.55-.76-.98-1.82-.21-2.6.56-.56 1.39-.5 2.12-.45.41.3.41-.63 -.65" fill="%2394B33"/><path d="M18.347 41.227c-.956.2-1.96.457-2.25 1.456-.258.89.197 1.853 1.13 2.3 2.43.386 2.757-4.4.655-3.797-.41.47-.415.76 .657.96-.14.6 1.11.427 1.64-.21.574-.62 1.27-1.28.76-.48-.32-.44-.975-.15-1.41.33-.487.9-.642 1.46-.642.42 .42-.658 -.658m-6.95-6.855c-.92.443-1.23 1.53-1.1 2.49.24 1.55 1.1 1.84 1.99 2.21.39.145.56-.49.17-.636-1.22-.453-2.51-2.692-.84-3.495.37-.18.4-.74-.33-.56" fill="%2394B33"/><path d="M7.78 3.77c1.56 1.365 2.166 2.683 3.33 3.956.283.312.74-.154.458-.464-1.163-1.273-2.273-2.592-3.33-3.957-.257-.333-.713.136-.458.465" fill="%2394B33"/><path d="M7.552 3.174c-.795.645-1.212 1.656-1.17 2.683.42.416.69.42.648 -.9-.877.24-1.667.917-2.218.326-.27-.135-.73-.458-.47" fill="%2394B33"/><path d="M6.338 32.87c1.373 1.997 2.885 3.88 4.54 5.644.29.31.747-.15.46-.46-1.618-1.72-3.1-3.56-4.44-5.51-.236-.34-.8-.1-.56.34M2.32 23.86c1.26 1.41 2.453 2.873 3.578 4.395.247.335.81.8.56-.33-1.157-1.57-2.382-3.8-3.68-4.53-.28-.315-.737.15-.457.464" fill="%2394B33"/><path d="M6.246 27.827c-1.23-.156-2.33.427-2.13 1.547-.11 1.262 1.225 2.29 1.97 3.122.282.315.74-.152.46-.464-.42-.468-.854-.924-1.256-1.45-.27-.246-.44-.533-.51-.86-.17-.82.53-1.422 1.294-1.35.48.62.584-.57.172-.635" fill="%2394B33"/><path d="M2.377 23.144C.73 23.118-.278 24.674.34 26.21c.372.982 1.224 1.835 1.883 2.624.872 1.43 1.786 2.34 2.823 2.91.32.27.78-.194.46-.465-1.138-.96-2.124-2.6-3.72-3.21-.48-.59-1.3-1.16-1.372-1.84-.584-1.17.2-2.45 1.35-2.43.418 .418-.65 -.66" fill="%2394B33"/><path d="M3.83 24.67c2.76-2.947 3.984-6.12 5.69-9.194.57-1.62 1.92-5.88 3.52-4.11.863.527 1.453 1.582 2.46 2.375.585.79 1.17 1.57 1.756 2.36.25.34.812.1.56-.33l-2.132-2.86c-.53-.71-1.4-1.5-1.775-2.1-1.49-1.4-2.423.8-3.74 1.4-2.7 4.2-4.46 8.23-7.15 12.5-.24.35.32.68.56.33m14.97-6.51c.84.83 1.59 1.72 2.34 2.63.27.33.73-.14.46-.46-.75-.91-1.5-1.79-2.33-2.62-.3-.29-.76.17-.46.47m4.52 4.61c1.96 1.96 4 3.81 6.11 5.6.32.27.78-.19.46-.46-2.11-1.79-4.15-3.64-6.11-5.6-.3-.29-.76.17-.46.47" fill="%2394B33"/><path d="M19.263 43.354c1.434-2.52 2.87-5.4 4.33-7.57.718-1.25 1.435-2.52 2.152-3.754.65-1.133 1.243-2.717 2.222-3.596.464-.415 1.8-.428 1.542.62.166.17.242.7.285.94.84.47.97.96.19 1.43.173.87.55 1.7 1.9 2.4.58.75 1.292 1.25 2.12 1.71.5.28 1.7.57 1.36 1.1.62 1.14-.52 1.92-1.44 2.22-.4.13-.23.76.17.63.96-.31 2.3-.99 2.12-2.12.9-1.15-.9-1.83-1.77-2.34-1.41-.83-2.53-1.82-2.95-3.49-.26-1.4-.7-2.52-.96-3.29-.76-.65-1.71-.29-2.32.36-1.13 1.19-1.83 2.94-2.65 4.36L18.7 43.2c-.21.368.35.7.56.332" fill="%2394B33"/><path d="M18.524 44.16l15.417-5.356c.4-.137.23-.772-.17-.634l-15.42 5.357c-.39.136-.22.772.18.634" fill="%2394B33"/><path d="M19.892 43.348c-.897.385-2.5 1.183-1.64 2.35.28.796 1.28 1.75 2.3.76.876-.38 1.28-1.473 1.25-2.385-.68-.846-.927-1.777-1.765-1.12-.326.254-.3.825.327.566.73-.55.836.77.755 1.18-.96.49-.384 1.5-.9 1.19-.46.12-1.76-.13-1.52-.68.3-.72.84-1.7 1.394-1.31.38-.17.5-.73-.33-.57" fill="%2394B33"/><g transform="translate(16.8 43.636)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M.15 1.16c.573.747 1.26 1.377 2.4 1.892.35.23.676-.338.327-.568C1.78 1.945 1.147 1.344.61.64.353.38-.13.776.15 1.17" fill="%2394B33" mask="url(%23b)"/><\/g><path d="M15.728 37.47c.878-3.268 2.82-6.17 4.473-9.77l5.7-8.95c.79-1.376 1.49-2.88 2.42-4.155.96-1.37 2.33-1.59 3.82-1.865 2.24-.415 4.3-1.36 4.36-3.842.6-4.545-3.33-9.333-7.83-9.613C26.1-.11 24.9.68 23.29 2.59c-1.123 2.695.3 5.637-1.438 8.21-1.1 1.624-2.637 3-3.97 4.424l-3.86 4.116-8.36 8.87c-.287.38.17.774.46.466l13.35-14.253c1.66-1.77 3.612-3.52 3.934-6.6.32-2.54-.724-6.44 2.234-7.324 4.93-2.14 1.68 4.14 9.44 9.3-.755 2.98-3.88 2.4-6.1 3.35-.94.38-1.55 1.5-2.9 1.87-.894 1.35-1.634 2.83-2.436 4.23l-5.17 9.9c-1.583 2.78-3.38 5.55-4.22 8.68-.11.41.515.58.624.17" fill="%2394B33"/><path d="M5.26 31.196c2.932.283 5.2-2.353 6.686-4.398 2.21-2.686 4.27-5.497 6.482-8.18 1.125-1.365 2.29-2.695 3.53-3.955.988-1.4 2.65-1.962 2.818-3.17.757-1.215.942-2.5.82-3.912-.14-1.62-.592-5.74 2.273-5.3.4.1.57-.53.17-.63-1.5-.26-2.9.2-2.69 1.12-.81 1.24-.59 2.79-.45 4.17.21 2.14-.26 3.66-1.69 5.24-1.12 1.25-2.35 2.38-3.47 3.63-2.36 2.65-4.47 5.5-6.67 8.28-1.86 2.36-4.4 6.53-7.83 6.2-.42-.4-.42.62 .66" fill="%2394B33"/><path d="M27.74 2.567c3.7.46 5.95 3.983 5.18 7.12-.733 3.155-4.715.37-6.8 2.546-.226.36.335.69.56.332.543-.868 2-.56 2.847-.526.62-.2 1.267-.8 1.84-.34 1.312-.59 1.66-2.4 1.543-3.38-.274-3.11-2.82-6-5.89-6.42-.41-.6-.47.6 .65" fill="%2394B33"/><path d="M13.184 37.95c.393-2.47 1.518-4.688 2.65-6.885 1.11-2.158 2.278-4.287 3.512-6.376 2.41-4.8 5.83-7.99 7.888-11.8.25-.34-.313-.67-.56-.33-2.878 3.91-5.616 7.92-8.76 12.11-1.232 2.1-2.398 4.24-3.57 6.41-1.9 2.13-2.15 4.29-2.53 6.68-.6.41.56.59.63.17M27.3 26.37c2.16-.15 5.43-.3 6.38-2.67.586-1.45.746-2.91 2.55-3.21 1.525-.252 3.16.267 4.596.745 1.593.53 3.165 1.294 4.32 2.56 1.158 1.27 2.14 3.21 1.476 4.942-1.143 2.974-4.62 1.44-6.82.93-3.265-.72-6.127 1.96-8.715 2.894-.343.24-.2.81.327.57 1.565-1.8 3.19-2.21 5.43-2.72 1.685-.46 3.147-.11 4.78.31 2.22.58 4.92.93 5.977-1.68 1.76-2.67-1.46-5.62-3.163-7.1-1.49-.98-3.24-1.55-4.96-1.96-1.23-.29-2.63-.48-3.84.3-1.47.63-1.62 2.3-2.16 3.37-.82 2.4-3.93 2.14-5.78 2.27-.41.3-.41.69 .66" fill="%2394B33"/><path d="M28.98 27.835c2.463-.212 5.497-.644 6.547-3.298.336-.85.365-1.976 1.42-2.257.866-.23 1.942.194 2.744.5 1.51.576 3.2 1.457 4.29 2.693.78.88 1.27 2.253-.14 2.864-.83.36-1.75.4-2.57-.198-1.28-.38-2.55-.59-3.89-.5-2.7.18-5.24 1.39-7.1 3.38-.29.31.17.77.46.46 2.58-2.76 6.44-3.83 1.5-2.81 1.27.36 2.82.88 3.95-.13.93-.84.76-2.4.11-3.1-.83-1.25-2.28-2.12-3.58-2.78-1.28-.65-3.5-1.51-4.51-1.13-1.57.41-1.4 2.1-2.12 3.18-1.18 1.93-3.68 2.17-5.69 2.34-.42.3-.42.69 .66" fill="%2394B33"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion .headline,.f_branding_on .blog-group-theonion .headline,.f_branding_on.blog-group-theonion .inset-headline,.f_branding_on .blog-group-theonion .inset-headline,.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .headline,.f_branding_on.f_branding_theonion_on .inset-headline,.f_branding_on.f_branding_theonion_on .kinja-slide__caption,.f_branding_on.blog-group-theonion .post-content h1,.f_branding_on .blog-group-theonion .post-content h1,.f_branding_on.blog-group-theonion .post-content h2,.f_branding_on .blog-group-theonion .post-content h2,.f_branding_on.blog-group-theonion .post-content h3,.f_branding_on .blog-group-theonion .post-content h3,.f_branding_on.blog-group-theonion .post-content h4,.f_branding_on .blog-group-theonion .post-content h4,.f_branding_on.blog-group-theonion .post-content h5,.f_branding_on .blog-group-theonion .post-content h5,.f_branding_on.blog-group-theonion .post-content h6,.f_branding_on .blog-group-theonion .post-content h6,.f_branding_on.f_branding_theonion_on .post-content h1,.f_branding_on.f_branding_theonion_on .post-content h2,.f_branding_on.f_branding_theonion_on .post-content h3,.f_branding_on.f_branding_theonion_on .post-content h4,.f_branding_on.f_branding_theonion_on .post-content h5,.f_branding_on.f_branding_theonion_on .post-content h6{font-family:"ElizabethSerif",Georgia,serif}.f_branding_on.blog-group-theonion.permalink .post .entry-title,.f_branding_on .blog-group-theonion.permalink .post .entry-title,.f_branding_on.f_branding_theonion_on.permalink .post .entry-title{font-size:34px;line-height:1.3}.f_branding_on.blog-group-theonion .postlist__item .headline,.f_branding_on .blog-group-theonion .postlist__item .headline,.f_branding_on.f_branding_theonion_on .postlist__item .headline{font-size:22px;line-height:1.4}.f_branding_on.blog-group-theonion .thumb-inset .inset-headline,.f_branding_on .blog-group-theonion .thumb-inset .inset-headline,.f_branding_on.f_branding_theonion_on .thumb-inset .inset-headline{font-size:14px;line-height:1.4}.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .kinja-slide__caption{font-size:13px;line-height:1.5}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theonion .entry-content .pullquote,.f_branding_on .blog-group-theonion .entry-content .pullquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theonion_on .entry-content .pullquote{border-top:none;border-bottom:8px solid #6b3a;padding: 3px;position:relative;font-size:28px;line-height:1.3;text-align:left;font-family:"ElizabethSerif",Georgia,serif;font-weight:bold;color:#6b3a}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--left{margin-top:}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-a{min-width:6px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="6" height="5" viewBox=" 6 5" xmlns="http://www.w3.org/2/svg"><title>onion-storybreak<\/title><path d="M h6v1Hzm 4h6v1Hz" fill="%2391D8B6" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{display:none !important}.f_branding_on .networknav__hovernav-wrapper.theonion .hovernav__post-list h4{font-family:"ElizabethSerif",Georgia,serif;font-size:15px;line-height:1.4}.f_branding_on.blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theroot_on.f_article_split_on .scroll-list-break{border-top:3px solid #59b22}.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#59b22;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theroot .post-content .quotable a,.f_branding_on .blog-group-theroot .post-content .quotable a,.f_branding_on.blog-group-theroot .post-content footer a,.f_branding_on .blog-group-theroot .post-content footer a,.f_branding_on.blog-group-theroot .post-content h1 a,.f_branding_on .blog-group-theroot .post-content h1 a,.f_branding_on.blog-group-theroot .post-content h2 a,.f_branding_on .blog-group-theroot .post-content h2 a,.f_branding_on.blog-group-theroot .post-content h3 a,.f_branding_on .blog-group-theroot .post-content h3 a,.f_branding_on.blog-group-theroot .post-content h4 a,.f_branding_on .blog-group-theroot .post-content h4 a,.f_branding_on.blog-group-theroot .post-content h5 a,.f_branding_on .blog-group-theroot .post-content h5 a,.f_branding_on.blog-group-theroot .post-content h6 a,.f_branding_on .blog-group-theroot .post-content h6 a,.f_branding_on.blog-group-theroot .post-content li a,.f_branding_on .blog-group-theroot .post-content li a,.f_branding_on.blog-group-theroot .post-content p a,.f_branding_on .blog-group-theroot .post-content p a,.f_branding_on.f_branding_theroot_on .post-content .quotable a,.f_branding_on.f_branding_theroot_on .post-content footer a,.f_branding_on.f_branding_theroot_on .post-content h1 a,.f_branding_on.f_branding_theroot_on .post-content h2 a,.f_branding_on.f_branding_theroot_on .post-content h3 a,.f_branding_on.f_branding_theroot_on .post-content h4 a,.f_branding_on.f_branding_theroot_on .post-content h5 a,.f_branding_on.f_branding_theroot_on .post-content h6 a,.f_branding_on.f_branding_theroot_on .post-content li a,.f_branding_on.f_branding_theroot_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theroot .post-content .quotable a:hover,.f_branding_on .blog-group-theroot .post-content .quotable a:hover,.f_branding_on.blog-group-theroot .post-content footer a:hover,.f_branding_on .blog-group-theroot .post-content footer a:hover,.f_branding_on.blog-group-theroot .post-content h1 a:hover,.f_branding_on .blog-group-theroot .post-content h1 a:hover,.f_branding_on.blog-group-theroot .post-content h2 a:hover,.f_branding_on .blog-group-theroot .post-content h2 a:hover,.f_branding_on.blog-group-theroot .post-content h3 a:hover,.f_branding_on .blog-group-theroot .post-content h3 a:hover,.f_branding_on.blog-group-theroot .post-content h4 a:hover,.f_branding_on .blog-group-theroot .post-content h4 a:hover,.f_branding_on.blog-group-theroot .post-content h5 a:hover,.f_branding_on .blog-group-theroot .post-content h5 a:hover,.f_branding_on.blog-group-theroot .post-content h6 a:hover,.f_branding_on .blog-group-theroot .post-content h6 a:hover,.f_branding_on.blog-group-theroot .post-content li a:hover,.f_branding_on .blog-group-theroot .post-content li a:hover,.f_branding_on.blog-group-theroot .post-content p a:hover,.f_branding_on .blog-group-theroot .post-content p a:hover,.f_branding_on.f_branding_theroot_on .post-content .quotable a:hover,.f_branding_on.f_branding_theroot_on .post-content footer a:hover,.f_branding_on.f_branding_theroot_on .post-content h1 a:hover,.f_branding_on.f_branding_theroot_on .post-content h2 a:hover,.f_branding_on.f_branding_theroot_on .post-content h3 a:hover,.f_branding_on.f_branding_theroot_on .post-content h4 a:hover,.f_branding_on.f_branding_theroot_on .post-content h5 a:hover,.f_branding_on.f_branding_theroot_on .post-content h6 a:hover,.f_branding_on.f_branding_theroot_on .post-content li a:hover,.f_branding_on.f_branding_theroot_on .post-content p a:hover,.f_branding_on.blog-group-theroot figcaption a,.f_branding_on .blog-group-theroot figcaption a,.f_branding_on.f_branding_theroot_on figcaption a{color:#59b22}.f_branding_on.blog-group-theroot figcaption a:hover,.f_branding_on .blog-group-theroot figcaption a:hover,.f_branding_on.f_branding_theroot_on figcaption a:hover{color:#3a7119}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on.blog-group-theroot .entry-content blockquote,.f_branding_on .blog-group-theroot .entry-content blockquote,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theroot_on .entry-content blockquote{border-radius:;border-left:5px solid #dd6634;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before,.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theroot .entry-content .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote__content,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theroot .review-score,.f_branding_on .blog-group-theroot .review-score,.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theroot_on .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#dd6634}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white){color:#59b22;border-color:#59b22}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white):hover{color:#3a7119;border-color:#3a7119}.f_branding_on.blog-group-theroot .author-bio__name,.f_branding_on .blog-group-theroot .author-bio__name,.f_branding_on.f_branding_theroot_on .author-bio__name{color:#222}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name){color:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover{color:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#3a7119}.f_branding_on.blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theroot_on .sidebar-content .newsletter-subscribe{border-color:#dd6634}.f_branding_on.blog-group-theroot .entry-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote{padding: 2px;max-width:4px}.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#;-webkit-box-shadow:2px #,-2px #;box-shadow:2px #,-2px #;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:1px ;line-height:37px;font-size:26px;font-weight:normal;font-style:normal;position:relative}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{width:15px;height:32px;left:-2px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="15" height="32" viewBox=" 15 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-green<\/title><path d="M14.345 Hv32h3.627" fill="%2359B22" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after{width:14px;height:32px;right:-2px;bottom:;background-image:url('data:image/svg+xml;utf8,<svg width="14" height="32" viewBox=" 14 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-red<\/title><path d="M 32h14Vh-4" fill="%23DD6634" fill-rule="evenodd"/><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-a{min-width:24px;height:55px;background-image:url('data:image/svg+xml;utf8,<svg width="24" height="55" viewBox=" 24 55" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-afropicker<\/title><g fill-rule="evenodd"><path d="M23.32 27.59l-6.346-4.574-.475-4.45-2.83.42 2.79-1.39 2.3-3.49 2.393-2.87.14-1.63-2.347-5.31-1.22-.328-2.66.42-2.856-.66-1.62.74v1.68l2.13 1.7s2.638.54 2.83.44c.19-.1 2.686-1.2 2.686-1.2L16.2 9.17l1.73 3.3-3.3-2.74-1.162.66-1.258.233-.28.838-.852 4.264-.218-3.655-.76.343-.766-.19-1.625.81-2.3-.643L3.63 8.84l-.29.91.62 1.384.96 3.87.664.67 1.38 2.44.128 1.336-.364 3.56L 27.586v7.69h1.243V54.54c .258.21.467.467.467s.466-.21.466-.468V35.27H3.73v19.27c .26.21.468.467.468.258 .467-.21.467-.47v-19.26h1.554v19.265c .258.21.467.467.467.258 .467-.21.467-.47V35.278h1.554v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.55v19.265c .258.21.467.46.467s.463-.21.463-.47V35.278h1.554v19.265c .258.21.467.47.467.255 .464-.21.464-.47V35.278h1.555v19.265c .258.25.467.462.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.47.467s.466-.21.466-.47V35.278h1.246V27.59z"/><path d="M1.515 11.187c.144-.48.956-.526.956-.526l.43-1.9s-1.29-3.39-1.29-3.54c-.14-1.25-2.49-1.25-2.49l-.8-.325-1.29.56-.47 1.162 2.91 6.16s.67.144.81.96m-2.77.57l1.1-.813-2.59-5.4-.91-.336-1.48 1.484-.24 1.387 2.87 3.2m7.26-1.95l.82-.53-1.44-.39-1.4-1.246.776 1.73m2.38-8.9l-.998 1.242.562 2.8 1.46.29 1.89-.19V1.44L16.51.98m-5.938 3.62l1.84-.84 1.314.28-.46-1.58L12.32.98l-1.714.56-.643 1.56.61 2.285"/><\/g><\/svg>')}.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{min-width:32px;height:41px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="41" viewBox=" 32 41" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-fist<\/title><g fill-rule="evenodd"><path d="M2.474 L18.62 2.18l1.2 3.524 2.85.53 3.698-.335V2.517l-2.51-2.35m-5.22 5.37l-.848-2.77-1.693-1.47-3.48.985-.75 1.85 1.466 4.1V6.52l2.868-1.473m-1.3 11.73S12.87 1.82 12.87 1.57c-.252-2.22-4.378-2.22-4.378L9.228 5.62l-2.296.982-.825 2.46L11.26 19.46s1.185.252 1.44.17c.253-.85 1.693-.924 1.693-.924l.762-1.93zM4.994 9.73l4.58 9.475-1.786 1.43-2.37-.84-5.8-5.62.422-2.432 2.625-2.6m11.313 3.433l1.376 3.34 2.22.755 1.46-.925-2.55-.677"/><path d="M6.266 4.37L6.66 34.1l-.283-2.328-2.47-4.27-1.192-1.168-1.612-6.792L 17.112l.57-1.594L4.62 21.25l3.592 1.13 2.88-1.426 1.353.336 1.347-.63.388 6.47 1.51-7.48.495-1.474 2.23-.48 2.66-1.64 5.37 4.746-3.54-5.32 4.472-3.174s-4.38 1.616-4.72 1.784c-.34.167-4.664-.78-4.664-.78l-3.15-2.985V7.99l2.462-1.31 4.783 1.64 3.587-.736 2.125.574 4.145 9.32-.257 2.81-4.24 5.35-4.74 6.124-4.933 2.44 5.4-.78 1.133 7.773H6.266z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_thetakeout_on.f_article_split_on .scroll-list-break{border-top:3px solid #E5371A}.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#E5371A;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-thetakeout .post-content .quotable a,.f_branding_on .blog-group-thetakeout .post-content .quotable a,.f_branding_on.blog-group-thetakeout .post-content footer a,.f_branding_on .blog-group-thetakeout .post-content footer a,.f_branding_on.blog-group-thetakeout .post-content h1 a,.f_branding_on .blog-group-thetakeout .post-content h1 a,.f_branding_on.blog-group-thetakeout .post-content h2 a,.f_branding_on .blog-group-thetakeout .post-content h2 a,.f_branding_on.blog-group-thetakeout .post-content h3 a,.f_branding_on .blog-group-thetakeout .post-content h3 a,.f_branding_on.blog-group-thetakeout .post-content h4 a,.f_branding_on .blog-group-thetakeout .post-content h4 a,.f_branding_on.blog-group-thetakeout .post-content h5 a,.f_branding_on .blog-group-thetakeout .post-content h5 a,.f_branding_on.blog-group-thetakeout .post-content h6 a,.f_branding_on .blog-group-thetakeout .post-content h6 a,.f_branding_on.blog-group-thetakeout .post-content li a,.f_branding_on .blog-group-thetakeout .post-content li a,.f_branding_on.blog-group-thetakeout .post-content p a,.f_branding_on .blog-group-thetakeout .post-content p a,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a,.f_branding_on.f_branding_thetakeout_on .post-content footer a,.f_branding_on.f_branding_thetakeout_on .post-content h1 a,.f_branding_on.f_branding_thetakeout_on .post-content h2 a,.f_branding_on.f_branding_thetakeout_on .post-content h3 a,.f_branding_on.f_branding_thetakeout_on .post-content h4 a,.f_branding_on.f_branding_thetakeout_on .post-content h5 a,.f_branding_on.f_branding_thetakeout_on .post-content h6 a,.f_branding_on.f_branding_thetakeout_on .post-content li a,.f_branding_on.f_branding_thetakeout_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f9db5d;box-shadow:inset -2px #f9db5d;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on .blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on.blog-group-thetakeout .post-content footer a:hover,.f_branding_on .blog-group-thetakeout .post-content footer a:hover,.f_branding_on.blog-group-thetakeout .post-content h1 a:hover,.f_branding_on .blog-group-thetakeout .post-content h1 a:hover,.f_branding_on.blog-group-thetakeout .post-content h2 a:hover,.f_branding_on .blog-group-thetakeout .post-content h2 a:hover,.f_branding_on.blog-group-thetakeout .post-content h3 a:hover,.f_branding_on .blog-group-thetakeout .post-content h3 a:hover,.f_branding_on.blog-group-thetakeout .post-content h4 a:hover,.f_branding_on .blog-group-thetakeout .post-content h4 a:hover,.f_branding_on.blog-group-thetakeout .post-content h5 a:hover,.f_branding_on .blog-group-thetakeout .post-content h5 a:hover,.f_branding_on.blog-group-thetakeout .post-content h6 a:hover,.f_branding_on .blog-group-thetakeout .post-content h6 a:hover,.f_branding_on.blog-group-thetakeout .post-content li a:hover,.f_branding_on .blog-group-thetakeout .post-content li a:hover,.f_branding_on.blog-group-thetakeout .post-content p a:hover,.f_branding_on .blog-group-thetakeout .post-content p a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a:hover,.f_branding_on.f_branding_thetakeout_on .post-content footer a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h1 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h2 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h3 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h4 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h5 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h6 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content li a:hover,.f_branding_on.f_branding_thetakeout_on .post-content p a:hover{color:#F9DB5D}.f_branding_on.blog-group-thetakeout figcaption a,.f_branding_on .blog-group-thetakeout figcaption a,.f_branding_on.f_branding_thetakeout_on figcaption a{color:#E5371A}.f_branding_on.blog-group-thetakeout figcaption a:hover,.f_branding_on .blog-group-thetakeout figcaption a:hover,.f_branding_on.f_branding_thetakeout_on figcaption a:hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on.blog-group-thetakeout .entry-content blockquote,.f_branding_on .blog-group-thetakeout .entry-content blockquote,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote{border-radius:;border-left:5px solid #17466;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before,.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-thetakeout .review-score,.f_branding_on .blog-group-thetakeout .review-score,.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_thetakeout_on .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white){color:#E5371A;border-color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white):hover{color:#b72c15;border-color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio__name,.f_branding_on .blog-group-thetakeout .author-bio__name,.f_branding_on.f_branding_thetakeout_on .author-bio__name{color:#222}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name){color:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#b72c15}.f_branding_on.blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_thetakeout_on .sidebar-content .newsletter-subscribe{border-color:#17466}.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{padding:3px;max-width:4px;border:1px solid #F9DB5D;border-radius:5px;font-style:normal;text-align:left;position:relative;margin-top:3rem}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before{display:block;content:'';position:absolute;margin:;width:79px;height:33px;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="79" height="33" viewBox=" 79 33" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>pq-thetakeout<\/title><defs><path id="a" d="M334.76 H.5v136.817h334.26z"/><path id="c" d="M22.72 v18.41HVh22.72z"/><\/defs><g fill="none" fill-rule="evenodd"><g transform="translate(-3)"><mask id="b" fill="%23fff"><use xlink:href="%23a"/><\/mask><path d="M16.262 21.627l-.775-14.652c-.27-3.65-3.31-6.475-6.972-6.475H4.28c-3.662 -6.74 2.825-6.974 6.474l-.775 14.652c-.8 1.95-.99 1.944-2.9 1.944H3.998C2.67 23.57.5 25.134.5 27.64v16.258c 1.93 1.565 3.495 3.496 3.495H331.21c1.93 3.496-1.565 3.496-3.495V27.64c-1.93-1.565-3.494-3.496-3.494H18.354c-1.1 -2.1-.85-2.92-1.944z" stroke="%23F9DB5D" mask="url(#b)"/><\/g><g transform="translate(28 14)"><mask id="d" fill="%23fff"><use xlink:href="%23c"/><\/mask><path d="M12.243 11.274c-6.46 4.37-9.844 5.722-11.13.43-.33.86-.43 1.353.127l.923.923c.435.49.31 1.45-.6 1.353-.674.493-4.34 3.2-4.37 7.384 1.5-.43 2.465-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43-2.338 -5.6-1.783-5.6-7.136M 11.274C 4.814 4.36 1.43 5.722.26c.43-.36.86-.43 1.353.124l.923.923c.43.492.37 1.46-.62 1.354-.676.496-4.36 3.2-4.368 7.387 1.46-.43 2.46-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43C3.26 18.41 16.628 11.274" fill="%23F9DB5D" mask="url(#d)"/><\/g><\/g><\/svg>');left:3px;top:-24px}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote .pullquote__content{padding:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:1.5rem;margin-bottom:1rem}}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a{min-width:19px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="19" height="13" viewBox=" 19 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-a<\/title><g stroke="%23F9DB5D" fill="none" fill-rule="evenodd"><path d="M3.35 5.733c-.28.17-.47.345-.47.523v2.18c 1.728 1.413 3.14 3.14 3.14H22.77c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M26.96.5H3.116C1.676.5.5 1.677.5 3.117s1.177 2.616 2.616 2.616h.235c.255-1.48 1.548-2.616 3.96-2.616H22.77c1.548 2.84 1.136 3.92 2.616h.234c1.44 2.617-1.177 2.617-2.616 -1.44-1.178-2.617-2.617-2.617zM43.9 5.733c-.3.17-.5.345-.5.523v2.18c 1.728 1.414 3.14 3.14 3.14h16.33c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M65.834.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.54-2.616 3.9-2.616h16.324c1.55 2.84 1.136 3.93 2.616h.233c1.44 2.617-1.177 2.618-2.616C68.45 1.677 67.274.5 65.835.5zm16.993 5.233c-.3.17-.48.345-.48.523v2.18c 1.728 1.41 3.14 3.14 3.14h16.323c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M15.572.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.544-2.616 3.92-2.616h16.322c1.55 2.84 1.136 3.93 2.616h.234c1.44 2.616-1.177 2.616-2.616 -1.44-1.177-2.617-2.616-2.617z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{min-width:43px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="43" height="13" viewBox=" 43 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-b<\/title><path d="M7 1.38L36.154 1M7 12.38L36.154 12M.5 6.735l42.11-.445" stroke="%23E5371A" fill="none" stroke-linecap="round"/><\/svg>')}.f_branding_on.blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_splinter_on.f_article_split_on .scroll-list-break{border-top:3px solid #f85637}.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#f85637;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-splinter .post-content .quotable a,.f_branding_on .blog-group-splinter .post-content .quotable a,.f_branding_on.blog-group-splinter .post-content footer a,.f_branding_on .blog-group-splinter .post-content footer a,.f_branding_on.blog-group-splinter .post-content h1 a,.f_branding_on .blog-group-splinter .post-content h1 a,.f_branding_on.blog-group-splinter .post-content h2 a,.f_branding_on .blog-group-splinter .post-content h2 a,.f_branding_on.blog-group-splinter .post-content h3 a,.f_branding_on .blog-group-splinter .post-content h3 a,.f_branding_on.blog-group-splinter .post-content h4 a,.f_branding_on .blog-group-splinter .post-content h4 a,.f_branding_on.blog-group-splinter .post-content h5 a,.f_branding_on .blog-group-splinter .post-content h5 a,.f_branding_on.blog-group-splinter .post-content h6 a,.f_branding_on .blog-group-splinter .post-content h6 a,.f_branding_on.blog-group-splinter .post-content li a,.f_branding_on .blog-group-splinter .post-content li a,.f_branding_on.blog-group-splinter .post-content p a,.f_branding_on .blog-group-splinter .post-content p a,.f_branding_on.f_branding_splinter_on .post-content .quotable a,.f_branding_on.f_branding_splinter_on .post-content footer a,.f_branding_on.f_branding_splinter_on .post-content h1 a,.f_branding_on.f_branding_splinter_on .post-content h2 a,.f_branding_on.f_branding_splinter_on .post-content h3 a,.f_branding_on.f_branding_splinter_on .post-content h4 a,.f_branding_on.f_branding_splinter_on .post-content h5 a,.f_branding_on.f_branding_splinter_on .post-content h6 a,.f_branding_on.f_branding_splinter_on .post-content li a,.f_branding_on.f_branding_splinter_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-splinter .post-content .quotable a:hover,.f_branding_on .blog-group-splinter .post-content .quotable a:hover,.f_branding_on.blog-group-splinter .post-content footer a:hover,.f_branding_on .blog-group-splinter .post-content footer a:hover,.f_branding_on.blog-group-splinter .post-content h1 a:hover,.f_branding_on .blog-group-splinter .post-content h1 a:hover,.f_branding_on.blog-group-splinter .post-content h2 a:hover,.f_branding_on .blog-group-splinter .post-content h2 a:hover,.f_branding_on.blog-group-splinter .post-content h3 a:hover,.f_branding_on .blog-group-splinter .post-content h3 a:hover,.f_branding_on.blog-group-splinter .post-content h4 a:hover,.f_branding_on .blog-group-splinter .post-content h4 a:hover,.f_branding_on.blog-group-splinter .post-content h5 a:hover,.f_branding_on .blog-group-splinter .post-content h5 a:hover,.f_branding_on.blog-group-splinter .post-content h6 a:hover,.f_branding_on .blog-group-splinter .post-content h6 a:hover,.f_branding_on.blog-group-splinter .post-content li a:hover,.f_branding_on .blog-group-splinter .post-content li a:hover,.f_branding_on.blog-group-splinter .post-content p a:hover,.f_branding_on .blog-group-splinter .post-content p a:hover,.f_branding_on.f_branding_splinter_on .post-content .quotable a:hover,.f_branding_on.f_branding_splinter_on .post-content footer a:hover,.f_branding_on.f_branding_splinter_on .post-content h1 a:hover,.f_branding_on.f_branding_splinter_on .post-content h2 a:hover,.f_branding_on.f_branding_splinter_on .post-content h3 a:hover,.f_branding_on.f_branding_splinter_on .post-content h4 a:hover,.f_branding_on.f_branding_splinter_on .post-content h5 a:hover,.f_branding_on.f_branding_splinter_on .post-content h6 a:hover,.f_branding_on.f_branding_splinter_on .post-content li a:hover,.f_branding_on.f_branding_splinter_on .post-content p a:hover,.f_branding_on.blog-group-splinter figcaption a,.f_branding_on .blog-group-splinter figcaption a,.f_branding_on.f_branding_splinter_on figcaption a{color:#f85637}.f_branding_on.blog-group-splinter figcaption a:hover,.f_branding_on .blog-group-splinter figcaption a:hover,.f_branding_on.f_branding_splinter_on figcaption a:hover{color:#f32e9}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on.blog-group-splinter .entry-content blockquote,.f_branding_on .blog-group-splinter .entry-content blockquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_splinter_on .entry-content blockquote{border-radius:;border-left:5px solid #f85637;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before,.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-splinter .entry-content .pullquote__content,.f_branding_on .blog-group-splinter .entry-content .pullquote__content,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_splinter_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-splinter .review-score,.f_branding_on .blog-group-splinter .review-score,.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_splinter_on .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white){color:#f85637;border-color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white):hover{color:#f32e9;border-color:#f32e9}.f_branding_on.blog-group-splinter .author-bio__name,.f_branding_on .blog-group-splinter .author-bio__name,.f_branding_on.f_branding_splinter_on .author-bio__name{color:#222}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name){color:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover{color:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#f32e9}.f_branding_on.blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_splinter_on .sidebar-content .newsletter-subscribe{border-color:#f85637}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on.blog-group-splinter .entry-content .pullquote,.f_branding_on .blog-group-splinter .entry-content .pullquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_splinter_on .entry-content .pullquote{border-top:4px solid #f85637;padding-top:3px;padding-bottom:;position:relative;font-weight:bold;font-style:normal}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before{height:32px;width:32px;position:absolute;left:calc(5% - 18px);top:-18px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="32" viewBox=" 32 32" xmlns="http://www.w3.org/2/svg"><title>splinter-pq<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M 32h32VH"/><path d="M14 7.466c-.15-.227.162-.42.39-.423L17.657 7c.233-.2.417.195.398.427C17.82 1.26 16.49 26.6 15.94 26.6c-.547 -1.735-15.85-1.94-18.593z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-a{min-width:31px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="5" viewBox=" 31 5" xmlns="http://www.w3.org/2/svg"><title>storybreak-1-splinter<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M1.47 9.33l6.696-3.54v7.495l-6.696 3.6"/><path d="M9.167 24.32H7.223V5.27c-1.455-1.183-2.637-2.637-2.637S1.95 3.572 1.95 5.27V24.32H.5V5.27C.5 2.5 2.6.447 4.585.447c2.527 4.58 2.54 4.58 4.58V24.32z" fill="%23"/><path d="M11.84 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.637-1.18 2.637-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.81c 2.53-2.5 4.58-4.58 4.58" fill="%23"/><path d="M19.2 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.638-1.18 2.638-2.63v-6.8c-1.45-1.184-2.64-2.638-2.64m 14.2c-2.525 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.55-4.58 4.58-4.58 2.526 4.58 2.6 4.58 4.58v6.8c 2.53-2.54 4.58-4.58 4.58" fill="%23"/><path d="M26.2 17.935c-1.453 -2.636 1.183-2.636 2.638v6.8c 1.455 1.183 2.638 2.637 2.638 1.46 2.64-1.18 2.64-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.8c 2.53-2.5 4.58-4.58 4.58m-1.65 7.36h-5.14v-1.95h5.14c1.46 2.64-1.18 2.64-2.63s-1.18-2.633-2.64-2.633H4.59c-1.454 -2.637 1.183-2.637 2.637H.1c-2.524 2.55-4.58 4.58-4.58h1.96c2.526 4.58 2.56 4.58 4.58 2.527-2.54 4.58-4.58 4.58" fill="%23"/><path d="M15.36 49.895c-4.86 -7.94-1.62-1.85-4.51C1.63 42.475 38.62 34.535V2.99h1.955v13.545c 3.564 1.4 6.926 3.94 9.466 2.538 2.54 5.9 3.94 9.466 3.94 3.57 6.93-1.4 9.47-3.94s3.94-5.9 3.94-9.46V2.99h1.96v13.545c 4.87-1.6 7.94-4.51 1.85-2.91 2.98-6.76 4.51-1.85 4.51" fill="%23"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_avclub_on.f_article_split_on .scroll-list-break{border-top:3px solid #1c263c}.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#91dbd9;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-avclub .post-content .quotable a,.f_branding_on .blog-group-avclub .post-content .quotable a,.f_branding_on.blog-group-avclub .post-content footer a,.f_branding_on .blog-group-avclub .post-content footer a,.f_branding_on.blog-group-avclub .post-content h1 a,.f_branding_on .blog-group-avclub .post-content h1 a,.f_branding_on.blog-group-avclub .post-content h2 a,.f_branding_on .blog-group-avclub .post-content h2 a,.f_branding_on.blog-group-avclub .post-content h3 a,.f_branding_on .blog-group-avclub .post-content h3 a,.f_branding_on.blog-group-avclub .post-content h4 a,.f_branding_on .blog-group-avclub .post-content h4 a,.f_branding_on.blog-group-avclub .post-content h5 a,.f_branding_on .blog-group-avclub .post-content h5 a,.f_branding_on.blog-group-avclub .post-content h6 a,.f_branding_on .blog-group-avclub .post-content h6 a,.f_branding_on.blog-group-avclub .post-content li a,.f_branding_on .blog-group-avclub .post-content li a,.f_branding_on.blog-group-avclub .post-content p a,.f_branding_on .blog-group-avclub .post-content p a,.f_branding_on.f_branding_avclub_on .post-content .quotable a,.f_branding_on.f_branding_avclub_on .post-content footer a,.f_branding_on.f_branding_avclub_on .post-content h1 a,.f_branding_on.f_branding_avclub_on .post-content h2 a,.f_branding_on.f_branding_avclub_on .post-content h3 a,.f_branding_on.f_branding_avclub_on .post-content h4 a,.f_branding_on.f_branding_avclub_on .post-content h5 a,.f_branding_on.f_branding_avclub_on .post-content h6 a,.f_branding_on.f_branding_avclub_on .post-content li a,.f_branding_on.f_branding_avclub_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #e33af5;box-shadow:inset -2px #e33af5;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-avclub .post-content .quotable a:hover,.f_branding_on .blog-group-avclub .post-content .quotable a:hover,.f_branding_on.blog-group-avclub .post-content footer a:hover,.f_branding_on .blog-group-avclub .post-content footer a:hover,.f_branding_on.blog-group-avclub .post-content h1 a:hover,.f_branding_on .blog-group-avclub .post-content h1 a:hover,.f_branding_on.blog-group-avclub .post-content h2 a:hover,.f_branding_on .blog-group-avclub .post-content h2 a:hover,.f_branding_on.blog-group-avclub .post-content h3 a:hover,.f_branding_on .blog-group-avclub .post-content h3 a:hover,.f_branding_on.blog-group-avclub .post-content h4 a:hover,.f_branding_on .blog-group-avclub .post-content h4 a:hover,.f_branding_on.blog-group-avclub .post-content h5 a:hover,.f_branding_on .blog-group-avclub .post-content h5 a:hover,.f_branding_on.blog-group-avclub .post-content h6 a:hover,.f_branding_on .blog-group-avclub .post-content h6 a:hover,.f_branding_on.blog-group-avclub .post-content li a:hover,.f_branding_on .blog-group-avclub .post-content li a:hover,.f_branding_on.blog-group-avclub .post-content p a:hover,.f_branding_on .blog-group-avclub .post-content p a:hover,.f_branding_on.f_branding_avclub_on .post-content .quotable a:hover,.f_branding_on.f_branding_avclub_on .post-content footer a:hover,.f_branding_on.f_branding_avclub_on .post-content h1 a:hover,.f_branding_on.f_branding_avclub_on .post-content h2 a:hover,.f_branding_on.f_branding_avclub_on .post-content h3 a:hover,.f_branding_on.f_branding_avclub_on .post-content h4 a:hover,.f_branding_on.f_branding_avclub_on .post-content h5 a:hover,.f_branding_on.f_branding_avclub_on .post-content h6 a:hover,.f_branding_on.f_branding_avclub_on .post-content li a:hover,.f_branding_on.f_branding_avclub_on .post-content p a:hover,.f_branding_on.blog-group-avclub figcaption a,.f_branding_on .blog-group-avclub figcaption a,.f_branding_on.f_branding_avclub_on figcaption a{color:#948a3}.f_branding_on.blog-group-avclub figcaption a:hover,.f_branding_on .blog-group-avclub figcaption a:hover,.f_branding_on.f_branding_avclub_on figcaption a:hover{color:#68672}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on.blog-group-avclub .entry-content blockquote,.f_branding_on .blog-group-avclub .entry-content blockquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_avclub_on .entry-content blockquote{border-radius:;border-left:5px solid #1c263c;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before,.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-avclub .entry-content .pullquote__content,.f_branding_on .blog-group-avclub .entry-content .pullquote__content,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_avclub_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-avclub .review-score,.f_branding_on .blog-group-avclub .review-score,.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_avclub_on .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1c263c}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white){color:#948a3;border-color:#948a3}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white):hover{color:#68672;border-color:#68672}.f_branding_on.blog-group-avclub .author-bio__name,.f_branding_on .blog-group-avclub .author-bio__name,.f_branding_on.f_branding_avclub_on .author-bio__name{color:#222}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name){color:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover{color:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#68672}.f_branding_on.blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_avclub_on .sidebar-content .newsletter-subscribe{border-color:#1c263c}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on.blog-group-avclub .entry-content .pullquote,.f_branding_on .blog-group-avclub .entry-content .pullquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_avclub_on .entry-content .pullquote{border:2px solid #91dbd9;padding:3px;position:relative;font-weight:normal;font-style:normal}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before{height:3px;width:4px;position:absolute;left:-14px;top:-14px;background-repeat:no-repeat;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="23" viewBox=" 33 23" xmlns="http://www.w3.org/2/svg"><title>avc-pq<\/title><path d="M22.725 4.39c-1.4 1.14-1.763 2.345-2.157 3.61-.274.894-.41 1.736-.41 2.53 .496.6 1.55.186 1.674 1.362-1.586 3.223-2.38 5.58-2.38 2.3 3.657.577 4.872 1.727 1.213 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.38 1.86-5.17 1.86-1.34 -2.53-.243-3.57-.723-1.43-.487-1.86-1.187-2.455-2.13-.573-.745-1.3-1.76-1.377-3.5-.348-1.29-.52-2.69-.52-4.24 -2.652.682-5.94 2.44-7.326 1.362-2.23 3.37-3.956 6.25-5.17l.67 1.376c-1.34.62-2.53 1.52-3.57 2.64m-17.518 C4.165 5.53 3.447 6.734 3.5 8c-.274.894-.41 1.736-.41 2.53 .496.62 1.55.188 1.674 1.362-1.586 3.22-2.38 5.578-2.38 2.32 3.66.577 4.872 1.727 1.215 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.5 1.86-5.28 1.86-1.315 -2.492-.243-3.533-.723-1.48-.487-1.86-1.187-2.46-2.13-.57-.77-1.35-1.795-1.395-3.7C.18 15.78 14.382 12.87c-2.653.69-5.95 2.62-7.327 1.38-2.23 3.392-3.956 6.47-5.17l.66 1.377c-1.338.62-2.53 1.5-3.57 2.64" fill="%231C263C" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-a{min-width:18px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="18" height="11" viewBox=" 18 11" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-a<\/title><g fill="none" fill-rule="evenodd"><path fill="%231C263C" d="M4.63 L 1.56h9.59"/><path fill="%2391DBD9" d="M7.8 l4.784 1.56L17.658.3"/><\/g><\/svg>')}.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{min-width:162px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="162" height="13" viewBox=" 162 13" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path fill="%23948A3" d="M93.427 6.925h67.595V6.14H93.427M 6.925h67.595V6.14H"/><path d="M86.664 6.216c 3.433-2.783 6.216-6.216 6.215-3.433 -6.216-2.78-6.216-6.213S77.15 8.448 c3.433 6.216 2.783 6.216 6.216" fill="%23E6E6E6"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theonion_on.f_article_split_on .scroll-list-break{border-top:3px solid #6b3a}.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94d1b4;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theonion .post-content .quotable a,.f_branding_on .blog-group-theonion .post-content .quotable a,.f_branding_on.blog-group-theonion .post-content footer a,.f_branding_on .blog-group-theonion .post-content footer a,.f_branding_on.blog-group-theonion .post-content h1 a,.f_branding_on .blog-group-theonion .post-content h1 a,.f_branding_on.blog-group-theonion .post-content h2 a,.f_branding_on .blog-group-theonion .post-content h2 a,.f_branding_on.blog-group-theonion .post-content h3 a,.f_branding_on .blog-group-theonion .post-content h3 a,.f_branding_on.blog-group-theonion .post-content h4 a,.f_branding_on .blog-group-theonion .post-content h4 a,.f_branding_on.blog-group-theonion .post-content h5 a,.f_branding_on .blog-group-theonion .post-content h5 a,.f_branding_on.blog-group-theonion .post-content h6 a,.f_branding_on .blog-group-theonion .post-content h6 a,.f_branding_on.blog-group-theonion .post-content li a,.f_branding_on .blog-group-theonion .post-content li a,.f_branding_on.blog-group-theonion .post-content p a,.f_branding_on .blog-group-theonion .post-content p a,.f_branding_on.f_branding_theonion_on .post-content .quotable a,.f_branding_on.f_branding_theonion_on .post-content footer a,.f_branding_on.f_branding_theonion_on .post-content h1 a,.f_branding_on.f_branding_theonion_on .post-content h2 a,.f_branding_on.f_branding_theonion_on .post-content h3 a,.f_branding_on.f_branding_theonion_on .post-content h4 a,.f_branding_on.f_branding_theonion_on .post-content h5 a,.f_branding_on.f_branding_theonion_on .post-content h6 a,.f_branding_on.f_branding_theonion_on .post-content li a,.f_branding_on.f_branding_theonion_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #94d1b4;box-shadow:inset -2px #94d1b4;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theonion .post-content .quotable a:hover,.f_branding_on .blog-group-theonion .post-content .quotable a:hover,.f_branding_on.blog-group-theonion .post-content footer a:hover,.f_branding_on .blog-group-theonion .post-content footer a:hover,.f_branding_on.blog-group-theonion .post-content h1 a:hover,.f_branding_on .blog-group-theonion .post-content h1 a:hover,.f_branding_on.blog-group-theonion .post-content h2 a:hover,.f_branding_on .blog-group-theonion .post-content h2 a:hover,.f_branding_on.blog-group-theonion .post-content h3 a:hover,.f_branding_on .blog-group-theonion .post-content h3 a:hover,.f_branding_on.blog-group-theonion .post-content h4 a:hover,.f_branding_on .blog-group-theonion .post-content h4 a:hover,.f_branding_on.blog-group-theonion .post-content h5 a:hover,.f_branding_on .blog-group-theonion .post-content h5 a:hover,.f_branding_on.blog-group-theonion .post-content h6 a:hover,.f_branding_on .blog-group-theonion .post-content h6 a:hover,.f_branding_on.blog-group-theonion .post-content li a:hover,.f_branding_on .blog-group-theonion .post-content li a:hover,.f_branding_on.blog-group-theonion .post-content p a:hover,.f_branding_on .blog-group-theonion .post-content p a:hover,.f_branding_on.f_branding_theonion_on .post-content .quotable a:hover,.f_branding_on.f_branding_theonion_on .post-content footer a:hover,.f_branding_on.f_branding_theonion_on .post-content h1 a:hover,.f_branding_on.f_branding_theonion_on .post-content h2 a:hover,.f_branding_on.f_branding_theonion_on .post-content h3 a:hover,.f_branding_on.f_branding_theonion_on .post-content h4 a:hover,.f_branding_on.f_branding_theonion_on .post-content h5 a:hover,.f_branding_on.f_branding_theonion_on .post-content h6 a:hover,.f_branding_on.f_branding_theonion_on .post-content li a:hover,.f_branding_on.f_branding_theonion_on .post-content p a:hover{color:#94d1b4}.f_branding_on.blog-group-theonion figcaption a,.f_branding_on .blog-group-theonion figcaption a,.f_branding_on.f_branding_theonion_on figcaption a{color:#6b3a}.f_branding_on.blog-group-theonion figcaption a:hover,.f_branding_on .blog-group-theonion figcaption a:hover,.f_branding_on.f_branding_theonion_on figcaption a:hover{color:#381e}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on.blog-group-theonion .entry-content blockquote,.f_branding_on .blog-group-theonion .entry-content blockquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theonion_on .entry-content blockquote{border-radius:;border-left:5px solid #94d1b4;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theonion .review-score,.f_branding_on .blog-group-theonion .review-score,.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theonion_on .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white){color:#6b3a;border-color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white):hover{color:#381e;border-color:#381e}.f_branding_on.blog-group-theonion .author-bio__name,.f_branding_on .blog-group-theonion .author-bio__name,.f_branding_on.f_branding_theonion_on .author-bio__name{color:#222}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name){color:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover{color:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#381e}.f_branding_on.blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theonion_on .sidebar-content .newsletter-subscribe{border-color:#94d1b4}.f_branding_on.blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_earther_on.f_article_split_on .scroll-list-break{border-top:3px solid #75b2}.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#75b2;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-earther .post-content .inset--story__headline a,.f_branding_on .blog-group-earther .post-content .inset--story__headline a,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-earther .post-content .quotable a,.f_branding_on .blog-group-earther .post-content .quotable a,.f_branding_on.blog-group-earther .post-content footer a,.f_branding_on .blog-group-earther .post-content footer a,.f_branding_on.blog-group-earther .post-content h1 a,.f_branding_on .blog-group-earther .post-content h1 a,.f_branding_on.blog-group-earther .post-content h2 a,.f_branding_on .blog-group-earther .post-content h2 a,.f_branding_on.blog-group-earther .post-content h3 a,.f_branding_on .blog-group-earther .post-content h3 a,.f_branding_on.blog-group-earther .post-content h4 a,.f_branding_on .blog-group-earther .post-content h4 a,.f_branding_on.blog-group-earther .post-content h5 a,.f_branding_on .blog-group-earther .post-content h5 a,.f_branding_on.blog-group-earther .post-content h6 a,.f_branding_on .blog-group-earther .post-content h6 a,.f_branding_on.blog-group-earther .post-content li a,.f_branding_on .blog-group-earther .post-content li a,.f_branding_on.blog-group-earther .post-content p a,.f_branding_on .blog-group-earther .post-content p a,.f_branding_on.f_branding_earther_on .post-content .quotable a,.f_branding_on.f_branding_earther_on .post-content footer a,.f_branding_on.f_branding_earther_on .post-content h1 a,.f_branding_on.f_branding_earther_on .post-content h2 a,.f_branding_on.f_branding_earther_on .post-content h3 a,.f_branding_on.f_branding_earther_on .post-content h4 a,.f_branding_on.f_branding_earther_on .post-content h5 a,.f_branding_on.f_branding_earther_on .post-content h6 a,.f_branding_on.f_branding_earther_on .post-content li a,.f_branding_on.f_branding_earther_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-earther .post-content .quotable a:hover,.f_branding_on .blog-group-earther .post-content .quotable a:hover,.f_branding_on.blog-group-earther .post-content footer a:hover,.f_branding_on .blog-group-earther .post-content footer a:hover,.f_branding_on.blog-group-earther .post-content h1 a:hover,.f_branding_on .blog-group-earther .post-content h1 a:hover,.f_branding_on.blog-group-earther .post-content h2 a:hover,.f_branding_on .blog-group-earther .post-content h2 a:hover,.f_branding_on.blog-group-earther .post-content h3 a:hover,.f_branding_on .blog-group-earther .post-content h3 a:hover,.f_branding_on.blog-group-earther .post-content h4 a:hover,.f_branding_on .blog-group-earther .post-content h4 a:hover,.f_branding_on.blog-group-earther .post-content h5 a:hover,.f_branding_on .blog-group-earther .post-content h5 a:hover,.f_branding_on.blog-group-earther .post-content h6 a:hover,.f_branding_on .blog-group-earther .post-content h6 a:hover,.f_branding_on.blog-group-earther .post-content li a:hover,.f_branding_on .blog-group-earther .post-content li a:hover,.f_branding_on.blog-group-earther .post-content p a:hover,.f_branding_on .blog-group-earther .post-content p a:hover,.f_branding_on.f_branding_earther_on .post-content .quotable a:hover,.f_branding_on.f_branding_earther_on .post-content footer a:hover,.f_branding_on.f_branding_earther_on .post-content h1 a:hover,.f_branding_on.f_branding_earther_on .post-content h2 a:hover,.f_branding_on.f_branding_earther_on .post-content h3 a:hover,.f_branding_on.f_branding_earther_on .post-content h4 a:hover,.f_branding_on.f_branding_earther_on .post-content h5 a:hover,.f_branding_on.f_branding_earther_on .post-content h6 a:hover,.f_branding_on.f_branding_earther_on .post-content li a:hover,.f_branding_on.f_branding_earther_on .post-content p a:hover,.f_branding_on.blog-group-earther figcaption a,.f_branding_on .blog-group-earther figcaption a,.f_branding_on.f_branding_earther_on figcaption a{color:#75b2}.f_branding_on.blog-group-earther figcaption a:hover,.f_branding_on .blog-group-earther figcaption a:hover,.f_branding_on.f_branding_earther_on figcaption a:hover{color:#537f}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote,.f_branding_on.blog-group-earther .entry-content blockquote,.f_branding_on .blog-group-earther .entry-content blockquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_earther_on .entry-content blockquote{border-radius:;border-left:5px solid #75b2;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-earther .review-score,.f_branding_on .blog-group-earther .review-score,.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_earther_on .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white){color:#75b2;border-color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white):hover{color:#537f;border-color:#537f}.f_branding_on.blog-group-earther .author-bio__name,.f_branding_on .blog-group-earther .author-bio__name,.f_branding_on.f_branding_earther_on .author-bio__name{color:#222}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name){color:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover{color:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#537f}.f_branding_on.blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_earther_on .sidebar-content .newsletter-subscribe{border-color:#75b2}.storytype--box{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;margin-bottom:1.5rem}.storytype--box__text{padding:}.storytype--box__title{margin:}.storytype--box__description{font-family:"ElizabethSerif",Georgia,serif;font-size:14px;line-height:1.5;color:#666;margin-top:.5rem}@media only screen and (max-width: 37.438em){.storytype--box__description{margin-bottom:1.5rem}}.storytype--box__asset img{display:block;width:1%}.storytype--box.storytype--box__wrap{margin-bottom:2.5rem;padding:1.125rem ;background-color:#f5f5f5}.storytype--box.storytype--box__wrap .storytype--box__text{padding: 1.125rem}@media only screen and (min-width: 37.5em){.storytype__content .postlist__item--compact{padding-left:1.125rem}.storytype__content .postlist__item--compact .item__content--thumb .asset{padding-left:}}.storytype--nav{margin: -16px;min-height:calc(36px + 2rem)}@media only screen and (max-width: 37.438em){.storytype--nav{min-height:calc(36px + 2rem)}}@media only screen and (max-width: 37.438em){.storytype--nav--two-dropdowns{min-height:calc(36px * 2 + 1rem + 2rem)}}.storytype--nav__categoryselector,.storytype--nav__subcategoryselector{margin-bottom:2rem}@media only screen and (max-width: 37.438em){.storytype--nav__subcategoryselector{margin-top:-1rem}}.storytype--nav .select-component-list{max-height:3px;overflow-y:scroll}.storytype--nav .select-component-list ul{overflow-y:hidden}@media only screen and (max-width: 37.438em){.storytype--section{margin-left:-1.125rem;margin-right:-1.125rem}}.storytype--section header{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;border-bottom:1px solid #e5e5e5;margin-bottom:15px}@media only screen and (max-width: 37.438em){.storytype--section header{margin-left:1.125rem;margin-right:1.125rem}}.storytype--section header h2{margin-bottom:5px}.storytype--section header h2 a{color:#}.storytype--section__viewall{text-transform:uppercase;display:inline-block;-ms-flex-item-align:center;align-self:center}.storytype--section__wrapper{margin-bottom:3rem}@media only screen and (max-width: 37.438em){.storytype--section__wrapper{width:1%;overflow-x:scroll;padding-left:1.125rem}}.storytype--section__items{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:nowrap;flex-wrap:nowrap;-webkit-box-pack:start;-ms-flex-pack:start;justify-content:flex-start}.storytype--section__item{width:31.8%;position:relative;-ms-flex-negative:;flex-shrink:;margin-right:1.125rem}.storytype--section__item:last-of-type{margin-right:}@media only screen and (max-width: 37.438em){.storytype--section__item{width:2px;margin-right:1.125rem}.storytype--section__item:last-of-type{width:218px;padding-right:1.125rem}}.storytype--section .item__image{display:block;margin-bottom:1px}.storytype--section .headline{margin-bottom:}.storytype-label{font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:bold;padding-right:1px;text-transform:uppercase;color:#93ec}.storytype-label:hover{color:#73b9;text-decoration:none}.storytype-label:hover.storytype-label--white{background-color:#ffffff;color:#}.storytype-label--white{color:#ffffff}.storytype-label--outlined{border:1px solid #93ec;line-height:27px;margin-right:5px;height:27px;padding: 8px}.storytype-label--outlined.storytype-label--white{border-color:#ffffff;color:white}.storytype-label-wrapper{display:-webkit-box;display:-ms-flexbox;display:flex;max-width:1%;overflow:hidden}.storytype-label-wrapper--small-margin{margin-bottom:5px}.storytype-label-wrapper--medium-margin{margin-bottom:1px}.storytype-label-wrapper--large-margin{margin-bottom:15px}.storytype-label-wrapper--huge-margin{margin-bottom:2px}@media only screen and (max-width: 53.125em){.storytype-label-wrapper--curation{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;padding: 18px}}.storytype-label-wrapper .storytype-label{overflow:hidden;text-overflow:ellipsis;white-space:nowrap}.storytype-label-wrapper :last-child{margin-right:}.postlist__item--compact{margin-bottom:3px;padding-bottom:3px;border-bottom:1px solid #e5e5e5}.postlist__item--compact:last-of-type{border-bottom:;margin-bottom:}.postlist__item--compact .item__content{margin: -1.125rem;max-width:none;width:auto}.postlist__item--compact .item__content:after,.postlist__item--compact .item__content:before{content:" ";display:table}.postlist__item--compact .item__content:after{clear:both}.postlist__item--compact .item__text{padding-left:1.125rem;padding-right:1.125rem;float:left}@media only screen and (min-width: 37.5em){.postlist__item--compact .item__content--thumb .asset{padding-left:1.125rem;padding-right:1.125rem;width:33.333%;float:left;margin-bottom:}.postlist__item--compact .item__content--thumb .item__text{padding-left:1.125rem;padding-right:1.125rem;width:66.667%;float:left;padding-left:}}.postlist__item--compact .asset{width:1%;position:relative;margin: 2px}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{padding:}}.postlist__item--compact .asset img{width:1%}.postlist__item--compact .asset img[data-sizes=auto],.postlist__item--compact .asset video[data-sizes=auto]{display:block;width:1%}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{float:none}}.postlist__item--compact .headline{font-size:24px;margin-bottom:5px}html.fallback-fonts .postlist__item--compact .headline{font-family:"Arial Narrow",Arial,sans-serif;font-size:22.68px;line-height:1.349;letter-spacing:.5px}.postlist__item--compact .meta--pe{display:block;margin-bottom:7px}.postlist__item--compact .meta__container{font-size:15px}.postlist__item--compact .meta__byline,.postlist__item--compact .meta__time{display:inline-block}.postlist__item--compact .meta__byline:after{display:inline-block;content:'*';color:#aaa;padding: 5px}.postlist__item--compact .meta__right{display:none}.postlist__item--compact .excerpt{font-family:"ElizabethSerif",Georgia,serif}.postlist__item--compact .excerpt p{margin-bottom:}</style><script>window._K_MSGS = []; window._K_MSG_L = function (e) {_K_MSGS.push(e);}; window.addEventListener('message', window._K_MSG_L);</script><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/blog-2545d75c35bc9d9491eb61d4b29724.css" as="style" onload="this.rel='stylesheet'"><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/insets-13541366ddfac4e8eca127496e.css" as="style" onload="this.rel='stylesheet'"><script src="https://kinja.com/api/profile/accountwithtoken?jsonp=_fasttoken&newFollows=true" async defer></script><meta name="dynamic-stylesheet" id="editor-css-url" content="//x.kinja-static.com/assets/stylesheets/editor-7ed31791155c6bedc63fda5ded339b2.css"><meta name="google-site-verification" content="P13oAn8o8LB6FVCJWKsHWXvxfbR-SJrmvox6EgULpUs" /><meta name="viewport" content="width=device-width, initial-scale=1., minimum-scale=1.,maximum-scale=1." /><meta name="ROBOTS" content="INDEX, FOLLOW" /><title>The 218 Ford F-15 Gets A New Engine And More Horsepower
2014 intro...
storybreak stars<\/title><path d="M5.146 9.1l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953L5.147 H3.76l.158 3.623L.893 1.67.2 2.867l3.214 1.638L.2 6.175l.693 1.197 3.25-1.985L3.76 9.1m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H23.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H43.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623" fill="%23CCC" fill-rule="evenodd"/><\/svg>');background-repeat:no-repeat;background-position:center}.editor .editor-inner div.legacy-raw-html,.post-content div.legacy-raw-html{border:3px solid #eeb544;padding:5px;margin-bottom:2px}.editor .editor-inner div.legacy-raw-html:before,.post-content div.legacy-raw-html:before{content:'Before this post can be saved, this block must be removed.';font-size:12px;display:inline-block}.editor .editor-inner div.legacy-raw-html table,.post-content div.legacy-raw-html table{margin-bottom:}.f_dap_tables_on .editor .editor-inner table,.f_dap_tables_on .post-content table,.f_use_dap .editor .editor-inner table,.f_use_dap .post-content table{font-family:"ProximaNovaCond",sans-serif;border:1px solid #e5e5e5;width:1%;margin-bottom:1.5rem;border-spacing:}.f_dap_tables_on .editor .editor-inner table td,.f_dap_tables_on .editor .editor-inner table th,.f_dap_tables_on .post-content table td,.f_dap_tables_on .post-content table th,.f_use_dap .editor .editor-inner table td,.f_use_dap .editor .editor-inner table th,.f_use_dap .post-content table td,.f_use_dap .post-content table th{padding:1px;text-align:left;border:;border-right:1px solid #fff}.f_dap_tables_on .editor .editor-inner table td:last-child,.f_dap_tables_on .editor .editor-inner table th:last-child,.f_dap_tables_on .post-content table td:last-child,.f_dap_tables_on .post-content table th:last-child,.f_use_dap .editor .editor-inner table td:last-child,.f_use_dap .editor .editor-inner table th:last-child,.f_use_dap .post-content table td:last-child,.f_use_dap .post-content table th:last-child{border-right:}.f_dap_tables_on .editor .editor-inner table tr:nth-child(2n) td,.f_dap_tables_on .post-content table tr:nth-child(2n) td,.f_use_dap .editor .editor-inner table tr:nth-child(2n) td,.f_use_dap .post-content table tr:nth-child(2n) td{background-color:#f5f5f5}.above-headline-image .featured-post__caption,.above-headline-image .video-embed__caption,.above-headline-image figcaption,.editor .editor-inner .featured-post__caption,.editor .editor-inner .video-embed__caption,.editor .editor-inner figcaption,.featured-post__asset .featured-post__caption,.featured-post__asset .video-embed__caption,.featured-post__asset figcaption,.post-content .featured-post__caption,.post-content .video-embed__caption,.post-content figcaption{position:relative;font-family:"ProximaNovaCond",sans-serif;color:#aaa;font-size:15px;line-height:21px;text-align:left;margin-top:.5rem;display:block}.above-headline-image .featured-post__caption:focus,.above-headline-image .video-embed__caption:focus,.above-headline-image figcaption:focus,.editor .editor-inner .featured-post__caption:focus,.editor .editor-inner .video-embed__caption:focus,.editor .editor-inner figcaption:focus,.featured-post__asset .featured-post__caption:focus,.featured-post__asset .video-embed__caption:focus,.featured-post__asset figcaption:focus,.post-content .featured-post__caption:focus,.post-content .video-embed__caption:focus,.post-content figcaption:focus{outline:none}.above-headline-image .video-embed__caption,.editor .editor-inner .video-embed__caption,.featured-post__asset .video-embed__caption,.post-content .video-embed__caption{margin-top:-.5rem}.above-headline-image .featured-post__caption,.editor .editor-inner .featured-post__caption,.featured-post__asset .featured-post__caption,.post-content .featured-post__caption{position:absolute;top:1%}.ad-unit--featured-recirculation{opacity:1;pointer-events:auto;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;z-index:97}.ad-unit--featured-recirculation .ad-container{background:#f5f5f5;width:3px;height:25px}.ad-unit--featured-recirculation .ad-container--hidden{opacity:;pointer-events:none;visibility:hidden}.ad-unit--fixed-bottom{position:fixed;bottom:3.5rem;right:1.125rem;height:auto;width:3px;opacity:1;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;pointer-events:auto}.ad-unit--fixed-bottom--invisible{opacity:;pointer-events:none}.ad-unit--fixed-bottom .ad-container{background:#f5f5f5;width:3px;height:25px}.editor .editor-inner .has-image.align--center.media-large{max-width:636px}.shared{margin-bottom:3.4rem}.shared .content-wrapper{background-color:#f5f5f5;padding-top:24px;border:1px #aaa solid}.shared .referenced-label{background-color:#f5f5f5}.shared .reframe-post{margin-bottom:1.875rem}.post .linked,.post .recommend{background-color:rgba(,,,.7);position:absolute;cursor:pointer;top:8px;right:8px;width:32px;height:32px;opacity:;-webkit-transition:all .15s ease-out;transition:all .15s ease-out;border-radius:5px;z-index:1}.post .linked{bottom:;border-top-left-radius:5px}.post .flex-video:hover .recommend,.post .has-image:hover .linked,.post .has-image:hover .recommend,.post figure:hover .linked,.post figure:hover .recommend{opacity:1}.post .has-image .recommend{right:8px}.post .movementventures,.post .qzzr{width:1%}.post a[x-inset=hidden]{display:none}.pullquote{margin-bottom:2rem;margin-top:2rem;text-align:center;padding:1px ;font-family:"ProximaNovaCond",sans-serif;font-weight:lighter;font-style:italic;font-size:25px;line-height:37px;clear:left}.pullquote:after,.pullquote:before{content:'';display:block;width:45px;height:;margin: auto;position:relative;border-top-width:1px;border-top-style:solid;border-color:#aaa}.pullquote:before{margin-bottom:2px}.pullquote:after{margin-top:2px}@media only screen and (min-width: 37.5em){.pullquote.align--left{width:4%;max-width:32px;float:left;margin-right:2.25rem;text-align:left;margin-bottom:.5em;margin-top:}.pullquote.align--left:after,.pullquote.align--left:before{margin-left:;margin-right:}}.pullquote__helper{display:none}.commentlist .pullquote,.quickreply .pullquote{margin-bottom:1em;margin-top:1em;text-align:left;padding: 1.125rem;font-size:22px;line-height:3px;position:relative}.commentlist .pullquote:before,.quickreply .pullquote:before{position:absolute;left:;top:3px;bottom:5px;width:;height:auto;border-top:;border-left-width:1px;border-left-style:solid;margin:}.commentlist .pullquote:after,.quickreply .pullquote:after{display:none}.post-content .inset--story{clear:both;margin:2rem auto;padding:1.125rem;border:#e5e5e5 1px solid;border-radius:5px;-webkit-box-shadow:#e5e5e5 2px 5px;box-shadow:#e5e5e5 2px 5px;max-width:636px}.post-content .inset--story p{font-size:15px;line-height:25px;margin-bottom:.6rem}@media only screen and (min-width: 37.5em){.post-content .inset--story{display:-webkit-box;display:-ms-flexbox;display:flex}}.post-content .inset--story__thumb{display:block;position:relative;margin:-1.125rem -1.125rem 1rem}@media only screen and (min-width: 37.5em){.post-content .inset--story__thumb{width:25%;min-width:25%;margin: 1.125rem ;float:left}}.post-content .inset--story__thumb figure{margin:;position:relative}.post-content .inset--story__thumb img{width:1%}.post-content .inset--story__headline{font-size:2px;line-height:24px;margin-bottom:1px}.post-content .inset--story__headline a,.post-content .inset--story__headline a:hover{color:#}.post-content .inset--story__readmore{font-family:"ProximaNovaCond",sans-serif;font-size:16px}.post-content .inset--story__readmore .hostname{font-weight:bold}.non-secure-iframe-embed{position:relative;padding-bottom:56.25%}.iframe-container{position:absolute;top:;left:;height:1%;width:1%}.iframe-container__external-source{height:92.5%;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;background-color:#e5e5e5}@media only screen and (max-width: 37.438em){.iframe-container__external-source{position:relative}}.iframe-container__external-source svg{opacity:.1}.iframe-container__external-source img{position:absolute;top:;left:;width:1%;opacity:.8}@media only screen and (max-width: 37.438em){.iframe-container__external-source img{position:relative}}.iframe-container__link-to-source{position:absolute;top:25px;right:25px}.iframe-container__link-to-source svg{opacity:.7;fill:#fff}.iframe-container__message{position:absolute;bottom:;height:7.5%;width:1%;background:#fff;color:#aaa;font-size:15px}@media only screen and (max-width: 37.438em){.iframe-container__message{position:absolute;height:auto}}.iframe-container__message p{position:absolute;font-family:"ProximaNovaCond", sans-serif;bottom:;margin:;font-size:15px;text-align:left}@media only screen and (max-width: 37.438em){.iframe-container__message p{position:relative}}.iframe-container__message a{text-decoration:none;color:#93ec}.google-adx .container{background-color:#f5f5f5;line-height:18px;padding:5px 1.125rem}.google-adx .by-google{color:#;font-size:14px}.google-adx .google-headline{color:#333}.post-bottom{margin: -1.125rem;max-width:none;width:auto}.post-bottom:after,.post-bottom:before{content:" ";display:table}.post-bottom:after{clear:both}@media only screen and (max-width: 37.438em){.post-bottom{margin:2rem 1rem}}@media only screen and (min-width: 37.5em){.post-bottom{margin:1.5rem }}.post-bottom .post-bottom__inner{max-width:636px;margin: auto}.post-bottom,.post-bottom a{color:#777}.post-bottom .fb-like{float:left;z-index:4;width:auto}.post-bottom .reply-to-post{color:#aaa}.post-bottom .reply-to-post .icon{margin-left:7px}.post-bottom .icon{opacity:.3;margin-left:5px;vertical-align:middle}.private-post-list{border-bottom:2px #aaa solid}.stream{padding-bottom:}.stream .meta .publish-time .icon{margin: 5px}.stream .post-dropdown-ct{display:none}.unshare-bloglist{position:absolute;top:;right:;z-index:1}.unshare-bloglist .unshare-bloglist-select,.unshare-bloglist .unshare-bloglist-title{display:inline-block;vertical-align:middle}.unshare-bloglist .unshare-bloglist-title{padding: 3px;background-color:#fff;margin: 1px }.unshare-bloglist .unshare-bloglist-select{margin-bottom:}.text-red{color:#eeb544}.post-tools-wrapper .reply-to-post__container .svg-icon{margin-left:;position:relative;top:2px}@media only screen and (max-width: 37.438em){.post-tools-wrapper .reply-to-post__container{display:none}}@media only screen and (max-width: 37.438em){.post-tools-wrapper{-webkit-box-flex:1;-moz-flex:1 1 1%;-ms-flex:1 1 1%;flex:1 1 1%;-webkit-box-ordinal-group:3;-moz-order:2;-ms-flex-order:2;order:2;margin:3px 14px}}@media only screen and (max-width: 37.438em){.post-tools-wrapper .button-recommend-post,.post-tools-wrapper .reply-count{display:none}}.newsletter-subscribe-post{display:block;font-family:"ElizabethSerif",Georgia,serif;border-top:#e5e5e5 1px solid;margin:1.5rem ;max-width:636px}.newsletter-subscribe-post__copy{color:#aaa;margin:1.5rem 1rem;line-height:29px}.newsletter-subscribe-post .button{font-size:1.1rem;padding: 1.2rem}.newsletter-subscribe-post .svg-icon{opacity:1;fill:#93ec}.center{margin: auto}ul.commerce-inset.fake-list{margin-bottom:;margin-top:-2px}.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:4px;margin:.5rem 1.125rem .5rem }.asset.has-media.has-image.align--left.media-large{width:1%}.asset.has-media.has-image.media-large.align--center{max-width:636px}@media only screen and (max-width: 27.25rem){.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:1%}}@media only screen and (min-width: 37.5em){.asset.has-media.has-image{margin-left:auto;margin-right:auto;max-width:636px}.asset.has-media.has-image.media-large{margin-left:-1.125rem;margin-right:-1.125rem;max-width:initial}.asset.has-media.has-image.media-large.align--center{margin-left:auto;margin-right:auto}.asset.media-small.has-media.has-image:not(.align--center){margin-bottom:.5rem;margin-right:1.125rem}}@media only screen and (min-width: 53.126em){.asset.has-media.has-image.media-large{margin-left:auto;margin-right:auto}}.post-content{font-family:"ElizabethSerif",Georgia,serif}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper{position:relative;background:#f5f5f5}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper img{background:none}.post-content .has-image.has-image.media-large .img-wrapper,.post-content .has-image.has-image.media-medium .img-wrapper,.post-content .has-image.has-image.media-small .img-wrapper{max-width:1%}.post-content .has-image.has-image.media-large .img-wrapper img,.post-content .has-image.has-image.media-medium .img-wrapper img,.post-content .has-image.has-image.media-small .img-wrapper img{position:absolute;height:auto;top:;left:;right:;bottom:}.post-content .has-image.has-image.media-large .lightbox-wrapper,.post-content .has-image.has-image.media-medium .lightbox-wrapper,.post-content .has-image.has-image.media-small .lightbox-wrapper{display:block}.img-wrapper{max-width:1%}.old-post-type-img{display:block;margin:1.125rem auto}.gmg-text-ad{margin:2rem auto;max-width:636px;font-family:"ProximaNovaCond", sans-serif}.gmg-text-ad .text-ad__inner{border:1px solid #e5e5e5;border-left-width:;border-right-width:;padding:3px 18px 1px;position:relative;background-color:#f5f5f5}.gmg-text-ad .text-ad__inner:before{content:'Advertisement';text-transform:uppercase;position:absolute;top:;width:1%;text-align:center;color:#ccc;font-size:13px}.gmg-text-ad a{display:block;color:#}.gmg-text-ad a:hover{text-decoration:none}.gmg-text-ad .text-ad__headline{font-size:2px;line-height:24px;margin-bottom:5px;color:#}.gmg-text-ad a:hover .text-ad__headline{text-decoration:underline}.gmg-text-ad .text-ad__excerpt{font-family:"ElizabethSerif", Georgia, serif;font-size:15px;color:#333;line-height:26px;margin: 3px}.gmg-text-ad .text-ad__more{color:#ccc;font-size:15px}@-webkit-keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}@keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}.discussion-status-badge-wrapper{display:block;margin-bottom:2px}.discussion-status-badge-wrapper .discussion-status-badge{color:#fff;background-color:rgba(,,,.7);display:inline;padding:5px 1px}.discussion-status-badge{color:#ef774;line-height:24px;margin-bottom:12px;text-transform:uppercase}.discussion-status-badge:before{display:inline-block;content:'';width:11px;height:11px;background-color:#ef774;border-radius:11px;margin-right:5px;-webkit-animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite;animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite}.meta__tools .f-dropdown{text-align:left}.commerce-disclaimer{margin-bottom:2px;display:-webkit-box;display:-ms-flexbox;display:flex}.commerce-disclaimer:before{content:"";border-left:2px solid #72ad75;margin:4px 6px}.commerce-disclaimer span{padding-left:1px}.customkinja-backlink{max-width:636px;margin:2em auto}.customkinja-backlink:after,.customkinja-backlink:before{content:'';display:block;height:;width:auto;border-top-width:1px;border-top-style:solid;border-color:#ccc}.customkinja-backlink a{display:inline-block;padding:1em }.post__misc{clear:both}.permalink.featured-post .main{left:;padding:}.permalink.featured-post .entry-title{color:white;font-size:8.5vw;font-weight:normal;line-height:1.1;text-align:center;margin: auto;max-width:118px;width:1%}.permalink.featured-post .entry-title a{color:white}.permalink.featured-post .row.content-wrapper,.permalink.featured-post .post-wrapper{margin:}.permalink.featured-post .post{padding:}.permalink.featured-post .post .meta--pe{margin-bottom:;margin-left:auto;margin-right:auto;max-width:636px}.permalink.featured-post .post__misc{padding: 1.125rem}.permalink.featured-post .post--empty .meta--pe{margin-top: !important;margin-bottom: !important;padding-bottom:;border-top:;border-bottom:}.permalink.featured-post .post-content:not(.reply__content){margin-top:3px;padding: 1.125rem}.permalink.featured-post .ad-unit--in-post .ad-container{height:25px}.permalink.featured-post .entry-content.fixed{position:fixed;right:1px;top:}.permalink.featured-post .entry-content.unfixed{position:absolute;right:}.featured-post__sponsored-label{color:#aaa;font-size:13px;text-transform:uppercase}.featured-post__header{background:black;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-align:center;-ms-flex-align:center;align-items:center;position:relative}.featured-post__header .discussion-status-badge{font-size:.42em;margin:18px ;text-align:center}.featured-post__header.magazine{-webkit-box-align:initial;-ms-flex-align:initial;align-items:initial;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__asset-group{width:1%}.featured-post__header.magazine .featured-post__asset-group:after{display:none}.featured-post__header.magazine .featured-post__asset{padding:}.featured-post__header.magazine .featured-post__asset .featured-post__caption,.featured-post__header.magazine .featured-post__asset figcaption{display:none}.featured-post__header.magazine .featured-post__alternate-image-caption{display:block}.featured-post__header.magazine .featured-post__meta-container{display:none}.featured-post__header.magazine .featured-post__headline-container{width:1%}.featured-post__header.magazine .featured-post__headline-container-author{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__headline-container-author .meta--pe.secondary-byline{margin:;max-width:1%}.featured-post__header.magazine .featured-post__headline-container-author .meta__label--sponsored{color:#aaa}.featured-post__headline-container-author{width:1%}.featured-post__headline-container-author .meta--pe{margin-bottom:;padding-top:3px;width:1%}.featured-post__headline-container-author .meta--pe .svg-icon{opacity:1;stroke:#aaa}.featured-post__headline-container-author .meta--pe .svg-icon.stroked{stroke:#aaa}.featured-post__headline-container-author .meta--pe .meta__byline,.featured-post__headline-container-author .meta--pe .meta__byline a,.featured-post__headline-container-author .post-tags-container .first-tag span{color:white}.featured-post__headline-container{padding:2px}.featured-post__headline-container,.featured-post__headline-container .featured-post__headline-container-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:center;-ms-flex-align:center;align-items:center}.featured-post__meta-container,.featured-post__meta-container-alt{display:none;-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:1%}.featured-post__meta-container-alt .meta--pe,.featured-post__meta-container .meta--pe{border-top:1px solid #e5e5e5;border-bottom:1px solid #e5e5e5;margin:4px !important;max-width:636px;padding:4px ;width:1%}.featured-post__asset-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-ordinal-group:;-ms-flex-order:-1;order:-1;position:relative;width:1%}.featured-post__asset-group:after{background:white;bottom:;content:'';display:none;left:;height:25%;position:absolute;right:;width:1%}.featured-post__asset-group .featured-post__cover{height:1%;max-height:1%}.featured-post__asset{padding:;position:relative;width:1%;z-index:1}.featured-post__asset,.featured-post__asset.pillarboxed{background:transparent}.featured-post__asset img,.featured-post__asset video{width:1%}.featured-post__asset .featured-post__caption,.featured-post__asset figcaption{display:none;margin:auto;max-width:636px;padding:1px }.featured-post__asset .img-wrapper{background-size:cover}.featured-post__asset__container{height:calc(1vw*9/16);margin: auto;max-height:calc(85vh);max-width:calc(85vh*16/9);width:1%}.featured-post__asset__container.video-type--JwPlayer,.featured-post__asset__container.video-type--Mcp,.featured-post__asset__container.video-type--OnionStudios,.featured-post__asset__container.video-type--YoutubeVideo{position:relative;height:1%;max-height:1%;max-width:1%;width:1%}.featured-post__asset__container.video-type--JwPlayer:after,.featured-post__asset__container.video-type--Mcp:after,.featured-post__asset__container.video-type--OnionStudios:after,.featured-post__asset__container.video-type--YoutubeVideo:after{content:"";display:block;padding-top:56.25%;width:1%}.featured-post__asset__container.video-type--JwPlayer>iframe,.featured-post__asset__container.video-type--Mcp>iframe,.featured-post__asset__container.video-type--OnionStudios>iframe,.featured-post__asset__container.video-type--YoutubeVideo>iframe{bottom:;left:;position:absolute;right:;top:}.featured-post__asset__container iframe{height:1%;width:1%}.featured-post__cover{background-position:center;background-repeat:no-repeat;background-size:contain;cursor:pointer;height:calc(1vw*9/16);left:;max-height:calc(85vh);position:absolute;top:;width:1%}.featured-post__cover .play-icon{background:rgba(,,,.6);border-radius:5px;display:block;height:6px;left:calc(5% - 18px);position:absolute;top:calc(5% - 3px);width:56px}.featured-post__cover .svg-icon{height:6px;margin-top:;opacity:.8;width:56px}.featured-post__cover:hover .svg-icon{opacity:1}.featured-post__alternate-image-caption{color:#aaa;display:block;padding:1px 1.25rem }.featured-post__alternate-image-caption>div{margin:auto;max-width:636px}.featured-post__alternate-image-caption.magazine{display:block}@media only screen and (min-width: 768px){.permalink.featured-post .entry-title{font-size:6vw}}@media only screen and (min-width: 124px){.permalink.featured-post .post .post-content{margin:auto;margin-top:;max-width:124px;width:1%}.permalink.featured-post .ad-unit--in-post{display:none}.permalink.featured-post .entry-title{font-size:4vw}.permalink.featured-post .featured-post__alternate-image-caption{display:none}.permalink.featured-post .featured-post__alternate-image-caption.magazine{display:block}.featured-post__headline-container{padding:4px}.featured-post__header{margin-bottom:}.featured-post__header .featured-post__headline-container-author,.featured-post__header .featured-post__meta-container .featured-post__headline-container-author,.featured-post__header.magazine .featured-post__headline-container-author{display:none}.featured-post__header .featured-post__asset .featured-post__caption,.featured-post__header .featured-post__asset figcaption{display:block}.featured-post__header.magazine{-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row}.featured-post__header.magazine .entry-title{font-size:3vw}.featured-post__header.magazine .featured-post__asset-group{width:75%}.featured-post__header.magazine .featured-post__headline-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;min-width:35px;width:25%}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:start;-ms-flex-align:start;align-items:flex-start}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group h1{text-align:left}.featured-post__header.magazine .meta--pe{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .meta__right{margin-top:15px;right:;width:1%}.featured-post__header.magazine .meta__data--comment{margin-left:auto}.featured-post__header.magazine .featured-post__category-label-wrapper{margin-bottom:}.featured-post__meta-container-alt,.featured-post__meta-container{display:-webkit-box;display:-ms-flexbox;display:flex}.featured-post__meta-container{background:white}.featured-post__asset-group{-webkit-box-ordinal-group:initial;-ms-flex-order:initial;order:initial}.featured-post__asset-group:after{display:block}.featured-post__asset{padding: 2.5%}}@media only screen and (min-width: 18px){.permalink.featured-post .entry-title{font-size:3vw}.featured-post__header.magazine .entry-title{font-size:2.5vw}}.sharingfooter{position:fixed;bottom:;left:;right:;background:#fff;z-index:98;-webkit-box-shadow: 1px rgba(,,,.4);box-shadow: 1px rgba(,,,.4);height:38px;line-height:38px;vertical-align:middle;font-size:13px}html.fallback-fonts .sharingfooter{font-family:"Arial Narrow",Arial,sans-serif;font-size:12.285px;line-height:39.444px;letter-spacing:.5px}.sharingfooter:active,.sharingfooter:hover{-webkit-box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);-webkit-transition:all 2ms ease-in-out;transition:all 2ms ease-in-out}.sharingfooter__wrapper{margin: auto;max-width:63rem;width:1%;max-width:1336px}.sharingfooter__wrapper:after,.sharingfooter__wrapper:before{content:" ";display:table}.sharingfooter__wrapper:after{clear:both}.sharingfooter__content{float:right;padding: 1.125rem}.sharingfooter__content a{display:inline-block;margin-left:1px}.sharingfooter__content .button--share{margin-top:5px}@media only screen and (max-width: 53.125em){.sharingfooter__content{float:none;text-align:center}.sharingfooter__content a{margin:}.sharingfooter__content .sharingfooter__facebook{text-align:right;padding-right:1px}.sharingfooter__content .sharingfooter__twitter{text-align:left;padding-left:1px}}.alert-bar{position:relative;padding:.5em;background-color:#eeb544;color:rgba(,,,.6)}.alert-bar.alert-bar__hero{margin:2em ;font-size:1.1em}.alert-bar.alert-bar__inline{width:1%}.alert-bar.alert-bar__control{padding-right:2em}.alert-bar .alert-bar__text{position:relative;top:1px}.alert-bar .alert-bar__icon{position:absolute;top:1px;right:1px}.reply__byline,a.reply__count span,a.reply__link span{font-family:"ProximaNovaCond",sans-serif;font-weight:5}.reply .unapproved-msg,.reply__pending-label,.reply__publish-time,.reply__to-author{font-family:"ProximaNovaCond",sans-serif;font-weight:4}@media only screen and (max-width: 37.438em){.reply--depth-{margin-left:}}.reply--depth->.reply__header>.avatar{margin-top:}.reply--depth->.reply__header>.avatar img{width:4px;height:4px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__header>.avatar{margin-top:2px}.reply--depth->.reply__header>.avatar img{width:32px;height:32px}}.reply--depth->.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;max-width:696px;padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply--depth->.reply__tools{padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__tools{padding-left:1.125rem}}.reply--depth-.anchor>.reply__content{max-width:666px}ul.commentlist{margin:}ul.commentlist--depth-{position:relative;left:-5px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-{left:}}ul.commentlist--depth- .unapproved-filter--thread{width:686px;margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth- .unapproved-filter--thread{width:auto;margin-left:}}ul.commentlist--depth-1{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1{margin-left:18px}}ul.commentlist--depth-1+.reply-footer-bar{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1+.reply-footer-bar{margin-left:}}.commentlist__item:after{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5;margin: 6px}@media only screen and (max-width: 37.438em){.commentlist__item:after{position:relative;width:12%;left:-2%;margin:}}.commentlist__item:last-child:after{display:none}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:after{width:auto;margin: 46px 5px}}@media screen and (min-width: 64em) and (max-width: 69.375em){.commentlist__item--depth-1:after{margin: 5px}}.commentlist__item--depth-1:first-child:before{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5}@media only screen and (max-width: 37.438em){.commentlist__item--depth-1:first-child:before{position:relative;width:12%;left:-2%}}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:first-child:before{margin-right:5px}}@media screen and (min-width: 124px) and (max-width: 111px){.commentlist__item--depth-1:first-child:before{margin:}}.commentlist__item:not(.commentlist__item--depth-) .editor{margin-left:}.commentlist__item--depth-.commentlist__item--expandable:after{display:none}.commentlist__item--depth-.commentlist__item--expandable .reply-footer-bar{display:block}.reply{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row wrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row wrap;max-width:8px;padding:2px ;position:relative}.reply:hover .post-dropdown-trigger .svg-icon{opacity:1}.reply p.media-64{padding-bottom:1rem}.reply .media-3{float:left;max-width:5%;margin: 2.25rem ;padding:5px 15px }.reply .post-tools{bottom:;margin:;position:absolute;right:}.reply .post-tools .post-bottom{margin:}.reply .unapproved-msg{color:#aaa;font-size:.875rem;padding-bottom:1rem;font-style:italic}.reply img{width:1%}.reply.anchor:before{content:'';display:inline-block;height:1%;width:3px;position:absolute;left:-16px;top:}@media only screen and (max-width: 37.438em){.reply.anchor:before{left:-1.125rem}}.reply__header{-webkit-box-ordinal-group:1;-moz-order:;-ms-flex-order:;order:;width:1%;color:#aaa;line-height:1.4;position:relative;padding-right:23px;padding-bottom:1px}@media only screen and (min-width: 66.3em){.reply__header{padding-right:}}.reply__header .icon{opacity:.3;margin-left:1px}@media only screen and (max-width: 124px){.reply__header .icon{margin-top:-5px;margin-left:3px}}.reply__header>.avatar{float:left;display:block;position:relative;margin-top:2px;margin-right:2px}@media only screen and (max-width: 37.438em){.reply__header>.avatar{margin-right:1px}}.reply__header>.avatar img{height:3px;width:3px;display:block}@media only screen and (max-width: 37.438em){.reply__header>.avatar img{width:32px;height:32px}}.reply__header>.avatar .svg-checkmark{right:-6px;bottom:-5px}.reply__header .avatar .svg-checkmark,.reply__header .avatar .svg-checkmark--small{display:none;position:absolute;fill:#93ec;opacity:.9}.reply__header .post-dropdown-trigger{position:absolute;right:}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-trigger{right:1px}}.reply__header .post-dropdown-ct{position:absolute;top:3px}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct{position:static}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct{right:-14px}}@media only screen and (min-width: 9px) and (max-width: 124px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 128px) and (max-width: 147px){.reply__header .post-dropdown-ct{right:-41px;min-width:3px;min-height:1px}}@media only screen and (min-width: 148px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:6px}}@media only screen and (min-width: 88em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:-169px}}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct .f-dropdown{width:9%;left:5%;right:5%}}.reply__header .post-dropdown-ct .f-dropdown .repostblock{background:inherit;cursor:default}.reply__header .post-dropdown-ct .f-dropdown .repostblock ul{margin:}.reply__header .post-dropdown-ct .f-dropdown .repostblock .repostheader{display:block;background:inherit;cursor:default;padding-left:.5rem}.reply__header.without-dropdown{padding-right:}.reply__header.without-dropdown .post-dropdown-ct{display:none}.reply__header.followed .avatar .svg-checkmark,.reply__header.followed .avatar .svg-checkmark--small{display:block}.featured-post .reply__header .post-dropdown-ct{right:-14px}.reply__byline{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row nowrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row nowrap;font-size:16px}@media only screen and (max-width: 37.438em){.reply__byline{font-size:14px}}.reply__byline a{overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;font-weight:bold;color:#}.reply__byline a:focus,.reply__byline a:hover{color:#}.reply__to-author{-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;font-weight:normal}@media only screen and (max-width: 124px){.reply__to-author .icon{margin-top:-3px}}.reply__publish-time{font-size:.812rem}.reply__publish-time a{color:#aaa}.reply__publish-time a:active,.reply__publish-time a:focus,.reply__publish-time a:hover{color:#aaa;text-decoration:underline}.reply__pending-label{color:#;text-transform:uppercase;font-size:14px;display:none;float:right;margin-right:5px}@media only screen and (max-width: 37.438em){.reply__pending-label{float:none;margin:;position:absolute;right:;top:22px}}.reply--unapproved .reply__publish-time .reply__pending-label{display:none}@media only screen and (max-width: 37.438em){.reply--unapproved .reply__publish-time .reply__pending-label{color:black;position:static;font-size:13px;margin-left:5px;display:inline-block}}.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;-webkit-box-ordinal-group:2;-moz-order:1;-ms-flex-order:1;order:1;max-width:636px;position:relative;padding-left:5px}@media only screen and (max-width: 37.438em){.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply__content blockquote,.reply__content ol,.reply__content p,.reply__content ul{font-size:15px;line-height:28px;padding-bottom:.625rem}.reply__content>:last-child{padding-bottom:}@media only screen and (max-width: 37.438em){.reply__content{width:1%}}@media only screen and (max-width: 53.125em){.reply__content .has-video.has-video.media-large{margin:}}a.reply__count,a.reply__link{line-height:1;color:#aaa}a.reply__count span,a.reply__link span{color:#}a.reply__count .icon,a.reply__link .icon{margin-left:5px}a.reply__count:active,a.reply__count:focus,a.reply__count:hover,a.reply__link:active,a.reply__link:focus,a.reply__link:hover{color:#aaa;text-decoration:none}.reply__link{margin-left:6.5px;position:relative}@media only screen and (max-width: 37.438em){.reply-disabled,.reply__content p,.reply__header{padding-left:1.125rem;padding-right:1.125rem}}@-webkit-keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}@keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}.kinja-slide{-webkit-transition-timing-function:cubic-bezier(.25, .1, .25, 1);transition-timing-function:cubic-bezier(.25, .1, .25, 1)}.kinja-slide__container{width:1%;padding-bottom:66.6666%;position:relative}.kinja-slide__container--wide{padding-bottom:56.25%}@media only screen and (max-width: 37.438em){.kinja-slide--ad .kinja-slide__container{padding-bottom:18px}}.kinja-slide__image-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;background:#;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}@media only screen and (max-width: 37.438em){.kinja-slide__image-container{background:#333}}.kinja-slide__image{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden}.kinja-slide__image,.kinja-slide__image img{-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}.kinja-slide__image img{max-width:1%;max-height:1%;-ms-flex-item-align:center;align-self:center;position:relative;-o-object-fit:contain;object-fit:contain}.kinja-slide__image.kinja-slide__image.kinja-slide__image.kinja-slide__image{width:auto}.kinja-slide__image--hidden{display:none}.kinja-slide__blur-background{background-size:cover;background-position:center center;-webkit-filter:blur(3px);filter:blur(3px);position:absolute;width:12%;height:12%;opacity:.6}.kinja-slide__blur-background--hidden{display:none}@media only screen and (max-width: 37.438em){.kinja-slide__blur-background{display:none}}.kinja-slide__caption{color:#333;font-size:16px;line-height:21px;margin: auto;padding:18px;max-width:636px}@media only screen and (min-width: 37.5em){.kinja-slide__caption{padding:18px ;margin: 82px}}.kinja-slide .loading .container{background:#f5f5f5}.kinja-slide__ad-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-sizing:border-box;box-sizing:border-box;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none;color:#aaa;font-size:14px;font-weight:bold;line-height:17px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-container{background:#333;position:absolute;left:;top:;right:;bottom:}}.kinja-slide__ad-container .ad-container{width:3px;height:25px;background-color:#fff}.kinja-slide__ad-label{margin-bottom:5px;margin-top:15px;text-transform:uppercase}.kinja-slide__ad-buttons{display:-webkit-box;display:-ms-flexbox;display:flex;margin-top:1px;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;width:3px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-buttons{display:none}}.kinja-slide.wiggle .kinja-slide__caption,.kinja-slide.wiggle .kinja-slide__container{-webkit-animation:kinja-slide-wiggle .6s ease-in-out both;animation:kinja-slide-wiggle .6s ease-in-out both}.kinja-slideshow{margin-bottom:2px;position:relative;overflow:hidden;background-color:#f5f5f5;font-family:"ProximaNovaCond",sans-serif}.kinja-slideshow__deck{display:-webkit-box;display:-ms-flexbox;display:flex}.kinja-slideshow .kinja-slide{width:1%;position:relative;-webkit-box-flex:;-ms-flex: 1%;flex: 1%}.kinja-slideshow__navigate-left.button{display:none;position:absolute;top:2px;margin-top:66.6666%;left:2px}.kinja-slideshow__navigate-left.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-left.button{display:inherit}}.kinja-slideshow__navigate-right.button{display:none;position:absolute;top:2px;margin-top:66.6666%;right:2px}.kinja-slideshow__navigate-right.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-right.button{display:inherit}}.kinja-slideshow--wide .kinja-slideshow__navigate-left,.kinja-slideshow--wide .kinja-slideshow__navigate-right{margin-top:56.25%}.kinja-slideshow__index{padding: 18px 15px;max-width:636px;margin: auto;font-size:16px;line-height:21px;font-weight:normal;color:#aaa}.kinja-slideshow__index .svg-icon{margin-right:3px}@media only screen and (min-width: 37.5em){.kinja-slideshow__index{padding: 15px;margin: 82px}}.reviewbox-inset{clear:left}.reviewbox-inset .review-box__head-content-wrapper{display:none}@media only screen and (min-width: 37.5em){.reviewbox-inset.align--left .review-box{width:32px;margin:}}.reviewbox-inset.align--left .review-box__head-content{display:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box{max-width:1%}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head{position:relative;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:left;-ms-flex-align:left;align-items:left;padding-left:64%}}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{position:relative;display:block;width:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:before{content:"";width:1px;margin-left:-1px;float:left;height:;padding-top:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:after{content:"";display:table;clear:both}@media only screen and (max-width: 53.125em){.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head-content{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-flex:1;-ms-flex-positive:1;flex-grow:1;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;max-width:1%;padding:15px}.reviewbox-inset.align--fullbleed .review-box__head-content .review-score{position:unset;margin: auto;background:#fff;border-color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content .review-box__title{color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content:not(.review-box__head-content--visually-hidden){position:absolute;top:;right:;bottom:;left:}.reviewbox-inset.align--fullbleed .review-box__head-content--visually-hidden{visibility:hidden}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image-wrapper{-ms-flex-preferred-size:64%;flex-basis:64%;padding-top:36%;padding:;position:absolute;width:64%;top:;left:;right:36%;bottom:;height:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image{position:absolute;top:-9999px;right:-9999px;bottom:-9999px;left:-9999px;min-height:1%;max-width:none;width:auto;margin:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__content .review-box__title,.reviewbox-inset.align--fullbleed .review-box__content .review-score,.reviewbox-inset.align--fullbleed .review-box__content--nodata{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__data-wrapper:not(.review-box__data-wrapper--single){-webkit-column-count:2;column-count:2;-webkit-column-gap:3px;column-gap:3px}}.reviewbox-inset.align--fullbleed .review-box__data-item{-webkit-column-break-inside:avoid;break-inside:avoid;page-break-inside:avoid}.reviewbox-inset.align--fullbleed .review-box__data-label,.reviewbox-inset.align--fullbleed .review-box__data-value{max-width:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .storytype-label-wrapper--top{display:none}}.reviewbox-inset.align--fullbleed .storytype-label-wrapper--head{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;margin-bottom:2px}.review-box{margin:3px auto;max-width:47px;width:1%}.review-inset-editor .review-box{width:32px}.review-box__tag-wrapper{max-width:1%;height:26px;margin-bottom:1px}.review-box__tag-wrapper,.review-box__tag{display:-webkit-box;display:-ms-flexbox;display:flex}.review-box__tag{height:1%;padding:5px 5px 5px 7px;-webkit-box-flex:;-ms-flex: auto;flex: auto;overflow:hidden;font-family:"ProximaNovaCond",sans-serif;font-size:15px;line-height:18px;background-color:#93ec;-webkit-transition:background-color .1s ease-out;transition:background-color .1s ease-out}.review-box__tag:first-child{-webkit-box-flex:;-ms-flex: 1 auto;flex: 1 auto}.review-box__tag:first-child .review-box__text{white-space:nowrap;overflow:hidden;text-overflow:ellipsis}.review-box__tag:hover{text-decoration:none;background-color:#73b9}.review-box__tag:not:)last-child){margin-right:1px}.review-box__tag .svg-icon.small{min-width:1px;height:1%;-ms-flex-item-align:end;align-self:flex-end;stroke:#fff;opacity:1}.review-box__text{margin-right:5px;color:#fff;text-transform:uppercase}.review-box__image-wrapper{position:relative;height:;padding-top:56.25%}.review-box__image-container{width:1%;overflow:hidden;position:absolute;top:;right:;bottom:;left:}.review-box__image-container .spinner.bounce{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;width:1%;height:1%;background-color:#e5e5e5}.review-box__image{width:1%}.review-box__head-content-wrapper{display:none}.review-box__content{position:relative;padding:15px 15px 15px;background-color:#f5f5f5}.review-box__content--nodata{padding:15px}.review-box__content--nodata .review-box__title{margin-bottom:}.review-box__content--nodata .review-box__data-wrapper{display:none}.review-box__title{margin-bottom:15px;font-size:24px;line-height:28px;text-align:center}.review-box__title:last-child{margin-bottom:}.review-box__data-item{padding-bottom:15px}.review-box__data-label{margin-bottom:;font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:normal;line-height:28px;color:#666;text-transform:uppercase}.review-box__data-value{font-family:"ElizabethSerif",Georgia,serif;color:#222;margin-bottom:}.post-content .review-box__data-value,.dui-modal .review-box__data-value{font-size:15px;line-height:28px}.review-score{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:48px;height:48px;margin: auto 15px;border:2px solid #f5f5f5;border-radius:5%;font-family:"ProximaNovaCond",sans-serif;font-size:24px;line-height:24px;color:#fff;background-color:#333}.review-score--img{margin:;position:absolute;top:-38px;left:calc(5% - 24px)}.review-score--small{font-size:19px;line-height:19px;height:36px;width:36px}@media only screen and (min-width: 37.5em){.review-score--small-on-medium-up{font-size:19px;line-height:19px;height:36px;width:36px}}.postlist__item--compact .asset,.postlist__item .asset,.storytype--section .item__image{position:relative}.postlist__item--compact .asset .review-score,.postlist__item .asset .review-score,.storytype--section .item__image .review-score{margin:;position:absolute;left:1px;top:1px;z-index:1}@media only screen and (min-width: 37.5em){.postlist__item .asset .review-score{left:28px}}.branded-item .headline a{color:# !important}.branded-item .inset--story__thumb figure,.branded-item.item .image__wrapper{border-bottom:5px solid transparent}.branded-item .gmg-avatar{width:2px;position:absolute;bottom:-5px;left:}.branded-item .inset--story__readmore{display:inline-block}.branded-item--deadspin .inset--story__thumb figure,.branded-item--deadspin.item .image__wrapper{border-bottom-color:#1b3a4d}.branded-item--deadspin .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #3d84af;box-shadow:inset -2px #3d84af;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--deadspin .inset--story__readmore:hover{color:#1b3a4d;text-decoration:none}.branded-item--earther .inset--story__thumb figure,.branded-item--earther.item .image__wrapper{border-bottom-color:#75b2}.branded-item--earther .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--earther .inset--story__readmore:hover{color:#75b2;text-decoration:none}.branded-item--fusion .inset--story__thumb figure,.branded-item--fusion.item .image__wrapper{border-bottom-color:#4e}.branded-item--fusion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #7ae8ff;box-shadow:inset -2px #7ae8ff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--fusion .inset--story__readmore:hover{color:#caf4;text-decoration:none}.branded-item--gizmodo .inset--story__thumb figure,.branded-item--gizmodo.item .image__wrapper{border-bottom-color:#18afed}.branded-item--gizmodo .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #93daf7;box-shadow:inset -2px #93daf7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--gizmodo .inset--story__readmore:hover{color:#18afed;text-decoration:none}.branded-item--jalopnik .inset--story__thumb figure,.branded-item--jalopnik.item .image__wrapper{border-bottom-color:#ff4d}.branded-item--jalopnik .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffaa85;box-shadow:inset -2px #ffaa85;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jalopnik .inset--story__readmore:hover{color:#ff4d;text-decoration:none}.branded-item--jezebel .inset--story__thumb figure,.branded-item--jezebel.item .image__wrapper{border-bottom-color:#ec1238}.branded-item--jezebel .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jezebel .inset--story__readmore:hover{color:#ec1238;text-decoration:none}.branded-item--kotaku .inset--story__thumb figure,.branded-item--kotaku.item .image__wrapper{border-bottom-color:#fbc}.branded-item--kotaku .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--kotaku .inset--story__readmore:hover{color:#fbc;text-decoration:none}.branded-item--lifehacker .inset--story__thumb figure,.branded-item--lifehacker.item .image__wrapper{border-bottom-color:#94b33}.branded-item--lifehacker .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #cbdf88;box-shadow:inset -2px #cbdf88;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--lifehacker .inset--story__readmore:hover{color:#94b33;text-decoration:none}.branded-item--theonion .inset--story__thumb figure,.branded-item--theonion.item .image__wrapper{border-bottom-color:#6b3a}.branded-item--theonion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f82;box-shadow:inset -2px #f82;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theonion .inset--story__readmore:hover{color:#6b3a;text-decoration:none}.branded-item--theroot .inset--story__thumb figure,.branded-item--theroot.item .image__wrapper{border-bottom-color:#59b22}.branded-item--theroot .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theroot .inset--story__readmore:hover{color:#59b22;text-decoration:none}.branded-item--splinter .inset--story__thumb figure,.branded-item--splinter.item .image__wrapper{border-bottom-color:#f85637}.branded-item--splinter .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--splinter .inset--story__readmore:hover{color:#f85637;text-decoration:none}.branded-item--avclub .inset--story__thumb figure,.branded-item--avclub.item .image__wrapper{border-bottom-color:#1c263c}.branded-item--avclub .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #465f96;box-shadow:inset -2px #465f96;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--avclub .inset--story__readmore:hover{color:#1c263c;text-decoration:none}.branded-item--thetakeout .inset--story__thumb figure,.branded-item--thetakeout.item .image__wrapper{border-bottom-color:#E5371A}.branded-item--thetakeout .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fef7dd;box-shadow:inset -2px #fef7dd;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--thetakeout .inset--story__readmore:hover{color:#F9DB5D;text-decoration:none}.f_branding_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on .post-content .quotable a,.f_branding_on .post-content footer a,.f_branding_on .post-content h1 a,.f_branding_on .post-content h2 a,.f_branding_on .post-content h3 a,.f_branding_on .post-content h4 a,.f_branding_on .post-content h5 a,.f_branding_on .post-content h6 a,.f_branding_on .post-content li a,.f_branding_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on .post-content .quotable a:hover,.f_branding_on .post-content footer a:hover,.f_branding_on .post-content h1 a:hover,.f_branding_on .post-content h2 a:hover,.f_branding_on .post-content h3 a:hover,.f_branding_on .post-content h4 a:hover,.f_branding_on .post-content h5 a:hover,.f_branding_on .post-content h6 a:hover,.f_branding_on .post-content li a:hover,.f_branding_on .post-content p a:hover,.f_branding_on figcaption a{color:#93ec}.f_branding_on figcaption a:hover{color:#73b9}.f_branding_on .editor-inner.post-content blockquote,.f_branding_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on .editor-inner.post-content .pullquote:before,.f_branding_on .entry-content .pullquote:before,.f_branding_on .editor-inner.post-content .pullquote:after,.f_branding_on .entry-content .pullquote:after{border:}.f_branding_on .editor-inner.post-content .pullquote__content,.f_branding_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on .storybreak-branded-a,.f_branding_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on .review-score,.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#333}.f_branding_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on .author-bio__name{color:#222}.f_branding_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_deadspin_on.f_article_split_on .scroll-list-break{border-top:3px solid #2d9d92}.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#1b3a4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-deadspin .post-content .quotable a,.f_branding_on .blog-group-deadspin .post-content .quotable a,.f_branding_on.blog-group-deadspin .post-content footer a,.f_branding_on .blog-group-deadspin .post-content footer a,.f_branding_on.blog-group-deadspin .post-content h1 a,.f_branding_on .blog-group-deadspin .post-content h1 a,.f_branding_on.blog-group-deadspin .post-content h2 a,.f_branding_on .blog-group-deadspin .post-content h2 a,.f_branding_on.blog-group-deadspin .post-content h3 a,.f_branding_on .blog-group-deadspin .post-content h3 a,.f_branding_on.blog-group-deadspin .post-content h4 a,.f_branding_on .blog-group-deadspin .post-content h4 a,.f_branding_on.blog-group-deadspin .post-content h5 a,.f_branding_on .blog-group-deadspin .post-content h5 a,.f_branding_on.blog-group-deadspin .post-content h6 a,.f_branding_on .blog-group-deadspin .post-content h6 a,.f_branding_on.blog-group-deadspin .post-content li a,.f_branding_on .blog-group-deadspin .post-content li a,.f_branding_on.blog-group-deadspin .post-content p a,.f_branding_on .blog-group-deadspin .post-content p a,.f_branding_on.f_branding_deadspin_on .post-content .quotable a,.f_branding_on.f_branding_deadspin_on .post-content footer a,.f_branding_on.f_branding_deadspin_on .post-content h1 a,.f_branding_on.f_branding_deadspin_on .post-content h2 a,.f_branding_on.f_branding_deadspin_on .post-content h3 a,.f_branding_on.f_branding_deadspin_on .post-content h4 a,.f_branding_on.f_branding_deadspin_on .post-content h5 a,.f_branding_on.f_branding_deadspin_on .post-content h6 a,.f_branding_on.f_branding_deadspin_on .post-content li a,.f_branding_on.f_branding_deadspin_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #77d8ce;box-shadow:inset -2px #77d8ce;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-deadspin .post-content .quotable a:hover,.f_branding_on .blog-group-deadspin .post-content .quotable a:hover,.f_branding_on.blog-group-deadspin .post-content footer a:hover,.f_branding_on .blog-group-deadspin .post-content footer a:hover,.f_branding_on.blog-group-deadspin .post-content h1 a:hover,.f_branding_on .blog-group-deadspin .post-content h1 a:hover,.f_branding_on.blog-group-deadspin .post-content h2 a:hover,.f_branding_on .blog-group-deadspin .post-content h2 a:hover,.f_branding_on.blog-group-deadspin .post-content h3 a:hover,.f_branding_on .blog-group-deadspin .post-content h3 a:hover,.f_branding_on.blog-group-deadspin .post-content h4 a:hover,.f_branding_on .blog-group-deadspin .post-content h4 a:hover,.f_branding_on.blog-group-deadspin .post-content h5 a:hover,.f_branding_on .blog-group-deadspin .post-content h5 a:hover,.f_branding_on.blog-group-deadspin .post-content h6 a:hover,.f_branding_on .blog-group-deadspin .post-content h6 a:hover,.f_branding_on.blog-group-deadspin .post-content li a:hover,.f_branding_on .blog-group-deadspin .post-content li a:hover,.f_branding_on.blog-group-deadspin .post-content p a:hover,.f_branding_on .blog-group-deadspin .post-content p a:hover,.f_branding_on.f_branding_deadspin_on .post-content .quotable a:hover,.f_branding_on.f_branding_deadspin_on .post-content footer a:hover,.f_branding_on.f_branding_deadspin_on .post-content h1 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h2 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h3 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h4 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h5 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h6 a:hover,.f_branding_on.f_branding_deadspin_on .post-content li a:hover,.f_branding_on.f_branding_deadspin_on .post-content p a:hover,.f_branding_on.blog-group-deadspin figcaption a,.f_branding_on .blog-group-deadspin figcaption a,.f_branding_on.f_branding_deadspin_on figcaption a{color:#2d9d92}.f_branding_on.blog-group-deadspin figcaption a:hover,.f_branding_on .blog-group-deadspin figcaption a:hover,.f_branding_on.f_branding_deadspin_on figcaption a:hover{color:#22756d}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on.blog-group-deadspin .entry-content blockquote,.f_branding_on .blog-group-deadspin .entry-content blockquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_deadspin_on .entry-content blockquote{border-radius:;border-left:5px solid #1b3a4d;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-deadspin .entry-content .pullquote__content,.f_branding_on .blog-group-deadspin .entry-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-deadspin .review-score,.f_branding_on .blog-group-deadspin .review-score,.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_deadspin_on .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1b3a4d}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white){color:#2d9d92;border-color:#2d9d92}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white):hover{color:#22756d;border-color:#22756d}.f_branding_on.blog-group-deadspin .author-bio__name,.f_branding_on .blog-group-deadspin .author-bio__name,.f_branding_on.f_branding_deadspin_on .author-bio__name{color:#222}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name){color:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover{color:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#22756d}.f_branding_on.blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_deadspin_on .sidebar-content .newsletter-subscribe{border-color:#1b3a4d}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on.blog-group-deadspin .entry-content .pullquote,.f_branding_on .blog-group-deadspin .entry-content .pullquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote{border-top:1px solid #1b3a4d;border-bottom:1px solid #1b3a4d;padding:3px ;position:relative;color:#1b3a4d;font-size:22px;line-height:32px;font-weight:bold;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{height:4px;width:26px;position:absolute;left:calc(5% - 13px);background-image:url('data:image/svg+xml;utf8,<svg xmlns="http://www.w3.org/2/svg" width="26" height="4" viewBox=" 26 4"><title>deadspin-quote-carrot-aligned-w-bgr-2<\/title><path d="M1,3.5l3-3,3,3Z" style="fill:%23fff;stroke:%23fff"/><path d="M,3.5H1l3-3,3,3H26" style="fill:none;stroke:%231b3a4d"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{top:-4px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{bottom:-4px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;width:1%}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child{top:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child{bottom:6px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{display:block;content:'';height:9px;width:18px;position:absolute;top:-1px;background-color:#fff}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{left:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after{right:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{top:-2px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{background-image:url('data:image/svg+xml;utf8,<svg width="19" height="9" viewBox=" 19 9" xmlns="http://www.w3.org/2/svg"><title>deadspin-quote-topleft<\/title><path d="M.5 8.5c-4.43 3.655-8.54 8-8h1" stroke="%231B3A4D" fill="none" stroke-linecap="square" stroke-linejoin="round"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after{-webkit-transform:scaleX(-1);transform:scaleX(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{-webkit-transform:scaleY(-1);transform:scaleY(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after{-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>diamond-blue<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%231B3A4D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>deadspin-diamond-teal<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%23249D9D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on.blog-group-earther .entry-content .pullquote,.f_branding_on .blog-group-earther .entry-content .pullquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_earther_on .entry-content .pullquote{border-top:none;border-bottom:none;padding:3px;position:relative;font-size:22px;line-height:32px;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-earther .entry-content .pullquote.align--left,.f_branding_on .blog-group-earther .entry-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{height:3px;width:3px;position:absolute;background-image:url('data:image/svg+xml;utf8,<svg width="3" height="3" viewBox=" 4 4" xmlns="http://www.w3.org/2/svg"><title>pq-earther<\/title><path d="M4 h36v8H8v32HVh4z" fill="%2375B2" fill-rule="evenodd"/><\/svg>');margin:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{top:;left:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{bottom:;right:;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-a{min-width:26px;height:26px;background-image:url('data:image/svg+xml;utf8,<svg width="26" height="26" viewBox=" 26 26" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-a<\/title><g stroke="%2375B2" fill="none" fill-rule="evenodd" stroke-linejoin="round"><path d="M21.292 21.292c-4.757 4.757-12.47 4.756-17.225 -4.756-4.757-4.756-12.47 -17.225 4.757-4.756 12.47-4.756 17.225 4.756 4.757 4.756 12.47 17.225z"/><path d="M21.69 2.988c-3.98 2.526-1.537 1.65-14.767-2.578C2.69 14.177 1.857 8.238 4.67 3.655"/><path d="M22.75 14.657c-2.53 2.5-7.226 1.83-1.55-1.494C8.88 9.84 8.215 5.117 1.718 2.617c2.54-2.5 7.227-1.83 1.55 1.494 3.323 3.33 3.987 8.5 1.484 1.55z" stroke-width="1.77"/><path d="M2.294 9.234c-.793.793-2.37.5-3.524-.654s-1.447-2.732-.654-3.525c.792-.793 2.37-.5 3.524.654 1.154 1.15 1.446 2.73.654 3.52zm-.2.17c2.69 4.38 1.677 1.43-1.856 13.964M2.14 6.963c3.567-3.566 9.973-5.35 13.926-2.225m4.456 2.548c1.473.93 2.75.523 3.745 1.32m-6.7-3.77c-.11-1.416-.534-2.646-1.31-3.61"/><path d="M18.852 9.85c-.55 2.345-2.5 6.53-4.95 8.998-2.427 2.428-4.818 3.666-6.967 4.52m-4.512-4.512c.846-2.16 1.646-4.94 4.98-7.39 2.95-2.945 6.66-3.93 9.1-4.478"/><\/g><\/svg>')}.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-b{min-width:25px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="25" height="25" viewBox=" 25 25" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path d="M24.398 12.438c 6.63-5.374 12.4-12.4 12.4S.39 19.68.39 12.438 5.765.434 12.394.434c6.63 12.4 5.375 12.4 12.4" fill="%2375B2"/><path d="M 12.32h24.64M12.32 v24.42m8.74-2.818L3.73 2.932M3.727 3.596l17.336 17.34m-1.358-8.67c 4.37-3.273 7.31-7.31 7.31-4.37 -7.31-3.273-7.31-7.31 -4.37 3.273-7.31 7.31-7.31 4.37 7.31 3.273 7.31 7.31z" stroke="%23FFF" stroke-width=".88"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_gizmodo_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-gizmodo .post-content .quotable a,.f_branding_on .blog-group-gizmodo .post-content .quotable a,.f_branding_on.blog-group-gizmodo .post-content footer a,.f_branding_on .blog-group-gizmodo .post-content footer a,.f_branding_on.blog-group-gizmodo .post-content h1 a,.f_branding_on .blog-group-gizmodo .post-content h1 a,.f_branding_on.blog-group-gizmodo .post-content h2 a,.f_branding_on .blog-group-gizmodo .post-content h2 a,.f_branding_on.blog-group-gizmodo .post-content h3 a,.f_branding_on .blog-group-gizmodo .post-content h3 a,.f_branding_on.blog-group-gizmodo .post-content h4 a,.f_branding_on .blog-group-gizmodo .post-content h4 a,.f_branding_on.blog-group-gizmodo .post-content h5 a,.f_branding_on .blog-group-gizmodo .post-content h5 a,.f_branding_on.blog-group-gizmodo .post-content h6 a,.f_branding_on .blog-group-gizmodo .post-content h6 a,.f_branding_on.blog-group-gizmodo .post-content li a,.f_branding_on .blog-group-gizmodo .post-content li a,.f_branding_on.blog-group-gizmodo .post-content p a,.f_branding_on .blog-group-gizmodo .post-content p a,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a,.f_branding_on.f_branding_gizmodo_on .post-content footer a,.f_branding_on.f_branding_gizmodo_on .post-content h1 a,.f_branding_on.f_branding_gizmodo_on .post-content h2 a,.f_branding_on.f_branding_gizmodo_on .post-content h3 a,.f_branding_on.f_branding_gizmodo_on .post-content h4 a,.f_branding_on.f_branding_gizmodo_on .post-content h5 a,.f_branding_on.f_branding_gizmodo_on .post-content h6 a,.f_branding_on.f_branding_gizmodo_on .post-content li a,.f_branding_on.f_branding_gizmodo_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on .blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on.blog-group-gizmodo .post-content footer a:hover,.f_branding_on .blog-group-gizmodo .post-content footer a:hover,.f_branding_on.blog-group-gizmodo .post-content h1 a:hover,.f_branding_on .blog-group-gizmodo .post-content h1 a:hover,.f_branding_on.blog-group-gizmodo .post-content h2 a:hover,.f_branding_on .blog-group-gizmodo .post-content h2 a:hover,.f_branding_on.blog-group-gizmodo .post-content h3 a:hover,.f_branding_on .blog-group-gizmodo .post-content h3 a:hover,.f_branding_on.blog-group-gizmodo .post-content h4 a:hover,.f_branding_on .blog-group-gizmodo .post-content h4 a:hover,.f_branding_on.blog-group-gizmodo .post-content h5 a:hover,.f_branding_on .blog-group-gizmodo .post-content h5 a:hover,.f_branding_on.blog-group-gizmodo .post-content h6 a:hover,.f_branding_on .blog-group-gizmodo .post-content h6 a:hover,.f_branding_on.blog-group-gizmodo .post-content li a:hover,.f_branding_on .blog-group-gizmodo .post-content li a:hover,.f_branding_on.blog-group-gizmodo .post-content p a:hover,.f_branding_on .blog-group-gizmodo .post-content p a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a:hover,.f_branding_on.f_branding_gizmodo_on .post-content footer a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h1 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h2 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h3 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h4 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h5 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h6 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content li a:hover,.f_branding_on.f_branding_gizmodo_on .post-content p a:hover,.f_branding_on.blog-group-gizmodo figcaption a,.f_branding_on .blog-group-gizmodo figcaption a,.f_branding_on.f_branding_gizmodo_on figcaption a{color:#93ec}.f_branding_on.blog-group-gizmodo figcaption a:hover,.f_branding_on .blog-group-gizmodo figcaption a:hover,.f_branding_on.f_branding_gizmodo_on figcaption a:hover{color:#73b9}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on.blog-group-gizmodo .entry-content blockquote,.f_branding_on .blog-group-gizmodo .entry-content blockquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before,.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on .blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-gizmodo .review-score,.f_branding_on .blog-group-gizmodo .review-score,.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_gizmodo_on .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio__name,.f_branding_on .blog-group-gizmodo .author-bio__name,.f_branding_on.f_branding_gizmodo_on .author-bio__name{color:#222}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on.blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_gizmodo_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on.blog-group-gizmodo .entry-content .pullquote,.f_branding_on .blog-group-gizmodo .entry-content .pullquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote{border-top:2px solid #18afed;border-bottom:2px solid #18afed;padding-top:3px;padding-bottom:3px;position:relative}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before{height:42px;width:42px;position:absolute;left:calc(5% - 21px);top:-21px;background-image:url('data:image/svg+xml;utf8,<svg width="42" height="42" viewBox=" 42 42" xmlns="http://www.w3.org/2/svg"><title>gizmodo-quote<\/title><g fill="none" fill-rule="evenodd"><path d="M41.95 2.974c 11.583-9.392 2.974-2.976 2.974S 32.558 2.974 9.39 2.974 41.95 9.39 41.95 2.974" fill="%2318AFED"/><path d="M21.8 21.422c-6.874 3.744-9.434 9.622-9.623l.76 3.46c-3.178.38-4.74 1.894-4.647 4.453h3.51l-.2 9.245H21.8v-7.54zm-12.562 c-6.874 3.697-9.434 9.622-9.623l.71 3.46c-3.175.38-4.74 1.894-4.597 4.453h3.58l.4 9.245H9.238v-7.54z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a{min-width:33px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="12" viewBox=" 33 12" xmlns="http://www.w3.org/2/svg"><title>gizmodo-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2318AFED" d="M11 12h11VH11"/><path fill="%23" d="M 12h11VHm22 12h11VH22"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{min-width:111px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="111" height="25" viewBox=" 111 25" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>gizmodo-plots<\/title><defs><path id="a" d="M 5V.324h4.676V5Hz"/><path id="c" d="M4.985.26v4.8H.977V.26h4.8z"/><path id="e" d="M.398.842H3.7v2.672H.398V.842z"/><\/defs><g fill="none" fill-rule="evenodd"><path stroke="%2318AFED" stroke-width=".445" d="M34.61 19.42L1.762 21.857l9.583-18.2 22.69 15.63L44.157 1.372l1.73 1.52 18.44 9.124 3.855-14.23"/><g transform="translate( 19.158)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M4.67 2.516c.84 1.29-.896 2.4-2.184 2.48-1.29.8-2.4-.9-2.48-2.188-.8-1.29.898-2.4 2.188-2.48C3.48.25 4.59 1.23 4.67 2.518" fill="%2318AFED" mask="url(%23b)"/><\/g><path d="M13.587 3.714c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m43.543 8.38c.6.92-.64 1.713-1.56 1.77-.922.6-1.715-.64-1.772-1.56-.58-.922.64-1.715 1.562-1.772.92-.58 1.713.64 1.77 1.562m42.882-7.84c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m-25.368 16.46c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562M79.36 6.625c.7 1.15-.77 2.56-1.874 2.125-1.15.7-2.56-.77-2.125-1.875-.66-1.14.77-2.56 1.878-2.125 1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED"/><g transform="translate(16 18.158)"><mask id="d" fill="%23fff"><use xlink-underline:href="%23c"/><\/mask><path d="M4.98 2.14c.7 1.14-.77 2.55-1.874 2.124C2 4.334 1.5 3.494.98 2.39.91 1.284 1.75.332 2.857.263c1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED" mask="url(%23d)"/><\/g><path d="M36.61 19.296c.7 1.15-.77 2.56-1.875 2.125-1.15.7-2.56-.77-2.125-1.872-.7-1.14.77-2.56 1.875-2.125 1.14-.68 2.56.77 2.125 1.876" fill="%2318AFED"/><g transform="translate(43 -.842)"><mask id="f" fill="%23fff"><use xlink-underline:href="%23e"/><\/mask><path d="M3.67 2.95c.46.735-.514 1.37-1.25 1.416C1.8 3.56.447 3 .4 2.265.354 1.524.914.89 1.65.844c.737-.46 1.37.514 1.417 1.25" fill="%2318AFED" mask="url(%23f)"/><\/g><path d="M55.464 11.856L34.61 19.42m-32.272 2.4L44.734 1.336 77.36 6.75l32.24 13.83L97.985 3.574 72.977 2.512" stroke="%2318AFED" stroke-width=".445"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jalopnik_on.f_article_split_on .scroll-list-break{border-top:3px solid #ff4d}.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ff4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jalopnik .post-content .quotable a,.f_branding_on .blog-group-jalopnik .post-content .quotable a,.f_branding_on.blog-group-jalopnik .post-content footer a,.f_branding_on .blog-group-jalopnik .post-content footer a,.f_branding_on.blog-group-jalopnik .post-content h1 a,.f_branding_on .blog-group-jalopnik .post-content h1 a,.f_branding_on.blog-group-jalopnik .post-content h2 a,.f_branding_on .blog-group-jalopnik .post-content h2 a,.f_branding_on.blog-group-jalopnik .post-content h3 a,.f_branding_on .blog-group-jalopnik .post-content h3 a,.f_branding_on.blog-group-jalopnik .post-content h4 a,.f_branding_on .blog-group-jalopnik .post-content h4 a,.f_branding_on.blog-group-jalopnik .post-content h5 a,.f_branding_on .blog-group-jalopnik .post-content h5 a,.f_branding_on.blog-group-jalopnik .post-content h6 a,.f_branding_on .blog-group-jalopnik .post-content h6 a,.f_branding_on.blog-group-jalopnik .post-content li a,.f_branding_on .blog-group-jalopnik .post-content li a,.f_branding_on.blog-group-jalopnik .post-content p a,.f_branding_on .blog-group-jalopnik .post-content p a,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a,.f_branding_on.f_branding_jalopnik_on .post-content footer a,.f_branding_on.f_branding_jalopnik_on .post-content h1 a,.f_branding_on.f_branding_jalopnik_on .post-content h2 a,.f_branding_on.f_branding_jalopnik_on .post-content h3 a,.f_branding_on.f_branding_jalopnik_on .post-content h4 a,.f_branding_on.f_branding_jalopnik_on .post-content h5 a,.f_branding_on.f_branding_jalopnik_on .post-content h6 a,.f_branding_on.f_branding_jalopnik_on .post-content li a,.f_branding_on.f_branding_jalopnik_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #a1cde;box-shadow:inset -2px #a1cde;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on .blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on.blog-group-jalopnik .post-content footer a:hover,.f_branding_on .blog-group-jalopnik .post-content footer a:hover,.f_branding_on.blog-group-jalopnik .post-content h1 a:hover,.f_branding_on .blog-group-jalopnik .post-content h1 a:hover,.f_branding_on.blog-group-jalopnik .post-content h2 a:hover,.f_branding_on .blog-group-jalopnik .post-content h2 a:hover,.f_branding_on.blog-group-jalopnik .post-content h3 a:hover,.f_branding_on .blog-group-jalopnik .post-content h3 a:hover,.f_branding_on.blog-group-jalopnik .post-content h4 a:hover,.f_branding_on .blog-group-jalopnik .post-content h4 a:hover,.f_branding_on.blog-group-jalopnik .post-content h5 a:hover,.f_branding_on .blog-group-jalopnik .post-content h5 a:hover,.f_branding_on.blog-group-jalopnik .post-content h6 a:hover,.f_branding_on .blog-group-jalopnik .post-content h6 a:hover,.f_branding_on.blog-group-jalopnik .post-content li a:hover,.f_branding_on .blog-group-jalopnik .post-content li a:hover,.f_branding_on.blog-group-jalopnik .post-content p a:hover,.f_branding_on .blog-group-jalopnik .post-content p a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a:hover,.f_branding_on.f_branding_jalopnik_on .post-content footer a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h1 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h2 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h3 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h4 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h5 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h6 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content li a:hover,.f_branding_on.f_branding_jalopnik_on .post-content p a:hover,.f_branding_on.blog-group-jalopnik figcaption a,.f_branding_on .blog-group-jalopnik figcaption a,.f_branding_on.f_branding_jalopnik_on figcaption a{color:#417eb9}.f_branding_on.blog-group-jalopnik figcaption a:hover,.f_branding_on .blog-group-jalopnik figcaption a:hover,.f_branding_on.f_branding_jalopnik_on figcaption a:hover{color:#346493}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on.blog-group-jalopnik .entry-content blockquote,.f_branding_on .blog-group-jalopnik .entry-content blockquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote{border-radius:;border-left:5px solid #417eb9;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before,.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on .blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jalopnik .review-score,.f_branding_on .blog-group-jalopnik .review-score,.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jalopnik_on .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ff4d}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white){color:#417eb9;border-color:#417eb9}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white):hover{color:#346493;border-color:#346493}.f_branding_on.blog-group-jalopnik .author-bio__name,.f_branding_on .blog-group-jalopnik .author-bio__name,.f_branding_on.f_branding_jalopnik_on .author-bio__name{color:#222}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name){color:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover{color:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#346493}.f_branding_on.blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jalopnik_on .sidebar-content .newsletter-subscribe{border-color:#417eb9}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jalopnik .entry-content .pullquote,.f_branding_on .blog-group-jalopnik .entry-content .pullquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before{height:8px;width:219px;background-image:url('data:image/svg+xml;utf8,<svg width="219" height="8" viewBox=" 219 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-top<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" transform="matrix(-1 1 265 )" d="M46 h17l3 4H49"/><path fill="%23FF4D" d="M116 4H2L 8h114"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{height:8px;width:116px;background-image:url('data:image/svg+xml;utf8,<svg width="116" height="8" viewBox=" 116 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-bottom<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="%23FF4D" d="M116 H48l-1 4h68"/><path fill="url(%23a)" transform="matrix(-1 1 84 )" d="M 4h83l1 4H1"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a{min-width:77px;height:1px;background-image:url('data:image/svg+xml;utf8,<svg width="77" height="1" viewBox=" 77 1" xmlns="http://www.w3.org/2/svg"><title>%23-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%23CCC" d="M12.423 4L1 1h64.577L77 4"/><path fill="%23FF4D" d="M2.423 L 6h64.577L67 "/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{min-width:8px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="8" height="12" viewBox=" 8 12" xmlns="http://www.w3.org/2/svg"><title>%23-gradient<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" d="M75.1 5.982L78.82 12H3L4.185 H8"/><path d="M3.517 11.977c-.194 -.696.23-.96.23Hl.5-5.86h2.585c.264 .5-.22.527-.49L4.242 H9l-.665 6.92c-.26.27-.15.75-.175.965 -.532 4.68-4.643 4.92z" fill="%23FF4D"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .pullquote__content,.f_branding_on .blog-group-jalopnik .pullquote__content,.f_branding_on.f_branding_jalopnik_on .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jezebel_on.f_article_split_on .scroll-list-break{border-top:3px solid #ec1238}.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ec1238;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jezebel .post-content .quotable a,.f_branding_on .blog-group-jezebel .post-content .quotable a,.f_branding_on.blog-group-jezebel .post-content footer a,.f_branding_on .blog-group-jezebel .post-content footer a,.f_branding_on.blog-group-jezebel .post-content h1 a,.f_branding_on .blog-group-jezebel .post-content h1 a,.f_branding_on.blog-group-jezebel .post-content h2 a,.f_branding_on .blog-group-jezebel .post-content h2 a,.f_branding_on.blog-group-jezebel .post-content h3 a,.f_branding_on .blog-group-jezebel .post-content h3 a,.f_branding_on.blog-group-jezebel .post-content h4 a,.f_branding_on .blog-group-jezebel .post-content h4 a,.f_branding_on.blog-group-jezebel .post-content h5 a,.f_branding_on .blog-group-jezebel .post-content h5 a,.f_branding_on.blog-group-jezebel .post-content h6 a,.f_branding_on .blog-group-jezebel .post-content h6 a,.f_branding_on.blog-group-jezebel .post-content li a,.f_branding_on .blog-group-jezebel .post-content li a,.f_branding_on.blog-group-jezebel .post-content p a,.f_branding_on .blog-group-jezebel .post-content p a,.f_branding_on.f_branding_jezebel_on .post-content .quotable a,.f_branding_on.f_branding_jezebel_on .post-content footer a,.f_branding_on.f_branding_jezebel_on .post-content h1 a,.f_branding_on.f_branding_jezebel_on .post-content h2 a,.f_branding_on.f_branding_jezebel_on .post-content h3 a,.f_branding_on.f_branding_jezebel_on .post-content h4 a,.f_branding_on.f_branding_jezebel_on .post-content h5 a,.f_branding_on.f_branding_jezebel_on .post-content h6 a,.f_branding_on.f_branding_jezebel_on .post-content li a,.f_branding_on.f_branding_jezebel_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jezebel .post-content .quotable a:hover,.f_branding_on .blog-group-jezebel .post-content .quotable a:hover,.f_branding_on.blog-group-jezebel .post-content footer a:hover,.f_branding_on .blog-group-jezebel .post-content footer a:hover,.f_branding_on.blog-group-jezebel .post-content h1 a:hover,.f_branding_on .blog-group-jezebel .post-content h1 a:hover,.f_branding_on.blog-group-jezebel .post-content h2 a:hover,.f_branding_on .blog-group-jezebel .post-content h2 a:hover,.f_branding_on.blog-group-jezebel .post-content h3 a:hover,.f_branding_on .blog-group-jezebel .post-content h3 a:hover,.f_branding_on.blog-group-jezebel .post-content h4 a:hover,.f_branding_on .blog-group-jezebel .post-content h4 a:hover,.f_branding_on.blog-group-jezebel .post-content h5 a:hover,.f_branding_on .blog-group-jezebel .post-content h5 a:hover,.f_branding_on.blog-group-jezebel .post-content h6 a:hover,.f_branding_on .blog-group-jezebel .post-content h6 a:hover,.f_branding_on.blog-group-jezebel .post-content li a:hover,.f_branding_on .blog-group-jezebel .post-content li a:hover,.f_branding_on.blog-group-jezebel .post-content p a:hover,.f_branding_on .blog-group-jezebel .post-content p a:hover,.f_branding_on.f_branding_jezebel_on .post-content .quotable a:hover,.f_branding_on.f_branding_jezebel_on .post-content footer a:hover,.f_branding_on.f_branding_jezebel_on .post-content h1 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h2 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h3 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h4 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h5 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h6 a:hover,.f_branding_on.f_branding_jezebel_on .post-content li a:hover,.f_branding_on.f_branding_jezebel_on .post-content p a:hover,.f_branding_on.blog-group-jezebel figcaption a,.f_branding_on .blog-group-jezebel figcaption a,.f_branding_on.f_branding_jezebel_on figcaption a{color:#ec1238}.f_branding_on.blog-group-jezebel figcaption a:hover,.f_branding_on .blog-group-jezebel figcaption a:hover,.f_branding_on.f_branding_jezebel_on figcaption a:hover{color:#bde2d}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on.blog-group-jezebel .entry-content blockquote,.f_branding_on .blog-group-jezebel .entry-content blockquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jezebel_on .entry-content blockquote{border-radius:;border-left:5px solid #ec1238;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jezebel .review-score,.f_branding_on .blog-group-jezebel .review-score,.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jezebel_on .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white){color:#ec1238;border-color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white):hover{color:#bde2d;border-color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio__name,.f_branding_on .blog-group-jezebel .author-bio__name,.f_branding_on.f_branding_jezebel_on .author-bio__name{color:#222}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name){color:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover{color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#bde2d}.f_branding_on.blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jezebel_on .sidebar-content .newsletter-subscribe{border-color:#ec1238}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jezebel .entry-content .pullquote,.f_branding_on .blog-group-jezebel .entry-content .pullquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold;position:relative;padding:36px ;text-transform:uppercase;font-weight:1;color:#ec1238;font-size:31px;line-height:33px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{display:block;content:'';position:absolute;width:23px;height:18px;left:calc(5% - 12px);background-image:url('data:image/svg+xml;utf8,<svg width="23" height="18" viewBox=" 23 18" xmlns="http://www.w3.org/2/svg"><title>jezbel-quote<\/title><path d="M23 13.46c 1.253-.45 2.323-1.345 3.21-.897.887-1.977 1.33-3.243 1.33-1.69 -2.968-.548-3.837-1.644-.87-1.95-1.36-2.426-1.36-3.99 -2.192.76-4.435 2.29-6.73C17.9 3.338 19.252 1.46 22.5 L23 1.41c-1.32 1.147-2.36 2.347-3.125 3.598-.765 1.253-1.358 2.48-1.78 3.68 1.53.14 2.73.613 3.6 1.525.87.913 1.35 1.995 1.35 3.248m-12.385 c 1.258-.457 2.328-1.373 3.21-.915.89-2 1.33-3.256 1.33-1.622 -2.878-.543-3.767-1.64-.89-1.1-1.34-2.43-1.34-3.99 -2.194.756-4.437 2.273-6.73C4.677 3.335 6.85 1.46 9.673 l.86 1.41c-1.35 1.147-2.34 2.347-3.1 3.598-.755 1.253-1.344 2.48-1.762 3.68 1.52.14 2.72.613 3.61 1.525.89.913 1.338 1.995 1.338 3.248" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{top:-6px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{bottom:-6px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;height:7px;width:calc(5% - 2px);background-color:#ec1238;-webkit-transform:skewX(-7deg);transform:skewX(-7deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:first-child{top:;left:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:last-child{bottom:;right:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left{padding:31px ;text-align:left;margin-bottom:1rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:before{display:none}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a{min-width:31px;height:31px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="31" viewBox=" 31 31" xmlns="http://www.w3.org/2/svg"><title>jezebel-wheel<\/title><path d="M18.53.852h2.96v7.85c 1-.852 2.643-1.91 3.39-.392.275-.855.582-1.42.738v-.613c.29-.284.425-1.11.425-1.762V.852zM8.46 2.337L1.684.5l5.13 6.14c.652.765 1.72 2.563.75 3.84-.12.46-.274.986-.67 1.465l-.398-.472c.3-.4-.41-1.11-.83-1.61L8.46 2.34M1.713 9.844L2.22 7.3l7.858 1.362c1 .173 2.497 1.285 3.6 2.44.27.427.434.928.492 1.54l-.613-.18c-.234-.33-1.4-.63-1.69-.716-.96-.157-6.215-1.8-9.612-1.668M1.453 19.86C.963 19.23.49 18.22 17.384l6.91-3.925c.88-.5 2.752-.6 3.938-.7.438.19.94.43 1.36.84-.63.3-.334.19-.54.3-.394-.16-1.19.193-1.763.52l-8.452 4.8m6.342 7.84l-2.73-.978 2.73-7.376c.347-.94 1.72-2.197 2.972-2.54.464-.13 1.6-.26 1.593-.218-.26.7-.135.354-.216.574-.37.17-.784.93-1.1 1.515l-3.34 9.3m9.98 1.99l-2.73.978-2.73-7.38c-.345-.94-.116-2.77.62-3.83.272-.39.6-.837 1.8-1.175.23.7.127.357.21.576-.175.364-.13 1.186.213 1.8.315.85 2.16 5.833 3.338 9.22m8.948-4.785c-.49.837-.962 1.64-1.453 2.476l-6.91-3.926c-.88-.5-1.9-2.48-2.27-3.32-.47-.474-.86-1.2.6-1.58l.537.36c.16.39.767.917 1.34 1.243l8.453 4.8m3.727-9.32l.55 2.815-7.858 1.36c-1 .175-2.792-.366-3.722-1.262-.345-.332-.732-.727-.987-1.25.73-.1.38-.62.614-.13.334.23 1.185.22 1.837.17l9.61-1.667m-3.24-9.5l2.222 1.84c-1.756 2.6-3.37 3.953-5.13 6.13-.652.765-2.38 1.485-3.676 1.387-.48-.37-1.35-.94-1.57-.33.46-.6.25-.29.4-.47.41-.36 1.52-.584 1.477-1.8l6.274-7.36" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;font-family:"ElizabethSerif",Georgia,serif;letter-spacing:7px;margin-top:4px;margin-bottom:6px;overflow:visible;text-align:center}.f_branding_on.blog-group-jezebel .storybreak-branded-b:before,.f_branding_on .blog-group-jezebel .storybreak-branded-b:before,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b:before{color:#ec1238;content:'***';display:inline-block;font-size:17px}.f_branding_on.blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on .blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b.storybreak-variant--branded{margin:;padding:4px}.f_branding_on.blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_kotaku_on.f_article_split_on .scroll-list-break{border-top:3px solid #fbc}.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#b1246;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-kotaku .post-content .quotable a,.f_branding_on .blog-group-kotaku .post-content .quotable a,.f_branding_on.blog-group-kotaku .post-content footer a,.f_branding_on .blog-group-kotaku .post-content footer a,.f_branding_on.blog-group-kotaku .post-content h1 a,.f_branding_on .blog-group-kotaku .post-content h1 a,.f_branding_on.blog-group-kotaku .post-content h2 a,.f_branding_on .blog-group-kotaku .post-content h2 a,.f_branding_on.blog-group-kotaku .post-content h3 a,.f_branding_on .blog-group-kotaku .post-content h3 a,.f_branding_on.blog-group-kotaku .post-content h4 a,.f_branding_on .blog-group-kotaku .post-content h4 a,.f_branding_on.blog-group-kotaku .post-content h5 a,.f_branding_on .blog-group-kotaku .post-content h5 a,.f_branding_on.blog-group-kotaku .post-content h6 a,.f_branding_on .blog-group-kotaku .post-content h6 a,.f_branding_on.blog-group-kotaku .post-content li a,.f_branding_on .blog-group-kotaku .post-content li a,.f_branding_on.blog-group-kotaku .post-content p a,.f_branding_on .blog-group-kotaku .post-content p a,.f_branding_on.f_branding_kotaku_on .post-content .quotable a,.f_branding_on.f_branding_kotaku_on .post-content footer a,.f_branding_on.f_branding_kotaku_on .post-content h1 a,.f_branding_on.f_branding_kotaku_on .post-content h2 a,.f_branding_on.f_branding_kotaku_on .post-content h3 a,.f_branding_on.f_branding_kotaku_on .post-content h4 a,.f_branding_on.f_branding_kotaku_on .post-content h5 a,.f_branding_on.f_branding_kotaku_on .post-content h6 a,.f_branding_on.f_branding_kotaku_on .post-content li a,.f_branding_on.f_branding_kotaku_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-kotaku .post-content .quotable a:hover,.f_branding_on .blog-group-kotaku .post-content .quotable a:hover,.f_branding_on.blog-group-kotaku .post-content footer a:hover,.f_branding_on .blog-group-kotaku .post-content footer a:hover,.f_branding_on.blog-group-kotaku .post-content h1 a:hover,.f_branding_on .blog-group-kotaku .post-content h1 a:hover,.f_branding_on.blog-group-kotaku .post-content h2 a:hover,.f_branding_on .blog-group-kotaku .post-content h2 a:hover,.f_branding_on.blog-group-kotaku .post-content h3 a:hover,.f_branding_on .blog-group-kotaku .post-content h3 a:hover,.f_branding_on.blog-group-kotaku .post-content h4 a:hover,.f_branding_on .blog-group-kotaku .post-content h4 a:hover,.f_branding_on.blog-group-kotaku .post-content h5 a:hover,.f_branding_on .blog-group-kotaku .post-content h5 a:hover,.f_branding_on.blog-group-kotaku .post-content h6 a:hover,.f_branding_on .blog-group-kotaku .post-content h6 a:hover,.f_branding_on.blog-group-kotaku .post-content li a:hover,.f_branding_on .blog-group-kotaku .post-content li a:hover,.f_branding_on.blog-group-kotaku .post-content p a:hover,.f_branding_on .blog-group-kotaku .post-content p a:hover,.f_branding_on.f_branding_kotaku_on .post-content .quotable a:hover,.f_branding_on.f_branding_kotaku_on .post-content footer a:hover,.f_branding_on.f_branding_kotaku_on .post-content h1 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h2 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h3 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h4 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h5 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h6 a:hover,.f_branding_on.f_branding_kotaku_on .post-content li a:hover,.f_branding_on.f_branding_kotaku_on .post-content p a:hover{color:#fbc}.f_branding_on.blog-group-kotaku figcaption a,.f_branding_on .blog-group-kotaku figcaption a,.f_branding_on.f_branding_kotaku_on figcaption a{color:#b1246}.f_branding_on.blog-group-kotaku figcaption a:hover,.f_branding_on .blog-group-kotaku figcaption a:hover,.f_branding_on.f_branding_kotaku_on figcaption a:hover{color:#871b49}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on.blog-group-kotaku .entry-content blockquote,.f_branding_on .blog-group-kotaku .entry-content blockquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_kotaku_on .entry-content blockquote{border-radius:;border-left:5px solid #fbc;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before,.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-kotaku .review-score,.f_branding_on .blog-group-kotaku .review-score,.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_kotaku_on .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white){color:#b1246;border-color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white):hover{color:#871b49;border-color:#871b49}.f_branding_on.blog-group-kotaku .author-bio__name,.f_branding_on .blog-group-kotaku .author-bio__name,.f_branding_on.f_branding_kotaku_on .author-bio__name{color:#222}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name){color:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover{color:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#871b49}.f_branding_on.blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_kotaku_on .sidebar-content .newsletter-subscribe{border-color:#fbc}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on.blog-group-kotaku .entry-content .pullquote,.f_branding_on .blog-group-kotaku .entry-content .pullquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before{height:7px;width:244px;background-image:url('data:image/svg+xml;utf8,<svg width="244" height="7" viewBox=" 244 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-top<\/title><g fill="none" fill-rule="evenodd"><path d="M243 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M177.167 6.972c2.622.13 5.38-1.883 6.14-4.54L184 .22 64.833.2v.4c-2.622-.13-5.38 1.884-6.14 4.54L58 6.956l.1.44 119.157-.28z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{height:7px;width:129px;background-image:url('data:image/svg+xml;utf8,<svg width="129" height="7" viewBox=" 129 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-bottom<\/title><g fill="none" fill-rule="evenodd"><path d="M128 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M81.75 6.972c2.657.13 5.452-1.883 6.224-4.54l.7-2.41-4.76-.2v.4c-2.657-.13-5.452 1.884-6.224 4.54l-.7 2.41.1.44 4.65-.28z" fill="%23FBC"/><\/g><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:before{background-image:url('data:image/svg+xml;utf8,<svg width="243" height="7" viewBox=" 243 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-lefttop<\/title><g fill="none" fill-rule="evenodd"><path d="M242.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M157.912 6.845c2.375.128 4.872-1.85 5.562-4.457L164.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 122.896-.27z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:after{background-image:url('data:image/svg+xml;utf8,<svg width="117" height="7" viewBox=" 117 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-leftbottom<\/title><g fill="none" fill-rule="evenodd"><path d="M116.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M74.912 6.845c2.375.128 4.872-1.85 5.562-4.457L81.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 39.896-.27z" fill="%23FBC"/><\/g><\/svg>')}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a{min-width:75px;height:16px;background-image:url('data:image/svg+xml;utf8,<svg width="75" height="16" viewBox=" 75 16" xmlns="http://www.w3.org/2/svg"><title>kotaku-bars<\/title><g fill="none" fill-rule="evenodd"><path fill="%23B1246" d="M 16h5VHm7 16h5VH7m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><path fill="%23FBC" d="M49 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_lifehacker_on.f_article_split_on .scroll-list-break{border-top:3px solid #94b33}.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94b33;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-lifehacker .post-content .quotable a,.f_branding_on .blog-group-lifehacker .post-content .quotable a,.f_branding_on.blog-group-lifehacker .post-content footer a,.f_branding_on .blog-group-lifehacker .post-content footer a,.f_branding_on.blog-group-lifehacker .post-content h1 a,.f_branding_on .blog-group-lifehacker .post-content h1 a,.f_branding_on.blog-group-lifehacker .post-content h2 a,.f_branding_on .blog-group-lifehacker .post-content h2 a,.f_branding_on.blog-group-lifehacker .post-content h3 a,.f_branding_on .blog-group-lifehacker .post-content h3 a,.f_branding_on.blog-group-lifehacker .post-content h4 a,.f_branding_on .blog-group-lifehacker .post-content h4 a,.f_branding_on.blog-group-lifehacker .post-content h5 a,.f_branding_on .blog-group-lifehacker .post-content h5 a,.f_branding_on.blog-group-lifehacker .post-content h6 a,.f_branding_on .blog-group-lifehacker .post-content h6 a,.f_branding_on.blog-group-lifehacker .post-content li a,.f_branding_on .blog-group-lifehacker .post-content li a,.f_branding_on.blog-group-lifehacker .post-content p a,.f_branding_on .blog-group-lifehacker .post-content p a,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a,.f_branding_on.f_branding_lifehacker_on .post-content footer a,.f_branding_on.f_branding_lifehacker_on .post-content h1 a,.f_branding_on.f_branding_lifehacker_on .post-content h2 a,.f_branding_on.f_branding_lifehacker_on .post-content h3 a,.f_branding_on.f_branding_lifehacker_on .post-content h4 a,.f_branding_on.f_branding_lifehacker_on .post-content h5 a,.f_branding_on.f_branding_lifehacker_on .post-content h6 a,.f_branding_on.f_branding_lifehacker_on .post-content li a,.f_branding_on.f_branding_lifehacker_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #9dcee7;box-shadow:inset -2px #9dcee7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on .blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on.blog-group-lifehacker .post-content footer a:hover,.f_branding_on .blog-group-lifehacker .post-content footer a:hover,.f_branding_on.blog-group-lifehacker .post-content h1 a:hover,.f_branding_on .blog-group-lifehacker .post-content h1 a:hover,.f_branding_on.blog-group-lifehacker .post-content h2 a:hover,.f_branding_on .blog-group-lifehacker .post-content h2 a:hover,.f_branding_on.blog-group-lifehacker .post-content h3 a:hover,.f_branding_on .blog-group-lifehacker .post-content h3 a:hover,.f_branding_on.blog-group-lifehacker .post-content h4 a:hover,.f_branding_on .blog-group-lifehacker .post-content h4 a:hover,.f_branding_on.blog-group-lifehacker .post-content h5 a:hover,.f_branding_on .blog-group-lifehacker .post-content h5 a:hover,.f_branding_on.blog-group-lifehacker .post-content h6 a:hover,.f_branding_on .blog-group-lifehacker .post-content h6 a:hover,.f_branding_on.blog-group-lifehacker .post-content li a:hover,.f_branding_on .blog-group-lifehacker .post-content li a:hover,.f_branding_on.blog-group-lifehacker .post-content p a:hover,.f_branding_on .blog-group-lifehacker .post-content p a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a:hover,.f_branding_on.f_branding_lifehacker_on .post-content footer a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h1 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h2 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h3 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h4 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h5 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h6 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content li a:hover,.f_branding_on.f_branding_lifehacker_on .post-content p a:hover,.f_branding_on.blog-group-lifehacker figcaption a,.f_branding_on .blog-group-lifehacker figcaption a,.f_branding_on.f_branding_lifehacker_on figcaption a{color:#39c}.f_branding_on.blog-group-lifehacker figcaption a:hover,.f_branding_on .blog-group-lifehacker figcaption a:hover,.f_branding_on.f_branding_lifehacker_on figcaption a:hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on.blog-group-lifehacker .entry-content blockquote,.f_branding_on .blog-group-lifehacker .entry-content blockquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote{border-radius:;border-left:5px solid #94b33;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-lifehacker .review-score,.f_branding_on .blog-group-lifehacker .review-score,.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_lifehacker_on .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#94b33}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white){color:#39c;border-color:#39c}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white):hover{color:#297aa3;border-color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio__name,.f_branding_on .blog-group-lifehacker .author-bio__name,.f_branding_on.f_branding_lifehacker_on .author-bio__name{color:#222}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name){color:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#297aa3}.f_branding_on.blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_lifehacker_on .sidebar-content .newsletter-subscribe{border-color:#94b33}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on.blog-group-lifehacker .entry-content .pullquote,.f_branding_on .blog-group-lifehacker .entry-content .pullquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote{padding: 23px 61px;text-align:left;max-width:4px}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#39c;-webkit-box-shadow:1px #39c,-1px #39c;box-shadow:1px #39c,-1px #39c;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:4px 3px;line-height:4px;position:relative}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{width:46px;height:36px;left:-61px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="36" viewBox=" 46 36" xmlns="http://www.w3.org/2/svg"><title>lifehacker-quote<\/title><path d="M36 L25 18v18h21V17h-8l8-17M11 L 18v18h21V17h-8l8-17" fill="%2394B33" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after{width:1px;height:36px;background-color:#94b33;right:-23px;bottom:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a{min-width:46px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="11" viewBox=" 46 11" xmlns="http://www.w3.org/2/svg"><title>lifehacker-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2394B33" d="M 11h11VH"/><path fill="%2339C" d="M18 11h11VH18"/><path fill="%2394B33" d="M35 11h11VH35"/><\/g><\/svg>')}.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{min-width:48px;height:47px;background-image:url('data:image/svg+xml;utf8,<svg width="48" height="47" viewBox=" 48 47" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>lifehacker-binder<\/title><defs><path id="a" d="M2.667 3.52H.77V.526h2.59v2.526z"/><\/defs><g fill="none" fill-rule="evenodd"><path d="M18.638 41.243c.347 .348-.568 -.568-.347 -.347.568 .568" fill="%2394B33"/><path d="M18.946 4.75c-1.36-1.347-2.153-2.62-3.35-3.824-.297-.297-.756.167-.46.466 1.2 1.22 2.315 2.477 3.352 3.824.256.334.712-.135.458-.465" fill="%2394B33"/><path d="M15.494 36.886c-1.74-.117-3.66.613-3.115 2.77.28 1.13 1.21 1.998 1.95 2.832.46.523.92 1.5 1.4 1.57.24.272.37.474.74.478.15 .26-.14.31-.24l.2-.75c.13-.4-.49-.57-.63-.17l-.3.8.31-.24c-.33 -1.16-1.26-1.4-1.54-.51-.57-1.5-1.12-1.5-1.74-.55-.76-.98-1.82-.21-2.6.56-.56 1.39-.5 2.12-.45.41.3.41-.63 -.65" fill="%2394B33"/><path d="M18.347 41.227c-.956.2-1.96.457-2.25 1.456-.258.89.197 1.853 1.13 2.3 2.43.386 2.757-4.4.655-3.797-.41.47-.415.76 .657.96-.14.6 1.11.427 1.64-.21.574-.62 1.27-1.28.76-.48-.32-.44-.975-.15-1.41.33-.487.9-.642 1.46-.642.42 .42-.658 -.658m-6.95-6.855c-.92.443-1.23 1.53-1.1 2.49.24 1.55 1.1 1.84 1.99 2.21.39.145.56-.49.17-.636-1.22-.453-2.51-2.692-.84-3.495.37-.18.4-.74-.33-.56" fill="%2394B33"/><path d="M7.78 3.77c1.56 1.365 2.166 2.683 3.33 3.956.283.312.74-.154.458-.464-1.163-1.273-2.273-2.592-3.33-3.957-.257-.333-.713.136-.458.465" fill="%2394B33"/><path d="M7.552 3.174c-.795.645-1.212 1.656-1.17 2.683.42.416.69.42.648 -.9-.877.24-1.667.917-2.218.326-.27-.135-.73-.458-.47" fill="%2394B33"/><path d="M6.338 32.87c1.373 1.997 2.885 3.88 4.54 5.644.29.31.747-.15.46-.46-1.618-1.72-3.1-3.56-4.44-5.51-.236-.34-.8-.1-.56.34M2.32 23.86c1.26 1.41 2.453 2.873 3.578 4.395.247.335.81.8.56-.33-1.157-1.57-2.382-3.8-3.68-4.53-.28-.315-.737.15-.457.464" fill="%2394B33"/><path d="M6.246 27.827c-1.23-.156-2.33.427-2.13 1.547-.11 1.262 1.225 2.29 1.97 3.122.282.315.74-.152.46-.464-.42-.468-.854-.924-1.256-1.45-.27-.246-.44-.533-.51-.86-.17-.82.53-1.422 1.294-1.35.48.62.584-.57.172-.635" fill="%2394B33"/><path d="M2.377 23.144C.73 23.118-.278 24.674.34 26.21c.372.982 1.224 1.835 1.883 2.624.872 1.43 1.786 2.34 2.823 2.91.32.27.78-.194.46-.465-1.138-.96-2.124-2.6-3.72-3.21-.48-.59-1.3-1.16-1.372-1.84-.584-1.17.2-2.45 1.35-2.43.418 .418-.65 -.66" fill="%2394B33"/><path d="M3.83 24.67c2.76-2.947 3.984-6.12 5.69-9.194.57-1.62 1.92-5.88 3.52-4.11.863.527 1.453 1.582 2.46 2.375.585.79 1.17 1.57 1.756 2.36.25.34.812.1.56-.33l-2.132-2.86c-.53-.71-1.4-1.5-1.775-2.1-1.49-1.4-2.423.8-3.74 1.4-2.7 4.2-4.46 8.23-7.15 12.5-.24.35.32.68.56.33m14.97-6.51c.84.83 1.59 1.72 2.34 2.63.27.33.73-.14.46-.46-.75-.91-1.5-1.79-2.33-2.62-.3-.29-.76.17-.46.47m4.52 4.61c1.96 1.96 4 3.81 6.11 5.6.32.27.78-.19.46-.46-2.11-1.79-4.15-3.64-6.11-5.6-.3-.29-.76.17-.46.47" fill="%2394B33"/><path d="M19.263 43.354c1.434-2.52 2.87-5.4 4.33-7.57.718-1.25 1.435-2.52 2.152-3.754.65-1.133 1.243-2.717 2.222-3.596.464-.415 1.8-.428 1.542.62.166.17.242.7.285.94.84.47.97.96.19 1.43.173.87.55 1.7 1.9 2.4.58.75 1.292 1.25 2.12 1.71.5.28 1.7.57 1.36 1.1.62 1.14-.52 1.92-1.44 2.22-.4.13-.23.76.17.63.96-.31 2.3-.99 2.12-2.12.9-1.15-.9-1.83-1.77-2.34-1.41-.83-2.53-1.82-2.95-3.49-.26-1.4-.7-2.52-.96-3.29-.76-.65-1.71-.29-2.32.36-1.13 1.19-1.83 2.94-2.65 4.36L18.7 43.2c-.21.368.35.7.56.332" fill="%2394B33"/><path d="M18.524 44.16l15.417-5.356c.4-.137.23-.772-.17-.634l-15.42 5.357c-.39.136-.22.772.18.634" fill="%2394B33"/><path d="M19.892 43.348c-.897.385-2.5 1.183-1.64 2.35.28.796 1.28 1.75 2.3.76.876-.38 1.28-1.473 1.25-2.385-.68-.846-.927-1.777-1.765-1.12-.326.254-.3.825.327.566.73-.55.836.77.755 1.18-.96.49-.384 1.5-.9 1.19-.46.12-1.76-.13-1.52-.68.3-.72.84-1.7 1.394-1.31.38-.17.5-.73-.33-.57" fill="%2394B33"/><g transform="translate(16.8 43.636)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M.15 1.16c.573.747 1.26 1.377 2.4 1.892.35.23.676-.338.327-.568C1.78 1.945 1.147 1.344.61.64.353.38-.13.776.15 1.17" fill="%2394B33" mask="url(%23b)"/><\/g><path d="M15.728 37.47c.878-3.268 2.82-6.17 4.473-9.77l5.7-8.95c.79-1.376 1.49-2.88 2.42-4.155.96-1.37 2.33-1.59 3.82-1.865 2.24-.415 4.3-1.36 4.36-3.842.6-4.545-3.33-9.333-7.83-9.613C26.1-.11 24.9.68 23.29 2.59c-1.123 2.695.3 5.637-1.438 8.21-1.1 1.624-2.637 3-3.97 4.424l-3.86 4.116-8.36 8.87c-.287.38.17.774.46.466l13.35-14.253c1.66-1.77 3.612-3.52 3.934-6.6.32-2.54-.724-6.44 2.234-7.324 4.93-2.14 1.68 4.14 9.44 9.3-.755 2.98-3.88 2.4-6.1 3.35-.94.38-1.55 1.5-2.9 1.87-.894 1.35-1.634 2.83-2.436 4.23l-5.17 9.9c-1.583 2.78-3.38 5.55-4.22 8.68-.11.41.515.58.624.17" fill="%2394B33"/><path d="M5.26 31.196c2.932.283 5.2-2.353 6.686-4.398 2.21-2.686 4.27-5.497 6.482-8.18 1.125-1.365 2.29-2.695 3.53-3.955.988-1.4 2.65-1.962 2.818-3.17.757-1.215.942-2.5.82-3.912-.14-1.62-.592-5.74 2.273-5.3.4.1.57-.53.17-.63-1.5-.26-2.9.2-2.69 1.12-.81 1.24-.59 2.79-.45 4.17.21 2.14-.26 3.66-1.69 5.24-1.12 1.25-2.35 2.38-3.47 3.63-2.36 2.65-4.47 5.5-6.67 8.28-1.86 2.36-4.4 6.53-7.83 6.2-.42-.4-.42.62 .66" fill="%2394B33"/><path d="M27.74 2.567c3.7.46 5.95 3.983 5.18 7.12-.733 3.155-4.715.37-6.8 2.546-.226.36.335.69.56.332.543-.868 2-.56 2.847-.526.62-.2 1.267-.8 1.84-.34 1.312-.59 1.66-2.4 1.543-3.38-.274-3.11-2.82-6-5.89-6.42-.41-.6-.47.6 .65" fill="%2394B33"/><path d="M13.184 37.95c.393-2.47 1.518-4.688 2.65-6.885 1.11-2.158 2.278-4.287 3.512-6.376 2.41-4.8 5.83-7.99 7.888-11.8.25-.34-.313-.67-.56-.33-2.878 3.91-5.616 7.92-8.76 12.11-1.232 2.1-2.398 4.24-3.57 6.41-1.9 2.13-2.15 4.29-2.53 6.68-.6.41.56.59.63.17M27.3 26.37c2.16-.15 5.43-.3 6.38-2.67.586-1.45.746-2.91 2.55-3.21 1.525-.252 3.16.267 4.596.745 1.593.53 3.165 1.294 4.32 2.56 1.158 1.27 2.14 3.21 1.476 4.942-1.143 2.974-4.62 1.44-6.82.93-3.265-.72-6.127 1.96-8.715 2.894-.343.24-.2.81.327.57 1.565-1.8 3.19-2.21 5.43-2.72 1.685-.46 3.147-.11 4.78.31 2.22.58 4.92.93 5.977-1.68 1.76-2.67-1.46-5.62-3.163-7.1-1.49-.98-3.24-1.55-4.96-1.96-1.23-.29-2.63-.48-3.84.3-1.47.63-1.62 2.3-2.16 3.37-.82 2.4-3.93 2.14-5.78 2.27-.41.3-.41.69 .66" fill="%2394B33"/><path d="M28.98 27.835c2.463-.212 5.497-.644 6.547-3.298.336-.85.365-1.976 1.42-2.257.866-.23 1.942.194 2.744.5 1.51.576 3.2 1.457 4.29 2.693.78.88 1.27 2.253-.14 2.864-.83.36-1.75.4-2.57-.198-1.28-.38-2.55-.59-3.89-.5-2.7.18-5.24 1.39-7.1 3.38-.29.31.17.77.46.46 2.58-2.76 6.44-3.83 1.5-2.81 1.27.36 2.82.88 3.95-.13.93-.84.76-2.4.11-3.1-.83-1.25-2.28-2.12-3.58-2.78-1.28-.65-3.5-1.51-4.51-1.13-1.57.41-1.4 2.1-2.12 3.18-1.18 1.93-3.68 2.17-5.69 2.34-.42.3-.42.69 .66" fill="%2394B33"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion .headline,.f_branding_on .blog-group-theonion .headline,.f_branding_on.blog-group-theonion .inset-headline,.f_branding_on .blog-group-theonion .inset-headline,.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .headline,.f_branding_on.f_branding_theonion_on .inset-headline,.f_branding_on.f_branding_theonion_on .kinja-slide__caption,.f_branding_on.blog-group-theonion .post-content h1,.f_branding_on .blog-group-theonion .post-content h1,.f_branding_on.blog-group-theonion .post-content h2,.f_branding_on .blog-group-theonion .post-content h2,.f_branding_on.blog-group-theonion .post-content h3,.f_branding_on .blog-group-theonion .post-content h3,.f_branding_on.blog-group-theonion .post-content h4,.f_branding_on .blog-group-theonion .post-content h4,.f_branding_on.blog-group-theonion .post-content h5,.f_branding_on .blog-group-theonion .post-content h5,.f_branding_on.blog-group-theonion .post-content h6,.f_branding_on .blog-group-theonion .post-content h6,.f_branding_on.f_branding_theonion_on .post-content h1,.f_branding_on.f_branding_theonion_on .post-content h2,.f_branding_on.f_branding_theonion_on .post-content h3,.f_branding_on.f_branding_theonion_on .post-content h4,.f_branding_on.f_branding_theonion_on .post-content h5,.f_branding_on.f_branding_theonion_on .post-content h6{font-family:"ElizabethSerif",Georgia,serif}.f_branding_on.blog-group-theonion.permalink .post .entry-title,.f_branding_on .blog-group-theonion.permalink .post .entry-title,.f_branding_on.f_branding_theonion_on.permalink .post .entry-title{font-size:34px;line-height:1.3}.f_branding_on.blog-group-theonion .postlist__item .headline,.f_branding_on .blog-group-theonion .postlist__item .headline,.f_branding_on.f_branding_theonion_on .postlist__item .headline{font-size:22px;line-height:1.4}.f_branding_on.blog-group-theonion .thumb-inset .inset-headline,.f_branding_on .blog-group-theonion .thumb-inset .inset-headline,.f_branding_on.f_branding_theonion_on .thumb-inset .inset-headline{font-size:14px;line-height:1.4}.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .kinja-slide__caption{font-size:13px;line-height:1.5}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theonion .entry-content .pullquote,.f_branding_on .blog-group-theonion .entry-content .pullquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theonion_on .entry-content .pullquote{border-top:none;border-bottom:8px solid #6b3a;padding: 3px;position:relative;font-size:28px;line-height:1.3;text-align:left;font-family:"ElizabethSerif",Georgia,serif;font-weight:bold;color:#6b3a}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--left{margin-top:}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-a{min-width:6px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="6" height="5" viewBox=" 6 5" xmlns="http://www.w3.org/2/svg"><title>onion-storybreak<\/title><path d="M h6v1Hzm 4h6v1Hz" fill="%2391D8B6" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{display:none !important}.f_branding_on .networknav__hovernav-wrapper.theonion .hovernav__post-list h4{font-family:"ElizabethSerif",Georgia,serif;font-size:15px;line-height:1.4}.f_branding_on.blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theroot_on.f_article_split_on .scroll-list-break{border-top:3px solid #59b22}.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#59b22;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theroot .post-content .quotable a,.f_branding_on .blog-group-theroot .post-content .quotable a,.f_branding_on.blog-group-theroot .post-content footer a,.f_branding_on .blog-group-theroot .post-content footer a,.f_branding_on.blog-group-theroot .post-content h1 a,.f_branding_on .blog-group-theroot .post-content h1 a,.f_branding_on.blog-group-theroot .post-content h2 a,.f_branding_on .blog-group-theroot .post-content h2 a,.f_branding_on.blog-group-theroot .post-content h3 a,.f_branding_on .blog-group-theroot .post-content h3 a,.f_branding_on.blog-group-theroot .post-content h4 a,.f_branding_on .blog-group-theroot .post-content h4 a,.f_branding_on.blog-group-theroot .post-content h5 a,.f_branding_on .blog-group-theroot .post-content h5 a,.f_branding_on.blog-group-theroot .post-content h6 a,.f_branding_on .blog-group-theroot .post-content h6 a,.f_branding_on.blog-group-theroot .post-content li a,.f_branding_on .blog-group-theroot .post-content li a,.f_branding_on.blog-group-theroot .post-content p a,.f_branding_on .blog-group-theroot .post-content p a,.f_branding_on.f_branding_theroot_on .post-content .quotable a,.f_branding_on.f_branding_theroot_on .post-content footer a,.f_branding_on.f_branding_theroot_on .post-content h1 a,.f_branding_on.f_branding_theroot_on .post-content h2 a,.f_branding_on.f_branding_theroot_on .post-content h3 a,.f_branding_on.f_branding_theroot_on .post-content h4 a,.f_branding_on.f_branding_theroot_on .post-content h5 a,.f_branding_on.f_branding_theroot_on .post-content h6 a,.f_branding_on.f_branding_theroot_on .post-content li a,.f_branding_on.f_branding_theroot_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theroot .post-content .quotable a:hover,.f_branding_on .blog-group-theroot .post-content .quotable a:hover,.f_branding_on.blog-group-theroot .post-content footer a:hover,.f_branding_on .blog-group-theroot .post-content footer a:hover,.f_branding_on.blog-group-theroot .post-content h1 a:hover,.f_branding_on .blog-group-theroot .post-content h1 a:hover,.f_branding_on.blog-group-theroot .post-content h2 a:hover,.f_branding_on .blog-group-theroot .post-content h2 a:hover,.f_branding_on.blog-group-theroot .post-content h3 a:hover,.f_branding_on .blog-group-theroot .post-content h3 a:hover,.f_branding_on.blog-group-theroot .post-content h4 a:hover,.f_branding_on .blog-group-theroot .post-content h4 a:hover,.f_branding_on.blog-group-theroot .post-content h5 a:hover,.f_branding_on .blog-group-theroot .post-content h5 a:hover,.f_branding_on.blog-group-theroot .post-content h6 a:hover,.f_branding_on .blog-group-theroot .post-content h6 a:hover,.f_branding_on.blog-group-theroot .post-content li a:hover,.f_branding_on .blog-group-theroot .post-content li a:hover,.f_branding_on.blog-group-theroot .post-content p a:hover,.f_branding_on .blog-group-theroot .post-content p a:hover,.f_branding_on.f_branding_theroot_on .post-content .quotable a:hover,.f_branding_on.f_branding_theroot_on .post-content footer a:hover,.f_branding_on.f_branding_theroot_on .post-content h1 a:hover,.f_branding_on.f_branding_theroot_on .post-content h2 a:hover,.f_branding_on.f_branding_theroot_on .post-content h3 a:hover,.f_branding_on.f_branding_theroot_on .post-content h4 a:hover,.f_branding_on.f_branding_theroot_on .post-content h5 a:hover,.f_branding_on.f_branding_theroot_on .post-content h6 a:hover,.f_branding_on.f_branding_theroot_on .post-content li a:hover,.f_branding_on.f_branding_theroot_on .post-content p a:hover,.f_branding_on.blog-group-theroot figcaption a,.f_branding_on .blog-group-theroot figcaption a,.f_branding_on.f_branding_theroot_on figcaption a{color:#59b22}.f_branding_on.blog-group-theroot figcaption a:hover,.f_branding_on .blog-group-theroot figcaption a:hover,.f_branding_on.f_branding_theroot_on figcaption a:hover{color:#3a7119}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on.blog-group-theroot .entry-content blockquote,.f_branding_on .blog-group-theroot .entry-content blockquote,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theroot_on .entry-content blockquote{border-radius:;border-left:5px solid #dd6634;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before,.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theroot .entry-content .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote__content,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theroot .review-score,.f_branding_on .blog-group-theroot .review-score,.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theroot_on .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#dd6634}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white){color:#59b22;border-color:#59b22}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white):hover{color:#3a7119;border-color:#3a7119}.f_branding_on.blog-group-theroot .author-bio__name,.f_branding_on .blog-group-theroot .author-bio__name,.f_branding_on.f_branding_theroot_on .author-bio__name{color:#222}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name){color:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover{color:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#3a7119}.f_branding_on.blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theroot_on .sidebar-content .newsletter-subscribe{border-color:#dd6634}.f_branding_on.blog-group-theroot .entry-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote{padding: 2px;max-width:4px}.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#;-webkit-box-shadow:2px #,-2px #;box-shadow:2px #,-2px #;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:1px ;line-height:37px;font-size:26px;font-weight:normal;font-style:normal;position:relative}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{width:15px;height:32px;left:-2px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="15" height="32" viewBox=" 15 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-green<\/title><path d="M14.345 Hv32h3.627" fill="%2359B22" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after{width:14px;height:32px;right:-2px;bottom:;background-image:url('data:image/svg+xml;utf8,<svg width="14" height="32" viewBox=" 14 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-red<\/title><path d="M 32h14Vh-4" fill="%23DD6634" fill-rule="evenodd"/><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-a{min-width:24px;height:55px;background-image:url('data:image/svg+xml;utf8,<svg width="24" height="55" viewBox=" 24 55" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-afropicker<\/title><g fill-rule="evenodd"><path d="M23.32 27.59l-6.346-4.574-.475-4.45-2.83.42 2.79-1.39 2.3-3.49 2.393-2.87.14-1.63-2.347-5.31-1.22-.328-2.66.42-2.856-.66-1.62.74v1.68l2.13 1.7s2.638.54 2.83.44c.19-.1 2.686-1.2 2.686-1.2L16.2 9.17l1.73 3.3-3.3-2.74-1.162.66-1.258.233-.28.838-.852 4.264-.218-3.655-.76.343-.766-.19-1.625.81-2.3-.643L3.63 8.84l-.29.91.62 1.384.96 3.87.664.67 1.38 2.44.128 1.336-.364 3.56L 27.586v7.69h1.243V54.54c .258.21.467.467.467s.466-.21.466-.468V35.27H3.73v19.27c .26.21.468.467.468.258 .467-.21.467-.47v-19.26h1.554v19.265c .258.21.467.467.467.258 .467-.21.467-.47V35.278h1.554v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.55v19.265c .258.21.467.46.467s.463-.21.463-.47V35.278h1.554v19.265c .258.21.467.47.467.255 .464-.21.464-.47V35.278h1.555v19.265c .258.25.467.462.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.47.467s.466-.21.466-.47V35.278h1.246V27.59z"/><path d="M1.515 11.187c.144-.48.956-.526.956-.526l.43-1.9s-1.29-3.39-1.29-3.54c-.14-1.25-2.49-1.25-2.49l-.8-.325-1.29.56-.47 1.162 2.91 6.16s.67.144.81.96m-2.77.57l1.1-.813-2.59-5.4-.91-.336-1.48 1.484-.24 1.387 2.87 3.2m7.26-1.95l.82-.53-1.44-.39-1.4-1.246.776 1.73m2.38-8.9l-.998 1.242.562 2.8 1.46.29 1.89-.19V1.44L16.51.98m-5.938 3.62l1.84-.84 1.314.28-.46-1.58L12.32.98l-1.714.56-.643 1.56.61 2.285"/><\/g><\/svg>')}.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{min-width:32px;height:41px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="41" viewBox=" 32 41" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-fist<\/title><g fill-rule="evenodd"><path d="M2.474 L18.62 2.18l1.2 3.524 2.85.53 3.698-.335V2.517l-2.51-2.35m-5.22 5.37l-.848-2.77-1.693-1.47-3.48.985-.75 1.85 1.466 4.1V6.52l2.868-1.473m-1.3 11.73S12.87 1.82 12.87 1.57c-.252-2.22-4.378-2.22-4.378L9.228 5.62l-2.296.982-.825 2.46L11.26 19.46s1.185.252 1.44.17c.253-.85 1.693-.924 1.693-.924l.762-1.93zM4.994 9.73l4.58 9.475-1.786 1.43-2.37-.84-5.8-5.62.422-2.432 2.625-2.6m11.313 3.433l1.376 3.34 2.22.755 1.46-.925-2.55-.677"/><path d="M6.266 4.37L6.66 34.1l-.283-2.328-2.47-4.27-1.192-1.168-1.612-6.792L 17.112l.57-1.594L4.62 21.25l3.592 1.13 2.88-1.426 1.353.336 1.347-.63.388 6.47 1.51-7.48.495-1.474 2.23-.48 2.66-1.64 5.37 4.746-3.54-5.32 4.472-3.174s-4.38 1.616-4.72 1.784c-.34.167-4.664-.78-4.664-.78l-3.15-2.985V7.99l2.462-1.31 4.783 1.64 3.587-.736 2.125.574 4.145 9.32-.257 2.81-4.24 5.35-4.74 6.124-4.933 2.44 5.4-.78 1.133 7.773H6.266z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_thetakeout_on.f_article_split_on .scroll-list-break{border-top:3px solid #E5371A}.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#E5371A;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-thetakeout .post-content .quotable a,.f_branding_on .blog-group-thetakeout .post-content .quotable a,.f_branding_on.blog-group-thetakeout .post-content footer a,.f_branding_on .blog-group-thetakeout .post-content footer a,.f_branding_on.blog-group-thetakeout .post-content h1 a,.f_branding_on .blog-group-thetakeout .post-content h1 a,.f_branding_on.blog-group-thetakeout .post-content h2 a,.f_branding_on .blog-group-thetakeout .post-content h2 a,.f_branding_on.blog-group-thetakeout .post-content h3 a,.f_branding_on .blog-group-thetakeout .post-content h3 a,.f_branding_on.blog-group-thetakeout .post-content h4 a,.f_branding_on .blog-group-thetakeout .post-content h4 a,.f_branding_on.blog-group-thetakeout .post-content h5 a,.f_branding_on .blog-group-thetakeout .post-content h5 a,.f_branding_on.blog-group-thetakeout .post-content h6 a,.f_branding_on .blog-group-thetakeout .post-content h6 a,.f_branding_on.blog-group-thetakeout .post-content li a,.f_branding_on .blog-group-thetakeout .post-content li a,.f_branding_on.blog-group-thetakeout .post-content p a,.f_branding_on .blog-group-thetakeout .post-content p a,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a,.f_branding_on.f_branding_thetakeout_on .post-content footer a,.f_branding_on.f_branding_thetakeout_on .post-content h1 a,.f_branding_on.f_branding_thetakeout_on .post-content h2 a,.f_branding_on.f_branding_thetakeout_on .post-content h3 a,.f_branding_on.f_branding_thetakeout_on .post-content h4 a,.f_branding_on.f_branding_thetakeout_on .post-content h5 a,.f_branding_on.f_branding_thetakeout_on .post-content h6 a,.f_branding_on.f_branding_thetakeout_on .post-content li a,.f_branding_on.f_branding_thetakeout_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f9db5d;box-shadow:inset -2px #f9db5d;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on .blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on.blog-group-thetakeout .post-content footer a:hover,.f_branding_on .blog-group-thetakeout .post-content footer a:hover,.f_branding_on.blog-group-thetakeout .post-content h1 a:hover,.f_branding_on .blog-group-thetakeout .post-content h1 a:hover,.f_branding_on.blog-group-thetakeout .post-content h2 a:hover,.f_branding_on .blog-group-thetakeout .post-content h2 a:hover,.f_branding_on.blog-group-thetakeout .post-content h3 a:hover,.f_branding_on .blog-group-thetakeout .post-content h3 a:hover,.f_branding_on.blog-group-thetakeout .post-content h4 a:hover,.f_branding_on .blog-group-thetakeout .post-content h4 a:hover,.f_branding_on.blog-group-thetakeout .post-content h5 a:hover,.f_branding_on .blog-group-thetakeout .post-content h5 a:hover,.f_branding_on.blog-group-thetakeout .post-content h6 a:hover,.f_branding_on .blog-group-thetakeout .post-content h6 a:hover,.f_branding_on.blog-group-thetakeout .post-content li a:hover,.f_branding_on .blog-group-thetakeout .post-content li a:hover,.f_branding_on.blog-group-thetakeout .post-content p a:hover,.f_branding_on .blog-group-thetakeout .post-content p a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a:hover,.f_branding_on.f_branding_thetakeout_on .post-content footer a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h1 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h2 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h3 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h4 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h5 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h6 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content li a:hover,.f_branding_on.f_branding_thetakeout_on .post-content p a:hover{color:#F9DB5D}.f_branding_on.blog-group-thetakeout figcaption a,.f_branding_on .blog-group-thetakeout figcaption a,.f_branding_on.f_branding_thetakeout_on figcaption a{color:#E5371A}.f_branding_on.blog-group-thetakeout figcaption a:hover,.f_branding_on .blog-group-thetakeout figcaption a:hover,.f_branding_on.f_branding_thetakeout_on figcaption a:hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on.blog-group-thetakeout .entry-content blockquote,.f_branding_on .blog-group-thetakeout .entry-content blockquote,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote{border-radius:;border-left:5px solid #17466;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before,.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-thetakeout .review-score,.f_branding_on .blog-group-thetakeout .review-score,.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_thetakeout_on .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white){color:#E5371A;border-color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white):hover{color:#b72c15;border-color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio__name,.f_branding_on .blog-group-thetakeout .author-bio__name,.f_branding_on.f_branding_thetakeout_on .author-bio__name{color:#222}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name){color:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#b72c15}.f_branding_on.blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_thetakeout_on .sidebar-content .newsletter-subscribe{border-color:#17466}.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{padding:3px;max-width:4px;border:1px solid #F9DB5D;border-radius:5px;font-style:normal;text-align:left;position:relative;margin-top:3rem}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before{display:block;content:'';position:absolute;margin:;width:79px;height:33px;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="79" height="33" viewBox=" 79 33" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>pq-thetakeout<\/title><defs><path id="a" d="M334.76 H.5v136.817h334.26z"/><path id="c" d="M22.72 v18.41HVh22.72z"/><\/defs><g fill="none" fill-rule="evenodd"><g transform="translate(-3)"><mask id="b" fill="%23fff"><use xlink:href="%23a"/><\/mask><path d="M16.262 21.627l-.775-14.652c-.27-3.65-3.31-6.475-6.972-6.475H4.28c-3.662 -6.74 2.825-6.974 6.474l-.775 14.652c-.8 1.95-.99 1.944-2.9 1.944H3.998C2.67 23.57.5 25.134.5 27.64v16.258c 1.93 1.565 3.495 3.496 3.495H331.21c1.93 3.496-1.565 3.496-3.495V27.64c-1.93-1.565-3.494-3.496-3.494H18.354c-1.1 -2.1-.85-2.92-1.944z" stroke="%23F9DB5D" mask="url(#b)"/><\/g><g transform="translate(28 14)"><mask id="d" fill="%23fff"><use xlink:href="%23c"/><\/mask><path d="M12.243 11.274c-6.46 4.37-9.844 5.722-11.13.43-.33.86-.43 1.353.127l.923.923c.435.49.31 1.45-.6 1.353-.674.493-4.34 3.2-4.37 7.384 1.5-.43 2.465-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43-2.338 -5.6-1.783-5.6-7.136M 11.274C 4.814 4.36 1.43 5.722.26c.43-.36.86-.43 1.353.124l.923.923c.43.492.37 1.46-.62 1.354-.676.496-4.36 3.2-4.368 7.387 1.46-.43 2.46-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43C3.26 18.41 16.628 11.274" fill="%23F9DB5D" mask="url(#d)"/><\/g><\/g><\/svg>');left:3px;top:-24px}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote .pullquote__content{padding:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:1.5rem;margin-bottom:1rem}}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a{min-width:19px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="19" height="13" viewBox=" 19 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-a<\/title><g stroke="%23F9DB5D" fill="none" fill-rule="evenodd"><path d="M3.35 5.733c-.28.17-.47.345-.47.523v2.18c 1.728 1.413 3.14 3.14 3.14H22.77c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M26.96.5H3.116C1.676.5.5 1.677.5 3.117s1.177 2.616 2.616 2.616h.235c.255-1.48 1.548-2.616 3.96-2.616H22.77c1.548 2.84 1.136 3.92 2.616h.234c1.44 2.617-1.177 2.617-2.616 -1.44-1.178-2.617-2.617-2.617zM43.9 5.733c-.3.17-.5.345-.5.523v2.18c 1.728 1.414 3.14 3.14 3.14h16.33c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M65.834.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.54-2.616 3.9-2.616h16.324c1.55 2.84 1.136 3.93 2.616h.233c1.44 2.617-1.177 2.618-2.616C68.45 1.677 67.274.5 65.835.5zm16.993 5.233c-.3.17-.48.345-.48.523v2.18c 1.728 1.41 3.14 3.14 3.14h16.323c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M15.572.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.544-2.616 3.92-2.616h16.322c1.55 2.84 1.136 3.93 2.616h.234c1.44 2.616-1.177 2.616-2.616 -1.44-1.177-2.617-2.616-2.617z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{min-width:43px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="43" height="13" viewBox=" 43 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-b<\/title><path d="M7 1.38L36.154 1M7 12.38L36.154 12M.5 6.735l42.11-.445" stroke="%23E5371A" fill="none" stroke-linecap="round"/><\/svg>')}.f_branding_on.blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_splinter_on.f_article_split_on .scroll-list-break{border-top:3px solid #f85637}.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#f85637;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-splinter .post-content .quotable a,.f_branding_on .blog-group-splinter .post-content .quotable a,.f_branding_on.blog-group-splinter .post-content footer a,.f_branding_on .blog-group-splinter .post-content footer a,.f_branding_on.blog-group-splinter .post-content h1 a,.f_branding_on .blog-group-splinter .post-content h1 a,.f_branding_on.blog-group-splinter .post-content h2 a,.f_branding_on .blog-group-splinter .post-content h2 a,.f_branding_on.blog-group-splinter .post-content h3 a,.f_branding_on .blog-group-splinter .post-content h3 a,.f_branding_on.blog-group-splinter .post-content h4 a,.f_branding_on .blog-group-splinter .post-content h4 a,.f_branding_on.blog-group-splinter .post-content h5 a,.f_branding_on .blog-group-splinter .post-content h5 a,.f_branding_on.blog-group-splinter .post-content h6 a,.f_branding_on .blog-group-splinter .post-content h6 a,.f_branding_on.blog-group-splinter .post-content li a,.f_branding_on .blog-group-splinter .post-content li a,.f_branding_on.blog-group-splinter .post-content p a,.f_branding_on .blog-group-splinter .post-content p a,.f_branding_on.f_branding_splinter_on .post-content .quotable a,.f_branding_on.f_branding_splinter_on .post-content footer a,.f_branding_on.f_branding_splinter_on .post-content h1 a,.f_branding_on.f_branding_splinter_on .post-content h2 a,.f_branding_on.f_branding_splinter_on .post-content h3 a,.f_branding_on.f_branding_splinter_on .post-content h4 a,.f_branding_on.f_branding_splinter_on .post-content h5 a,.f_branding_on.f_branding_splinter_on .post-content h6 a,.f_branding_on.f_branding_splinter_on .post-content li a,.f_branding_on.f_branding_splinter_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-splinter .post-content .quotable a:hover,.f_branding_on .blog-group-splinter .post-content .quotable a:hover,.f_branding_on.blog-group-splinter .post-content footer a:hover,.f_branding_on .blog-group-splinter .post-content footer a:hover,.f_branding_on.blog-group-splinter .post-content h1 a:hover,.f_branding_on .blog-group-splinter .post-content h1 a:hover,.f_branding_on.blog-group-splinter .post-content h2 a:hover,.f_branding_on .blog-group-splinter .post-content h2 a:hover,.f_branding_on.blog-group-splinter .post-content h3 a:hover,.f_branding_on .blog-group-splinter .post-content h3 a:hover,.f_branding_on.blog-group-splinter .post-content h4 a:hover,.f_branding_on .blog-group-splinter .post-content h4 a:hover,.f_branding_on.blog-group-splinter .post-content h5 a:hover,.f_branding_on .blog-group-splinter .post-content h5 a:hover,.f_branding_on.blog-group-splinter .post-content h6 a:hover,.f_branding_on .blog-group-splinter .post-content h6 a:hover,.f_branding_on.blog-group-splinter .post-content li a:hover,.f_branding_on .blog-group-splinter .post-content li a:hover,.f_branding_on.blog-group-splinter .post-content p a:hover,.f_branding_on .blog-group-splinter .post-content p a:hover,.f_branding_on.f_branding_splinter_on .post-content .quotable a:hover,.f_branding_on.f_branding_splinter_on .post-content footer a:hover,.f_branding_on.f_branding_splinter_on .post-content h1 a:hover,.f_branding_on.f_branding_splinter_on .post-content h2 a:hover,.f_branding_on.f_branding_splinter_on .post-content h3 a:hover,.f_branding_on.f_branding_splinter_on .post-content h4 a:hover,.f_branding_on.f_branding_splinter_on .post-content h5 a:hover,.f_branding_on.f_branding_splinter_on .post-content h6 a:hover,.f_branding_on.f_branding_splinter_on .post-content li a:hover,.f_branding_on.f_branding_splinter_on .post-content p a:hover,.f_branding_on.blog-group-splinter figcaption a,.f_branding_on .blog-group-splinter figcaption a,.f_branding_on.f_branding_splinter_on figcaption a{color:#f85637}.f_branding_on.blog-group-splinter figcaption a:hover,.f_branding_on .blog-group-splinter figcaption a:hover,.f_branding_on.f_branding_splinter_on figcaption a:hover{color:#f32e9}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on.blog-group-splinter .entry-content blockquote,.f_branding_on .blog-group-splinter .entry-content blockquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_splinter_on .entry-content blockquote{border-radius:;border-left:5px solid #f85637;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before,.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-splinter .entry-content .pullquote__content,.f_branding_on .blog-group-splinter .entry-content .pullquote__content,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_splinter_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-splinter .review-score,.f_branding_on .blog-group-splinter .review-score,.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_splinter_on .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white){color:#f85637;border-color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white):hover{color:#f32e9;border-color:#f32e9}.f_branding_on.blog-group-splinter .author-bio__name,.f_branding_on .blog-group-splinter .author-bio__name,.f_branding_on.f_branding_splinter_on .author-bio__name{color:#222}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name){color:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover{color:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#f32e9}.f_branding_on.blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_splinter_on .sidebar-content .newsletter-subscribe{border-color:#f85637}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on.blog-group-splinter .entry-content .pullquote,.f_branding_on .blog-group-splinter .entry-content .pullquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_splinter_on .entry-content .pullquote{border-top:4px solid #f85637;padding-top:3px;padding-bottom:;position:relative;font-weight:bold;font-style:normal}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before{height:32px;width:32px;position:absolute;left:calc(5% - 18px);top:-18px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="32" viewBox=" 32 32" xmlns="http://www.w3.org/2/svg"><title>splinter-pq<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M 32h32VH"/><path d="M14 7.466c-.15-.227.162-.42.39-.423L17.657 7c.233-.2.417.195.398.427C17.82 1.26 16.49 26.6 15.94 26.6c-.547 -1.735-15.85-1.94-18.593z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-a{min-width:31px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="5" viewBox=" 31 5" xmlns="http://www.w3.org/2/svg"><title>storybreak-1-splinter<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M1.47 9.33l6.696-3.54v7.495l-6.696 3.6"/><path d="M9.167 24.32H7.223V5.27c-1.455-1.183-2.637-2.637-2.637S1.95 3.572 1.95 5.27V24.32H.5V5.27C.5 2.5 2.6.447 4.585.447c2.527 4.58 2.54 4.58 4.58V24.32z" fill="%23"/><path d="M11.84 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.637-1.18 2.637-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.81c 2.53-2.5 4.58-4.58 4.58" fill="%23"/><path d="M19.2 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.638-1.18 2.638-2.63v-6.8c-1.45-1.184-2.64-2.638-2.64m 14.2c-2.525 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.55-4.58 4.58-4.58 2.526 4.58 2.6 4.58 4.58v6.8c 2.53-2.54 4.58-4.58 4.58" fill="%23"/><path d="M26.2 17.935c-1.453 -2.636 1.183-2.636 2.638v6.8c 1.455 1.183 2.638 2.637 2.638 1.46 2.64-1.18 2.64-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.8c 2.53-2.5 4.58-4.58 4.58m-1.65 7.36h-5.14v-1.95h5.14c1.46 2.64-1.18 2.64-2.63s-1.18-2.633-2.64-2.633H4.59c-1.454 -2.637 1.183-2.637 2.637H.1c-2.524 2.55-4.58 4.58-4.58h1.96c2.526 4.58 2.56 4.58 4.58 2.527-2.54 4.58-4.58 4.58" fill="%23"/><path d="M15.36 49.895c-4.86 -7.94-1.62-1.85-4.51C1.63 42.475 38.62 34.535V2.99h1.955v13.545c 3.564 1.4 6.926 3.94 9.466 2.538 2.54 5.9 3.94 9.466 3.94 3.57 6.93-1.4 9.47-3.94s3.94-5.9 3.94-9.46V2.99h1.96v13.545c 4.87-1.6 7.94-4.51 1.85-2.91 2.98-6.76 4.51-1.85 4.51" fill="%23"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_avclub_on.f_article_split_on .scroll-list-break{border-top:3px solid #1c263c}.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#91dbd9;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-avclub .post-content .quotable a,.f_branding_on .blog-group-avclub .post-content .quotable a,.f_branding_on.blog-group-avclub .post-content footer a,.f_branding_on .blog-group-avclub .post-content footer a,.f_branding_on.blog-group-avclub .post-content h1 a,.f_branding_on .blog-group-avclub .post-content h1 a,.f_branding_on.blog-group-avclub .post-content h2 a,.f_branding_on .blog-group-avclub .post-content h2 a,.f_branding_on.blog-group-avclub .post-content h3 a,.f_branding_on .blog-group-avclub .post-content h3 a,.f_branding_on.blog-group-avclub .post-content h4 a,.f_branding_on .blog-group-avclub .post-content h4 a,.f_branding_on.blog-group-avclub .post-content h5 a,.f_branding_on .blog-group-avclub .post-content h5 a,.f_branding_on.blog-group-avclub .post-content h6 a,.f_branding_on .blog-group-avclub .post-content h6 a,.f_branding_on.blog-group-avclub .post-content li a,.f_branding_on .blog-group-avclub .post-content li a,.f_branding_on.blog-group-avclub .post-content p a,.f_branding_on .blog-group-avclub .post-content p a,.f_branding_on.f_branding_avclub_on .post-content .quotable a,.f_branding_on.f_branding_avclub_on .post-content footer a,.f_branding_on.f_branding_avclub_on .post-content h1 a,.f_branding_on.f_branding_avclub_on .post-content h2 a,.f_branding_on.f_branding_avclub_on .post-content h3 a,.f_branding_on.f_branding_avclub_on .post-content h4 a,.f_branding_on.f_branding_avclub_on .post-content h5 a,.f_branding_on.f_branding_avclub_on .post-content h6 a,.f_branding_on.f_branding_avclub_on .post-content li a,.f_branding_on.f_branding_avclub_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #e33af5;box-shadow:inset -2px #e33af5;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-avclub .post-content .quotable a:hover,.f_branding_on .blog-group-avclub .post-content .quotable a:hover,.f_branding_on.blog-group-avclub .post-content footer a:hover,.f_branding_on .blog-group-avclub .post-content footer a:hover,.f_branding_on.blog-group-avclub .post-content h1 a:hover,.f_branding_on .blog-group-avclub .post-content h1 a:hover,.f_branding_on.blog-group-avclub .post-content h2 a:hover,.f_branding_on .blog-group-avclub .post-content h2 a:hover,.f_branding_on.blog-group-avclub .post-content h3 a:hover,.f_branding_on .blog-group-avclub .post-content h3 a:hover,.f_branding_on.blog-group-avclub .post-content h4 a:hover,.f_branding_on .blog-group-avclub .post-content h4 a:hover,.f_branding_on.blog-group-avclub .post-content h5 a:hover,.f_branding_on .blog-group-avclub .post-content h5 a:hover,.f_branding_on.blog-group-avclub .post-content h6 a:hover,.f_branding_on .blog-group-avclub .post-content h6 a:hover,.f_branding_on.blog-group-avclub .post-content li a:hover,.f_branding_on .blog-group-avclub .post-content li a:hover,.f_branding_on.blog-group-avclub .post-content p a:hover,.f_branding_on .blog-group-avclub .post-content p a:hover,.f_branding_on.f_branding_avclub_on .post-content .quotable a:hover,.f_branding_on.f_branding_avclub_on .post-content footer a:hover,.f_branding_on.f_branding_avclub_on .post-content h1 a:hover,.f_branding_on.f_branding_avclub_on .post-content h2 a:hover,.f_branding_on.f_branding_avclub_on .post-content h3 a:hover,.f_branding_on.f_branding_avclub_on .post-content h4 a:hover,.f_branding_on.f_branding_avclub_on .post-content h5 a:hover,.f_branding_on.f_branding_avclub_on .post-content h6 a:hover,.f_branding_on.f_branding_avclub_on .post-content li a:hover,.f_branding_on.f_branding_avclub_on .post-content p a:hover,.f_branding_on.blog-group-avclub figcaption a,.f_branding_on .blog-group-avclub figcaption a,.f_branding_on.f_branding_avclub_on figcaption a{color:#948a3}.f_branding_on.blog-group-avclub figcaption a:hover,.f_branding_on .blog-group-avclub figcaption a:hover,.f_branding_on.f_branding_avclub_on figcaption a:hover{color:#68672}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on.blog-group-avclub .entry-content blockquote,.f_branding_on .blog-group-avclub .entry-content blockquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_avclub_on .entry-content blockquote{border-radius:;border-left:5px solid #1c263c;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before,.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-avclub .entry-content .pullquote__content,.f_branding_on .blog-group-avclub .entry-content .pullquote__content,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_avclub_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-avclub .review-score,.f_branding_on .blog-group-avclub .review-score,.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_avclub_on .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1c263c}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white){color:#948a3;border-color:#948a3}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white):hover{color:#68672;border-color:#68672}.f_branding_on.blog-group-avclub .author-bio__name,.f_branding_on .blog-group-avclub .author-bio__name,.f_branding_on.f_branding_avclub_on .author-bio__name{color:#222}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name){color:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover{color:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#68672}.f_branding_on.blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_avclub_on .sidebar-content .newsletter-subscribe{border-color:#1c263c}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on.blog-group-avclub .entry-content .pullquote,.f_branding_on .blog-group-avclub .entry-content .pullquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_avclub_on .entry-content .pullquote{border:2px solid #91dbd9;padding:3px;position:relative;font-weight:normal;font-style:normal}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before{height:3px;width:4px;position:absolute;left:-14px;top:-14px;background-repeat:no-repeat;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="23" viewBox=" 33 23" xmlns="http://www.w3.org/2/svg"><title>avc-pq<\/title><path d="M22.725 4.39c-1.4 1.14-1.763 2.345-2.157 3.61-.274.894-.41 1.736-.41 2.53 .496.6 1.55.186 1.674 1.362-1.586 3.223-2.38 5.58-2.38 2.3 3.657.577 4.872 1.727 1.213 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.38 1.86-5.17 1.86-1.34 -2.53-.243-3.57-.723-1.43-.487-1.86-1.187-2.455-2.13-.573-.745-1.3-1.76-1.377-3.5-.348-1.29-.52-2.69-.52-4.24 -2.652.682-5.94 2.44-7.326 1.362-2.23 3.37-3.956 6.25-5.17l.67 1.376c-1.34.62-2.53 1.52-3.57 2.64m-17.518 C4.165 5.53 3.447 6.734 3.5 8c-.274.894-.41 1.736-.41 2.53 .496.62 1.55.188 1.674 1.362-1.586 3.22-2.38 5.578-2.38 2.32 3.66.577 4.872 1.727 1.215 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.5 1.86-5.28 1.86-1.315 -2.492-.243-3.533-.723-1.48-.487-1.86-1.187-2.46-2.13-.57-.77-1.35-1.795-1.395-3.7C.18 15.78 14.382 12.87c-2.653.69-5.95 2.62-7.327 1.38-2.23 3.392-3.956 6.47-5.17l.66 1.377c-1.338.62-2.53 1.5-3.57 2.64" fill="%231C263C" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-a{min-width:18px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="18" height="11" viewBox=" 18 11" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-a<\/title><g fill="none" fill-rule="evenodd"><path fill="%231C263C" d="M4.63 L 1.56h9.59"/><path fill="%2391DBD9" d="M7.8 l4.784 1.56L17.658.3"/><\/g><\/svg>')}.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{min-width:162px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="162" height="13" viewBox=" 162 13" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path fill="%23948A3" d="M93.427 6.925h67.595V6.14H93.427M 6.925h67.595V6.14H"/><path d="M86.664 6.216c 3.433-2.783 6.216-6.216 6.215-3.433 -6.216-2.78-6.216-6.213S77.15 8.448 c3.433 6.216 2.783 6.216 6.216" fill="%23E6E6E6"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theonion_on.f_article_split_on .scroll-list-break{border-top:3px solid #6b3a}.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94d1b4;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theonion .post-content .quotable a,.f_branding_on .blog-group-theonion .post-content .quotable a,.f_branding_on.blog-group-theonion .post-content footer a,.f_branding_on .blog-group-theonion .post-content footer a,.f_branding_on.blog-group-theonion .post-content h1 a,.f_branding_on .blog-group-theonion .post-content h1 a,.f_branding_on.blog-group-theonion .post-content h2 a,.f_branding_on .blog-group-theonion .post-content h2 a,.f_branding_on.blog-group-theonion .post-content h3 a,.f_branding_on .blog-group-theonion .post-content h3 a,.f_branding_on.blog-group-theonion .post-content h4 a,.f_branding_on .blog-group-theonion .post-content h4 a,.f_branding_on.blog-group-theonion .post-content h5 a,.f_branding_on .blog-group-theonion .post-content h5 a,.f_branding_on.blog-group-theonion .post-content h6 a,.f_branding_on .blog-group-theonion .post-content h6 a,.f_branding_on.blog-group-theonion .post-content li a,.f_branding_on .blog-group-theonion .post-content li a,.f_branding_on.blog-group-theonion .post-content p a,.f_branding_on .blog-group-theonion .post-content p a,.f_branding_on.f_branding_theonion_on .post-content .quotable a,.f_branding_on.f_branding_theonion_on .post-content footer a,.f_branding_on.f_branding_theonion_on .post-content h1 a,.f_branding_on.f_branding_theonion_on .post-content h2 a,.f_branding_on.f_branding_theonion_on .post-content h3 a,.f_branding_on.f_branding_theonion_on .post-content h4 a,.f_branding_on.f_branding_theonion_on .post-content h5 a,.f_branding_on.f_branding_theonion_on .post-content h6 a,.f_branding_on.f_branding_theonion_on .post-content li a,.f_branding_on.f_branding_theonion_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #94d1b4;box-shadow:inset -2px #94d1b4;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theonion .post-content .quotable a:hover,.f_branding_on .blog-group-theonion .post-content .quotable a:hover,.f_branding_on.blog-group-theonion .post-content footer a:hover,.f_branding_on .blog-group-theonion .post-content footer a:hover,.f_branding_on.blog-group-theonion .post-content h1 a:hover,.f_branding_on .blog-group-theonion .post-content h1 a:hover,.f_branding_on.blog-group-theonion .post-content h2 a:hover,.f_branding_on .blog-group-theonion .post-content h2 a:hover,.f_branding_on.blog-group-theonion .post-content h3 a:hover,.f_branding_on .blog-group-theonion .post-content h3 a:hover,.f_branding_on.blog-group-theonion .post-content h4 a:hover,.f_branding_on .blog-group-theonion .post-content h4 a:hover,.f_branding_on.blog-group-theonion .post-content h5 a:hover,.f_branding_on .blog-group-theonion .post-content h5 a:hover,.f_branding_on.blog-group-theonion .post-content h6 a:hover,.f_branding_on .blog-group-theonion .post-content h6 a:hover,.f_branding_on.blog-group-theonion .post-content li a:hover,.f_branding_on .blog-group-theonion .post-content li a:hover,.f_branding_on.blog-group-theonion .post-content p a:hover,.f_branding_on .blog-group-theonion .post-content p a:hover,.f_branding_on.f_branding_theonion_on .post-content .quotable a:hover,.f_branding_on.f_branding_theonion_on .post-content footer a:hover,.f_branding_on.f_branding_theonion_on .post-content h1 a:hover,.f_branding_on.f_branding_theonion_on .post-content h2 a:hover,.f_branding_on.f_branding_theonion_on .post-content h3 a:hover,.f_branding_on.f_branding_theonion_on .post-content h4 a:hover,.f_branding_on.f_branding_theonion_on .post-content h5 a:hover,.f_branding_on.f_branding_theonion_on .post-content h6 a:hover,.f_branding_on.f_branding_theonion_on .post-content li a:hover,.f_branding_on.f_branding_theonion_on .post-content p a:hover{color:#94d1b4}.f_branding_on.blog-group-theonion figcaption a,.f_branding_on .blog-group-theonion figcaption a,.f_branding_on.f_branding_theonion_on figcaption a{color:#6b3a}.f_branding_on.blog-group-theonion figcaption a:hover,.f_branding_on .blog-group-theonion figcaption a:hover,.f_branding_on.f_branding_theonion_on figcaption a:hover{color:#381e}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on.blog-group-theonion .entry-content blockquote,.f_branding_on .blog-group-theonion .entry-content blockquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theonion_on .entry-content blockquote{border-radius:;border-left:5px solid #94d1b4;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theonion .review-score,.f_branding_on .blog-group-theonion .review-score,.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theonion_on .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white){color:#6b3a;border-color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white):hover{color:#381e;border-color:#381e}.f_branding_on.blog-group-theonion .author-bio__name,.f_branding_on .blog-group-theonion .author-bio__name,.f_branding_on.f_branding_theonion_on .author-bio__name{color:#222}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name){color:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover{color:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#381e}.f_branding_on.blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theonion_on .sidebar-content .newsletter-subscribe{border-color:#94d1b4}.f_branding_on.blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_earther_on.f_article_split_on .scroll-list-break{border-top:3px solid #75b2}.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#75b2;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-earther .post-content .inset--story__headline a,.f_branding_on .blog-group-earther .post-content .inset--story__headline a,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-earther .post-content .quotable a,.f_branding_on .blog-group-earther .post-content .quotable a,.f_branding_on.blog-group-earther .post-content footer a,.f_branding_on .blog-group-earther .post-content footer a,.f_branding_on.blog-group-earther .post-content h1 a,.f_branding_on .blog-group-earther .post-content h1 a,.f_branding_on.blog-group-earther .post-content h2 a,.f_branding_on .blog-group-earther .post-content h2 a,.f_branding_on.blog-group-earther .post-content h3 a,.f_branding_on .blog-group-earther .post-content h3 a,.f_branding_on.blog-group-earther .post-content h4 a,.f_branding_on .blog-group-earther .post-content h4 a,.f_branding_on.blog-group-earther .post-content h5 a,.f_branding_on .blog-group-earther .post-content h5 a,.f_branding_on.blog-group-earther .post-content h6 a,.f_branding_on .blog-group-earther .post-content h6 a,.f_branding_on.blog-group-earther .post-content li a,.f_branding_on .blog-group-earther .post-content li a,.f_branding_on.blog-group-earther .post-content p a,.f_branding_on .blog-group-earther .post-content p a,.f_branding_on.f_branding_earther_on .post-content .quotable a,.f_branding_on.f_branding_earther_on .post-content footer a,.f_branding_on.f_branding_earther_on .post-content h1 a,.f_branding_on.f_branding_earther_on .post-content h2 a,.f_branding_on.f_branding_earther_on .post-content h3 a,.f_branding_on.f_branding_earther_on .post-content h4 a,.f_branding_on.f_branding_earther_on .post-content h5 a,.f_branding_on.f_branding_earther_on .post-content h6 a,.f_branding_on.f_branding_earther_on .post-content li a,.f_branding_on.f_branding_earther_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-earther .post-content .quotable a:hover,.f_branding_on .blog-group-earther .post-content .quotable a:hover,.f_branding_on.blog-group-earther .post-content footer a:hover,.f_branding_on .blog-group-earther .post-content footer a:hover,.f_branding_on.blog-group-earther .post-content h1 a:hover,.f_branding_on .blog-group-earther .post-content h1 a:hover,.f_branding_on.blog-group-earther .post-content h2 a:hover,.f_branding_on .blog-group-earther .post-content h2 a:hover,.f_branding_on.blog-group-earther .post-content h3 a:hover,.f_branding_on .blog-group-earther .post-content h3 a:hover,.f_branding_on.blog-group-earther .post-content h4 a:hover,.f_branding_on .blog-group-earther .post-content h4 a:hover,.f_branding_on.blog-group-earther .post-content h5 a:hover,.f_branding_on .blog-group-earther .post-content h5 a:hover,.f_branding_on.blog-group-earther .post-content h6 a:hover,.f_branding_on .blog-group-earther .post-content h6 a:hover,.f_branding_on.blog-group-earther .post-content li a:hover,.f_branding_on .blog-group-earther .post-content li a:hover,.f_branding_on.blog-group-earther .post-content p a:hover,.f_branding_on .blog-group-earther .post-content p a:hover,.f_branding_on.f_branding_earther_on .post-content .quotable a:hover,.f_branding_on.f_branding_earther_on .post-content footer a:hover,.f_branding_on.f_branding_earther_on .post-content h1 a:hover,.f_branding_on.f_branding_earther_on .post-content h2 a:hover,.f_branding_on.f_branding_earther_on .post-content h3 a:hover,.f_branding_on.f_branding_earther_on .post-content h4 a:hover,.f_branding_on.f_branding_earther_on .post-content h5 a:hover,.f_branding_on.f_branding_earther_on .post-content h6 a:hover,.f_branding_on.f_branding_earther_on .post-content li a:hover,.f_branding_on.f_branding_earther_on .post-content p a:hover,.f_branding_on.blog-group-earther figcaption a,.f_branding_on .blog-group-earther figcaption a,.f_branding_on.f_branding_earther_on figcaption a{color:#75b2}.f_branding_on.blog-group-earther figcaption a:hover,.f_branding_on .blog-group-earther figcaption a:hover,.f_branding_on.f_branding_earther_on figcaption a:hover{color:#537f}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote,.f_branding_on.blog-group-earther .entry-content blockquote,.f_branding_on .blog-group-earther .entry-content blockquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_earther_on .entry-content blockquote{border-radius:;border-left:5px solid #75b2;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-earther .review-score,.f_branding_on .blog-group-earther .review-score,.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_earther_on .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white){color:#75b2;border-color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white):hover{color:#537f;border-color:#537f}.f_branding_on.blog-group-earther .author-bio__name,.f_branding_on .blog-group-earther .author-bio__name,.f_branding_on.f_branding_earther_on .author-bio__name{color:#222}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name){color:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover{color:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#537f}.f_branding_on.blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_earther_on .sidebar-content .newsletter-subscribe{border-color:#75b2}.storytype--box{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;margin-bottom:1.5rem}.storytype--box__text{padding:}.storytype--box__title{margin:}.storytype--box__description{font-family:"ElizabethSerif",Georgia,serif;font-size:14px;line-height:1.5;color:#666;margin-top:.5rem}@media only screen and (max-width: 37.438em){.storytype--box__description{margin-bottom:1.5rem}}.storytype--box__asset img{display:block;width:1%}.storytype--box.storytype--box__wrap{margin-bottom:2.5rem;padding:1.125rem ;background-color:#f5f5f5}.storytype--box.storytype--box__wrap .storytype--box__text{padding: 1.125rem}@media only screen and (min-width: 37.5em){.storytype__content .postlist__item--compact{padding-left:1.125rem}.storytype__content .postlist__item--compact .item__content--thumb .asset{padding-left:}}.storytype--nav{margin: -16px;min-height:calc(36px + 2rem)}@media only screen and (max-width: 37.438em){.storytype--nav{min-height:calc(36px + 2rem)}}@media only screen and (max-width: 37.438em){.storytype--nav--two-dropdowns{min-height:calc(36px * 2 + 1rem + 2rem)}}.storytype--nav__categoryselector,.storytype--nav__subcategoryselector{margin-bottom:2rem}@media only screen and (max-width: 37.438em){.storytype--nav__subcategoryselector{margin-top:-1rem}}.storytype--nav .select-component-list{max-height:3px;overflow-y:scroll}.storytype--nav .select-component-list ul{overflow-y:hidden}@media only screen and (max-width: 37.438em){.storytype--section{margin-left:-1.125rem;margin-right:-1.125rem}}.storytype--section header{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;border-bottom:1px solid #e5e5e5;margin-bottom:15px}@media only screen and (max-width: 37.438em){.storytype--section header{margin-left:1.125rem;margin-right:1.125rem}}.storytype--section header h2{margin-bottom:5px}.storytype--section header h2 a{color:#}.storytype--section__viewall{text-transform:uppercase;display:inline-block;-ms-flex-item-align:center;align-self:center}.storytype--section__wrapper{margin-bottom:3rem}@media only screen and (max-width: 37.438em){.storytype--section__wrapper{width:1%;overflow-x:scroll;padding-left:1.125rem}}.storytype--section__items{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:nowrap;flex-wrap:nowrap;-webkit-box-pack:start;-ms-flex-pack:start;justify-content:flex-start}.storytype--section__item{width:31.8%;position:relative;-ms-flex-negative:;flex-shrink:;margin-right:1.125rem}.storytype--section__item:last-of-type{margin-right:}@media only screen and (max-width: 37.438em){.storytype--section__item{width:2px;margin-right:1.125rem}.storytype--section__item:last-of-type{width:218px;padding-right:1.125rem}}.storytype--section .item__image{display:block;margin-bottom:1px}.storytype--section .headline{margin-bottom:}.storytype-label{font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:bold;padding-right:1px;text-transform:uppercase;color:#93ec}.storytype-label:hover{color:#73b9;text-decoration:none}.storytype-label:hover.storytype-label--white{background-color:#ffffff;color:#}.storytype-label--white{color:#ffffff}.storytype-label--outlined{border:1px solid #93ec;line-height:27px;margin-right:5px;height:27px;padding: 8px}.storytype-label--outlined.storytype-label--white{border-color:#ffffff;color:white}.storytype-label-wrapper{display:-webkit-box;display:-ms-flexbox;display:flex;max-width:1%;overflow:hidden}.storytype-label-wrapper--small-margin{margin-bottom:5px}.storytype-label-wrapper--medium-margin{margin-bottom:1px}.storytype-label-wrapper--large-margin{margin-bottom:15px}.storytype-label-wrapper--huge-margin{margin-bottom:2px}@media only screen and (max-width: 53.125em){.storytype-label-wrapper--curation{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;padding: 18px}}.storytype-label-wrapper .storytype-label{overflow:hidden;text-overflow:ellipsis;white-space:nowrap}.storytype-label-wrapper :last-child{margin-right:}.postlist__item--compact{margin-bottom:3px;padding-bottom:3px;border-bottom:1px solid #e5e5e5}.postlist__item--compact:last-of-type{border-bottom:;margin-bottom:}.postlist__item--compact .item__content{margin: -1.125rem;max-width:none;width:auto}.postlist__item--compact .item__content:after,.postlist__item--compact .item__content:before{content:" ";display:table}.postlist__item--compact .item__content:after{clear:both}.postlist__item--compact .item__text{padding-left:1.125rem;padding-right:1.125rem;float:left}@media only screen and (min-width: 37.5em){.postlist__item--compact .item__content--thumb .asset{padding-left:1.125rem;padding-right:1.125rem;width:33.333%;float:left;margin-bottom:}.postlist__item--compact .item__content--thumb .item__text{padding-left:1.125rem;padding-right:1.125rem;width:66.667%;float:left;padding-left:}}.postlist__item--compact .asset{width:1%;position:relative;margin: 2px}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{padding:}}.postlist__item--compact .asset img{width:1%}.postlist__item--compact .asset img[data-sizes=auto],.postlist__item--compact .asset video[data-sizes=auto]{display:block;width:1%}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{float:none}}.postlist__item--compact .headline{font-size:24px;margin-bottom:5px}html.fallback-fonts .postlist__item--compact .headline{font-family:"Arial Narrow",Arial,sans-serif;font-size:22.68px;line-height:1.349;letter-spacing:.5px}.postlist__item--compact .meta--pe{display:block;margin-bottom:7px}.postlist__item--compact .meta__container{font-size:15px}.postlist__item--compact .meta__byline,.postlist__item--compact .meta__time{display:inline-block}.postlist__item--compact .meta__byline:after{display:inline-block;content:'*';color:#aaa;padding: 5px}.postlist__item--compact .meta__right{display:none}.postlist__item--compact .excerpt{font-family:"ElizabethSerif",Georgia,serif}.postlist__item--compact .excerpt p{margin-bottom:}</style><script>window._K_MSGS = []; window._K_MSG_L = function (e) {_K_MSGS.push(e);}; window.addEventListener('message', window._K_MSG_L);</script><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/blog-2545d75c35bc9d9491eb61d4b29724.css" as="style" onload="this.rel='stylesheet'"><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/insets-13541366ddfac4e8eca127496e.css" as="style" onload="this.rel='stylesheet'"><script src="https://kinja.com/api/profile/accountwithtoken?jsonp=_fasttoken&newFollows=true" async defer></script><meta name="dynamic-stylesheet" id="editor-css-url" content="//x.kinja-static.com/assets/stylesheets/editor-7ed31791155c6bedc63fda5ded339b2.css"><meta name="google-site-verification" content="P13oAn8o8LB6FVCJWKsHWXvxfbR-SJrmvox6EgULpUs" /><meta name="viewport" content="width=device-width, initial-scale=1., minimum-scale=1.,maximum-scale=1." /><meta name="ROBOTS" content="INDEX, FOLLOW" /><title>The 218 Ford F-15 Gets A New Engine And More Horsepower
/ 2.7EB vs 3.5EB?
I was not under any idea that the exhaust manifolds are water-cooled. I knew the turbos were water-cooled. That is the case with all variable geometry turbos that are being used in both gasoline and diesel applications. It may also be possible that EGR is water cooled like the diesels are. Not sure what benefit it would be to cool exhaust manifolds, as it is advantageous to keep EGT's steady for maximum flow thru the exhaust system. Hotter exhaust gasses flow faster. That equates to maximum efficiency of the turbo spool up.
This why I even use turbo blankets on my turbos and heat wrap the down pipe from the turbo. Less heat loss thru the turbo housing and down pipe which keeps exhaust flowing more efficiently.
For anyone interested, PTP Turbo Blankets is taking pre-orders on F-150 ecoboost turbo blankets. This is the company I have gotten my turbo blankets from for a long time. Quality stuff.
PTP Ford F-15 Ecoboost Turbo Blankets - Pre-Order | PTP Turbo Blankets
2018 updates...
storybreak stars<\/title><path d="M5.146 9.1l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953L5.147 H3.76l.158 3.623L.893 1.67.2 2.867l3.214 1.638L.2 6.175l.693 1.197 3.25-1.985L3.76 9.1m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H23.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H43.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623" fill="%23CCC" fill-rule="evenodd"/><\/svg>');background-repeat:no-repeat;background-position:center}.editor .editor-inner div.legacy-raw-html,.post-content div.legacy-raw-html{border:3px solid #eeb544;padding:5px;margin-bottom:2px}.editor .editor-inner div.legacy-raw-html:before,.post-content div.legacy-raw-html:before{content:'Before this post can be saved, this block must be removed.';font-size:12px;display:inline-block}.editor .editor-inner div.legacy-raw-html table,.post-content div.legacy-raw-html table{margin-bottom:}.f_dap_tables_on .editor .editor-inner table,.f_dap_tables_on .post-content table,.f_use_dap .editor .editor-inner table,.f_use_dap .post-content table{font-family:"ProximaNovaCond",sans-serif;border:1px solid #e5e5e5;width:1%;margin-bottom:1.5rem;border-spacing:}.f_dap_tables_on .editor .editor-inner table td,.f_dap_tables_on .editor .editor-inner table th,.f_dap_tables_on .post-content table td,.f_dap_tables_on .post-content table th,.f_use_dap .editor .editor-inner table td,.f_use_dap .editor .editor-inner table th,.f_use_dap .post-content table td,.f_use_dap .post-content table th{padding:1px;text-align:left;border:;border-right:1px solid #fff}.f_dap_tables_on .editor .editor-inner table td:last-child,.f_dap_tables_on .editor .editor-inner table th:last-child,.f_dap_tables_on .post-content table td:last-child,.f_dap_tables_on .post-content table th:last-child,.f_use_dap .editor .editor-inner table td:last-child,.f_use_dap .editor .editor-inner table th:last-child,.f_use_dap .post-content table td:last-child,.f_use_dap .post-content table th:last-child{border-right:}.f_dap_tables_on .editor .editor-inner table tr:nth-child(2n) td,.f_dap_tables_on .post-content table tr:nth-child(2n) td,.f_use_dap .editor .editor-inner table tr:nth-child(2n) td,.f_use_dap .post-content table tr:nth-child(2n) td{background-color:#f5f5f5}.above-headline-image .featured-post__caption,.above-headline-image .video-embed__caption,.above-headline-image figcaption,.editor .editor-inner .featured-post__caption,.editor .editor-inner .video-embed__caption,.editor .editor-inner figcaption,.featured-post__asset .featured-post__caption,.featured-post__asset .video-embed__caption,.featured-post__asset figcaption,.post-content .featured-post__caption,.post-content .video-embed__caption,.post-content figcaption{position:relative;font-family:"ProximaNovaCond",sans-serif;color:#aaa;font-size:15px;line-height:21px;text-align:left;margin-top:.5rem;display:block}.above-headline-image .featured-post__caption:focus,.above-headline-image .video-embed__caption:focus,.above-headline-image figcaption:focus,.editor .editor-inner .featured-post__caption:focus,.editor .editor-inner .video-embed__caption:focus,.editor .editor-inner figcaption:focus,.featured-post__asset .featured-post__caption:focus,.featured-post__asset .video-embed__caption:focus,.featured-post__asset figcaption:focus,.post-content .featured-post__caption:focus,.post-content .video-embed__caption:focus,.post-content figcaption:focus{outline:none}.above-headline-image .video-embed__caption,.editor .editor-inner .video-embed__caption,.featured-post__asset .video-embed__caption,.post-content .video-embed__caption{margin-top:-.5rem}.above-headline-image .featured-post__caption,.editor .editor-inner .featured-post__caption,.featured-post__asset .featured-post__caption,.post-content .featured-post__caption{position:absolute;top:1%}.ad-unit--featured-recirculation{opacity:1;pointer-events:auto;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;z-index:97}.ad-unit--featured-recirculation .ad-container{background:#f5f5f5;width:3px;height:25px}.ad-unit--featured-recirculation .ad-container--hidden{opacity:;pointer-events:none;visibility:hidden}.ad-unit--fixed-bottom{position:fixed;bottom:3.5rem;right:1.125rem;height:auto;width:3px;opacity:1;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;pointer-events:auto}.ad-unit--fixed-bottom--invisible{opacity:;pointer-events:none}.ad-unit--fixed-bottom .ad-container{background:#f5f5f5;width:3px;height:25px}.editor .editor-inner .has-image.align--center.media-large{max-width:636px}.shared{margin-bottom:3.4rem}.shared .content-wrapper{background-color:#f5f5f5;padding-top:24px;border:1px #aaa solid}.shared .referenced-label{background-color:#f5f5f5}.shared .reframe-post{margin-bottom:1.875rem}.post .linked,.post .recommend{background-color:rgba(,,,.7);position:absolute;cursor:pointer;top:8px;right:8px;width:32px;height:32px;opacity:;-webkit-transition:all .15s ease-out;transition:all .15s ease-out;border-radius:5px;z-index:1}.post .linked{bottom:;border-top-left-radius:5px}.post .flex-video:hover .recommend,.post .has-image:hover .linked,.post .has-image:hover .recommend,.post figure:hover .linked,.post figure:hover .recommend{opacity:1}.post .has-image .recommend{right:8px}.post .movementventures,.post .qzzr{width:1%}.post a[x-inset=hidden]{display:none}.pullquote{margin-bottom:2rem;margin-top:2rem;text-align:center;padding:1px ;font-family:"ProximaNovaCond",sans-serif;font-weight:lighter;font-style:italic;font-size:25px;line-height:37px;clear:left}.pullquote:after,.pullquote:before{content:'';display:block;width:45px;height:;margin: auto;position:relative;border-top-width:1px;border-top-style:solid;border-color:#aaa}.pullquote:before{margin-bottom:2px}.pullquote:after{margin-top:2px}@media only screen and (min-width: 37.5em){.pullquote.align--left{width:4%;max-width:32px;float:left;margin-right:2.25rem;text-align:left;margin-bottom:.5em;margin-top:}.pullquote.align--left:after,.pullquote.align--left:before{margin-left:;margin-right:}}.pullquote__helper{display:none}.commentlist .pullquote,.quickreply .pullquote{margin-bottom:1em;margin-top:1em;text-align:left;padding: 1.125rem;font-size:22px;line-height:3px;position:relative}.commentlist .pullquote:before,.quickreply .pullquote:before{position:absolute;left:;top:3px;bottom:5px;width:;height:auto;border-top:;border-left-width:1px;border-left-style:solid;margin:}.commentlist .pullquote:after,.quickreply .pullquote:after{display:none}.post-content .inset--story{clear:both;margin:2rem auto;padding:1.125rem;border:#e5e5e5 1px solid;border-radius:5px;-webkit-box-shadow:#e5e5e5 2px 5px;box-shadow:#e5e5e5 2px 5px;max-width:636px}.post-content .inset--story p{font-size:15px;line-height:25px;margin-bottom:.6rem}@media only screen and (min-width: 37.5em){.post-content .inset--story{display:-webkit-box;display:-ms-flexbox;display:flex}}.post-content .inset--story__thumb{display:block;position:relative;margin:-1.125rem -1.125rem 1rem}@media only screen and (min-width: 37.5em){.post-content .inset--story__thumb{width:25%;min-width:25%;margin: 1.125rem ;float:left}}.post-content .inset--story__thumb figure{margin:;position:relative}.post-content .inset--story__thumb img{width:1%}.post-content .inset--story__headline{font-size:2px;line-height:24px;margin-bottom:1px}.post-content .inset--story__headline a,.post-content .inset--story__headline a:hover{color:#}.post-content .inset--story__readmore{font-family:"ProximaNovaCond",sans-serif;font-size:16px}.post-content .inset--story__readmore .hostname{font-weight:bold}.non-secure-iframe-embed{position:relative;padding-bottom:56.25%}.iframe-container{position:absolute;top:;left:;height:1%;width:1%}.iframe-container__external-source{height:92.5%;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;background-color:#e5e5e5}@media only screen and (max-width: 37.438em){.iframe-container__external-source{position:relative}}.iframe-container__external-source svg{opacity:.1}.iframe-container__external-source img{position:absolute;top:;left:;width:1%;opacity:.8}@media only screen and (max-width: 37.438em){.iframe-container__external-source img{position:relative}}.iframe-container__link-to-source{position:absolute;top:25px;right:25px}.iframe-container__link-to-source svg{opacity:.7;fill:#fff}.iframe-container__message{position:absolute;bottom:;height:7.5%;width:1%;background:#fff;color:#aaa;font-size:15px}@media only screen and (max-width: 37.438em){.iframe-container__message{position:absolute;height:auto}}.iframe-container__message p{position:absolute;font-family:"ProximaNovaCond", sans-serif;bottom:;margin:;font-size:15px;text-align:left}@media only screen and (max-width: 37.438em){.iframe-container__message p{position:relative}}.iframe-container__message a{text-decoration:none;color:#93ec}.google-adx .container{background-color:#f5f5f5;line-height:18px;padding:5px 1.125rem}.google-adx .by-google{color:#;font-size:14px}.google-adx .google-headline{color:#333}.post-bottom{margin: -1.125rem;max-width:none;width:auto}.post-bottom:after,.post-bottom:before{content:" ";display:table}.post-bottom:after{clear:both}@media only screen and (max-width: 37.438em){.post-bottom{margin:2rem 1rem}}@media only screen and (min-width: 37.5em){.post-bottom{margin:1.5rem }}.post-bottom .post-bottom__inner{max-width:636px;margin: auto}.post-bottom,.post-bottom a{color:#777}.post-bottom .fb-like{float:left;z-index:4;width:auto}.post-bottom .reply-to-post{color:#aaa}.post-bottom .reply-to-post .icon{margin-left:7px}.post-bottom .icon{opacity:.3;margin-left:5px;vertical-align:middle}.private-post-list{border-bottom:2px #aaa solid}.stream{padding-bottom:}.stream .meta .publish-time .icon{margin: 5px}.stream .post-dropdown-ct{display:none}.unshare-bloglist{position:absolute;top:;right:;z-index:1}.unshare-bloglist .unshare-bloglist-select,.unshare-bloglist .unshare-bloglist-title{display:inline-block;vertical-align:middle}.unshare-bloglist .unshare-bloglist-title{padding: 3px;background-color:#fff;margin: 1px }.unshare-bloglist .unshare-bloglist-select{margin-bottom:}.text-red{color:#eeb544}.post-tools-wrapper .reply-to-post__container .svg-icon{margin-left:;position:relative;top:2px}@media only screen and (max-width: 37.438em){.post-tools-wrapper .reply-to-post__container{display:none}}@media only screen and (max-width: 37.438em){.post-tools-wrapper{-webkit-box-flex:1;-moz-flex:1 1 1%;-ms-flex:1 1 1%;flex:1 1 1%;-webkit-box-ordinal-group:3;-moz-order:2;-ms-flex-order:2;order:2;margin:3px 14px}}@media only screen and (max-width: 37.438em){.post-tools-wrapper .button-recommend-post,.post-tools-wrapper .reply-count{display:none}}.newsletter-subscribe-post{display:block;font-family:"ElizabethSerif",Georgia,serif;border-top:#e5e5e5 1px solid;margin:1.5rem ;max-width:636px}.newsletter-subscribe-post__copy{color:#aaa;margin:1.5rem 1rem;line-height:29px}.newsletter-subscribe-post .button{font-size:1.1rem;padding: 1.2rem}.newsletter-subscribe-post .svg-icon{opacity:1;fill:#93ec}.center{margin: auto}ul.commerce-inset.fake-list{margin-bottom:;margin-top:-2px}.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:4px;margin:.5rem 1.125rem .5rem }.asset.has-media.has-image.align--left.media-large{width:1%}.asset.has-media.has-image.media-large.align--center{max-width:636px}@media only screen and (max-width: 27.25rem){.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:1%}}@media only screen and (min-width: 37.5em){.asset.has-media.has-image{margin-left:auto;margin-right:auto;max-width:636px}.asset.has-media.has-image.media-large{margin-left:-1.125rem;margin-right:-1.125rem;max-width:initial}.asset.has-media.has-image.media-large.align--center{margin-left:auto;margin-right:auto}.asset.media-small.has-media.has-image:not(.align--center){margin-bottom:.5rem;margin-right:1.125rem}}@media only screen and (min-width: 53.126em){.asset.has-media.has-image.media-large{margin-left:auto;margin-right:auto}}.post-content{font-family:"ElizabethSerif",Georgia,serif}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper{position:relative;background:#f5f5f5}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper img{background:none}.post-content .has-image.has-image.media-large .img-wrapper,.post-content .has-image.has-image.media-medium .img-wrapper,.post-content .has-image.has-image.media-small .img-wrapper{max-width:1%}.post-content .has-image.has-image.media-large .img-wrapper img,.post-content .has-image.has-image.media-medium .img-wrapper img,.post-content .has-image.has-image.media-small .img-wrapper img{position:absolute;height:auto;top:;left:;right:;bottom:}.post-content .has-image.has-image.media-large .lightbox-wrapper,.post-content .has-image.has-image.media-medium .lightbox-wrapper,.post-content .has-image.has-image.media-small .lightbox-wrapper{display:block}.img-wrapper{max-width:1%}.old-post-type-img{display:block;margin:1.125rem auto}.gmg-text-ad{margin:2rem auto;max-width:636px;font-family:"ProximaNovaCond", sans-serif}.gmg-text-ad .text-ad__inner{border:1px solid #e5e5e5;border-left-width:;border-right-width:;padding:3px 18px 1px;position:relative;background-color:#f5f5f5}.gmg-text-ad .text-ad__inner:before{content:'Advertisement';text-transform:uppercase;position:absolute;top:;width:1%;text-align:center;color:#ccc;font-size:13px}.gmg-text-ad a{display:block;color:#}.gmg-text-ad a:hover{text-decoration:none}.gmg-text-ad .text-ad__headline{font-size:2px;line-height:24px;margin-bottom:5px;color:#}.gmg-text-ad a:hover .text-ad__headline{text-decoration:underline}.gmg-text-ad .text-ad__excerpt{font-family:"ElizabethSerif", Georgia, serif;font-size:15px;color:#333;line-height:26px;margin: 3px}.gmg-text-ad .text-ad__more{color:#ccc;font-size:15px}@-webkit-keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}@keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}.discussion-status-badge-wrapper{display:block;margin-bottom:2px}.discussion-status-badge-wrapper .discussion-status-badge{color:#fff;background-color:rgba(,,,.7);display:inline;padding:5px 1px}.discussion-status-badge{color:#ef774;line-height:24px;margin-bottom:12px;text-transform:uppercase}.discussion-status-badge:before{display:inline-block;content:'';width:11px;height:11px;background-color:#ef774;border-radius:11px;margin-right:5px;-webkit-animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite;animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite}.meta__tools .f-dropdown{text-align:left}.commerce-disclaimer{margin-bottom:2px;display:-webkit-box;display:-ms-flexbox;display:flex}.commerce-disclaimer:before{content:"";border-left:2px solid #72ad75;margin:4px 6px}.commerce-disclaimer span{padding-left:1px}.customkinja-backlink{max-width:636px;margin:2em auto}.customkinja-backlink:after,.customkinja-backlink:before{content:'';display:block;height:;width:auto;border-top-width:1px;border-top-style:solid;border-color:#ccc}.customkinja-backlink a{display:inline-block;padding:1em }.post__misc{clear:both}.permalink.featured-post .main{left:;padding:}.permalink.featured-post .entry-title{color:white;font-size:8.5vw;font-weight:normal;line-height:1.1;text-align:center;margin: auto;max-width:118px;width:1%}.permalink.featured-post .entry-title a{color:white}.permalink.featured-post .row.content-wrapper,.permalink.featured-post .post-wrapper{margin:}.permalink.featured-post .post{padding:}.permalink.featured-post .post .meta--pe{margin-bottom:;margin-left:auto;margin-right:auto;max-width:636px}.permalink.featured-post .post__misc{padding: 1.125rem}.permalink.featured-post .post--empty .meta--pe{margin-top: !important;margin-bottom: !important;padding-bottom:;border-top:;border-bottom:}.permalink.featured-post .post-content:not(.reply__content){margin-top:3px;padding: 1.125rem}.permalink.featured-post .ad-unit--in-post .ad-container{height:25px}.permalink.featured-post .entry-content.fixed{position:fixed;right:1px;top:}.permalink.featured-post .entry-content.unfixed{position:absolute;right:}.featured-post__sponsored-label{color:#aaa;font-size:13px;text-transform:uppercase}.featured-post__header{background:black;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-align:center;-ms-flex-align:center;align-items:center;position:relative}.featured-post__header .discussion-status-badge{font-size:.42em;margin:18px ;text-align:center}.featured-post__header.magazine{-webkit-box-align:initial;-ms-flex-align:initial;align-items:initial;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__asset-group{width:1%}.featured-post__header.magazine .featured-post__asset-group:after{display:none}.featured-post__header.magazine .featured-post__asset{padding:}.featured-post__header.magazine .featured-post__asset .featured-post__caption,.featured-post__header.magazine .featured-post__asset figcaption{display:none}.featured-post__header.magazine .featured-post__alternate-image-caption{display:block}.featured-post__header.magazine .featured-post__meta-container{display:none}.featured-post__header.magazine .featured-post__headline-container{width:1%}.featured-post__header.magazine .featured-post__headline-container-author{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__headline-container-author .meta--pe.secondary-byline{margin:;max-width:1%}.featured-post__header.magazine .featured-post__headline-container-author .meta__label--sponsored{color:#aaa}.featured-post__headline-container-author{width:1%}.featured-post__headline-container-author .meta--pe{margin-bottom:;padding-top:3px;width:1%}.featured-post__headline-container-author .meta--pe .svg-icon{opacity:1;stroke:#aaa}.featured-post__headline-container-author .meta--pe .svg-icon.stroked{stroke:#aaa}.featured-post__headline-container-author .meta--pe .meta__byline,.featured-post__headline-container-author .meta--pe .meta__byline a,.featured-post__headline-container-author .post-tags-container .first-tag span{color:white}.featured-post__headline-container{padding:2px}.featured-post__headline-container,.featured-post__headline-container .featured-post__headline-container-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:center;-ms-flex-align:center;align-items:center}.featured-post__meta-container,.featured-post__meta-container-alt{display:none;-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:1%}.featured-post__meta-container-alt .meta--pe,.featured-post__meta-container .meta--pe{border-top:1px solid #e5e5e5;border-bottom:1px solid #e5e5e5;margin:4px !important;max-width:636px;padding:4px ;width:1%}.featured-post__asset-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-ordinal-group:;-ms-flex-order:-1;order:-1;position:relative;width:1%}.featured-post__asset-group:after{background:white;bottom:;content:'';display:none;left:;height:25%;position:absolute;right:;width:1%}.featured-post__asset-group .featured-post__cover{height:1%;max-height:1%}.featured-post__asset{padding:;position:relative;width:1%;z-index:1}.featured-post__asset,.featured-post__asset.pillarboxed{background:transparent}.featured-post__asset img,.featured-post__asset video{width:1%}.featured-post__asset .featured-post__caption,.featured-post__asset figcaption{display:none;margin:auto;max-width:636px;padding:1px }.featured-post__asset .img-wrapper{background-size:cover}.featured-post__asset__container{height:calc(1vw*9/16);margin: auto;max-height:calc(85vh);max-width:calc(85vh*16/9);width:1%}.featured-post__asset__container.video-type--JwPlayer,.featured-post__asset__container.video-type--Mcp,.featured-post__asset__container.video-type--OnionStudios,.featured-post__asset__container.video-type--YoutubeVideo{position:relative;height:1%;max-height:1%;max-width:1%;width:1%}.featured-post__asset__container.video-type--JwPlayer:after,.featured-post__asset__container.video-type--Mcp:after,.featured-post__asset__container.video-type--OnionStudios:after,.featured-post__asset__container.video-type--YoutubeVideo:after{content:"";display:block;padding-top:56.25%;width:1%}.featured-post__asset__container.video-type--JwPlayer>iframe,.featured-post__asset__container.video-type--Mcp>iframe,.featured-post__asset__container.video-type--OnionStudios>iframe,.featured-post__asset__container.video-type--YoutubeVideo>iframe{bottom:;left:;position:absolute;right:;top:}.featured-post__asset__container iframe{height:1%;width:1%}.featured-post__cover{background-position:center;background-repeat:no-repeat;background-size:contain;cursor:pointer;height:calc(1vw*9/16);left:;max-height:calc(85vh);position:absolute;top:;width:1%}.featured-post__cover .play-icon{background:rgba(,,,.6);border-radius:5px;display:block;height:6px;left:calc(5% - 18px);position:absolute;top:calc(5% - 3px);width:56px}.featured-post__cover .svg-icon{height:6px;margin-top:;opacity:.8;width:56px}.featured-post__cover:hover .svg-icon{opacity:1}.featured-post__alternate-image-caption{color:#aaa;display:block;padding:1px 1.25rem }.featured-post__alternate-image-caption>div{margin:auto;max-width:636px}.featured-post__alternate-image-caption.magazine{display:block}@media only screen and (min-width: 768px){.permalink.featured-post .entry-title{font-size:6vw}}@media only screen and (min-width: 124px){.permalink.featured-post .post .post-content{margin:auto;margin-top:;max-width:124px;width:1%}.permalink.featured-post .ad-unit--in-post{display:none}.permalink.featured-post .entry-title{font-size:4vw}.permalink.featured-post .featured-post__alternate-image-caption{display:none}.permalink.featured-post .featured-post__alternate-image-caption.magazine{display:block}.featured-post__headline-container{padding:4px}.featured-post__header{margin-bottom:}.featured-post__header .featured-post__headline-container-author,.featured-post__header .featured-post__meta-container .featured-post__headline-container-author,.featured-post__header.magazine .featured-post__headline-container-author{display:none}.featured-post__header .featured-post__asset .featured-post__caption,.featured-post__header .featured-post__asset figcaption{display:block}.featured-post__header.magazine{-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row}.featured-post__header.magazine .entry-title{font-size:3vw}.featured-post__header.magazine .featured-post__asset-group{width:75%}.featured-post__header.magazine .featured-post__headline-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;min-width:35px;width:25%}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:start;-ms-flex-align:start;align-items:flex-start}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group h1{text-align:left}.featured-post__header.magazine .meta--pe{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .meta__right{margin-top:15px;right:;width:1%}.featured-post__header.magazine .meta__data--comment{margin-left:auto}.featured-post__header.magazine .featured-post__category-label-wrapper{margin-bottom:}.featured-post__meta-container-alt,.featured-post__meta-container{display:-webkit-box;display:-ms-flexbox;display:flex}.featured-post__meta-container{background:white}.featured-post__asset-group{-webkit-box-ordinal-group:initial;-ms-flex-order:initial;order:initial}.featured-post__asset-group:after{display:block}.featured-post__asset{padding: 2.5%}}@media only screen and (min-width: 18px){.permalink.featured-post .entry-title{font-size:3vw}.featured-post__header.magazine .entry-title{font-size:2.5vw}}.sharingfooter{position:fixed;bottom:;left:;right:;background:#fff;z-index:98;-webkit-box-shadow: 1px rgba(,,,.4);box-shadow: 1px rgba(,,,.4);height:38px;line-height:38px;vertical-align:middle;font-size:13px}html.fallback-fonts .sharingfooter{font-family:"Arial Narrow",Arial,sans-serif;font-size:12.285px;line-height:39.444px;letter-spacing:.5px}.sharingfooter:active,.sharingfooter:hover{-webkit-box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);-webkit-transition:all 2ms ease-in-out;transition:all 2ms ease-in-out}.sharingfooter__wrapper{margin: auto;max-width:63rem;width:1%;max-width:1336px}.sharingfooter__wrapper:after,.sharingfooter__wrapper:before{content:" ";display:table}.sharingfooter__wrapper:after{clear:both}.sharingfooter__content{float:right;padding: 1.125rem}.sharingfooter__content a{display:inline-block;margin-left:1px}.sharingfooter__content .button--share{margin-top:5px}@media only screen and (max-width: 53.125em){.sharingfooter__content{float:none;text-align:center}.sharingfooter__content a{margin:}.sharingfooter__content .sharingfooter__facebook{text-align:right;padding-right:1px}.sharingfooter__content .sharingfooter__twitter{text-align:left;padding-left:1px}}.alert-bar{position:relative;padding:.5em;background-color:#eeb544;color:rgba(,,,.6)}.alert-bar.alert-bar__hero{margin:2em ;font-size:1.1em}.alert-bar.alert-bar__inline{width:1%}.alert-bar.alert-bar__control{padding-right:2em}.alert-bar .alert-bar__text{position:relative;top:1px}.alert-bar .alert-bar__icon{position:absolute;top:1px;right:1px}.reply__byline,a.reply__count span,a.reply__link span{font-family:"ProximaNovaCond",sans-serif;font-weight:5}.reply .unapproved-msg,.reply__pending-label,.reply__publish-time,.reply__to-author{font-family:"ProximaNovaCond",sans-serif;font-weight:4}@media only screen and (max-width: 37.438em){.reply--depth-{margin-left:}}.reply--depth->.reply__header>.avatar{margin-top:}.reply--depth->.reply__header>.avatar img{width:4px;height:4px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__header>.avatar{margin-top:2px}.reply--depth->.reply__header>.avatar img{width:32px;height:32px}}.reply--depth->.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;max-width:696px;padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply--depth->.reply__tools{padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__tools{padding-left:1.125rem}}.reply--depth-.anchor>.reply__content{max-width:666px}ul.commentlist{margin:}ul.commentlist--depth-{position:relative;left:-5px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-{left:}}ul.commentlist--depth- .unapproved-filter--thread{width:686px;margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth- .unapproved-filter--thread{width:auto;margin-left:}}ul.commentlist--depth-1{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1{margin-left:18px}}ul.commentlist--depth-1+.reply-footer-bar{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1+.reply-footer-bar{margin-left:}}.commentlist__item:after{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5;margin: 6px}@media only screen and (max-width: 37.438em){.commentlist__item:after{position:relative;width:12%;left:-2%;margin:}}.commentlist__item:last-child:after{display:none}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:after{width:auto;margin: 46px 5px}}@media screen and (min-width: 64em) and (max-width: 69.375em){.commentlist__item--depth-1:after{margin: 5px}}.commentlist__item--depth-1:first-child:before{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5}@media only screen and (max-width: 37.438em){.commentlist__item--depth-1:first-child:before{position:relative;width:12%;left:-2%}}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:first-child:before{margin-right:5px}}@media screen and (min-width: 124px) and (max-width: 111px){.commentlist__item--depth-1:first-child:before{margin:}}.commentlist__item:not(.commentlist__item--depth-) .editor{margin-left:}.commentlist__item--depth-.commentlist__item--expandable:after{display:none}.commentlist__item--depth-.commentlist__item--expandable .reply-footer-bar{display:block}.reply{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row wrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row wrap;max-width:8px;padding:2px ;position:relative}.reply:hover .post-dropdown-trigger .svg-icon{opacity:1}.reply p.media-64{padding-bottom:1rem}.reply .media-3{float:left;max-width:5%;margin: 2.25rem ;padding:5px 15px }.reply .post-tools{bottom:;margin:;position:absolute;right:}.reply .post-tools .post-bottom{margin:}.reply .unapproved-msg{color:#aaa;font-size:.875rem;padding-bottom:1rem;font-style:italic}.reply img{width:1%}.reply.anchor:before{content:'';display:inline-block;height:1%;width:3px;position:absolute;left:-16px;top:}@media only screen and (max-width: 37.438em){.reply.anchor:before{left:-1.125rem}}.reply__header{-webkit-box-ordinal-group:1;-moz-order:;-ms-flex-order:;order:;width:1%;color:#aaa;line-height:1.4;position:relative;padding-right:23px;padding-bottom:1px}@media only screen and (min-width: 66.3em){.reply__header{padding-right:}}.reply__header .icon{opacity:.3;margin-left:1px}@media only screen and (max-width: 124px){.reply__header .icon{margin-top:-5px;margin-left:3px}}.reply__header>.avatar{float:left;display:block;position:relative;margin-top:2px;margin-right:2px}@media only screen and (max-width: 37.438em){.reply__header>.avatar{margin-right:1px}}.reply__header>.avatar img{height:3px;width:3px;display:block}@media only screen and (max-width: 37.438em){.reply__header>.avatar img{width:32px;height:32px}}.reply__header>.avatar .svg-checkmark{right:-6px;bottom:-5px}.reply__header .avatar .svg-checkmark,.reply__header .avatar .svg-checkmark--small{display:none;position:absolute;fill:#93ec;opacity:.9}.reply__header .post-dropdown-trigger{position:absolute;right:}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-trigger{right:1px}}.reply__header .post-dropdown-ct{position:absolute;top:3px}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct{position:static}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct{right:-14px}}@media only screen and (min-width: 9px) and (max-width: 124px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 128px) and (max-width: 147px){.reply__header .post-dropdown-ct{right:-41px;min-width:3px;min-height:1px}}@media only screen and (min-width: 148px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:6px}}@media only screen and (min-width: 88em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:-169px}}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct .f-dropdown{width:9%;left:5%;right:5%}}.reply__header .post-dropdown-ct .f-dropdown .repostblock{background:inherit;cursor:default}.reply__header .post-dropdown-ct .f-dropdown .repostblock ul{margin:}.reply__header .post-dropdown-ct .f-dropdown .repostblock .repostheader{display:block;background:inherit;cursor:default;padding-left:.5rem}.reply__header.without-dropdown{padding-right:}.reply__header.without-dropdown .post-dropdown-ct{display:none}.reply__header.followed .avatar .svg-checkmark,.reply__header.followed .avatar .svg-checkmark--small{display:block}.featured-post .reply__header .post-dropdown-ct{right:-14px}.reply__byline{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row nowrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row nowrap;font-size:16px}@media only screen and (max-width: 37.438em){.reply__byline{font-size:14px}}.reply__byline a{overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;font-weight:bold;color:#}.reply__byline a:focus,.reply__byline a:hover{color:#}.reply__to-author{-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;font-weight:normal}@media only screen and (max-width: 124px){.reply__to-author .icon{margin-top:-3px}}.reply__publish-time{font-size:.812rem}.reply__publish-time a{color:#aaa}.reply__publish-time a:active,.reply__publish-time a:focus,.reply__publish-time a:hover{color:#aaa;text-decoration:underline}.reply__pending-label{color:#;text-transform:uppercase;font-size:14px;display:none;float:right;margin-right:5px}@media only screen and (max-width: 37.438em){.reply__pending-label{float:none;margin:;position:absolute;right:;top:22px}}.reply--unapproved .reply__publish-time .reply__pending-label{display:none}@media only screen and (max-width: 37.438em){.reply--unapproved .reply__publish-time .reply__pending-label{color:black;position:static;font-size:13px;margin-left:5px;display:inline-block}}.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;-webkit-box-ordinal-group:2;-moz-order:1;-ms-flex-order:1;order:1;max-width:636px;position:relative;padding-left:5px}@media only screen and (max-width: 37.438em){.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply__content blockquote,.reply__content ol,.reply__content p,.reply__content ul{font-size:15px;line-height:28px;padding-bottom:.625rem}.reply__content>:last-child{padding-bottom:}@media only screen and (max-width: 37.438em){.reply__content{width:1%}}@media only screen and (max-width: 53.125em){.reply__content .has-video.has-video.media-large{margin:}}a.reply__count,a.reply__link{line-height:1;color:#aaa}a.reply__count span,a.reply__link span{color:#}a.reply__count .icon,a.reply__link .icon{margin-left:5px}a.reply__count:active,a.reply__count:focus,a.reply__count:hover,a.reply__link:active,a.reply__link:focus,a.reply__link:hover{color:#aaa;text-decoration:none}.reply__link{margin-left:6.5px;position:relative}@media only screen and (max-width: 37.438em){.reply-disabled,.reply__content p,.reply__header{padding-left:1.125rem;padding-right:1.125rem}}@-webkit-keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}@keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}.kinja-slide{-webkit-transition-timing-function:cubic-bezier(.25, .1, .25, 1);transition-timing-function:cubic-bezier(.25, .1, .25, 1)}.kinja-slide__container{width:1%;padding-bottom:66.6666%;position:relative}.kinja-slide__container--wide{padding-bottom:56.25%}@media only screen and (max-width: 37.438em){.kinja-slide--ad .kinja-slide__container{padding-bottom:18px}}.kinja-slide__image-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;background:#;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}@media only screen and (max-width: 37.438em){.kinja-slide__image-container{background:#333}}.kinja-slide__image{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden}.kinja-slide__image,.kinja-slide__image img{-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}.kinja-slide__image img{max-width:1%;max-height:1%;-ms-flex-item-align:center;align-self:center;position:relative;-o-object-fit:contain;object-fit:contain}.kinja-slide__image.kinja-slide__image.kinja-slide__image.kinja-slide__image{width:auto}.kinja-slide__image--hidden{display:none}.kinja-slide__blur-background{background-size:cover;background-position:center center;-webkit-filter:blur(3px);filter:blur(3px);position:absolute;width:12%;height:12%;opacity:.6}.kinja-slide__blur-background--hidden{display:none}@media only screen and (max-width: 37.438em){.kinja-slide__blur-background{display:none}}.kinja-slide__caption{color:#333;font-size:16px;line-height:21px;margin: auto;padding:18px;max-width:636px}@media only screen and (min-width: 37.5em){.kinja-slide__caption{padding:18px ;margin: 82px}}.kinja-slide .loading .container{background:#f5f5f5}.kinja-slide__ad-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-sizing:border-box;box-sizing:border-box;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none;color:#aaa;font-size:14px;font-weight:bold;line-height:17px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-container{background:#333;position:absolute;left:;top:;right:;bottom:}}.kinja-slide__ad-container .ad-container{width:3px;height:25px;background-color:#fff}.kinja-slide__ad-label{margin-bottom:5px;margin-top:15px;text-transform:uppercase}.kinja-slide__ad-buttons{display:-webkit-box;display:-ms-flexbox;display:flex;margin-top:1px;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;width:3px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-buttons{display:none}}.kinja-slide.wiggle .kinja-slide__caption,.kinja-slide.wiggle .kinja-slide__container{-webkit-animation:kinja-slide-wiggle .6s ease-in-out both;animation:kinja-slide-wiggle .6s ease-in-out both}.kinja-slideshow{margin-bottom:2px;position:relative;overflow:hidden;background-color:#f5f5f5;font-family:"ProximaNovaCond",sans-serif}.kinja-slideshow__deck{display:-webkit-box;display:-ms-flexbox;display:flex}.kinja-slideshow .kinja-slide{width:1%;position:relative;-webkit-box-flex:;-ms-flex: 1%;flex: 1%}.kinja-slideshow__navigate-left.button{display:none;position:absolute;top:2px;margin-top:66.6666%;left:2px}.kinja-slideshow__navigate-left.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-left.button{display:inherit}}.kinja-slideshow__navigate-right.button{display:none;position:absolute;top:2px;margin-top:66.6666%;right:2px}.kinja-slideshow__navigate-right.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-right.button{display:inherit}}.kinja-slideshow--wide .kinja-slideshow__navigate-left,.kinja-slideshow--wide .kinja-slideshow__navigate-right{margin-top:56.25%}.kinja-slideshow__index{padding: 18px 15px;max-width:636px;margin: auto;font-size:16px;line-height:21px;font-weight:normal;color:#aaa}.kinja-slideshow__index .svg-icon{margin-right:3px}@media only screen and (min-width: 37.5em){.kinja-slideshow__index{padding: 15px;margin: 82px}}.reviewbox-inset{clear:left}.reviewbox-inset .review-box__head-content-wrapper{display:none}@media only screen and (min-width: 37.5em){.reviewbox-inset.align--left .review-box{width:32px;margin:}}.reviewbox-inset.align--left .review-box__head-content{display:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box{max-width:1%}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head{position:relative;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:left;-ms-flex-align:left;align-items:left;padding-left:64%}}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{position:relative;display:block;width:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:before{content:"";width:1px;margin-left:-1px;float:left;height:;padding-top:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:after{content:"";display:table;clear:both}@media only screen and (max-width: 53.125em){.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head-content{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-flex:1;-ms-flex-positive:1;flex-grow:1;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;max-width:1%;padding:15px}.reviewbox-inset.align--fullbleed .review-box__head-content .review-score{position:unset;margin: auto;background:#fff;border-color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content .review-box__title{color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content:not(.review-box__head-content--visually-hidden){position:absolute;top:;right:;bottom:;left:}.reviewbox-inset.align--fullbleed .review-box__head-content--visually-hidden{visibility:hidden}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image-wrapper{-ms-flex-preferred-size:64%;flex-basis:64%;padding-top:36%;padding:;position:absolute;width:64%;top:;left:;right:36%;bottom:;height:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image{position:absolute;top:-9999px;right:-9999px;bottom:-9999px;left:-9999px;min-height:1%;max-width:none;width:auto;margin:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__content .review-box__title,.reviewbox-inset.align--fullbleed .review-box__content .review-score,.reviewbox-inset.align--fullbleed .review-box__content--nodata{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__data-wrapper:not(.review-box__data-wrapper--single){-webkit-column-count:2;column-count:2;-webkit-column-gap:3px;column-gap:3px}}.reviewbox-inset.align--fullbleed .review-box__data-item{-webkit-column-break-inside:avoid;break-inside:avoid;page-break-inside:avoid}.reviewbox-inset.align--fullbleed .review-box__data-label,.reviewbox-inset.align--fullbleed .review-box__data-value{max-width:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .storytype-label-wrapper--top{display:none}}.reviewbox-inset.align--fullbleed .storytype-label-wrapper--head{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;margin-bottom:2px}.review-box{margin:3px auto;max-width:47px;width:1%}.review-inset-editor .review-box{width:32px}.review-box__tag-wrapper{max-width:1%;height:26px;margin-bottom:1px}.review-box__tag-wrapper,.review-box__tag{display:-webkit-box;display:-ms-flexbox;display:flex}.review-box__tag{height:1%;padding:5px 5px 5px 7px;-webkit-box-flex:;-ms-flex: auto;flex: auto;overflow:hidden;font-family:"ProximaNovaCond",sans-serif;font-size:15px;line-height:18px;background-color:#93ec;-webkit-transition:background-color .1s ease-out;transition:background-color .1s ease-out}.review-box__tag:first-child{-webkit-box-flex:;-ms-flex: 1 auto;flex: 1 auto}.review-box__tag:first-child .review-box__text{white-space:nowrap;overflow:hidden;text-overflow:ellipsis}.review-box__tag:hover{text-decoration:none;background-color:#73b9}.review-box__tag:not:)last-child){margin-right:1px}.review-box__tag .svg-icon.small{min-width:1px;height:1%;-ms-flex-item-align:end;align-self:flex-end;stroke:#fff;opacity:1}.review-box__text{margin-right:5px;color:#fff;text-transform:uppercase}.review-box__image-wrapper{position:relative;height:;padding-top:56.25%}.review-box__image-container{width:1%;overflow:hidden;position:absolute;top:;right:;bottom:;left:}.review-box__image-container .spinner.bounce{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;width:1%;height:1%;background-color:#e5e5e5}.review-box__image{width:1%}.review-box__head-content-wrapper{display:none}.review-box__content{position:relative;padding:15px 15px 15px;background-color:#f5f5f5}.review-box__content--nodata{padding:15px}.review-box__content--nodata .review-box__title{margin-bottom:}.review-box__content--nodata .review-box__data-wrapper{display:none}.review-box__title{margin-bottom:15px;font-size:24px;line-height:28px;text-align:center}.review-box__title:last-child{margin-bottom:}.review-box__data-item{padding-bottom:15px}.review-box__data-label{margin-bottom:;font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:normal;line-height:28px;color:#666;text-transform:uppercase}.review-box__data-value{font-family:"ElizabethSerif",Georgia,serif;color:#222;margin-bottom:}.post-content .review-box__data-value,.dui-modal .review-box__data-value{font-size:15px;line-height:28px}.review-score{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:48px;height:48px;margin: auto 15px;border:2px solid #f5f5f5;border-radius:5%;font-family:"ProximaNovaCond",sans-serif;font-size:24px;line-height:24px;color:#fff;background-color:#333}.review-score--img{margin:;position:absolute;top:-38px;left:calc(5% - 24px)}.review-score--small{font-size:19px;line-height:19px;height:36px;width:36px}@media only screen and (min-width: 37.5em){.review-score--small-on-medium-up{font-size:19px;line-height:19px;height:36px;width:36px}}.postlist__item--compact .asset,.postlist__item .asset,.storytype--section .item__image{position:relative}.postlist__item--compact .asset .review-score,.postlist__item .asset .review-score,.storytype--section .item__image .review-score{margin:;position:absolute;left:1px;top:1px;z-index:1}@media only screen and (min-width: 37.5em){.postlist__item .asset .review-score{left:28px}}.branded-item .headline a{color:# !important}.branded-item .inset--story__thumb figure,.branded-item.item .image__wrapper{border-bottom:5px solid transparent}.branded-item .gmg-avatar{width:2px;position:absolute;bottom:-5px;left:}.branded-item .inset--story__readmore{display:inline-block}.branded-item--deadspin .inset--story__thumb figure,.branded-item--deadspin.item .image__wrapper{border-bottom-color:#1b3a4d}.branded-item--deadspin .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #3d84af;box-shadow:inset -2px #3d84af;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--deadspin .inset--story__readmore:hover{color:#1b3a4d;text-decoration:none}.branded-item--earther .inset--story__thumb figure,.branded-item--earther.item .image__wrapper{border-bottom-color:#75b2}.branded-item--earther .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--earther .inset--story__readmore:hover{color:#75b2;text-decoration:none}.branded-item--fusion .inset--story__thumb figure,.branded-item--fusion.item .image__wrapper{border-bottom-color:#4e}.branded-item--fusion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #7ae8ff;box-shadow:inset -2px #7ae8ff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--fusion .inset--story__readmore:hover{color:#caf4;text-decoration:none}.branded-item--gizmodo .inset--story__thumb figure,.branded-item--gizmodo.item .image__wrapper{border-bottom-color:#18afed}.branded-item--gizmodo .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #93daf7;box-shadow:inset -2px #93daf7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--gizmodo .inset--story__readmore:hover{color:#18afed;text-decoration:none}.branded-item--jalopnik .inset--story__thumb figure,.branded-item--jalopnik.item .image__wrapper{border-bottom-color:#ff4d}.branded-item--jalopnik .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffaa85;box-shadow:inset -2px #ffaa85;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jalopnik .inset--story__readmore:hover{color:#ff4d;text-decoration:none}.branded-item--jezebel .inset--story__thumb figure,.branded-item--jezebel.item .image__wrapper{border-bottom-color:#ec1238}.branded-item--jezebel .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jezebel .inset--story__readmore:hover{color:#ec1238;text-decoration:none}.branded-item--kotaku .inset--story__thumb figure,.branded-item--kotaku.item .image__wrapper{border-bottom-color:#fbc}.branded-item--kotaku .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--kotaku .inset--story__readmore:hover{color:#fbc;text-decoration:none}.branded-item--lifehacker .inset--story__thumb figure,.branded-item--lifehacker.item .image__wrapper{border-bottom-color:#94b33}.branded-item--lifehacker .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #cbdf88;box-shadow:inset -2px #cbdf88;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--lifehacker .inset--story__readmore:hover{color:#94b33;text-decoration:none}.branded-item--theonion .inset--story__thumb figure,.branded-item--theonion.item .image__wrapper{border-bottom-color:#6b3a}.branded-item--theonion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f82;box-shadow:inset -2px #f82;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theonion .inset--story__readmore:hover{color:#6b3a;text-decoration:none}.branded-item--theroot .inset--story__thumb figure,.branded-item--theroot.item .image__wrapper{border-bottom-color:#59b22}.branded-item--theroot .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theroot .inset--story__readmore:hover{color:#59b22;text-decoration:none}.branded-item--splinter .inset--story__thumb figure,.branded-item--splinter.item .image__wrapper{border-bottom-color:#f85637}.branded-item--splinter .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--splinter .inset--story__readmore:hover{color:#f85637;text-decoration:none}.branded-item--avclub .inset--story__thumb figure,.branded-item--avclub.item .image__wrapper{border-bottom-color:#1c263c}.branded-item--avclub .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #465f96;box-shadow:inset -2px #465f96;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--avclub .inset--story__readmore:hover{color:#1c263c;text-decoration:none}.branded-item--thetakeout .inset--story__thumb figure,.branded-item--thetakeout.item .image__wrapper{border-bottom-color:#E5371A}.branded-item--thetakeout .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fef7dd;box-shadow:inset -2px #fef7dd;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--thetakeout .inset--story__readmore:hover{color:#F9DB5D;text-decoration:none}.f_branding_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on .post-content .quotable a,.f_branding_on .post-content footer a,.f_branding_on .post-content h1 a,.f_branding_on .post-content h2 a,.f_branding_on .post-content h3 a,.f_branding_on .post-content h4 a,.f_branding_on .post-content h5 a,.f_branding_on .post-content h6 a,.f_branding_on .post-content li a,.f_branding_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on .post-content .quotable a:hover,.f_branding_on .post-content footer a:hover,.f_branding_on .post-content h1 a:hover,.f_branding_on .post-content h2 a:hover,.f_branding_on .post-content h3 a:hover,.f_branding_on .post-content h4 a:hover,.f_branding_on .post-content h5 a:hover,.f_branding_on .post-content h6 a:hover,.f_branding_on .post-content li a:hover,.f_branding_on .post-content p a:hover,.f_branding_on figcaption a{color:#93ec}.f_branding_on figcaption a:hover{color:#73b9}.f_branding_on .editor-inner.post-content blockquote,.f_branding_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on .editor-inner.post-content .pullquote:before,.f_branding_on .entry-content .pullquote:before,.f_branding_on .editor-inner.post-content .pullquote:after,.f_branding_on .entry-content .pullquote:after{border:}.f_branding_on .editor-inner.post-content .pullquote__content,.f_branding_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on .storybreak-branded-a,.f_branding_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on .review-score,.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#333}.f_branding_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on .author-bio__name{color:#222}.f_branding_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_deadspin_on.f_article_split_on .scroll-list-break{border-top:3px solid #2d9d92}.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#1b3a4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-deadspin .post-content .quotable a,.f_branding_on .blog-group-deadspin .post-content .quotable a,.f_branding_on.blog-group-deadspin .post-content footer a,.f_branding_on .blog-group-deadspin .post-content footer a,.f_branding_on.blog-group-deadspin .post-content h1 a,.f_branding_on .blog-group-deadspin .post-content h1 a,.f_branding_on.blog-group-deadspin .post-content h2 a,.f_branding_on .blog-group-deadspin .post-content h2 a,.f_branding_on.blog-group-deadspin .post-content h3 a,.f_branding_on .blog-group-deadspin .post-content h3 a,.f_branding_on.blog-group-deadspin .post-content h4 a,.f_branding_on .blog-group-deadspin .post-content h4 a,.f_branding_on.blog-group-deadspin .post-content h5 a,.f_branding_on .blog-group-deadspin .post-content h5 a,.f_branding_on.blog-group-deadspin .post-content h6 a,.f_branding_on .blog-group-deadspin .post-content h6 a,.f_branding_on.blog-group-deadspin .post-content li a,.f_branding_on .blog-group-deadspin .post-content li a,.f_branding_on.blog-group-deadspin .post-content p a,.f_branding_on .blog-group-deadspin .post-content p a,.f_branding_on.f_branding_deadspin_on .post-content .quotable a,.f_branding_on.f_branding_deadspin_on .post-content footer a,.f_branding_on.f_branding_deadspin_on .post-content h1 a,.f_branding_on.f_branding_deadspin_on .post-content h2 a,.f_branding_on.f_branding_deadspin_on .post-content h3 a,.f_branding_on.f_branding_deadspin_on .post-content h4 a,.f_branding_on.f_branding_deadspin_on .post-content h5 a,.f_branding_on.f_branding_deadspin_on .post-content h6 a,.f_branding_on.f_branding_deadspin_on .post-content li a,.f_branding_on.f_branding_deadspin_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #77d8ce;box-shadow:inset -2px #77d8ce;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-deadspin .post-content .quotable a:hover,.f_branding_on .blog-group-deadspin .post-content .quotable a:hover,.f_branding_on.blog-group-deadspin .post-content footer a:hover,.f_branding_on .blog-group-deadspin .post-content footer a:hover,.f_branding_on.blog-group-deadspin .post-content h1 a:hover,.f_branding_on .blog-group-deadspin .post-content h1 a:hover,.f_branding_on.blog-group-deadspin .post-content h2 a:hover,.f_branding_on .blog-group-deadspin .post-content h2 a:hover,.f_branding_on.blog-group-deadspin .post-content h3 a:hover,.f_branding_on .blog-group-deadspin .post-content h3 a:hover,.f_branding_on.blog-group-deadspin .post-content h4 a:hover,.f_branding_on .blog-group-deadspin .post-content h4 a:hover,.f_branding_on.blog-group-deadspin .post-content h5 a:hover,.f_branding_on .blog-group-deadspin .post-content h5 a:hover,.f_branding_on.blog-group-deadspin .post-content h6 a:hover,.f_branding_on .blog-group-deadspin .post-content h6 a:hover,.f_branding_on.blog-group-deadspin .post-content li a:hover,.f_branding_on .blog-group-deadspin .post-content li a:hover,.f_branding_on.blog-group-deadspin .post-content p a:hover,.f_branding_on .blog-group-deadspin .post-content p a:hover,.f_branding_on.f_branding_deadspin_on .post-content .quotable a:hover,.f_branding_on.f_branding_deadspin_on .post-content footer a:hover,.f_branding_on.f_branding_deadspin_on .post-content h1 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h2 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h3 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h4 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h5 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h6 a:hover,.f_branding_on.f_branding_deadspin_on .post-content li a:hover,.f_branding_on.f_branding_deadspin_on .post-content p a:hover,.f_branding_on.blog-group-deadspin figcaption a,.f_branding_on .blog-group-deadspin figcaption a,.f_branding_on.f_branding_deadspin_on figcaption a{color:#2d9d92}.f_branding_on.blog-group-deadspin figcaption a:hover,.f_branding_on .blog-group-deadspin figcaption a:hover,.f_branding_on.f_branding_deadspin_on figcaption a:hover{color:#22756d}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on.blog-group-deadspin .entry-content blockquote,.f_branding_on .blog-group-deadspin .entry-content blockquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_deadspin_on .entry-content blockquote{border-radius:;border-left:5px solid #1b3a4d;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-deadspin .entry-content .pullquote__content,.f_branding_on .blog-group-deadspin .entry-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-deadspin .review-score,.f_branding_on .blog-group-deadspin .review-score,.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_deadspin_on .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1b3a4d}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white){color:#2d9d92;border-color:#2d9d92}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white):hover{color:#22756d;border-color:#22756d}.f_branding_on.blog-group-deadspin .author-bio__name,.f_branding_on .blog-group-deadspin .author-bio__name,.f_branding_on.f_branding_deadspin_on .author-bio__name{color:#222}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name){color:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover{color:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#22756d}.f_branding_on.blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_deadspin_on .sidebar-content .newsletter-subscribe{border-color:#1b3a4d}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on.blog-group-deadspin .entry-content .pullquote,.f_branding_on .blog-group-deadspin .entry-content .pullquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote{border-top:1px solid #1b3a4d;border-bottom:1px solid #1b3a4d;padding:3px ;position:relative;color:#1b3a4d;font-size:22px;line-height:32px;font-weight:bold;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{height:4px;width:26px;position:absolute;left:calc(5% - 13px);background-image:url('data:image/svg+xml;utf8,<svg xmlns="http://www.w3.org/2/svg" width="26" height="4" viewBox=" 26 4"><title>deadspin-quote-carrot-aligned-w-bgr-2<\/title><path d="M1,3.5l3-3,3,3Z" style="fill:%23fff;stroke:%23fff"/><path d="M,3.5H1l3-3,3,3H26" style="fill:none;stroke:%231b3a4d"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{top:-4px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{bottom:-4px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;width:1%}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child{top:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child{bottom:6px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{display:block;content:'';height:9px;width:18px;position:absolute;top:-1px;background-color:#fff}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{left:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after{right:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{top:-2px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{background-image:url('data:image/svg+xml;utf8,<svg width="19" height="9" viewBox=" 19 9" xmlns="http://www.w3.org/2/svg"><title>deadspin-quote-topleft<\/title><path d="M.5 8.5c-4.43 3.655-8.54 8-8h1" stroke="%231B3A4D" fill="none" stroke-linecap="square" stroke-linejoin="round"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after{-webkit-transform:scaleX(-1);transform:scaleX(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{-webkit-transform:scaleY(-1);transform:scaleY(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after{-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>diamond-blue<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%231B3A4D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>deadspin-diamond-teal<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%23249D9D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on.blog-group-earther .entry-content .pullquote,.f_branding_on .blog-group-earther .entry-content .pullquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_earther_on .entry-content .pullquote{border-top:none;border-bottom:none;padding:3px;position:relative;font-size:22px;line-height:32px;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-earther .entry-content .pullquote.align--left,.f_branding_on .blog-group-earther .entry-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{height:3px;width:3px;position:absolute;background-image:url('data:image/svg+xml;utf8,<svg width="3" height="3" viewBox=" 4 4" xmlns="http://www.w3.org/2/svg"><title>pq-earther<\/title><path d="M4 h36v8H8v32HVh4z" fill="%2375B2" fill-rule="evenodd"/><\/svg>');margin:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{top:;left:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{bottom:;right:;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-a{min-width:26px;height:26px;background-image:url('data:image/svg+xml;utf8,<svg width="26" height="26" viewBox=" 26 26" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-a<\/title><g stroke="%2375B2" fill="none" fill-rule="evenodd" stroke-linejoin="round"><path d="M21.292 21.292c-4.757 4.757-12.47 4.756-17.225 -4.756-4.757-4.756-12.47 -17.225 4.757-4.756 12.47-4.756 17.225 4.756 4.757 4.756 12.47 17.225z"/><path d="M21.69 2.988c-3.98 2.526-1.537 1.65-14.767-2.578C2.69 14.177 1.857 8.238 4.67 3.655"/><path d="M22.75 14.657c-2.53 2.5-7.226 1.83-1.55-1.494C8.88 9.84 8.215 5.117 1.718 2.617c2.54-2.5 7.227-1.83 1.55 1.494 3.323 3.33 3.987 8.5 1.484 1.55z" stroke-width="1.77"/><path d="M2.294 9.234c-.793.793-2.37.5-3.524-.654s-1.447-2.732-.654-3.525c.792-.793 2.37-.5 3.524.654 1.154 1.15 1.446 2.73.654 3.52zm-.2.17c2.69 4.38 1.677 1.43-1.856 13.964M2.14 6.963c3.567-3.566 9.973-5.35 13.926-2.225m4.456 2.548c1.473.93 2.75.523 3.745 1.32m-6.7-3.77c-.11-1.416-.534-2.646-1.31-3.61"/><path d="M18.852 9.85c-.55 2.345-2.5 6.53-4.95 8.998-2.427 2.428-4.818 3.666-6.967 4.52m-4.512-4.512c.846-2.16 1.646-4.94 4.98-7.39 2.95-2.945 6.66-3.93 9.1-4.478"/><\/g><\/svg>')}.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-b{min-width:25px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="25" height="25" viewBox=" 25 25" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path d="M24.398 12.438c 6.63-5.374 12.4-12.4 12.4S.39 19.68.39 12.438 5.765.434 12.394.434c6.63 12.4 5.375 12.4 12.4" fill="%2375B2"/><path d="M 12.32h24.64M12.32 v24.42m8.74-2.818L3.73 2.932M3.727 3.596l17.336 17.34m-1.358-8.67c 4.37-3.273 7.31-7.31 7.31-4.37 -7.31-3.273-7.31-7.31 -4.37 3.273-7.31 7.31-7.31 4.37 7.31 3.273 7.31 7.31z" stroke="%23FFF" stroke-width=".88"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_gizmodo_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-gizmodo .post-content .quotable a,.f_branding_on .blog-group-gizmodo .post-content .quotable a,.f_branding_on.blog-group-gizmodo .post-content footer a,.f_branding_on .blog-group-gizmodo .post-content footer a,.f_branding_on.blog-group-gizmodo .post-content h1 a,.f_branding_on .blog-group-gizmodo .post-content h1 a,.f_branding_on.blog-group-gizmodo .post-content h2 a,.f_branding_on .blog-group-gizmodo .post-content h2 a,.f_branding_on.blog-group-gizmodo .post-content h3 a,.f_branding_on .blog-group-gizmodo .post-content h3 a,.f_branding_on.blog-group-gizmodo .post-content h4 a,.f_branding_on .blog-group-gizmodo .post-content h4 a,.f_branding_on.blog-group-gizmodo .post-content h5 a,.f_branding_on .blog-group-gizmodo .post-content h5 a,.f_branding_on.blog-group-gizmodo .post-content h6 a,.f_branding_on .blog-group-gizmodo .post-content h6 a,.f_branding_on.blog-group-gizmodo .post-content li a,.f_branding_on .blog-group-gizmodo .post-content li a,.f_branding_on.blog-group-gizmodo .post-content p a,.f_branding_on .blog-group-gizmodo .post-content p a,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a,.f_branding_on.f_branding_gizmodo_on .post-content footer a,.f_branding_on.f_branding_gizmodo_on .post-content h1 a,.f_branding_on.f_branding_gizmodo_on .post-content h2 a,.f_branding_on.f_branding_gizmodo_on .post-content h3 a,.f_branding_on.f_branding_gizmodo_on .post-content h4 a,.f_branding_on.f_branding_gizmodo_on .post-content h5 a,.f_branding_on.f_branding_gizmodo_on .post-content h6 a,.f_branding_on.f_branding_gizmodo_on .post-content li a,.f_branding_on.f_branding_gizmodo_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on .blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on.blog-group-gizmodo .post-content footer a:hover,.f_branding_on .blog-group-gizmodo .post-content footer a:hover,.f_branding_on.blog-group-gizmodo .post-content h1 a:hover,.f_branding_on .blog-group-gizmodo .post-content h1 a:hover,.f_branding_on.blog-group-gizmodo .post-content h2 a:hover,.f_branding_on .blog-group-gizmodo .post-content h2 a:hover,.f_branding_on.blog-group-gizmodo .post-content h3 a:hover,.f_branding_on .blog-group-gizmodo .post-content h3 a:hover,.f_branding_on.blog-group-gizmodo .post-content h4 a:hover,.f_branding_on .blog-group-gizmodo .post-content h4 a:hover,.f_branding_on.blog-group-gizmodo .post-content h5 a:hover,.f_branding_on .blog-group-gizmodo .post-content h5 a:hover,.f_branding_on.blog-group-gizmodo .post-content h6 a:hover,.f_branding_on .blog-group-gizmodo .post-content h6 a:hover,.f_branding_on.blog-group-gizmodo .post-content li a:hover,.f_branding_on .blog-group-gizmodo .post-content li a:hover,.f_branding_on.blog-group-gizmodo .post-content p a:hover,.f_branding_on .blog-group-gizmodo .post-content p a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a:hover,.f_branding_on.f_branding_gizmodo_on .post-content footer a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h1 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h2 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h3 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h4 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h5 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h6 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content li a:hover,.f_branding_on.f_branding_gizmodo_on .post-content p a:hover,.f_branding_on.blog-group-gizmodo figcaption a,.f_branding_on .blog-group-gizmodo figcaption a,.f_branding_on.f_branding_gizmodo_on figcaption a{color:#93ec}.f_branding_on.blog-group-gizmodo figcaption a:hover,.f_branding_on .blog-group-gizmodo figcaption a:hover,.f_branding_on.f_branding_gizmodo_on figcaption a:hover{color:#73b9}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on.blog-group-gizmodo .entry-content blockquote,.f_branding_on .blog-group-gizmodo .entry-content blockquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before,.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on .blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-gizmodo .review-score,.f_branding_on .blog-group-gizmodo .review-score,.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_gizmodo_on .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio__name,.f_branding_on .blog-group-gizmodo .author-bio__name,.f_branding_on.f_branding_gizmodo_on .author-bio__name{color:#222}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on.blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_gizmodo_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on.blog-group-gizmodo .entry-content .pullquote,.f_branding_on .blog-group-gizmodo .entry-content .pullquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote{border-top:2px solid #18afed;border-bottom:2px solid #18afed;padding-top:3px;padding-bottom:3px;position:relative}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before{height:42px;width:42px;position:absolute;left:calc(5% - 21px);top:-21px;background-image:url('data:image/svg+xml;utf8,<svg width="42" height="42" viewBox=" 42 42" xmlns="http://www.w3.org/2/svg"><title>gizmodo-quote<\/title><g fill="none" fill-rule="evenodd"><path d="M41.95 2.974c 11.583-9.392 2.974-2.976 2.974S 32.558 2.974 9.39 2.974 41.95 9.39 41.95 2.974" fill="%2318AFED"/><path d="M21.8 21.422c-6.874 3.744-9.434 9.622-9.623l.76 3.46c-3.178.38-4.74 1.894-4.647 4.453h3.51l-.2 9.245H21.8v-7.54zm-12.562 c-6.874 3.697-9.434 9.622-9.623l.71 3.46c-3.175.38-4.74 1.894-4.597 4.453h3.58l.4 9.245H9.238v-7.54z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a{min-width:33px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="12" viewBox=" 33 12" xmlns="http://www.w3.org/2/svg"><title>gizmodo-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2318AFED" d="M11 12h11VH11"/><path fill="%23" d="M 12h11VHm22 12h11VH22"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{min-width:111px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="111" height="25" viewBox=" 111 25" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>gizmodo-plots<\/title><defs><path id="a" d="M 5V.324h4.676V5Hz"/><path id="c" d="M4.985.26v4.8H.977V.26h4.8z"/><path id="e" d="M.398.842H3.7v2.672H.398V.842z"/><\/defs><g fill="none" fill-rule="evenodd"><path stroke="%2318AFED" stroke-width=".445" d="M34.61 19.42L1.762 21.857l9.583-18.2 22.69 15.63L44.157 1.372l1.73 1.52 18.44 9.124 3.855-14.23"/><g transform="translate( 19.158)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M4.67 2.516c.84 1.29-.896 2.4-2.184 2.48-1.29.8-2.4-.9-2.48-2.188-.8-1.29.898-2.4 2.188-2.48C3.48.25 4.59 1.23 4.67 2.518" fill="%2318AFED" mask="url(%23b)"/><\/g><path d="M13.587 3.714c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m43.543 8.38c.6.92-.64 1.713-1.56 1.77-.922.6-1.715-.64-1.772-1.56-.58-.922.64-1.715 1.562-1.772.92-.58 1.713.64 1.77 1.562m42.882-7.84c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m-25.368 16.46c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562M79.36 6.625c.7 1.15-.77 2.56-1.874 2.125-1.15.7-2.56-.77-2.125-1.875-.66-1.14.77-2.56 1.878-2.125 1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED"/><g transform="translate(16 18.158)"><mask id="d" fill="%23fff"><use xlink-underline:href="%23c"/><\/mask><path d="M4.98 2.14c.7 1.14-.77 2.55-1.874 2.124C2 4.334 1.5 3.494.98 2.39.91 1.284 1.75.332 2.857.263c1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED" mask="url(%23d)"/><\/g><path d="M36.61 19.296c.7 1.15-.77 2.56-1.875 2.125-1.15.7-2.56-.77-2.125-1.872-.7-1.14.77-2.56 1.875-2.125 1.14-.68 2.56.77 2.125 1.876" fill="%2318AFED"/><g transform="translate(43 -.842)"><mask id="f" fill="%23fff"><use xlink-underline:href="%23e"/><\/mask><path d="M3.67 2.95c.46.735-.514 1.37-1.25 1.416C1.8 3.56.447 3 .4 2.265.354 1.524.914.89 1.65.844c.737-.46 1.37.514 1.417 1.25" fill="%2318AFED" mask="url(%23f)"/><\/g><path d="M55.464 11.856L34.61 19.42m-32.272 2.4L44.734 1.336 77.36 6.75l32.24 13.83L97.985 3.574 72.977 2.512" stroke="%2318AFED" stroke-width=".445"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jalopnik_on.f_article_split_on .scroll-list-break{border-top:3px solid #ff4d}.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ff4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jalopnik .post-content .quotable a,.f_branding_on .blog-group-jalopnik .post-content .quotable a,.f_branding_on.blog-group-jalopnik .post-content footer a,.f_branding_on .blog-group-jalopnik .post-content footer a,.f_branding_on.blog-group-jalopnik .post-content h1 a,.f_branding_on .blog-group-jalopnik .post-content h1 a,.f_branding_on.blog-group-jalopnik .post-content h2 a,.f_branding_on .blog-group-jalopnik .post-content h2 a,.f_branding_on.blog-group-jalopnik .post-content h3 a,.f_branding_on .blog-group-jalopnik .post-content h3 a,.f_branding_on.blog-group-jalopnik .post-content h4 a,.f_branding_on .blog-group-jalopnik .post-content h4 a,.f_branding_on.blog-group-jalopnik .post-content h5 a,.f_branding_on .blog-group-jalopnik .post-content h5 a,.f_branding_on.blog-group-jalopnik .post-content h6 a,.f_branding_on .blog-group-jalopnik .post-content h6 a,.f_branding_on.blog-group-jalopnik .post-content li a,.f_branding_on .blog-group-jalopnik .post-content li a,.f_branding_on.blog-group-jalopnik .post-content p a,.f_branding_on .blog-group-jalopnik .post-content p a,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a,.f_branding_on.f_branding_jalopnik_on .post-content footer a,.f_branding_on.f_branding_jalopnik_on .post-content h1 a,.f_branding_on.f_branding_jalopnik_on .post-content h2 a,.f_branding_on.f_branding_jalopnik_on .post-content h3 a,.f_branding_on.f_branding_jalopnik_on .post-content h4 a,.f_branding_on.f_branding_jalopnik_on .post-content h5 a,.f_branding_on.f_branding_jalopnik_on .post-content h6 a,.f_branding_on.f_branding_jalopnik_on .post-content li a,.f_branding_on.f_branding_jalopnik_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #a1cde;box-shadow:inset -2px #a1cde;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on .blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on.blog-group-jalopnik .post-content footer a:hover,.f_branding_on .blog-group-jalopnik .post-content footer a:hover,.f_branding_on.blog-group-jalopnik .post-content h1 a:hover,.f_branding_on .blog-group-jalopnik .post-content h1 a:hover,.f_branding_on.blog-group-jalopnik .post-content h2 a:hover,.f_branding_on .blog-group-jalopnik .post-content h2 a:hover,.f_branding_on.blog-group-jalopnik .post-content h3 a:hover,.f_branding_on .blog-group-jalopnik .post-content h3 a:hover,.f_branding_on.blog-group-jalopnik .post-content h4 a:hover,.f_branding_on .blog-group-jalopnik .post-content h4 a:hover,.f_branding_on.blog-group-jalopnik .post-content h5 a:hover,.f_branding_on .blog-group-jalopnik .post-content h5 a:hover,.f_branding_on.blog-group-jalopnik .post-content h6 a:hover,.f_branding_on .blog-group-jalopnik .post-content h6 a:hover,.f_branding_on.blog-group-jalopnik .post-content li a:hover,.f_branding_on .blog-group-jalopnik .post-content li a:hover,.f_branding_on.blog-group-jalopnik .post-content p a:hover,.f_branding_on .blog-group-jalopnik .post-content p a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a:hover,.f_branding_on.f_branding_jalopnik_on .post-content footer a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h1 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h2 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h3 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h4 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h5 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h6 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content li a:hover,.f_branding_on.f_branding_jalopnik_on .post-content p a:hover,.f_branding_on.blog-group-jalopnik figcaption a,.f_branding_on .blog-group-jalopnik figcaption a,.f_branding_on.f_branding_jalopnik_on figcaption a{color:#417eb9}.f_branding_on.blog-group-jalopnik figcaption a:hover,.f_branding_on .blog-group-jalopnik figcaption a:hover,.f_branding_on.f_branding_jalopnik_on figcaption a:hover{color:#346493}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on.blog-group-jalopnik .entry-content blockquote,.f_branding_on .blog-group-jalopnik .entry-content blockquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote{border-radius:;border-left:5px solid #417eb9;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before,.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on .blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jalopnik .review-score,.f_branding_on .blog-group-jalopnik .review-score,.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jalopnik_on .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ff4d}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white){color:#417eb9;border-color:#417eb9}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white):hover{color:#346493;border-color:#346493}.f_branding_on.blog-group-jalopnik .author-bio__name,.f_branding_on .blog-group-jalopnik .author-bio__name,.f_branding_on.f_branding_jalopnik_on .author-bio__name{color:#222}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name){color:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover{color:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#346493}.f_branding_on.blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jalopnik_on .sidebar-content .newsletter-subscribe{border-color:#417eb9}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jalopnik .entry-content .pullquote,.f_branding_on .blog-group-jalopnik .entry-content .pullquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before{height:8px;width:219px;background-image:url('data:image/svg+xml;utf8,<svg width="219" height="8" viewBox=" 219 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-top<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" transform="matrix(-1 1 265 )" d="M46 h17l3 4H49"/><path fill="%23FF4D" d="M116 4H2L 8h114"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{height:8px;width:116px;background-image:url('data:image/svg+xml;utf8,<svg width="116" height="8" viewBox=" 116 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-bottom<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="%23FF4D" d="M116 H48l-1 4h68"/><path fill="url(%23a)" transform="matrix(-1 1 84 )" d="M 4h83l1 4H1"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a{min-width:77px;height:1px;background-image:url('data:image/svg+xml;utf8,<svg width="77" height="1" viewBox=" 77 1" xmlns="http://www.w3.org/2/svg"><title>%23-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%23CCC" d="M12.423 4L1 1h64.577L77 4"/><path fill="%23FF4D" d="M2.423 L 6h64.577L67 "/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{min-width:8px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="8" height="12" viewBox=" 8 12" xmlns="http://www.w3.org/2/svg"><title>%23-gradient<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" d="M75.1 5.982L78.82 12H3L4.185 H8"/><path d="M3.517 11.977c-.194 -.696.23-.96.23Hl.5-5.86h2.585c.264 .5-.22.527-.49L4.242 H9l-.665 6.92c-.26.27-.15.75-.175.965 -.532 4.68-4.643 4.92z" fill="%23FF4D"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .pullquote__content,.f_branding_on .blog-group-jalopnik .pullquote__content,.f_branding_on.f_branding_jalopnik_on .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jezebel_on.f_article_split_on .scroll-list-break{border-top:3px solid #ec1238}.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ec1238;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jezebel .post-content .quotable a,.f_branding_on .blog-group-jezebel .post-content .quotable a,.f_branding_on.blog-group-jezebel .post-content footer a,.f_branding_on .blog-group-jezebel .post-content footer a,.f_branding_on.blog-group-jezebel .post-content h1 a,.f_branding_on .blog-group-jezebel .post-content h1 a,.f_branding_on.blog-group-jezebel .post-content h2 a,.f_branding_on .blog-group-jezebel .post-content h2 a,.f_branding_on.blog-group-jezebel .post-content h3 a,.f_branding_on .blog-group-jezebel .post-content h3 a,.f_branding_on.blog-group-jezebel .post-content h4 a,.f_branding_on .blog-group-jezebel .post-content h4 a,.f_branding_on.blog-group-jezebel .post-content h5 a,.f_branding_on .blog-group-jezebel .post-content h5 a,.f_branding_on.blog-group-jezebel .post-content h6 a,.f_branding_on .blog-group-jezebel .post-content h6 a,.f_branding_on.blog-group-jezebel .post-content li a,.f_branding_on .blog-group-jezebel .post-content li a,.f_branding_on.blog-group-jezebel .post-content p a,.f_branding_on .blog-group-jezebel .post-content p a,.f_branding_on.f_branding_jezebel_on .post-content .quotable a,.f_branding_on.f_branding_jezebel_on .post-content footer a,.f_branding_on.f_branding_jezebel_on .post-content h1 a,.f_branding_on.f_branding_jezebel_on .post-content h2 a,.f_branding_on.f_branding_jezebel_on .post-content h3 a,.f_branding_on.f_branding_jezebel_on .post-content h4 a,.f_branding_on.f_branding_jezebel_on .post-content h5 a,.f_branding_on.f_branding_jezebel_on .post-content h6 a,.f_branding_on.f_branding_jezebel_on .post-content li a,.f_branding_on.f_branding_jezebel_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jezebel .post-content .quotable a:hover,.f_branding_on .blog-group-jezebel .post-content .quotable a:hover,.f_branding_on.blog-group-jezebel .post-content footer a:hover,.f_branding_on .blog-group-jezebel .post-content footer a:hover,.f_branding_on.blog-group-jezebel .post-content h1 a:hover,.f_branding_on .blog-group-jezebel .post-content h1 a:hover,.f_branding_on.blog-group-jezebel .post-content h2 a:hover,.f_branding_on .blog-group-jezebel .post-content h2 a:hover,.f_branding_on.blog-group-jezebel .post-content h3 a:hover,.f_branding_on .blog-group-jezebel .post-content h3 a:hover,.f_branding_on.blog-group-jezebel .post-content h4 a:hover,.f_branding_on .blog-group-jezebel .post-content h4 a:hover,.f_branding_on.blog-group-jezebel .post-content h5 a:hover,.f_branding_on .blog-group-jezebel .post-content h5 a:hover,.f_branding_on.blog-group-jezebel .post-content h6 a:hover,.f_branding_on .blog-group-jezebel .post-content h6 a:hover,.f_branding_on.blog-group-jezebel .post-content li a:hover,.f_branding_on .blog-group-jezebel .post-content li a:hover,.f_branding_on.blog-group-jezebel .post-content p a:hover,.f_branding_on .blog-group-jezebel .post-content p a:hover,.f_branding_on.f_branding_jezebel_on .post-content .quotable a:hover,.f_branding_on.f_branding_jezebel_on .post-content footer a:hover,.f_branding_on.f_branding_jezebel_on .post-content h1 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h2 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h3 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h4 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h5 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h6 a:hover,.f_branding_on.f_branding_jezebel_on .post-content li a:hover,.f_branding_on.f_branding_jezebel_on .post-content p a:hover,.f_branding_on.blog-group-jezebel figcaption a,.f_branding_on .blog-group-jezebel figcaption a,.f_branding_on.f_branding_jezebel_on figcaption a{color:#ec1238}.f_branding_on.blog-group-jezebel figcaption a:hover,.f_branding_on .blog-group-jezebel figcaption a:hover,.f_branding_on.f_branding_jezebel_on figcaption a:hover{color:#bde2d}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on.blog-group-jezebel .entry-content blockquote,.f_branding_on .blog-group-jezebel .entry-content blockquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jezebel_on .entry-content blockquote{border-radius:;border-left:5px solid #ec1238;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jezebel .review-score,.f_branding_on .blog-group-jezebel .review-score,.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jezebel_on .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white){color:#ec1238;border-color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white):hover{color:#bde2d;border-color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio__name,.f_branding_on .blog-group-jezebel .author-bio__name,.f_branding_on.f_branding_jezebel_on .author-bio__name{color:#222}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name){color:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover{color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#bde2d}.f_branding_on.blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jezebel_on .sidebar-content .newsletter-subscribe{border-color:#ec1238}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jezebel .entry-content .pullquote,.f_branding_on .blog-group-jezebel .entry-content .pullquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold;position:relative;padding:36px ;text-transform:uppercase;font-weight:1;color:#ec1238;font-size:31px;line-height:33px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{display:block;content:'';position:absolute;width:23px;height:18px;left:calc(5% - 12px);background-image:url('data:image/svg+xml;utf8,<svg width="23" height="18" viewBox=" 23 18" xmlns="http://www.w3.org/2/svg"><title>jezbel-quote<\/title><path d="M23 13.46c 1.253-.45 2.323-1.345 3.21-.897.887-1.977 1.33-3.243 1.33-1.69 -2.968-.548-3.837-1.644-.87-1.95-1.36-2.426-1.36-3.99 -2.192.76-4.435 2.29-6.73C17.9 3.338 19.252 1.46 22.5 L23 1.41c-1.32 1.147-2.36 2.347-3.125 3.598-.765 1.253-1.358 2.48-1.78 3.68 1.53.14 2.73.613 3.6 1.525.87.913 1.35 1.995 1.35 3.248m-12.385 c 1.258-.457 2.328-1.373 3.21-.915.89-2 1.33-3.256 1.33-1.622 -2.878-.543-3.767-1.64-.89-1.1-1.34-2.43-1.34-3.99 -2.194.756-4.437 2.273-6.73C4.677 3.335 6.85 1.46 9.673 l.86 1.41c-1.35 1.147-2.34 2.347-3.1 3.598-.755 1.253-1.344 2.48-1.762 3.68 1.52.14 2.72.613 3.61 1.525.89.913 1.338 1.995 1.338 3.248" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{top:-6px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{bottom:-6px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;height:7px;width:calc(5% - 2px);background-color:#ec1238;-webkit-transform:skewX(-7deg);transform:skewX(-7deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:first-child{top:;left:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:last-child{bottom:;right:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left{padding:31px ;text-align:left;margin-bottom:1rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:before{display:none}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a{min-width:31px;height:31px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="31" viewBox=" 31 31" xmlns="http://www.w3.org/2/svg"><title>jezebel-wheel<\/title><path d="M18.53.852h2.96v7.85c 1-.852 2.643-1.91 3.39-.392.275-.855.582-1.42.738v-.613c.29-.284.425-1.11.425-1.762V.852zM8.46 2.337L1.684.5l5.13 6.14c.652.765 1.72 2.563.75 3.84-.12.46-.274.986-.67 1.465l-.398-.472c.3-.4-.41-1.11-.83-1.61L8.46 2.34M1.713 9.844L2.22 7.3l7.858 1.362c1 .173 2.497 1.285 3.6 2.44.27.427.434.928.492 1.54l-.613-.18c-.234-.33-1.4-.63-1.69-.716-.96-.157-6.215-1.8-9.612-1.668M1.453 19.86C.963 19.23.49 18.22 17.384l6.91-3.925c.88-.5 2.752-.6 3.938-.7.438.19.94.43 1.36.84-.63.3-.334.19-.54.3-.394-.16-1.19.193-1.763.52l-8.452 4.8m6.342 7.84l-2.73-.978 2.73-7.376c.347-.94 1.72-2.197 2.972-2.54.464-.13 1.6-.26 1.593-.218-.26.7-.135.354-.216.574-.37.17-.784.93-1.1 1.515l-3.34 9.3m9.98 1.99l-2.73.978-2.73-7.38c-.345-.94-.116-2.77.62-3.83.272-.39.6-.837 1.8-1.175.23.7.127.357.21.576-.175.364-.13 1.186.213 1.8.315.85 2.16 5.833 3.338 9.22m8.948-4.785c-.49.837-.962 1.64-1.453 2.476l-6.91-3.926c-.88-.5-1.9-2.48-2.27-3.32-.47-.474-.86-1.2.6-1.58l.537.36c.16.39.767.917 1.34 1.243l8.453 4.8m3.727-9.32l.55 2.815-7.858 1.36c-1 .175-2.792-.366-3.722-1.262-.345-.332-.732-.727-.987-1.25.73-.1.38-.62.614-.13.334.23 1.185.22 1.837.17l9.61-1.667m-3.24-9.5l2.222 1.84c-1.756 2.6-3.37 3.953-5.13 6.13-.652.765-2.38 1.485-3.676 1.387-.48-.37-1.35-.94-1.57-.33.46-.6.25-.29.4-.47.41-.36 1.52-.584 1.477-1.8l6.274-7.36" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;font-family:"ElizabethSerif",Georgia,serif;letter-spacing:7px;margin-top:4px;margin-bottom:6px;overflow:visible;text-align:center}.f_branding_on.blog-group-jezebel .storybreak-branded-b:before,.f_branding_on .blog-group-jezebel .storybreak-branded-b:before,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b:before{color:#ec1238;content:'***';display:inline-block;font-size:17px}.f_branding_on.blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on .blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b.storybreak-variant--branded{margin:;padding:4px}.f_branding_on.blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_kotaku_on.f_article_split_on .scroll-list-break{border-top:3px solid #fbc}.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#b1246;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-kotaku .post-content .quotable a,.f_branding_on .blog-group-kotaku .post-content .quotable a,.f_branding_on.blog-group-kotaku .post-content footer a,.f_branding_on .blog-group-kotaku .post-content footer a,.f_branding_on.blog-group-kotaku .post-content h1 a,.f_branding_on .blog-group-kotaku .post-content h1 a,.f_branding_on.blog-group-kotaku .post-content h2 a,.f_branding_on .blog-group-kotaku .post-content h2 a,.f_branding_on.blog-group-kotaku .post-content h3 a,.f_branding_on .blog-group-kotaku .post-content h3 a,.f_branding_on.blog-group-kotaku .post-content h4 a,.f_branding_on .blog-group-kotaku .post-content h4 a,.f_branding_on.blog-group-kotaku .post-content h5 a,.f_branding_on .blog-group-kotaku .post-content h5 a,.f_branding_on.blog-group-kotaku .post-content h6 a,.f_branding_on .blog-group-kotaku .post-content h6 a,.f_branding_on.blog-group-kotaku .post-content li a,.f_branding_on .blog-group-kotaku .post-content li a,.f_branding_on.blog-group-kotaku .post-content p a,.f_branding_on .blog-group-kotaku .post-content p a,.f_branding_on.f_branding_kotaku_on .post-content .quotable a,.f_branding_on.f_branding_kotaku_on .post-content footer a,.f_branding_on.f_branding_kotaku_on .post-content h1 a,.f_branding_on.f_branding_kotaku_on .post-content h2 a,.f_branding_on.f_branding_kotaku_on .post-content h3 a,.f_branding_on.f_branding_kotaku_on .post-content h4 a,.f_branding_on.f_branding_kotaku_on .post-content h5 a,.f_branding_on.f_branding_kotaku_on .post-content h6 a,.f_branding_on.f_branding_kotaku_on .post-content li a,.f_branding_on.f_branding_kotaku_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-kotaku .post-content .quotable a:hover,.f_branding_on .blog-group-kotaku .post-content .quotable a:hover,.f_branding_on.blog-group-kotaku .post-content footer a:hover,.f_branding_on .blog-group-kotaku .post-content footer a:hover,.f_branding_on.blog-group-kotaku .post-content h1 a:hover,.f_branding_on .blog-group-kotaku .post-content h1 a:hover,.f_branding_on.blog-group-kotaku .post-content h2 a:hover,.f_branding_on .blog-group-kotaku .post-content h2 a:hover,.f_branding_on.blog-group-kotaku .post-content h3 a:hover,.f_branding_on .blog-group-kotaku .post-content h3 a:hover,.f_branding_on.blog-group-kotaku .post-content h4 a:hover,.f_branding_on .blog-group-kotaku .post-content h4 a:hover,.f_branding_on.blog-group-kotaku .post-content h5 a:hover,.f_branding_on .blog-group-kotaku .post-content h5 a:hover,.f_branding_on.blog-group-kotaku .post-content h6 a:hover,.f_branding_on .blog-group-kotaku .post-content h6 a:hover,.f_branding_on.blog-group-kotaku .post-content li a:hover,.f_branding_on .blog-group-kotaku .post-content li a:hover,.f_branding_on.blog-group-kotaku .post-content p a:hover,.f_branding_on .blog-group-kotaku .post-content p a:hover,.f_branding_on.f_branding_kotaku_on .post-content .quotable a:hover,.f_branding_on.f_branding_kotaku_on .post-content footer a:hover,.f_branding_on.f_branding_kotaku_on .post-content h1 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h2 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h3 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h4 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h5 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h6 a:hover,.f_branding_on.f_branding_kotaku_on .post-content li a:hover,.f_branding_on.f_branding_kotaku_on .post-content p a:hover{color:#fbc}.f_branding_on.blog-group-kotaku figcaption a,.f_branding_on .blog-group-kotaku figcaption a,.f_branding_on.f_branding_kotaku_on figcaption a{color:#b1246}.f_branding_on.blog-group-kotaku figcaption a:hover,.f_branding_on .blog-group-kotaku figcaption a:hover,.f_branding_on.f_branding_kotaku_on figcaption a:hover{color:#871b49}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on.blog-group-kotaku .entry-content blockquote,.f_branding_on .blog-group-kotaku .entry-content blockquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_kotaku_on .entry-content blockquote{border-radius:;border-left:5px solid #fbc;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before,.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-kotaku .review-score,.f_branding_on .blog-group-kotaku .review-score,.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_kotaku_on .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white){color:#b1246;border-color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white):hover{color:#871b49;border-color:#871b49}.f_branding_on.blog-group-kotaku .author-bio__name,.f_branding_on .blog-group-kotaku .author-bio__name,.f_branding_on.f_branding_kotaku_on .author-bio__name{color:#222}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name){color:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover{color:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#871b49}.f_branding_on.blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_kotaku_on .sidebar-content .newsletter-subscribe{border-color:#fbc}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on.blog-group-kotaku .entry-content .pullquote,.f_branding_on .blog-group-kotaku .entry-content .pullquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before{height:7px;width:244px;background-image:url('data:image/svg+xml;utf8,<svg width="244" height="7" viewBox=" 244 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-top<\/title><g fill="none" fill-rule="evenodd"><path d="M243 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M177.167 6.972c2.622.13 5.38-1.883 6.14-4.54L184 .22 64.833.2v.4c-2.622-.13-5.38 1.884-6.14 4.54L58 6.956l.1.44 119.157-.28z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{height:7px;width:129px;background-image:url('data:image/svg+xml;utf8,<svg width="129" height="7" viewBox=" 129 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-bottom<\/title><g fill="none" fill-rule="evenodd"><path d="M128 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M81.75 6.972c2.657.13 5.452-1.883 6.224-4.54l.7-2.41-4.76-.2v.4c-2.657-.13-5.452 1.884-6.224 4.54l-.7 2.41.1.44 4.65-.28z" fill="%23FBC"/><\/g><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:before{background-image:url('data:image/svg+xml;utf8,<svg width="243" height="7" viewBox=" 243 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-lefttop<\/title><g fill="none" fill-rule="evenodd"><path d="M242.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M157.912 6.845c2.375.128 4.872-1.85 5.562-4.457L164.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 122.896-.27z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:after{background-image:url('data:image/svg+xml;utf8,<svg width="117" height="7" viewBox=" 117 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-leftbottom<\/title><g fill="none" fill-rule="evenodd"><path d="M116.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M74.912 6.845c2.375.128 4.872-1.85 5.562-4.457L81.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 39.896-.27z" fill="%23FBC"/><\/g><\/svg>')}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a{min-width:75px;height:16px;background-image:url('data:image/svg+xml;utf8,<svg width="75" height="16" viewBox=" 75 16" xmlns="http://www.w3.org/2/svg"><title>kotaku-bars<\/title><g fill="none" fill-rule="evenodd"><path fill="%23B1246" d="M 16h5VHm7 16h5VH7m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><path fill="%23FBC" d="M49 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_lifehacker_on.f_article_split_on .scroll-list-break{border-top:3px solid #94b33}.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94b33;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-lifehacker .post-content .quotable a,.f_branding_on .blog-group-lifehacker .post-content .quotable a,.f_branding_on.blog-group-lifehacker .post-content footer a,.f_branding_on .blog-group-lifehacker .post-content footer a,.f_branding_on.blog-group-lifehacker .post-content h1 a,.f_branding_on .blog-group-lifehacker .post-content h1 a,.f_branding_on.blog-group-lifehacker .post-content h2 a,.f_branding_on .blog-group-lifehacker .post-content h2 a,.f_branding_on.blog-group-lifehacker .post-content h3 a,.f_branding_on .blog-group-lifehacker .post-content h3 a,.f_branding_on.blog-group-lifehacker .post-content h4 a,.f_branding_on .blog-group-lifehacker .post-content h4 a,.f_branding_on.blog-group-lifehacker .post-content h5 a,.f_branding_on .blog-group-lifehacker .post-content h5 a,.f_branding_on.blog-group-lifehacker .post-content h6 a,.f_branding_on .blog-group-lifehacker .post-content h6 a,.f_branding_on.blog-group-lifehacker .post-content li a,.f_branding_on .blog-group-lifehacker .post-content li a,.f_branding_on.blog-group-lifehacker .post-content p a,.f_branding_on .blog-group-lifehacker .post-content p a,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a,.f_branding_on.f_branding_lifehacker_on .post-content footer a,.f_branding_on.f_branding_lifehacker_on .post-content h1 a,.f_branding_on.f_branding_lifehacker_on .post-content h2 a,.f_branding_on.f_branding_lifehacker_on .post-content h3 a,.f_branding_on.f_branding_lifehacker_on .post-content h4 a,.f_branding_on.f_branding_lifehacker_on .post-content h5 a,.f_branding_on.f_branding_lifehacker_on .post-content h6 a,.f_branding_on.f_branding_lifehacker_on .post-content li a,.f_branding_on.f_branding_lifehacker_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #9dcee7;box-shadow:inset -2px #9dcee7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on .blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on.blog-group-lifehacker .post-content footer a:hover,.f_branding_on .blog-group-lifehacker .post-content footer a:hover,.f_branding_on.blog-group-lifehacker .post-content h1 a:hover,.f_branding_on .blog-group-lifehacker .post-content h1 a:hover,.f_branding_on.blog-group-lifehacker .post-content h2 a:hover,.f_branding_on .blog-group-lifehacker .post-content h2 a:hover,.f_branding_on.blog-group-lifehacker .post-content h3 a:hover,.f_branding_on .blog-group-lifehacker .post-content h3 a:hover,.f_branding_on.blog-group-lifehacker .post-content h4 a:hover,.f_branding_on .blog-group-lifehacker .post-content h4 a:hover,.f_branding_on.blog-group-lifehacker .post-content h5 a:hover,.f_branding_on .blog-group-lifehacker .post-content h5 a:hover,.f_branding_on.blog-group-lifehacker .post-content h6 a:hover,.f_branding_on .blog-group-lifehacker .post-content h6 a:hover,.f_branding_on.blog-group-lifehacker .post-content li a:hover,.f_branding_on .blog-group-lifehacker .post-content li a:hover,.f_branding_on.blog-group-lifehacker .post-content p a:hover,.f_branding_on .blog-group-lifehacker .post-content p a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a:hover,.f_branding_on.f_branding_lifehacker_on .post-content footer a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h1 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h2 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h3 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h4 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h5 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h6 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content li a:hover,.f_branding_on.f_branding_lifehacker_on .post-content p a:hover,.f_branding_on.blog-group-lifehacker figcaption a,.f_branding_on .blog-group-lifehacker figcaption a,.f_branding_on.f_branding_lifehacker_on figcaption a{color:#39c}.f_branding_on.blog-group-lifehacker figcaption a:hover,.f_branding_on .blog-group-lifehacker figcaption a:hover,.f_branding_on.f_branding_lifehacker_on figcaption a:hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on.blog-group-lifehacker .entry-content blockquote,.f_branding_on .blog-group-lifehacker .entry-content blockquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote{border-radius:;border-left:5px solid #94b33;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-lifehacker .review-score,.f_branding_on .blog-group-lifehacker .review-score,.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_lifehacker_on .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#94b33}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white){color:#39c;border-color:#39c}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white):hover{color:#297aa3;border-color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio__name,.f_branding_on .blog-group-lifehacker .author-bio__name,.f_branding_on.f_branding_lifehacker_on .author-bio__name{color:#222}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name){color:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#297aa3}.f_branding_on.blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_lifehacker_on .sidebar-content .newsletter-subscribe{border-color:#94b33}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on.blog-group-lifehacker .entry-content .pullquote,.f_branding_on .blog-group-lifehacker .entry-content .pullquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote{padding: 23px 61px;text-align:left;max-width:4px}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#39c;-webkit-box-shadow:1px #39c,-1px #39c;box-shadow:1px #39c,-1px #39c;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:4px 3px;line-height:4px;position:relative}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{width:46px;height:36px;left:-61px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="36" viewBox=" 46 36" xmlns="http://www.w3.org/2/svg"><title>lifehacker-quote<\/title><path d="M36 L25 18v18h21V17h-8l8-17M11 L 18v18h21V17h-8l8-17" fill="%2394B33" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after{width:1px;height:36px;background-color:#94b33;right:-23px;bottom:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a{min-width:46px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="11" viewBox=" 46 11" xmlns="http://www.w3.org/2/svg"><title>lifehacker-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2394B33" d="M 11h11VH"/><path fill="%2339C" d="M18 11h11VH18"/><path fill="%2394B33" d="M35 11h11VH35"/><\/g><\/svg>')}.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{min-width:48px;height:47px;background-image:url('data:image/svg+xml;utf8,<svg width="48" height="47" viewBox=" 48 47" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>lifehacker-binder<\/title><defs><path id="a" d="M2.667 3.52H.77V.526h2.59v2.526z"/><\/defs><g fill="none" fill-rule="evenodd"><path d="M18.638 41.243c.347 .348-.568 -.568-.347 -.347.568 .568" fill="%2394B33"/><path d="M18.946 4.75c-1.36-1.347-2.153-2.62-3.35-3.824-.297-.297-.756.167-.46.466 1.2 1.22 2.315 2.477 3.352 3.824.256.334.712-.135.458-.465" fill="%2394B33"/><path d="M15.494 36.886c-1.74-.117-3.66.613-3.115 2.77.28 1.13 1.21 1.998 1.95 2.832.46.523.92 1.5 1.4 1.57.24.272.37.474.74.478.15 .26-.14.31-.24l.2-.75c.13-.4-.49-.57-.63-.17l-.3.8.31-.24c-.33 -1.16-1.26-1.4-1.54-.51-.57-1.5-1.12-1.5-1.74-.55-.76-.98-1.82-.21-2.6.56-.56 1.39-.5 2.12-.45.41.3.41-.63 -.65" fill="%2394B33"/><path d="M18.347 41.227c-.956.2-1.96.457-2.25 1.456-.258.89.197 1.853 1.13 2.3 2.43.386 2.757-4.4.655-3.797-.41.47-.415.76 .657.96-.14.6 1.11.427 1.64-.21.574-.62 1.27-1.28.76-.48-.32-.44-.975-.15-1.41.33-.487.9-.642 1.46-.642.42 .42-.658 -.658m-6.95-6.855c-.92.443-1.23 1.53-1.1 2.49.24 1.55 1.1 1.84 1.99 2.21.39.145.56-.49.17-.636-1.22-.453-2.51-2.692-.84-3.495.37-.18.4-.74-.33-.56" fill="%2394B33"/><path d="M7.78 3.77c1.56 1.365 2.166 2.683 3.33 3.956.283.312.74-.154.458-.464-1.163-1.273-2.273-2.592-3.33-3.957-.257-.333-.713.136-.458.465" fill="%2394B33"/><path d="M7.552 3.174c-.795.645-1.212 1.656-1.17 2.683.42.416.69.42.648 -.9-.877.24-1.667.917-2.218.326-.27-.135-.73-.458-.47" fill="%2394B33"/><path d="M6.338 32.87c1.373 1.997 2.885 3.88 4.54 5.644.29.31.747-.15.46-.46-1.618-1.72-3.1-3.56-4.44-5.51-.236-.34-.8-.1-.56.34M2.32 23.86c1.26 1.41 2.453 2.873 3.578 4.395.247.335.81.8.56-.33-1.157-1.57-2.382-3.8-3.68-4.53-.28-.315-.737.15-.457.464" fill="%2394B33"/><path d="M6.246 27.827c-1.23-.156-2.33.427-2.13 1.547-.11 1.262 1.225 2.29 1.97 3.122.282.315.74-.152.46-.464-.42-.468-.854-.924-1.256-1.45-.27-.246-.44-.533-.51-.86-.17-.82.53-1.422 1.294-1.35.48.62.584-.57.172-.635" fill="%2394B33"/><path d="M2.377 23.144C.73 23.118-.278 24.674.34 26.21c.372.982 1.224 1.835 1.883 2.624.872 1.43 1.786 2.34 2.823 2.91.32.27.78-.194.46-.465-1.138-.96-2.124-2.6-3.72-3.21-.48-.59-1.3-1.16-1.372-1.84-.584-1.17.2-2.45 1.35-2.43.418 .418-.65 -.66" fill="%2394B33"/><path d="M3.83 24.67c2.76-2.947 3.984-6.12 5.69-9.194.57-1.62 1.92-5.88 3.52-4.11.863.527 1.453 1.582 2.46 2.375.585.79 1.17 1.57 1.756 2.36.25.34.812.1.56-.33l-2.132-2.86c-.53-.71-1.4-1.5-1.775-2.1-1.49-1.4-2.423.8-3.74 1.4-2.7 4.2-4.46 8.23-7.15 12.5-.24.35.32.68.56.33m14.97-6.51c.84.83 1.59 1.72 2.34 2.63.27.33.73-.14.46-.46-.75-.91-1.5-1.79-2.33-2.62-.3-.29-.76.17-.46.47m4.52 4.61c1.96 1.96 4 3.81 6.11 5.6.32.27.78-.19.46-.46-2.11-1.79-4.15-3.64-6.11-5.6-.3-.29-.76.17-.46.47" fill="%2394B33"/><path d="M19.263 43.354c1.434-2.52 2.87-5.4 4.33-7.57.718-1.25 1.435-2.52 2.152-3.754.65-1.133 1.243-2.717 2.222-3.596.464-.415 1.8-.428 1.542.62.166.17.242.7.285.94.84.47.97.96.19 1.43.173.87.55 1.7 1.9 2.4.58.75 1.292 1.25 2.12 1.71.5.28 1.7.57 1.36 1.1.62 1.14-.52 1.92-1.44 2.22-.4.13-.23.76.17.63.96-.31 2.3-.99 2.12-2.12.9-1.15-.9-1.83-1.77-2.34-1.41-.83-2.53-1.82-2.95-3.49-.26-1.4-.7-2.52-.96-3.29-.76-.65-1.71-.29-2.32.36-1.13 1.19-1.83 2.94-2.65 4.36L18.7 43.2c-.21.368.35.7.56.332" fill="%2394B33"/><path d="M18.524 44.16l15.417-5.356c.4-.137.23-.772-.17-.634l-15.42 5.357c-.39.136-.22.772.18.634" fill="%2394B33"/><path d="M19.892 43.348c-.897.385-2.5 1.183-1.64 2.35.28.796 1.28 1.75 2.3.76.876-.38 1.28-1.473 1.25-2.385-.68-.846-.927-1.777-1.765-1.12-.326.254-.3.825.327.566.73-.55.836.77.755 1.18-.96.49-.384 1.5-.9 1.19-.46.12-1.76-.13-1.52-.68.3-.72.84-1.7 1.394-1.31.38-.17.5-.73-.33-.57" fill="%2394B33"/><g transform="translate(16.8 43.636)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M.15 1.16c.573.747 1.26 1.377 2.4 1.892.35.23.676-.338.327-.568C1.78 1.945 1.147 1.344.61.64.353.38-.13.776.15 1.17" fill="%2394B33" mask="url(%23b)"/><\/g><path d="M15.728 37.47c.878-3.268 2.82-6.17 4.473-9.77l5.7-8.95c.79-1.376 1.49-2.88 2.42-4.155.96-1.37 2.33-1.59 3.82-1.865 2.24-.415 4.3-1.36 4.36-3.842.6-4.545-3.33-9.333-7.83-9.613C26.1-.11 24.9.68 23.29 2.59c-1.123 2.695.3 5.637-1.438 8.21-1.1 1.624-2.637 3-3.97 4.424l-3.86 4.116-8.36 8.87c-.287.38.17.774.46.466l13.35-14.253c1.66-1.77 3.612-3.52 3.934-6.6.32-2.54-.724-6.44 2.234-7.324 4.93-2.14 1.68 4.14 9.44 9.3-.755 2.98-3.88 2.4-6.1 3.35-.94.38-1.55 1.5-2.9 1.87-.894 1.35-1.634 2.83-2.436 4.23l-5.17 9.9c-1.583 2.78-3.38 5.55-4.22 8.68-.11.41.515.58.624.17" fill="%2394B33"/><path d="M5.26 31.196c2.932.283 5.2-2.353 6.686-4.398 2.21-2.686 4.27-5.497 6.482-8.18 1.125-1.365 2.29-2.695 3.53-3.955.988-1.4 2.65-1.962 2.818-3.17.757-1.215.942-2.5.82-3.912-.14-1.62-.592-5.74 2.273-5.3.4.1.57-.53.17-.63-1.5-.26-2.9.2-2.69 1.12-.81 1.24-.59 2.79-.45 4.17.21 2.14-.26 3.66-1.69 5.24-1.12 1.25-2.35 2.38-3.47 3.63-2.36 2.65-4.47 5.5-6.67 8.28-1.86 2.36-4.4 6.53-7.83 6.2-.42-.4-.42.62 .66" fill="%2394B33"/><path d="M27.74 2.567c3.7.46 5.95 3.983 5.18 7.12-.733 3.155-4.715.37-6.8 2.546-.226.36.335.69.56.332.543-.868 2-.56 2.847-.526.62-.2 1.267-.8 1.84-.34 1.312-.59 1.66-2.4 1.543-3.38-.274-3.11-2.82-6-5.89-6.42-.41-.6-.47.6 .65" fill="%2394B33"/><path d="M13.184 37.95c.393-2.47 1.518-4.688 2.65-6.885 1.11-2.158 2.278-4.287 3.512-6.376 2.41-4.8 5.83-7.99 7.888-11.8.25-.34-.313-.67-.56-.33-2.878 3.91-5.616 7.92-8.76 12.11-1.232 2.1-2.398 4.24-3.57 6.41-1.9 2.13-2.15 4.29-2.53 6.68-.6.41.56.59.63.17M27.3 26.37c2.16-.15 5.43-.3 6.38-2.67.586-1.45.746-2.91 2.55-3.21 1.525-.252 3.16.267 4.596.745 1.593.53 3.165 1.294 4.32 2.56 1.158 1.27 2.14 3.21 1.476 4.942-1.143 2.974-4.62 1.44-6.82.93-3.265-.72-6.127 1.96-8.715 2.894-.343.24-.2.81.327.57 1.565-1.8 3.19-2.21 5.43-2.72 1.685-.46 3.147-.11 4.78.31 2.22.58 4.92.93 5.977-1.68 1.76-2.67-1.46-5.62-3.163-7.1-1.49-.98-3.24-1.55-4.96-1.96-1.23-.29-2.63-.48-3.84.3-1.47.63-1.62 2.3-2.16 3.37-.82 2.4-3.93 2.14-5.78 2.27-.41.3-.41.69 .66" fill="%2394B33"/><path d="M28.98 27.835c2.463-.212 5.497-.644 6.547-3.298.336-.85.365-1.976 1.42-2.257.866-.23 1.942.194 2.744.5 1.51.576 3.2 1.457 4.29 2.693.78.88 1.27 2.253-.14 2.864-.83.36-1.75.4-2.57-.198-1.28-.38-2.55-.59-3.89-.5-2.7.18-5.24 1.39-7.1 3.38-.29.31.17.77.46.46 2.58-2.76 6.44-3.83 1.5-2.81 1.27.36 2.82.88 3.95-.13.93-.84.76-2.4.11-3.1-.83-1.25-2.28-2.12-3.58-2.78-1.28-.65-3.5-1.51-4.51-1.13-1.57.41-1.4 2.1-2.12 3.18-1.18 1.93-3.68 2.17-5.69 2.34-.42.3-.42.69 .66" fill="%2394B33"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion .headline,.f_branding_on .blog-group-theonion .headline,.f_branding_on.blog-group-theonion .inset-headline,.f_branding_on .blog-group-theonion .inset-headline,.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .headline,.f_branding_on.f_branding_theonion_on .inset-headline,.f_branding_on.f_branding_theonion_on .kinja-slide__caption,.f_branding_on.blog-group-theonion .post-content h1,.f_branding_on .blog-group-theonion .post-content h1,.f_branding_on.blog-group-theonion .post-content h2,.f_branding_on .blog-group-theonion .post-content h2,.f_branding_on.blog-group-theonion .post-content h3,.f_branding_on .blog-group-theonion .post-content h3,.f_branding_on.blog-group-theonion .post-content h4,.f_branding_on .blog-group-theonion .post-content h4,.f_branding_on.blog-group-theonion .post-content h5,.f_branding_on .blog-group-theonion .post-content h5,.f_branding_on.blog-group-theonion .post-content h6,.f_branding_on .blog-group-theonion .post-content h6,.f_branding_on.f_branding_theonion_on .post-content h1,.f_branding_on.f_branding_theonion_on .post-content h2,.f_branding_on.f_branding_theonion_on .post-content h3,.f_branding_on.f_branding_theonion_on .post-content h4,.f_branding_on.f_branding_theonion_on .post-content h5,.f_branding_on.f_branding_theonion_on .post-content h6{font-family:"ElizabethSerif",Georgia,serif}.f_branding_on.blog-group-theonion.permalink .post .entry-title,.f_branding_on .blog-group-theonion.permalink .post .entry-title,.f_branding_on.f_branding_theonion_on.permalink .post .entry-title{font-size:34px;line-height:1.3}.f_branding_on.blog-group-theonion .postlist__item .headline,.f_branding_on .blog-group-theonion .postlist__item .headline,.f_branding_on.f_branding_theonion_on .postlist__item .headline{font-size:22px;line-height:1.4}.f_branding_on.blog-group-theonion .thumb-inset .inset-headline,.f_branding_on .blog-group-theonion .thumb-inset .inset-headline,.f_branding_on.f_branding_theonion_on .thumb-inset .inset-headline{font-size:14px;line-height:1.4}.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .kinja-slide__caption{font-size:13px;line-height:1.5}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theonion .entry-content .pullquote,.f_branding_on .blog-group-theonion .entry-content .pullquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theonion_on .entry-content .pullquote{border-top:none;border-bottom:8px solid #6b3a;padding: 3px;position:relative;font-size:28px;line-height:1.3;text-align:left;font-family:"ElizabethSerif",Georgia,serif;font-weight:bold;color:#6b3a}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--left{margin-top:}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-a{min-width:6px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="6" height="5" viewBox=" 6 5" xmlns="http://www.w3.org/2/svg"><title>onion-storybreak<\/title><path d="M h6v1Hzm 4h6v1Hz" fill="%2391D8B6" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{display:none !important}.f_branding_on .networknav__hovernav-wrapper.theonion .hovernav__post-list h4{font-family:"ElizabethSerif",Georgia,serif;font-size:15px;line-height:1.4}.f_branding_on.blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theroot_on.f_article_split_on .scroll-list-break{border-top:3px solid #59b22}.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#59b22;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theroot .post-content .quotable a,.f_branding_on .blog-group-theroot .post-content .quotable a,.f_branding_on.blog-group-theroot .post-content footer a,.f_branding_on .blog-group-theroot .post-content footer a,.f_branding_on.blog-group-theroot .post-content h1 a,.f_branding_on .blog-group-theroot .post-content h1 a,.f_branding_on.blog-group-theroot .post-content h2 a,.f_branding_on .blog-group-theroot .post-content h2 a,.f_branding_on.blog-group-theroot .post-content h3 a,.f_branding_on .blog-group-theroot .post-content h3 a,.f_branding_on.blog-group-theroot .post-content h4 a,.f_branding_on .blog-group-theroot .post-content h4 a,.f_branding_on.blog-group-theroot .post-content h5 a,.f_branding_on .blog-group-theroot .post-content h5 a,.f_branding_on.blog-group-theroot .post-content h6 a,.f_branding_on .blog-group-theroot .post-content h6 a,.f_branding_on.blog-group-theroot .post-content li a,.f_branding_on .blog-group-theroot .post-content li a,.f_branding_on.blog-group-theroot .post-content p a,.f_branding_on .blog-group-theroot .post-content p a,.f_branding_on.f_branding_theroot_on .post-content .quotable a,.f_branding_on.f_branding_theroot_on .post-content footer a,.f_branding_on.f_branding_theroot_on .post-content h1 a,.f_branding_on.f_branding_theroot_on .post-content h2 a,.f_branding_on.f_branding_theroot_on .post-content h3 a,.f_branding_on.f_branding_theroot_on .post-content h4 a,.f_branding_on.f_branding_theroot_on .post-content h5 a,.f_branding_on.f_branding_theroot_on .post-content h6 a,.f_branding_on.f_branding_theroot_on .post-content li a,.f_branding_on.f_branding_theroot_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theroot .post-content .quotable a:hover,.f_branding_on .blog-group-theroot .post-content .quotable a:hover,.f_branding_on.blog-group-theroot .post-content footer a:hover,.f_branding_on .blog-group-theroot .post-content footer a:hover,.f_branding_on.blog-group-theroot .post-content h1 a:hover,.f_branding_on .blog-group-theroot .post-content h1 a:hover,.f_branding_on.blog-group-theroot .post-content h2 a:hover,.f_branding_on .blog-group-theroot .post-content h2 a:hover,.f_branding_on.blog-group-theroot .post-content h3 a:hover,.f_branding_on .blog-group-theroot .post-content h3 a:hover,.f_branding_on.blog-group-theroot .post-content h4 a:hover,.f_branding_on .blog-group-theroot .post-content h4 a:hover,.f_branding_on.blog-group-theroot .post-content h5 a:hover,.f_branding_on .blog-group-theroot .post-content h5 a:hover,.f_branding_on.blog-group-theroot .post-content h6 a:hover,.f_branding_on .blog-group-theroot .post-content h6 a:hover,.f_branding_on.blog-group-theroot .post-content li a:hover,.f_branding_on .blog-group-theroot .post-content li a:hover,.f_branding_on.blog-group-theroot .post-content p a:hover,.f_branding_on .blog-group-theroot .post-content p a:hover,.f_branding_on.f_branding_theroot_on .post-content .quotable a:hover,.f_branding_on.f_branding_theroot_on .post-content footer a:hover,.f_branding_on.f_branding_theroot_on .post-content h1 a:hover,.f_branding_on.f_branding_theroot_on .post-content h2 a:hover,.f_branding_on.f_branding_theroot_on .post-content h3 a:hover,.f_branding_on.f_branding_theroot_on .post-content h4 a:hover,.f_branding_on.f_branding_theroot_on .post-content h5 a:hover,.f_branding_on.f_branding_theroot_on .post-content h6 a:hover,.f_branding_on.f_branding_theroot_on .post-content li a:hover,.f_branding_on.f_branding_theroot_on .post-content p a:hover,.f_branding_on.blog-group-theroot figcaption a,.f_branding_on .blog-group-theroot figcaption a,.f_branding_on.f_branding_theroot_on figcaption a{color:#59b22}.f_branding_on.blog-group-theroot figcaption a:hover,.f_branding_on .blog-group-theroot figcaption a:hover,.f_branding_on.f_branding_theroot_on figcaption a:hover{color:#3a7119}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on.blog-group-theroot .entry-content blockquote,.f_branding_on .blog-group-theroot .entry-content blockquote,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theroot_on .entry-content blockquote{border-radius:;border-left:5px solid #dd6634;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before,.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theroot .entry-content .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote__content,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theroot .review-score,.f_branding_on .blog-group-theroot .review-score,.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theroot_on .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#dd6634}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white){color:#59b22;border-color:#59b22}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white):hover{color:#3a7119;border-color:#3a7119}.f_branding_on.blog-group-theroot .author-bio__name,.f_branding_on .blog-group-theroot .author-bio__name,.f_branding_on.f_branding_theroot_on .author-bio__name{color:#222}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name){color:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover{color:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#3a7119}.f_branding_on.blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theroot_on .sidebar-content .newsletter-subscribe{border-color:#dd6634}.f_branding_on.blog-group-theroot .entry-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote{padding: 2px;max-width:4px}.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#;-webkit-box-shadow:2px #,-2px #;box-shadow:2px #,-2px #;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:1px ;line-height:37px;font-size:26px;font-weight:normal;font-style:normal;position:relative}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{width:15px;height:32px;left:-2px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="15" height="32" viewBox=" 15 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-green<\/title><path d="M14.345 Hv32h3.627" fill="%2359B22" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after{width:14px;height:32px;right:-2px;bottom:;background-image:url('data:image/svg+xml;utf8,<svg width="14" height="32" viewBox=" 14 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-red<\/title><path d="M 32h14Vh-4" fill="%23DD6634" fill-rule="evenodd"/><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-a{min-width:24px;height:55px;background-image:url('data:image/svg+xml;utf8,<svg width="24" height="55" viewBox=" 24 55" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-afropicker<\/title><g fill-rule="evenodd"><path d="M23.32 27.59l-6.346-4.574-.475-4.45-2.83.42 2.79-1.39 2.3-3.49 2.393-2.87.14-1.63-2.347-5.31-1.22-.328-2.66.42-2.856-.66-1.62.74v1.68l2.13 1.7s2.638.54 2.83.44c.19-.1 2.686-1.2 2.686-1.2L16.2 9.17l1.73 3.3-3.3-2.74-1.162.66-1.258.233-.28.838-.852 4.264-.218-3.655-.76.343-.766-.19-1.625.81-2.3-.643L3.63 8.84l-.29.91.62 1.384.96 3.87.664.67 1.38 2.44.128 1.336-.364 3.56L 27.586v7.69h1.243V54.54c .258.21.467.467.467s.466-.21.466-.468V35.27H3.73v19.27c .26.21.468.467.468.258 .467-.21.467-.47v-19.26h1.554v19.265c .258.21.467.467.467.258 .467-.21.467-.47V35.278h1.554v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.55v19.265c .258.21.467.46.467s.463-.21.463-.47V35.278h1.554v19.265c .258.21.467.47.467.255 .464-.21.464-.47V35.278h1.555v19.265c .258.25.467.462.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.47.467s.466-.21.466-.47V35.278h1.246V27.59z"/><path d="M1.515 11.187c.144-.48.956-.526.956-.526l.43-1.9s-1.29-3.39-1.29-3.54c-.14-1.25-2.49-1.25-2.49l-.8-.325-1.29.56-.47 1.162 2.91 6.16s.67.144.81.96m-2.77.57l1.1-.813-2.59-5.4-.91-.336-1.48 1.484-.24 1.387 2.87 3.2m7.26-1.95l.82-.53-1.44-.39-1.4-1.246.776 1.73m2.38-8.9l-.998 1.242.562 2.8 1.46.29 1.89-.19V1.44L16.51.98m-5.938 3.62l1.84-.84 1.314.28-.46-1.58L12.32.98l-1.714.56-.643 1.56.61 2.285"/><\/g><\/svg>')}.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{min-width:32px;height:41px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="41" viewBox=" 32 41" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-fist<\/title><g fill-rule="evenodd"><path d="M2.474 L18.62 2.18l1.2 3.524 2.85.53 3.698-.335V2.517l-2.51-2.35m-5.22 5.37l-.848-2.77-1.693-1.47-3.48.985-.75 1.85 1.466 4.1V6.52l2.868-1.473m-1.3 11.73S12.87 1.82 12.87 1.57c-.252-2.22-4.378-2.22-4.378L9.228 5.62l-2.296.982-.825 2.46L11.26 19.46s1.185.252 1.44.17c.253-.85 1.693-.924 1.693-.924l.762-1.93zM4.994 9.73l4.58 9.475-1.786 1.43-2.37-.84-5.8-5.62.422-2.432 2.625-2.6m11.313 3.433l1.376 3.34 2.22.755 1.46-.925-2.55-.677"/><path d="M6.266 4.37L6.66 34.1l-.283-2.328-2.47-4.27-1.192-1.168-1.612-6.792L 17.112l.57-1.594L4.62 21.25l3.592 1.13 2.88-1.426 1.353.336 1.347-.63.388 6.47 1.51-7.48.495-1.474 2.23-.48 2.66-1.64 5.37 4.746-3.54-5.32 4.472-3.174s-4.38 1.616-4.72 1.784c-.34.167-4.664-.78-4.664-.78l-3.15-2.985V7.99l2.462-1.31 4.783 1.64 3.587-.736 2.125.574 4.145 9.32-.257 2.81-4.24 5.35-4.74 6.124-4.933 2.44 5.4-.78 1.133 7.773H6.266z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_thetakeout_on.f_article_split_on .scroll-list-break{border-top:3px solid #E5371A}.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#E5371A;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-thetakeout .post-content .quotable a,.f_branding_on .blog-group-thetakeout .post-content .quotable a,.f_branding_on.blog-group-thetakeout .post-content footer a,.f_branding_on .blog-group-thetakeout .post-content footer a,.f_branding_on.blog-group-thetakeout .post-content h1 a,.f_branding_on .blog-group-thetakeout .post-content h1 a,.f_branding_on.blog-group-thetakeout .post-content h2 a,.f_branding_on .blog-group-thetakeout .post-content h2 a,.f_branding_on.blog-group-thetakeout .post-content h3 a,.f_branding_on .blog-group-thetakeout .post-content h3 a,.f_branding_on.blog-group-thetakeout .post-content h4 a,.f_branding_on .blog-group-thetakeout .post-content h4 a,.f_branding_on.blog-group-thetakeout .post-content h5 a,.f_branding_on .blog-group-thetakeout .post-content h5 a,.f_branding_on.blog-group-thetakeout .post-content h6 a,.f_branding_on .blog-group-thetakeout .post-content h6 a,.f_branding_on.blog-group-thetakeout .post-content li a,.f_branding_on .blog-group-thetakeout .post-content li a,.f_branding_on.blog-group-thetakeout .post-content p a,.f_branding_on .blog-group-thetakeout .post-content p a,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a,.f_branding_on.f_branding_thetakeout_on .post-content footer a,.f_branding_on.f_branding_thetakeout_on .post-content h1 a,.f_branding_on.f_branding_thetakeout_on .post-content h2 a,.f_branding_on.f_branding_thetakeout_on .post-content h3 a,.f_branding_on.f_branding_thetakeout_on .post-content h4 a,.f_branding_on.f_branding_thetakeout_on .post-content h5 a,.f_branding_on.f_branding_thetakeout_on .post-content h6 a,.f_branding_on.f_branding_thetakeout_on .post-content li a,.f_branding_on.f_branding_thetakeout_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f9db5d;box-shadow:inset -2px #f9db5d;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on .blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on.blog-group-thetakeout .post-content footer a:hover,.f_branding_on .blog-group-thetakeout .post-content footer a:hover,.f_branding_on.blog-group-thetakeout .post-content h1 a:hover,.f_branding_on .blog-group-thetakeout .post-content h1 a:hover,.f_branding_on.blog-group-thetakeout .post-content h2 a:hover,.f_branding_on .blog-group-thetakeout .post-content h2 a:hover,.f_branding_on.blog-group-thetakeout .post-content h3 a:hover,.f_branding_on .blog-group-thetakeout .post-content h3 a:hover,.f_branding_on.blog-group-thetakeout .post-content h4 a:hover,.f_branding_on .blog-group-thetakeout .post-content h4 a:hover,.f_branding_on.blog-group-thetakeout .post-content h5 a:hover,.f_branding_on .blog-group-thetakeout .post-content h5 a:hover,.f_branding_on.blog-group-thetakeout .post-content h6 a:hover,.f_branding_on .blog-group-thetakeout .post-content h6 a:hover,.f_branding_on.blog-group-thetakeout .post-content li a:hover,.f_branding_on .blog-group-thetakeout .post-content li a:hover,.f_branding_on.blog-group-thetakeout .post-content p a:hover,.f_branding_on .blog-group-thetakeout .post-content p a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a:hover,.f_branding_on.f_branding_thetakeout_on .post-content footer a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h1 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h2 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h3 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h4 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h5 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h6 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content li a:hover,.f_branding_on.f_branding_thetakeout_on .post-content p a:hover{color:#F9DB5D}.f_branding_on.blog-group-thetakeout figcaption a,.f_branding_on .blog-group-thetakeout figcaption a,.f_branding_on.f_branding_thetakeout_on figcaption a{color:#E5371A}.f_branding_on.blog-group-thetakeout figcaption a:hover,.f_branding_on .blog-group-thetakeout figcaption a:hover,.f_branding_on.f_branding_thetakeout_on figcaption a:hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on.blog-group-thetakeout .entry-content blockquote,.f_branding_on .blog-group-thetakeout .entry-content blockquote,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote{border-radius:;border-left:5px solid #17466;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before,.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-thetakeout .review-score,.f_branding_on .blog-group-thetakeout .review-score,.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_thetakeout_on .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white){color:#E5371A;border-color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white):hover{color:#b72c15;border-color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio__name,.f_branding_on .blog-group-thetakeout .author-bio__name,.f_branding_on.f_branding_thetakeout_on .author-bio__name{color:#222}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name){color:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#b72c15}.f_branding_on.blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_thetakeout_on .sidebar-content .newsletter-subscribe{border-color:#17466}.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{padding:3px;max-width:4px;border:1px solid #F9DB5D;border-radius:5px;font-style:normal;text-align:left;position:relative;margin-top:3rem}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before{display:block;content:'';position:absolute;margin:;width:79px;height:33px;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="79" height="33" viewBox=" 79 33" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>pq-thetakeout<\/title><defs><path id="a" d="M334.76 H.5v136.817h334.26z"/><path id="c" d="M22.72 v18.41HVh22.72z"/><\/defs><g fill="none" fill-rule="evenodd"><g transform="translate(-3)"><mask id="b" fill="%23fff"><use xlink:href="%23a"/><\/mask><path d="M16.262 21.627l-.775-14.652c-.27-3.65-3.31-6.475-6.972-6.475H4.28c-3.662 -6.74 2.825-6.974 6.474l-.775 14.652c-.8 1.95-.99 1.944-2.9 1.944H3.998C2.67 23.57.5 25.134.5 27.64v16.258c 1.93 1.565 3.495 3.496 3.495H331.21c1.93 3.496-1.565 3.496-3.495V27.64c-1.93-1.565-3.494-3.496-3.494H18.354c-1.1 -2.1-.85-2.92-1.944z" stroke="%23F9DB5D" mask="url(#b)"/><\/g><g transform="translate(28 14)"><mask id="d" fill="%23fff"><use xlink:href="%23c"/><\/mask><path d="M12.243 11.274c-6.46 4.37-9.844 5.722-11.13.43-.33.86-.43 1.353.127l.923.923c.435.49.31 1.45-.6 1.353-.674.493-4.34 3.2-4.37 7.384 1.5-.43 2.465-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43-2.338 -5.6-1.783-5.6-7.136M 11.274C 4.814 4.36 1.43 5.722.26c.43-.36.86-.43 1.353.124l.923.923c.43.492.37 1.46-.62 1.354-.676.496-4.36 3.2-4.368 7.387 1.46-.43 2.46-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43C3.26 18.41 16.628 11.274" fill="%23F9DB5D" mask="url(#d)"/><\/g><\/g><\/svg>');left:3px;top:-24px}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote .pullquote__content{padding:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:1.5rem;margin-bottom:1rem}}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a{min-width:19px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="19" height="13" viewBox=" 19 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-a<\/title><g stroke="%23F9DB5D" fill="none" fill-rule="evenodd"><path d="M3.35 5.733c-.28.17-.47.345-.47.523v2.18c 1.728 1.413 3.14 3.14 3.14H22.77c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M26.96.5H3.116C1.676.5.5 1.677.5 3.117s1.177 2.616 2.616 2.616h.235c.255-1.48 1.548-2.616 3.96-2.616H22.77c1.548 2.84 1.136 3.92 2.616h.234c1.44 2.617-1.177 2.617-2.616 -1.44-1.178-2.617-2.617-2.617zM43.9 5.733c-.3.17-.5.345-.5.523v2.18c 1.728 1.414 3.14 3.14 3.14h16.33c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M65.834.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.54-2.616 3.9-2.616h16.324c1.55 2.84 1.136 3.93 2.616h.233c1.44 2.617-1.177 2.618-2.616C68.45 1.677 67.274.5 65.835.5zm16.993 5.233c-.3.17-.48.345-.48.523v2.18c 1.728 1.41 3.14 3.14 3.14h16.323c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M15.572.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.544-2.616 3.92-2.616h16.322c1.55 2.84 1.136 3.93 2.616h.234c1.44 2.616-1.177 2.616-2.616 -1.44-1.177-2.617-2.616-2.617z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{min-width:43px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="43" height="13" viewBox=" 43 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-b<\/title><path d="M7 1.38L36.154 1M7 12.38L36.154 12M.5 6.735l42.11-.445" stroke="%23E5371A" fill="none" stroke-linecap="round"/><\/svg>')}.f_branding_on.blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_splinter_on.f_article_split_on .scroll-list-break{border-top:3px solid #f85637}.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#f85637;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-splinter .post-content .quotable a,.f_branding_on .blog-group-splinter .post-content .quotable a,.f_branding_on.blog-group-splinter .post-content footer a,.f_branding_on .blog-group-splinter .post-content footer a,.f_branding_on.blog-group-splinter .post-content h1 a,.f_branding_on .blog-group-splinter .post-content h1 a,.f_branding_on.blog-group-splinter .post-content h2 a,.f_branding_on .blog-group-splinter .post-content h2 a,.f_branding_on.blog-group-splinter .post-content h3 a,.f_branding_on .blog-group-splinter .post-content h3 a,.f_branding_on.blog-group-splinter .post-content h4 a,.f_branding_on .blog-group-splinter .post-content h4 a,.f_branding_on.blog-group-splinter .post-content h5 a,.f_branding_on .blog-group-splinter .post-content h5 a,.f_branding_on.blog-group-splinter .post-content h6 a,.f_branding_on .blog-group-splinter .post-content h6 a,.f_branding_on.blog-group-splinter .post-content li a,.f_branding_on .blog-group-splinter .post-content li a,.f_branding_on.blog-group-splinter .post-content p a,.f_branding_on .blog-group-splinter .post-content p a,.f_branding_on.f_branding_splinter_on .post-content .quotable a,.f_branding_on.f_branding_splinter_on .post-content footer a,.f_branding_on.f_branding_splinter_on .post-content h1 a,.f_branding_on.f_branding_splinter_on .post-content h2 a,.f_branding_on.f_branding_splinter_on .post-content h3 a,.f_branding_on.f_branding_splinter_on .post-content h4 a,.f_branding_on.f_branding_splinter_on .post-content h5 a,.f_branding_on.f_branding_splinter_on .post-content h6 a,.f_branding_on.f_branding_splinter_on .post-content li a,.f_branding_on.f_branding_splinter_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-splinter .post-content .quotable a:hover,.f_branding_on .blog-group-splinter .post-content .quotable a:hover,.f_branding_on.blog-group-splinter .post-content footer a:hover,.f_branding_on .blog-group-splinter .post-content footer a:hover,.f_branding_on.blog-group-splinter .post-content h1 a:hover,.f_branding_on .blog-group-splinter .post-content h1 a:hover,.f_branding_on.blog-group-splinter .post-content h2 a:hover,.f_branding_on .blog-group-splinter .post-content h2 a:hover,.f_branding_on.blog-group-splinter .post-content h3 a:hover,.f_branding_on .blog-group-splinter .post-content h3 a:hover,.f_branding_on.blog-group-splinter .post-content h4 a:hover,.f_branding_on .blog-group-splinter .post-content h4 a:hover,.f_branding_on.blog-group-splinter .post-content h5 a:hover,.f_branding_on .blog-group-splinter .post-content h5 a:hover,.f_branding_on.blog-group-splinter .post-content h6 a:hover,.f_branding_on .blog-group-splinter .post-content h6 a:hover,.f_branding_on.blog-group-splinter .post-content li a:hover,.f_branding_on .blog-group-splinter .post-content li a:hover,.f_branding_on.blog-group-splinter .post-content p a:hover,.f_branding_on .blog-group-splinter .post-content p a:hover,.f_branding_on.f_branding_splinter_on .post-content .quotable a:hover,.f_branding_on.f_branding_splinter_on .post-content footer a:hover,.f_branding_on.f_branding_splinter_on .post-content h1 a:hover,.f_branding_on.f_branding_splinter_on .post-content h2 a:hover,.f_branding_on.f_branding_splinter_on .post-content h3 a:hover,.f_branding_on.f_branding_splinter_on .post-content h4 a:hover,.f_branding_on.f_branding_splinter_on .post-content h5 a:hover,.f_branding_on.f_branding_splinter_on .post-content h6 a:hover,.f_branding_on.f_branding_splinter_on .post-content li a:hover,.f_branding_on.f_branding_splinter_on .post-content p a:hover,.f_branding_on.blog-group-splinter figcaption a,.f_branding_on .blog-group-splinter figcaption a,.f_branding_on.f_branding_splinter_on figcaption a{color:#f85637}.f_branding_on.blog-group-splinter figcaption a:hover,.f_branding_on .blog-group-splinter figcaption a:hover,.f_branding_on.f_branding_splinter_on figcaption a:hover{color:#f32e9}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on.blog-group-splinter .entry-content blockquote,.f_branding_on .blog-group-splinter .entry-content blockquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_splinter_on .entry-content blockquote{border-radius:;border-left:5px solid #f85637;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before,.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-splinter .entry-content .pullquote__content,.f_branding_on .blog-group-splinter .entry-content .pullquote__content,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_splinter_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-splinter .review-score,.f_branding_on .blog-group-splinter .review-score,.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_splinter_on .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white){color:#f85637;border-color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white):hover{color:#f32e9;border-color:#f32e9}.f_branding_on.blog-group-splinter .author-bio__name,.f_branding_on .blog-group-splinter .author-bio__name,.f_branding_on.f_branding_splinter_on .author-bio__name{color:#222}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name){color:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover{color:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#f32e9}.f_branding_on.blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_splinter_on .sidebar-content .newsletter-subscribe{border-color:#f85637}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on.blog-group-splinter .entry-content .pullquote,.f_branding_on .blog-group-splinter .entry-content .pullquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_splinter_on .entry-content .pullquote{border-top:4px solid #f85637;padding-top:3px;padding-bottom:;position:relative;font-weight:bold;font-style:normal}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before{height:32px;width:32px;position:absolute;left:calc(5% - 18px);top:-18px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="32" viewBox=" 32 32" xmlns="http://www.w3.org/2/svg"><title>splinter-pq<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M 32h32VH"/><path d="M14 7.466c-.15-.227.162-.42.39-.423L17.657 7c.233-.2.417.195.398.427C17.82 1.26 16.49 26.6 15.94 26.6c-.547 -1.735-15.85-1.94-18.593z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-a{min-width:31px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="5" viewBox=" 31 5" xmlns="http://www.w3.org/2/svg"><title>storybreak-1-splinter<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M1.47 9.33l6.696-3.54v7.495l-6.696 3.6"/><path d="M9.167 24.32H7.223V5.27c-1.455-1.183-2.637-2.637-2.637S1.95 3.572 1.95 5.27V24.32H.5V5.27C.5 2.5 2.6.447 4.585.447c2.527 4.58 2.54 4.58 4.58V24.32z" fill="%23"/><path d="M11.84 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.637-1.18 2.637-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.81c 2.53-2.5 4.58-4.58 4.58" fill="%23"/><path d="M19.2 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.638-1.18 2.638-2.63v-6.8c-1.45-1.184-2.64-2.638-2.64m 14.2c-2.525 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.55-4.58 4.58-4.58 2.526 4.58 2.6 4.58 4.58v6.8c 2.53-2.54 4.58-4.58 4.58" fill="%23"/><path d="M26.2 17.935c-1.453 -2.636 1.183-2.636 2.638v6.8c 1.455 1.183 2.638 2.637 2.638 1.46 2.64-1.18 2.64-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.8c 2.53-2.5 4.58-4.58 4.58m-1.65 7.36h-5.14v-1.95h5.14c1.46 2.64-1.18 2.64-2.63s-1.18-2.633-2.64-2.633H4.59c-1.454 -2.637 1.183-2.637 2.637H.1c-2.524 2.55-4.58 4.58-4.58h1.96c2.526 4.58 2.56 4.58 4.58 2.527-2.54 4.58-4.58 4.58" fill="%23"/><path d="M15.36 49.895c-4.86 -7.94-1.62-1.85-4.51C1.63 42.475 38.62 34.535V2.99h1.955v13.545c 3.564 1.4 6.926 3.94 9.466 2.538 2.54 5.9 3.94 9.466 3.94 3.57 6.93-1.4 9.47-3.94s3.94-5.9 3.94-9.46V2.99h1.96v13.545c 4.87-1.6 7.94-4.51 1.85-2.91 2.98-6.76 4.51-1.85 4.51" fill="%23"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_avclub_on.f_article_split_on .scroll-list-break{border-top:3px solid #1c263c}.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#91dbd9;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-avclub .post-content .quotable a,.f_branding_on .blog-group-avclub .post-content .quotable a,.f_branding_on.blog-group-avclub .post-content footer a,.f_branding_on .blog-group-avclub .post-content footer a,.f_branding_on.blog-group-avclub .post-content h1 a,.f_branding_on .blog-group-avclub .post-content h1 a,.f_branding_on.blog-group-avclub .post-content h2 a,.f_branding_on .blog-group-avclub .post-content h2 a,.f_branding_on.blog-group-avclub .post-content h3 a,.f_branding_on .blog-group-avclub .post-content h3 a,.f_branding_on.blog-group-avclub .post-content h4 a,.f_branding_on .blog-group-avclub .post-content h4 a,.f_branding_on.blog-group-avclub .post-content h5 a,.f_branding_on .blog-group-avclub .post-content h5 a,.f_branding_on.blog-group-avclub .post-content h6 a,.f_branding_on .blog-group-avclub .post-content h6 a,.f_branding_on.blog-group-avclub .post-content li a,.f_branding_on .blog-group-avclub .post-content li a,.f_branding_on.blog-group-avclub .post-content p a,.f_branding_on .blog-group-avclub .post-content p a,.f_branding_on.f_branding_avclub_on .post-content .quotable a,.f_branding_on.f_branding_avclub_on .post-content footer a,.f_branding_on.f_branding_avclub_on .post-content h1 a,.f_branding_on.f_branding_avclub_on .post-content h2 a,.f_branding_on.f_branding_avclub_on .post-content h3 a,.f_branding_on.f_branding_avclub_on .post-content h4 a,.f_branding_on.f_branding_avclub_on .post-content h5 a,.f_branding_on.f_branding_avclub_on .post-content h6 a,.f_branding_on.f_branding_avclub_on .post-content li a,.f_branding_on.f_branding_avclub_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #e33af5;box-shadow:inset -2px #e33af5;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-avclub .post-content .quotable a:hover,.f_branding_on .blog-group-avclub .post-content .quotable a:hover,.f_branding_on.blog-group-avclub .post-content footer a:hover,.f_branding_on .blog-group-avclub .post-content footer a:hover,.f_branding_on.blog-group-avclub .post-content h1 a:hover,.f_branding_on .blog-group-avclub .post-content h1 a:hover,.f_branding_on.blog-group-avclub .post-content h2 a:hover,.f_branding_on .blog-group-avclub .post-content h2 a:hover,.f_branding_on.blog-group-avclub .post-content h3 a:hover,.f_branding_on .blog-group-avclub .post-content h3 a:hover,.f_branding_on.blog-group-avclub .post-content h4 a:hover,.f_branding_on .blog-group-avclub .post-content h4 a:hover,.f_branding_on.blog-group-avclub .post-content h5 a:hover,.f_branding_on .blog-group-avclub .post-content h5 a:hover,.f_branding_on.blog-group-avclub .post-content h6 a:hover,.f_branding_on .blog-group-avclub .post-content h6 a:hover,.f_branding_on.blog-group-avclub .post-content li a:hover,.f_branding_on .blog-group-avclub .post-content li a:hover,.f_branding_on.blog-group-avclub .post-content p a:hover,.f_branding_on .blog-group-avclub .post-content p a:hover,.f_branding_on.f_branding_avclub_on .post-content .quotable a:hover,.f_branding_on.f_branding_avclub_on .post-content footer a:hover,.f_branding_on.f_branding_avclub_on .post-content h1 a:hover,.f_branding_on.f_branding_avclub_on .post-content h2 a:hover,.f_branding_on.f_branding_avclub_on .post-content h3 a:hover,.f_branding_on.f_branding_avclub_on .post-content h4 a:hover,.f_branding_on.f_branding_avclub_on .post-content h5 a:hover,.f_branding_on.f_branding_avclub_on .post-content h6 a:hover,.f_branding_on.f_branding_avclub_on .post-content li a:hover,.f_branding_on.f_branding_avclub_on .post-content p a:hover,.f_branding_on.blog-group-avclub figcaption a,.f_branding_on .blog-group-avclub figcaption a,.f_branding_on.f_branding_avclub_on figcaption a{color:#948a3}.f_branding_on.blog-group-avclub figcaption a:hover,.f_branding_on .blog-group-avclub figcaption a:hover,.f_branding_on.f_branding_avclub_on figcaption a:hover{color:#68672}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on.blog-group-avclub .entry-content blockquote,.f_branding_on .blog-group-avclub .entry-content blockquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_avclub_on .entry-content blockquote{border-radius:;border-left:5px solid #1c263c;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before,.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-avclub .entry-content .pullquote__content,.f_branding_on .blog-group-avclub .entry-content .pullquote__content,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_avclub_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-avclub .review-score,.f_branding_on .blog-group-avclub .review-score,.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_avclub_on .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1c263c}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white){color:#948a3;border-color:#948a3}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white):hover{color:#68672;border-color:#68672}.f_branding_on.blog-group-avclub .author-bio__name,.f_branding_on .blog-group-avclub .author-bio__name,.f_branding_on.f_branding_avclub_on .author-bio__name{color:#222}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name){color:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover{color:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#68672}.f_branding_on.blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_avclub_on .sidebar-content .newsletter-subscribe{border-color:#1c263c}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on.blog-group-avclub .entry-content .pullquote,.f_branding_on .blog-group-avclub .entry-content .pullquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_avclub_on .entry-content .pullquote{border:2px solid #91dbd9;padding:3px;position:relative;font-weight:normal;font-style:normal}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before{height:3px;width:4px;position:absolute;left:-14px;top:-14px;background-repeat:no-repeat;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="23" viewBox=" 33 23" xmlns="http://www.w3.org/2/svg"><title>avc-pq<\/title><path d="M22.725 4.39c-1.4 1.14-1.763 2.345-2.157 3.61-.274.894-.41 1.736-.41 2.53 .496.6 1.55.186 1.674 1.362-1.586 3.223-2.38 5.58-2.38 2.3 3.657.577 4.872 1.727 1.213 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.38 1.86-5.17 1.86-1.34 -2.53-.243-3.57-.723-1.43-.487-1.86-1.187-2.455-2.13-.573-.745-1.3-1.76-1.377-3.5-.348-1.29-.52-2.69-.52-4.24 -2.652.682-5.94 2.44-7.326 1.362-2.23 3.37-3.956 6.25-5.17l.67 1.376c-1.34.62-2.53 1.52-3.57 2.64m-17.518 C4.165 5.53 3.447 6.734 3.5 8c-.274.894-.41 1.736-.41 2.53 .496.62 1.55.188 1.674 1.362-1.586 3.22-2.38 5.578-2.38 2.32 3.66.577 4.872 1.727 1.215 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.5 1.86-5.28 1.86-1.315 -2.492-.243-3.533-.723-1.48-.487-1.86-1.187-2.46-2.13-.57-.77-1.35-1.795-1.395-3.7C.18 15.78 14.382 12.87c-2.653.69-5.95 2.62-7.327 1.38-2.23 3.392-3.956 6.47-5.17l.66 1.377c-1.338.62-2.53 1.5-3.57 2.64" fill="%231C263C" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-a{min-width:18px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="18" height="11" viewBox=" 18 11" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-a<\/title><g fill="none" fill-rule="evenodd"><path fill="%231C263C" d="M4.63 L 1.56h9.59"/><path fill="%2391DBD9" d="M7.8 l4.784 1.56L17.658.3"/><\/g><\/svg>')}.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{min-width:162px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="162" height="13" viewBox=" 162 13" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path fill="%23948A3" d="M93.427 6.925h67.595V6.14H93.427M 6.925h67.595V6.14H"/><path d="M86.664 6.216c 3.433-2.783 6.216-6.216 6.215-3.433 -6.216-2.78-6.216-6.213S77.15 8.448 c3.433 6.216 2.783 6.216 6.216" fill="%23E6E6E6"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theonion_on.f_article_split_on .scroll-list-break{border-top:3px solid #6b3a}.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94d1b4;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theonion .post-content .quotable a,.f_branding_on .blog-group-theonion .post-content .quotable a,.f_branding_on.blog-group-theonion .post-content footer a,.f_branding_on .blog-group-theonion .post-content footer a,.f_branding_on.blog-group-theonion .post-content h1 a,.f_branding_on .blog-group-theonion .post-content h1 a,.f_branding_on.blog-group-theonion .post-content h2 a,.f_branding_on .blog-group-theonion .post-content h2 a,.f_branding_on.blog-group-theonion .post-content h3 a,.f_branding_on .blog-group-theonion .post-content h3 a,.f_branding_on.blog-group-theonion .post-content h4 a,.f_branding_on .blog-group-theonion .post-content h4 a,.f_branding_on.blog-group-theonion .post-content h5 a,.f_branding_on .blog-group-theonion .post-content h5 a,.f_branding_on.blog-group-theonion .post-content h6 a,.f_branding_on .blog-group-theonion .post-content h6 a,.f_branding_on.blog-group-theonion .post-content li a,.f_branding_on .blog-group-theonion .post-content li a,.f_branding_on.blog-group-theonion .post-content p a,.f_branding_on .blog-group-theonion .post-content p a,.f_branding_on.f_branding_theonion_on .post-content .quotable a,.f_branding_on.f_branding_theonion_on .post-content footer a,.f_branding_on.f_branding_theonion_on .post-content h1 a,.f_branding_on.f_branding_theonion_on .post-content h2 a,.f_branding_on.f_branding_theonion_on .post-content h3 a,.f_branding_on.f_branding_theonion_on .post-content h4 a,.f_branding_on.f_branding_theonion_on .post-content h5 a,.f_branding_on.f_branding_theonion_on .post-content h6 a,.f_branding_on.f_branding_theonion_on .post-content li a,.f_branding_on.f_branding_theonion_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #94d1b4;box-shadow:inset -2px #94d1b4;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theonion .post-content .quotable a:hover,.f_branding_on .blog-group-theonion .post-content .quotable a:hover,.f_branding_on.blog-group-theonion .post-content footer a:hover,.f_branding_on .blog-group-theonion .post-content footer a:hover,.f_branding_on.blog-group-theonion .post-content h1 a:hover,.f_branding_on .blog-group-theonion .post-content h1 a:hover,.f_branding_on.blog-group-theonion .post-content h2 a:hover,.f_branding_on .blog-group-theonion .post-content h2 a:hover,.f_branding_on.blog-group-theonion .post-content h3 a:hover,.f_branding_on .blog-group-theonion .post-content h3 a:hover,.f_branding_on.blog-group-theonion .post-content h4 a:hover,.f_branding_on .blog-group-theonion .post-content h4 a:hover,.f_branding_on.blog-group-theonion .post-content h5 a:hover,.f_branding_on .blog-group-theonion .post-content h5 a:hover,.f_branding_on.blog-group-theonion .post-content h6 a:hover,.f_branding_on .blog-group-theonion .post-content h6 a:hover,.f_branding_on.blog-group-theonion .post-content li a:hover,.f_branding_on .blog-group-theonion .post-content li a:hover,.f_branding_on.blog-group-theonion .post-content p a:hover,.f_branding_on .blog-group-theonion .post-content p a:hover,.f_branding_on.f_branding_theonion_on .post-content .quotable a:hover,.f_branding_on.f_branding_theonion_on .post-content footer a:hover,.f_branding_on.f_branding_theonion_on .post-content h1 a:hover,.f_branding_on.f_branding_theonion_on .post-content h2 a:hover,.f_branding_on.f_branding_theonion_on .post-content h3 a:hover,.f_branding_on.f_branding_theonion_on .post-content h4 a:hover,.f_branding_on.f_branding_theonion_on .post-content h5 a:hover,.f_branding_on.f_branding_theonion_on .post-content h6 a:hover,.f_branding_on.f_branding_theonion_on .post-content li a:hover,.f_branding_on.f_branding_theonion_on .post-content p a:hover{color:#94d1b4}.f_branding_on.blog-group-theonion figcaption a,.f_branding_on .blog-group-theonion figcaption a,.f_branding_on.f_branding_theonion_on figcaption a{color:#6b3a}.f_branding_on.blog-group-theonion figcaption a:hover,.f_branding_on .blog-group-theonion figcaption a:hover,.f_branding_on.f_branding_theonion_on figcaption a:hover{color:#381e}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on.blog-group-theonion .entry-content blockquote,.f_branding_on .blog-group-theonion .entry-content blockquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theonion_on .entry-content blockquote{border-radius:;border-left:5px solid #94d1b4;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theonion .review-score,.f_branding_on .blog-group-theonion .review-score,.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theonion_on .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white){color:#6b3a;border-color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white):hover{color:#381e;border-color:#381e}.f_branding_on.blog-group-theonion .author-bio__name,.f_branding_on .blog-group-theonion .author-bio__name,.f_branding_on.f_branding_theonion_on .author-bio__name{color:#222}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name){color:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover{color:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#381e}.f_branding_on.blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theonion_on .sidebar-content .newsletter-subscribe{border-color:#94d1b4}.f_branding_on.blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_earther_on.f_article_split_on .scroll-list-break{border-top:3px solid #75b2}.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#75b2;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-earther .post-content .inset--story__headline a,.f_branding_on .blog-group-earther .post-content .inset--story__headline a,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-earther .post-content .quotable a,.f_branding_on .blog-group-earther .post-content .quotable a,.f_branding_on.blog-group-earther .post-content footer a,.f_branding_on .blog-group-earther .post-content footer a,.f_branding_on.blog-group-earther .post-content h1 a,.f_branding_on .blog-group-earther .post-content h1 a,.f_branding_on.blog-group-earther .post-content h2 a,.f_branding_on .blog-group-earther .post-content h2 a,.f_branding_on.blog-group-earther .post-content h3 a,.f_branding_on .blog-group-earther .post-content h3 a,.f_branding_on.blog-group-earther .post-content h4 a,.f_branding_on .blog-group-earther .post-content h4 a,.f_branding_on.blog-group-earther .post-content h5 a,.f_branding_on .blog-group-earther .post-content h5 a,.f_branding_on.blog-group-earther .post-content h6 a,.f_branding_on .blog-group-earther .post-content h6 a,.f_branding_on.blog-group-earther .post-content li a,.f_branding_on .blog-group-earther .post-content li a,.f_branding_on.blog-group-earther .post-content p a,.f_branding_on .blog-group-earther .post-content p a,.f_branding_on.f_branding_earther_on .post-content .quotable a,.f_branding_on.f_branding_earther_on .post-content footer a,.f_branding_on.f_branding_earther_on .post-content h1 a,.f_branding_on.f_branding_earther_on .post-content h2 a,.f_branding_on.f_branding_earther_on .post-content h3 a,.f_branding_on.f_branding_earther_on .post-content h4 a,.f_branding_on.f_branding_earther_on .post-content h5 a,.f_branding_on.f_branding_earther_on .post-content h6 a,.f_branding_on.f_branding_earther_on .post-content li a,.f_branding_on.f_branding_earther_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-earther .post-content .quotable a:hover,.f_branding_on .blog-group-earther .post-content .quotable a:hover,.f_branding_on.blog-group-earther .post-content footer a:hover,.f_branding_on .blog-group-earther .post-content footer a:hover,.f_branding_on.blog-group-earther .post-content h1 a:hover,.f_branding_on .blog-group-earther .post-content h1 a:hover,.f_branding_on.blog-group-earther .post-content h2 a:hover,.f_branding_on .blog-group-earther .post-content h2 a:hover,.f_branding_on.blog-group-earther .post-content h3 a:hover,.f_branding_on .blog-group-earther .post-content h3 a:hover,.f_branding_on.blog-group-earther .post-content h4 a:hover,.f_branding_on .blog-group-earther .post-content h4 a:hover,.f_branding_on.blog-group-earther .post-content h5 a:hover,.f_branding_on .blog-group-earther .post-content h5 a:hover,.f_branding_on.blog-group-earther .post-content h6 a:hover,.f_branding_on .blog-group-earther .post-content h6 a:hover,.f_branding_on.blog-group-earther .post-content li a:hover,.f_branding_on .blog-group-earther .post-content li a:hover,.f_branding_on.blog-group-earther .post-content p a:hover,.f_branding_on .blog-group-earther .post-content p a:hover,.f_branding_on.f_branding_earther_on .post-content .quotable a:hover,.f_branding_on.f_branding_earther_on .post-content footer a:hover,.f_branding_on.f_branding_earther_on .post-content h1 a:hover,.f_branding_on.f_branding_earther_on .post-content h2 a:hover,.f_branding_on.f_branding_earther_on .post-content h3 a:hover,.f_branding_on.f_branding_earther_on .post-content h4 a:hover,.f_branding_on.f_branding_earther_on .post-content h5 a:hover,.f_branding_on.f_branding_earther_on .post-content h6 a:hover,.f_branding_on.f_branding_earther_on .post-content li a:hover,.f_branding_on.f_branding_earther_on .post-content p a:hover,.f_branding_on.blog-group-earther figcaption a,.f_branding_on .blog-group-earther figcaption a,.f_branding_on.f_branding_earther_on figcaption a{color:#75b2}.f_branding_on.blog-group-earther figcaption a:hover,.f_branding_on .blog-group-earther figcaption a:hover,.f_branding_on.f_branding_earther_on figcaption a:hover{color:#537f}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote,.f_branding_on.blog-group-earther .entry-content blockquote,.f_branding_on .blog-group-earther .entry-content blockquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_earther_on .entry-content blockquote{border-radius:;border-left:5px solid #75b2;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-earther .review-score,.f_branding_on .blog-group-earther .review-score,.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_earther_on .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white){color:#75b2;border-color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white):hover{color:#537f;border-color:#537f}.f_branding_on.blog-group-earther .author-bio__name,.f_branding_on .blog-group-earther .author-bio__name,.f_branding_on.f_branding_earther_on .author-bio__name{color:#222}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name){color:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover{color:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#537f}.f_branding_on.blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_earther_on .sidebar-content .newsletter-subscribe{border-color:#75b2}.storytype--box{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;margin-bottom:1.5rem}.storytype--box__text{padding:}.storytype--box__title{margin:}.storytype--box__description{font-family:"ElizabethSerif",Georgia,serif;font-size:14px;line-height:1.5;color:#666;margin-top:.5rem}@media only screen and (max-width: 37.438em){.storytype--box__description{margin-bottom:1.5rem}}.storytype--box__asset img{display:block;width:1%}.storytype--box.storytype--box__wrap{margin-bottom:2.5rem;padding:1.125rem ;background-color:#f5f5f5}.storytype--box.storytype--box__wrap .storytype--box__text{padding: 1.125rem}@media only screen and (min-width: 37.5em){.storytype__content .postlist__item--compact{padding-left:1.125rem}.storytype__content .postlist__item--compact .item__content--thumb .asset{padding-left:}}.storytype--nav{margin: -16px;min-height:calc(36px + 2rem)}@media only screen and (max-width: 37.438em){.storytype--nav{min-height:calc(36px + 2rem)}}@media only screen and (max-width: 37.438em){.storytype--nav--two-dropdowns{min-height:calc(36px * 2 + 1rem + 2rem)}}.storytype--nav__categoryselector,.storytype--nav__subcategoryselector{margin-bottom:2rem}@media only screen and (max-width: 37.438em){.storytype--nav__subcategoryselector{margin-top:-1rem}}.storytype--nav .select-component-list{max-height:3px;overflow-y:scroll}.storytype--nav .select-component-list ul{overflow-y:hidden}@media only screen and (max-width: 37.438em){.storytype--section{margin-left:-1.125rem;margin-right:-1.125rem}}.storytype--section header{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;border-bottom:1px solid #e5e5e5;margin-bottom:15px}@media only screen and (max-width: 37.438em){.storytype--section header{margin-left:1.125rem;margin-right:1.125rem}}.storytype--section header h2{margin-bottom:5px}.storytype--section header h2 a{color:#}.storytype--section__viewall{text-transform:uppercase;display:inline-block;-ms-flex-item-align:center;align-self:center}.storytype--section__wrapper{margin-bottom:3rem}@media only screen and (max-width: 37.438em){.storytype--section__wrapper{width:1%;overflow-x:scroll;padding-left:1.125rem}}.storytype--section__items{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:nowrap;flex-wrap:nowrap;-webkit-box-pack:start;-ms-flex-pack:start;justify-content:flex-start}.storytype--section__item{width:31.8%;position:relative;-ms-flex-negative:;flex-shrink:;margin-right:1.125rem}.storytype--section__item:last-of-type{margin-right:}@media only screen and (max-width: 37.438em){.storytype--section__item{width:2px;margin-right:1.125rem}.storytype--section__item:last-of-type{width:218px;padding-right:1.125rem}}.storytype--section .item__image{display:block;margin-bottom:1px}.storytype--section .headline{margin-bottom:}.storytype-label{font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:bold;padding-right:1px;text-transform:uppercase;color:#93ec}.storytype-label:hover{color:#73b9;text-decoration:none}.storytype-label:hover.storytype-label--white{background-color:#ffffff;color:#}.storytype-label--white{color:#ffffff}.storytype-label--outlined{border:1px solid #93ec;line-height:27px;margin-right:5px;height:27px;padding: 8px}.storytype-label--outlined.storytype-label--white{border-color:#ffffff;color:white}.storytype-label-wrapper{display:-webkit-box;display:-ms-flexbox;display:flex;max-width:1%;overflow:hidden}.storytype-label-wrapper--small-margin{margin-bottom:5px}.storytype-label-wrapper--medium-margin{margin-bottom:1px}.storytype-label-wrapper--large-margin{margin-bottom:15px}.storytype-label-wrapper--huge-margin{margin-bottom:2px}@media only screen and (max-width: 53.125em){.storytype-label-wrapper--curation{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;padding: 18px}}.storytype-label-wrapper .storytype-label{overflow:hidden;text-overflow:ellipsis;white-space:nowrap}.storytype-label-wrapper :last-child{margin-right:}.postlist__item--compact{margin-bottom:3px;padding-bottom:3px;border-bottom:1px solid #e5e5e5}.postlist__item--compact:last-of-type{border-bottom:;margin-bottom:}.postlist__item--compact .item__content{margin: -1.125rem;max-width:none;width:auto}.postlist__item--compact .item__content:after,.postlist__item--compact .item__content:before{content:" ";display:table}.postlist__item--compact .item__content:after{clear:both}.postlist__item--compact .item__text{padding-left:1.125rem;padding-right:1.125rem;float:left}@media only screen and (min-width: 37.5em){.postlist__item--compact .item__content--thumb .asset{padding-left:1.125rem;padding-right:1.125rem;width:33.333%;float:left;margin-bottom:}.postlist__item--compact .item__content--thumb .item__text{padding-left:1.125rem;padding-right:1.125rem;width:66.667%;float:left;padding-left:}}.postlist__item--compact .asset{width:1%;position:relative;margin: 2px}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{padding:}}.postlist__item--compact .asset img{width:1%}.postlist__item--compact .asset img[data-sizes=auto],.postlist__item--compact .asset video[data-sizes=auto]{display:block;width:1%}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{float:none}}.postlist__item--compact .headline{font-size:24px;margin-bottom:5px}html.fallback-fonts .postlist__item--compact .headline{font-family:"Arial Narrow",Arial,sans-serif;font-size:22.68px;line-height:1.349;letter-spacing:.5px}.postlist__item--compact .meta--pe{display:block;margin-bottom:7px}.postlist__item--compact .meta__container{font-size:15px}.postlist__item--compact .meta__byline,.postlist__item--compact .meta__time{display:inline-block}.postlist__item--compact .meta__byline:after{display:inline-block;content:'*';color:#aaa;padding: 5px}.postlist__item--compact .meta__right{display:none}.postlist__item--compact .excerpt{font-family:"ElizabethSerif",Georgia,serif}.postlist__item--compact .excerpt p{margin-bottom:}</style><script>window._K_MSGS = []; window._K_MSG_L = function (e) {_K_MSGS.push(e);}; window.addEventListener('message', window._K_MSG_L);</script><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/blog-2545d75c35bc9d9491eb61d4b29724.css" as="style" onload="this.rel='stylesheet'"><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/insets-13541366ddfac4e8eca127496e.css" as="style" onload="this.rel='stylesheet'"><script src="https://kinja.com/api/profile/accountwithtoken?jsonp=_fasttoken&newFollows=true" async defer></script><meta name="dynamic-stylesheet" id="editor-css-url" content="//x.kinja-static.com/assets/stylesheets/editor-7ed31791155c6bedc63fda5ded339b2.css"><meta name="google-site-verification" content="P13oAn8o8LB6FVCJWKsHWXvxfbR-SJrmvox6EgULpUs" /><meta name="viewport" content="width=device-width, initial-scale=1., minimum-scale=1.,maximum-scale=1." /><meta name="ROBOTS" content="INDEX, FOLLOW" /><title>The 218 Ford F-15 Gets A New Engine And More Horsepower
2014 intro...
storybreak stars<\/title><path d="M5.146 9.1l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953L5.147 H3.76l.158 3.623L.893 1.67.2 2.867l3.214 1.638L.2 6.175l.693 1.197 3.25-1.985L3.76 9.1m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H23.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623m21.386 l-.19-3.623 3.57 1.985.693-1.197-3.213-1.67 3.213-1.638-.693-1.197-3.56 1.953.19-3.623H43.76l.158 3.623-3.25-1.953-.693 1.197 3.214 1.638-3.214 1.67.693 1.197 3.25-1.985-.158 3.623" fill="%23CCC" fill-rule="evenodd"/><\/svg>');background-repeat:no-repeat;background-position:center}.editor .editor-inner div.legacy-raw-html,.post-content div.legacy-raw-html{border:3px solid #eeb544;padding:5px;margin-bottom:2px}.editor .editor-inner div.legacy-raw-html:before,.post-content div.legacy-raw-html:before{content:'Before this post can be saved, this block must be removed.';font-size:12px;display:inline-block}.editor .editor-inner div.legacy-raw-html table,.post-content div.legacy-raw-html table{margin-bottom:}.f_dap_tables_on .editor .editor-inner table,.f_dap_tables_on .post-content table,.f_use_dap .editor .editor-inner table,.f_use_dap .post-content table{font-family:"ProximaNovaCond",sans-serif;border:1px solid #e5e5e5;width:1%;margin-bottom:1.5rem;border-spacing:}.f_dap_tables_on .editor .editor-inner table td,.f_dap_tables_on .editor .editor-inner table th,.f_dap_tables_on .post-content table td,.f_dap_tables_on .post-content table th,.f_use_dap .editor .editor-inner table td,.f_use_dap .editor .editor-inner table th,.f_use_dap .post-content table td,.f_use_dap .post-content table th{padding:1px;text-align:left;border:;border-right:1px solid #fff}.f_dap_tables_on .editor .editor-inner table td:last-child,.f_dap_tables_on .editor .editor-inner table th:last-child,.f_dap_tables_on .post-content table td:last-child,.f_dap_tables_on .post-content table th:last-child,.f_use_dap .editor .editor-inner table td:last-child,.f_use_dap .editor .editor-inner table th:last-child,.f_use_dap .post-content table td:last-child,.f_use_dap .post-content table th:last-child{border-right:}.f_dap_tables_on .editor .editor-inner table tr:nth-child(2n) td,.f_dap_tables_on .post-content table tr:nth-child(2n) td,.f_use_dap .editor .editor-inner table tr:nth-child(2n) td,.f_use_dap .post-content table tr:nth-child(2n) td{background-color:#f5f5f5}.above-headline-image .featured-post__caption,.above-headline-image .video-embed__caption,.above-headline-image figcaption,.editor .editor-inner .featured-post__caption,.editor .editor-inner .video-embed__caption,.editor .editor-inner figcaption,.featured-post__asset .featured-post__caption,.featured-post__asset .video-embed__caption,.featured-post__asset figcaption,.post-content .featured-post__caption,.post-content .video-embed__caption,.post-content figcaption{position:relative;font-family:"ProximaNovaCond",sans-serif;color:#aaa;font-size:15px;line-height:21px;text-align:left;margin-top:.5rem;display:block}.above-headline-image .featured-post__caption:focus,.above-headline-image .video-embed__caption:focus,.above-headline-image figcaption:focus,.editor .editor-inner .featured-post__caption:focus,.editor .editor-inner .video-embed__caption:focus,.editor .editor-inner figcaption:focus,.featured-post__asset .featured-post__caption:focus,.featured-post__asset .video-embed__caption:focus,.featured-post__asset figcaption:focus,.post-content .featured-post__caption:focus,.post-content .video-embed__caption:focus,.post-content figcaption:focus{outline:none}.above-headline-image .video-embed__caption,.editor .editor-inner .video-embed__caption,.featured-post__asset .video-embed__caption,.post-content .video-embed__caption{margin-top:-.5rem}.above-headline-image .featured-post__caption,.editor .editor-inner .featured-post__caption,.featured-post__asset .featured-post__caption,.post-content .featured-post__caption{position:absolute;top:1%}.ad-unit--featured-recirculation{opacity:1;pointer-events:auto;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;z-index:97}.ad-unit--featured-recirculation .ad-container{background:#f5f5f5;width:3px;height:25px}.ad-unit--featured-recirculation .ad-container--hidden{opacity:;pointer-events:none;visibility:hidden}.ad-unit--fixed-bottom{position:fixed;bottom:3.5rem;right:1.125rem;height:auto;width:3px;opacity:1;-webkit-transition:eek:pacity .2s ease-in-out;transition:eek:pacity .2s ease-in-out;pointer-events:auto}.ad-unit--fixed-bottom--invisible{opacity:;pointer-events:none}.ad-unit--fixed-bottom .ad-container{background:#f5f5f5;width:3px;height:25px}.editor .editor-inner .has-image.align--center.media-large{max-width:636px}.shared{margin-bottom:3.4rem}.shared .content-wrapper{background-color:#f5f5f5;padding-top:24px;border:1px #aaa solid}.shared .referenced-label{background-color:#f5f5f5}.shared .reframe-post{margin-bottom:1.875rem}.post .linked,.post .recommend{background-color:rgba(,,,.7);position:absolute;cursor:pointer;top:8px;right:8px;width:32px;height:32px;opacity:;-webkit-transition:all .15s ease-out;transition:all .15s ease-out;border-radius:5px;z-index:1}.post .linked{bottom:;border-top-left-radius:5px}.post .flex-video:hover .recommend,.post .has-image:hover .linked,.post .has-image:hover .recommend,.post figure:hover .linked,.post figure:hover .recommend{opacity:1}.post .has-image .recommend{right:8px}.post .movementventures,.post .qzzr{width:1%}.post a[x-inset=hidden]{display:none}.pullquote{margin-bottom:2rem;margin-top:2rem;text-align:center;padding:1px ;font-family:"ProximaNovaCond",sans-serif;font-weight:lighter;font-style:italic;font-size:25px;line-height:37px;clear:left}.pullquote:after,.pullquote:before{content:'';display:block;width:45px;height:;margin: auto;position:relative;border-top-width:1px;border-top-style:solid;border-color:#aaa}.pullquote:before{margin-bottom:2px}.pullquote:after{margin-top:2px}@media only screen and (min-width: 37.5em){.pullquote.align--left{width:4%;max-width:32px;float:left;margin-right:2.25rem;text-align:left;margin-bottom:.5em;margin-top:}.pullquote.align--left:after,.pullquote.align--left:before{margin-left:;margin-right:}}.pullquote__helper{display:none}.commentlist .pullquote,.quickreply .pullquote{margin-bottom:1em;margin-top:1em;text-align:left;padding: 1.125rem;font-size:22px;line-height:3px;position:relative}.commentlist .pullquote:before,.quickreply .pullquote:before{position:absolute;left:;top:3px;bottom:5px;width:;height:auto;border-top:;border-left-width:1px;border-left-style:solid;margin:}.commentlist .pullquote:after,.quickreply .pullquote:after{display:none}.post-content .inset--story{clear:both;margin:2rem auto;padding:1.125rem;border:#e5e5e5 1px solid;border-radius:5px;-webkit-box-shadow:#e5e5e5 2px 5px;box-shadow:#e5e5e5 2px 5px;max-width:636px}.post-content .inset--story p{font-size:15px;line-height:25px;margin-bottom:.6rem}@media only screen and (min-width: 37.5em){.post-content .inset--story{display:-webkit-box;display:-ms-flexbox;display:flex}}.post-content .inset--story__thumb{display:block;position:relative;margin:-1.125rem -1.125rem 1rem}@media only screen and (min-width: 37.5em){.post-content .inset--story__thumb{width:25%;min-width:25%;margin: 1.125rem ;float:left}}.post-content .inset--story__thumb figure{margin:;position:relative}.post-content .inset--story__thumb img{width:1%}.post-content .inset--story__headline{font-size:2px;line-height:24px;margin-bottom:1px}.post-content .inset--story__headline a,.post-content .inset--story__headline a:hover{color:#}.post-content .inset--story__readmore{font-family:"ProximaNovaCond",sans-serif;font-size:16px}.post-content .inset--story__readmore .hostname{font-weight:bold}.non-secure-iframe-embed{position:relative;padding-bottom:56.25%}.iframe-container{position:absolute;top:;left:;height:1%;width:1%}.iframe-container__external-source{height:92.5%;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;background-color:#e5e5e5}@media only screen and (max-width: 37.438em){.iframe-container__external-source{position:relative}}.iframe-container__external-source svg{opacity:.1}.iframe-container__external-source img{position:absolute;top:;left:;width:1%;opacity:.8}@media only screen and (max-width: 37.438em){.iframe-container__external-source img{position:relative}}.iframe-container__link-to-source{position:absolute;top:25px;right:25px}.iframe-container__link-to-source svg{opacity:.7;fill:#fff}.iframe-container__message{position:absolute;bottom:;height:7.5%;width:1%;background:#fff;color:#aaa;font-size:15px}@media only screen and (max-width: 37.438em){.iframe-container__message{position:absolute;height:auto}}.iframe-container__message p{position:absolute;font-family:"ProximaNovaCond", sans-serif;bottom:;margin:;font-size:15px;text-align:left}@media only screen and (max-width: 37.438em){.iframe-container__message p{position:relative}}.iframe-container__message a{text-decoration:none;color:#93ec}.google-adx .container{background-color:#f5f5f5;line-height:18px;padding:5px 1.125rem}.google-adx .by-google{color:#;font-size:14px}.google-adx .google-headline{color:#333}.post-bottom{margin: -1.125rem;max-width:none;width:auto}.post-bottom:after,.post-bottom:before{content:" ";display:table}.post-bottom:after{clear:both}@media only screen and (max-width: 37.438em){.post-bottom{margin:2rem 1rem}}@media only screen and (min-width: 37.5em){.post-bottom{margin:1.5rem }}.post-bottom .post-bottom__inner{max-width:636px;margin: auto}.post-bottom,.post-bottom a{color:#777}.post-bottom .fb-like{float:left;z-index:4;width:auto}.post-bottom .reply-to-post{color:#aaa}.post-bottom .reply-to-post .icon{margin-left:7px}.post-bottom .icon{opacity:.3;margin-left:5px;vertical-align:middle}.private-post-list{border-bottom:2px #aaa solid}.stream{padding-bottom:}.stream .meta .publish-time .icon{margin: 5px}.stream .post-dropdown-ct{display:none}.unshare-bloglist{position:absolute;top:;right:;z-index:1}.unshare-bloglist .unshare-bloglist-select,.unshare-bloglist .unshare-bloglist-title{display:inline-block;vertical-align:middle}.unshare-bloglist .unshare-bloglist-title{padding: 3px;background-color:#fff;margin: 1px }.unshare-bloglist .unshare-bloglist-select{margin-bottom:}.text-red{color:#eeb544}.post-tools-wrapper .reply-to-post__container .svg-icon{margin-left:;position:relative;top:2px}@media only screen and (max-width: 37.438em){.post-tools-wrapper .reply-to-post__container{display:none}}@media only screen and (max-width: 37.438em){.post-tools-wrapper{-webkit-box-flex:1;-moz-flex:1 1 1%;-ms-flex:1 1 1%;flex:1 1 1%;-webkit-box-ordinal-group:3;-moz-order:2;-ms-flex-order:2;order:2;margin:3px 14px}}@media only screen and (max-width: 37.438em){.post-tools-wrapper .button-recommend-post,.post-tools-wrapper .reply-count{display:none}}.newsletter-subscribe-post{display:block;font-family:"ElizabethSerif",Georgia,serif;border-top:#e5e5e5 1px solid;margin:1.5rem ;max-width:636px}.newsletter-subscribe-post__copy{color:#aaa;margin:1.5rem 1rem;line-height:29px}.newsletter-subscribe-post .button{font-size:1.1rem;padding: 1.2rem}.newsletter-subscribe-post .svg-icon{opacity:1;fill:#93ec}.center{margin: auto}ul.commerce-inset.fake-list{margin-bottom:;margin-top:-2px}.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:4px;margin:.5rem 1.125rem .5rem }.asset.has-media.has-image.align--left.media-large{width:1%}.asset.has-media.has-image.media-large.align--center{max-width:636px}@media only screen and (max-width: 27.25rem){.asset.has-media.has-image.align--left,.asset.has-media.has-image.align--left.media-large,.asset.has-media.has-image.align--left.media-medium{max-width:1%}}@media only screen and (min-width: 37.5em){.asset.has-media.has-image{margin-left:auto;margin-right:auto;max-width:636px}.asset.has-media.has-image.media-large{margin-left:-1.125rem;margin-right:-1.125rem;max-width:initial}.asset.has-media.has-image.media-large.align--center{margin-left:auto;margin-right:auto}.asset.media-small.has-media.has-image:not(.align--center){margin-bottom:.5rem;margin-right:1.125rem}}@media only screen and (min-width: 53.126em){.asset.has-media.has-image.media-large{margin-left:auto;margin-right:auto}}.post-content{font-family:"ElizabethSerif",Georgia,serif}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper{position:relative;background:#f5f5f5}.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper.img-permalink-sub-wrapper--nobackground,.post-content .has-image.has-image.media-large .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-medium .img-permalink-sub-wrapper img,.post-content .has-image.has-image.media-small .img-permalink-sub-wrapper img{background:none}.post-content .has-image.has-image.media-large .img-wrapper,.post-content .has-image.has-image.media-medium .img-wrapper,.post-content .has-image.has-image.media-small .img-wrapper{max-width:1%}.post-content .has-image.has-image.media-large .img-wrapper img,.post-content .has-image.has-image.media-medium .img-wrapper img,.post-content .has-image.has-image.media-small .img-wrapper img{position:absolute;height:auto;top:;left:;right:;bottom:}.post-content .has-image.has-image.media-large .lightbox-wrapper,.post-content .has-image.has-image.media-medium .lightbox-wrapper,.post-content .has-image.has-image.media-small .lightbox-wrapper{display:block}.img-wrapper{max-width:1%}.old-post-type-img{display:block;margin:1.125rem auto}.gmg-text-ad{margin:2rem auto;max-width:636px;font-family:"ProximaNovaCond", sans-serif}.gmg-text-ad .text-ad__inner{border:1px solid #e5e5e5;border-left-width:;border-right-width:;padding:3px 18px 1px;position:relative;background-color:#f5f5f5}.gmg-text-ad .text-ad__inner:before{content:'Advertisement';text-transform:uppercase;position:absolute;top:;width:1%;text-align:center;color:#ccc;font-size:13px}.gmg-text-ad a{display:block;color:#}.gmg-text-ad a:hover{text-decoration:none}.gmg-text-ad .text-ad__headline{font-size:2px;line-height:24px;margin-bottom:5px;color:#}.gmg-text-ad a:hover .text-ad__headline{text-decoration:underline}.gmg-text-ad .text-ad__excerpt{font-family:"ElizabethSerif", Georgia, serif;font-size:15px;color:#333;line-height:26px;margin: 3px}.gmg-text-ad .text-ad__more{color:#ccc;font-size:15px}@-webkit-keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}@keyframes discussion-status-badge-animation{%{opacity:}25%{opacity:1}75%{opacity:1}to{opacity:}}.discussion-status-badge-wrapper{display:block;margin-bottom:2px}.discussion-status-badge-wrapper .discussion-status-badge{color:#fff;background-color:rgba(,,,.7);display:inline;padding:5px 1px}.discussion-status-badge{color:#ef774;line-height:24px;margin-bottom:12px;text-transform:uppercase}.discussion-status-badge:before{display:inline-block;content:'';width:11px;height:11px;background-color:#ef774;border-radius:11px;margin-right:5px;-webkit-animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite;animation:discussion-status-badge-animation 4s cubic-bezier(.4, , .2, 1) infinite}.meta__tools .f-dropdown{text-align:left}.commerce-disclaimer{margin-bottom:2px;display:-webkit-box;display:-ms-flexbox;display:flex}.commerce-disclaimer:before{content:"";border-left:2px solid #72ad75;margin:4px 6px}.commerce-disclaimer span{padding-left:1px}.customkinja-backlink{max-width:636px;margin:2em auto}.customkinja-backlink:after,.customkinja-backlink:before{content:'';display:block;height:;width:auto;border-top-width:1px;border-top-style:solid;border-color:#ccc}.customkinja-backlink a{display:inline-block;padding:1em }.post__misc{clear:both}.permalink.featured-post .main{left:;padding:}.permalink.featured-post .entry-title{color:white;font-size:8.5vw;font-weight:normal;line-height:1.1;text-align:center;margin: auto;max-width:118px;width:1%}.permalink.featured-post .entry-title a{color:white}.permalink.featured-post .row.content-wrapper,.permalink.featured-post .post-wrapper{margin:}.permalink.featured-post .post{padding:}.permalink.featured-post .post .meta--pe{margin-bottom:;margin-left:auto;margin-right:auto;max-width:636px}.permalink.featured-post .post__misc{padding: 1.125rem}.permalink.featured-post .post--empty .meta--pe{margin-top: !important;margin-bottom: !important;padding-bottom:;border-top:;border-bottom:}.permalink.featured-post .post-content:not(.reply__content){margin-top:3px;padding: 1.125rem}.permalink.featured-post .ad-unit--in-post .ad-container{height:25px}.permalink.featured-post .entry-content.fixed{position:fixed;right:1px;top:}.permalink.featured-post .entry-content.unfixed{position:absolute;right:}.featured-post__sponsored-label{color:#aaa;font-size:13px;text-transform:uppercase}.featured-post__header{background:black;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-align:center;-ms-flex-align:center;align-items:center;position:relative}.featured-post__header .discussion-status-badge{font-size:.42em;margin:18px ;text-align:center}.featured-post__header.magazine{-webkit-box-align:initial;-ms-flex-align:initial;align-items:initial;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__asset-group{width:1%}.featured-post__header.magazine .featured-post__asset-group:after{display:none}.featured-post__header.magazine .featured-post__asset{padding:}.featured-post__header.magazine .featured-post__asset .featured-post__caption,.featured-post__header.magazine .featured-post__asset figcaption{display:none}.featured-post__header.magazine .featured-post__alternate-image-caption{display:block}.featured-post__header.magazine .featured-post__meta-container{display:none}.featured-post__header.magazine .featured-post__headline-container{width:1%}.featured-post__header.magazine .featured-post__headline-container-author{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .featured-post__headline-container-author .meta--pe.secondary-byline{margin:;max-width:1%}.featured-post__header.magazine .featured-post__headline-container-author .meta__label--sponsored{color:#aaa}.featured-post__headline-container-author{width:1%}.featured-post__headline-container-author .meta--pe{margin-bottom:;padding-top:3px;width:1%}.featured-post__headline-container-author .meta--pe .svg-icon{opacity:1;stroke:#aaa}.featured-post__headline-container-author .meta--pe .svg-icon.stroked{stroke:#aaa}.featured-post__headline-container-author .meta--pe .meta__byline,.featured-post__headline-container-author .meta--pe .meta__byline a,.featured-post__headline-container-author .post-tags-container .first-tag span{color:white}.featured-post__headline-container{padding:2px}.featured-post__headline-container,.featured-post__headline-container .featured-post__headline-container-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:center;-ms-flex-align:center;align-items:center}.featured-post__meta-container,.featured-post__meta-container-alt{display:none;-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:1%}.featured-post__meta-container-alt .meta--pe,.featured-post__meta-container .meta--pe{border-top:1px solid #e5e5e5;border-bottom:1px solid #e5e5e5;margin:4px !important;max-width:636px;padding:4px ;width:1%}.featured-post__asset-group{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-ordinal-group:;-ms-flex-order:-1;order:-1;position:relative;width:1%}.featured-post__asset-group:after{background:white;bottom:;content:'';display:none;left:;height:25%;position:absolute;right:;width:1%}.featured-post__asset-group .featured-post__cover{height:1%;max-height:1%}.featured-post__asset{padding:;position:relative;width:1%;z-index:1}.featured-post__asset,.featured-post__asset.pillarboxed{background:transparent}.featured-post__asset img,.featured-post__asset video{width:1%}.featured-post__asset .featured-post__caption,.featured-post__asset figcaption{display:none;margin:auto;max-width:636px;padding:1px }.featured-post__asset .img-wrapper{background-size:cover}.featured-post__asset__container{height:calc(1vw*9/16);margin: auto;max-height:calc(85vh);max-width:calc(85vh*16/9);width:1%}.featured-post__asset__container.video-type--JwPlayer,.featured-post__asset__container.video-type--Mcp,.featured-post__asset__container.video-type--OnionStudios,.featured-post__asset__container.video-type--YoutubeVideo{position:relative;height:1%;max-height:1%;max-width:1%;width:1%}.featured-post__asset__container.video-type--JwPlayer:after,.featured-post__asset__container.video-type--Mcp:after,.featured-post__asset__container.video-type--OnionStudios:after,.featured-post__asset__container.video-type--YoutubeVideo:after{content:"";display:block;padding-top:56.25%;width:1%}.featured-post__asset__container.video-type--JwPlayer>iframe,.featured-post__asset__container.video-type--Mcp>iframe,.featured-post__asset__container.video-type--OnionStudios>iframe,.featured-post__asset__container.video-type--YoutubeVideo>iframe{bottom:;left:;position:absolute;right:;top:}.featured-post__asset__container iframe{height:1%;width:1%}.featured-post__cover{background-position:center;background-repeat:no-repeat;background-size:contain;cursor:pointer;height:calc(1vw*9/16);left:;max-height:calc(85vh);position:absolute;top:;width:1%}.featured-post__cover .play-icon{background:rgba(,,,.6);border-radius:5px;display:block;height:6px;left:calc(5% - 18px);position:absolute;top:calc(5% - 3px);width:56px}.featured-post__cover .svg-icon{height:6px;margin-top:;opacity:.8;width:56px}.featured-post__cover:hover .svg-icon{opacity:1}.featured-post__alternate-image-caption{color:#aaa;display:block;padding:1px 1.25rem }.featured-post__alternate-image-caption>div{margin:auto;max-width:636px}.featured-post__alternate-image-caption.magazine{display:block}@media only screen and (min-width: 768px){.permalink.featured-post .entry-title{font-size:6vw}}@media only screen and (min-width: 124px){.permalink.featured-post .post .post-content{margin:auto;margin-top:;max-width:124px;width:1%}.permalink.featured-post .ad-unit--in-post{display:none}.permalink.featured-post .entry-title{font-size:4vw}.permalink.featured-post .featured-post__alternate-image-caption{display:none}.permalink.featured-post .featured-post__alternate-image-caption.magazine{display:block}.featured-post__headline-container{padding:4px}.featured-post__header{margin-bottom:}.featured-post__header .featured-post__headline-container-author,.featured-post__header .featured-post__meta-container .featured-post__headline-container-author,.featured-post__header.magazine .featured-post__headline-container-author{display:none}.featured-post__header .featured-post__asset .featured-post__caption,.featured-post__header .featured-post__asset figcaption{display:block}.featured-post__header.magazine{-webkit-box-orient:horizontal;-webkit-box-direction:normal;-ms-flex-direction:row;flex-direction:row}.featured-post__header.magazine .entry-title{font-size:3vw}.featured-post__header.magazine .featured-post__asset-group{width:75%}.featured-post__header.magazine .featured-post__headline-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;min-width:35px;width:25%}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group{-webkit-box-align:start;-ms-flex-align:start;align-items:flex-start}.featured-post__header.magazine .featured-post__headline-container .featured-post__headline-container-group h1{text-align:left}.featured-post__header.magazine .meta--pe{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column}.featured-post__header.magazine .meta__right{margin-top:15px;right:;width:1%}.featured-post__header.magazine .meta__data--comment{margin-left:auto}.featured-post__header.magazine .featured-post__category-label-wrapper{margin-bottom:}.featured-post__meta-container-alt,.featured-post__meta-container{display:-webkit-box;display:-ms-flexbox;display:flex}.featured-post__meta-container{background:white}.featured-post__asset-group{-webkit-box-ordinal-group:initial;-ms-flex-order:initial;order:initial}.featured-post__asset-group:after{display:block}.featured-post__asset{padding: 2.5%}}@media only screen and (min-width: 18px){.permalink.featured-post .entry-title{font-size:3vw}.featured-post__header.magazine .entry-title{font-size:2.5vw}}.sharingfooter{position:fixed;bottom:;left:;right:;background:#fff;z-index:98;-webkit-box-shadow: 1px rgba(,,,.4);box-shadow: 1px rgba(,,,.4);height:38px;line-height:38px;vertical-align:middle;font-size:13px}html.fallback-fonts .sharingfooter{font-family:"Arial Narrow",Arial,sans-serif;font-size:12.285px;line-height:39.444px;letter-spacing:.5px}.sharingfooter:active,.sharingfooter:hover{-webkit-box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);box-shadow: 1px rgba(,,,.55), 3px rgba(,,,.1);-webkit-transition:all 2ms ease-in-out;transition:all 2ms ease-in-out}.sharingfooter__wrapper{margin: auto;max-width:63rem;width:1%;max-width:1336px}.sharingfooter__wrapper:after,.sharingfooter__wrapper:before{content:" ";display:table}.sharingfooter__wrapper:after{clear:both}.sharingfooter__content{float:right;padding: 1.125rem}.sharingfooter__content a{display:inline-block;margin-left:1px}.sharingfooter__content .button--share{margin-top:5px}@media only screen and (max-width: 53.125em){.sharingfooter__content{float:none;text-align:center}.sharingfooter__content a{margin:}.sharingfooter__content .sharingfooter__facebook{text-align:right;padding-right:1px}.sharingfooter__content .sharingfooter__twitter{text-align:left;padding-left:1px}}.alert-bar{position:relative;padding:.5em;background-color:#eeb544;color:rgba(,,,.6)}.alert-bar.alert-bar__hero{margin:2em ;font-size:1.1em}.alert-bar.alert-bar__inline{width:1%}.alert-bar.alert-bar__control{padding-right:2em}.alert-bar .alert-bar__text{position:relative;top:1px}.alert-bar .alert-bar__icon{position:absolute;top:1px;right:1px}.reply__byline,a.reply__count span,a.reply__link span{font-family:"ProximaNovaCond",sans-serif;font-weight:5}.reply .unapproved-msg,.reply__pending-label,.reply__publish-time,.reply__to-author{font-family:"ProximaNovaCond",sans-serif;font-weight:4}@media only screen and (max-width: 37.438em){.reply--depth-{margin-left:}}.reply--depth->.reply__header>.avatar{margin-top:}.reply--depth->.reply__header>.avatar img{width:4px;height:4px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__header>.avatar{margin-top:2px}.reply--depth->.reply__header>.avatar img{width:32px;height:32px}}.reply--depth->.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;max-width:696px;padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply--depth->.reply__tools{padding-left:6px}@media only screen and (max-width: 37.438em){.reply--depth->.reply__tools{padding-left:1.125rem}}.reply--depth-.anchor>.reply__content{max-width:666px}ul.commentlist{margin:}ul.commentlist--depth-{position:relative;left:-5px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-{left:}}ul.commentlist--depth- .unapproved-filter--thread{width:686px;margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth- .unapproved-filter--thread{width:auto;margin-left:}}ul.commentlist--depth-1{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1{margin-left:18px}}ul.commentlist--depth-1+.reply-footer-bar{margin-left:6px}@media only screen and (max-width: 37.438em){ul.commentlist--depth-1+.reply-footer-bar{margin-left:}}.commentlist__item:after{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5;margin: 6px}@media only screen and (max-width: 37.438em){.commentlist__item:after{position:relative;width:12%;left:-2%;margin:}}.commentlist__item:last-child:after{display:none}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:after{width:auto;margin: 46px 5px}}@media screen and (min-width: 64em) and (max-width: 69.375em){.commentlist__item--depth-1:after{margin: 5px}}.commentlist__item--depth-1:first-child:before{content:'';display:block;height:;width:auto;border-bottom:1px solid #e5e5e5}@media only screen and (max-width: 37.438em){.commentlist__item--depth-1:first-child:before{position:relative;width:12%;left:-2%}}@media only screen and (min-width: 37.5em){.commentlist__item--depth-1:first-child:before{margin-right:5px}}@media screen and (min-width: 124px) and (max-width: 111px){.commentlist__item--depth-1:first-child:before{margin:}}.commentlist__item:not(.commentlist__item--depth-) .editor{margin-left:}.commentlist__item--depth-.commentlist__item--expandable:after{display:none}.commentlist__item--depth-.commentlist__item--expandable .reply-footer-bar{display:block}.reply{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row wrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row wrap;max-width:8px;padding:2px ;position:relative}.reply:hover .post-dropdown-trigger .svg-icon{opacity:1}.reply p.media-64{padding-bottom:1rem}.reply .media-3{float:left;max-width:5%;margin: 2.25rem ;padding:5px 15px }.reply .post-tools{bottom:;margin:;position:absolute;right:}.reply .post-tools .post-bottom{margin:}.reply .unapproved-msg{color:#aaa;font-size:.875rem;padding-bottom:1rem;font-style:italic}.reply img{width:1%}.reply.anchor:before{content:'';display:inline-block;height:1%;width:3px;position:absolute;left:-16px;top:}@media only screen and (max-width: 37.438em){.reply.anchor:before{left:-1.125rem}}.reply__header{-webkit-box-ordinal-group:1;-moz-order:;-ms-flex-order:;order:;width:1%;color:#aaa;line-height:1.4;position:relative;padding-right:23px;padding-bottom:1px}@media only screen and (min-width: 66.3em){.reply__header{padding-right:}}.reply__header .icon{opacity:.3;margin-left:1px}@media only screen and (max-width: 124px){.reply__header .icon{margin-top:-5px;margin-left:3px}}.reply__header>.avatar{float:left;display:block;position:relative;margin-top:2px;margin-right:2px}@media only screen and (max-width: 37.438em){.reply__header>.avatar{margin-right:1px}}.reply__header>.avatar img{height:3px;width:3px;display:block}@media only screen and (max-width: 37.438em){.reply__header>.avatar img{width:32px;height:32px}}.reply__header>.avatar .svg-checkmark{right:-6px;bottom:-5px}.reply__header .avatar .svg-checkmark,.reply__header .avatar .svg-checkmark--small{display:none;position:absolute;fill:#93ec;opacity:.9}.reply__header .post-dropdown-trigger{position:absolute;right:}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-trigger{right:1px}}.reply__header .post-dropdown-ct{position:absolute;top:3px}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct{position:static}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct{right:-14px}}@media only screen and (min-width: 9px) and (max-width: 124px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 128px) and (max-width: 147px){.reply__header .post-dropdown-ct{right:-41px;min-width:3px;min-height:1px}}@media only screen and (min-width: 148px){.reply__header .post-dropdown-ct{right:-67px;min-width:3px;min-height:1px}}@media only screen and (min-width: 37.5em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:6px}}@media only screen and (min-width: 88em){.reply__header .post-dropdown-ct .f-dropdown{margin-left:-169px}}@media only screen and (max-width: 37.438em){.reply__header .post-dropdown-ct .f-dropdown{width:9%;left:5%;right:5%}}.reply__header .post-dropdown-ct .f-dropdown .repostblock{background:inherit;cursor:default}.reply__header .post-dropdown-ct .f-dropdown .repostblock ul{margin:}.reply__header .post-dropdown-ct .f-dropdown .repostblock .repostheader{display:block;background:inherit;cursor:default;padding-left:.5rem}.reply__header.without-dropdown{padding-right:}.reply__header.without-dropdown .post-dropdown-ct{display:none}.reply__header.followed .avatar .svg-checkmark,.reply__header.followed .avatar .svg-checkmark--small{display:block}.featured-post .reply__header .post-dropdown-ct{right:-14px}.reply__byline{display:-webkit-box;display:-moz-flex;display:-ms-flexbox;display:flex;-ms-flex-flow:row nowrap;-webkit-box-orient:horizontal;-webkit-box-direction:normal;flex-flow:row nowrap;font-size:16px}@media only screen and (max-width: 37.438em){.reply__byline{font-size:14px}}.reply__byline a{overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;font-weight:bold;color:#}.reply__byline a:focus,.reply__byline a:hover{color:#}.reply__to-author{-webkit-box-flex:;-moz-flex: 1 auto;-ms-flex: 1 auto;flex: 1 auto;overflow:hidden;text-overflow:ellipsis;white-space:nowrap;max-width:none;font-weight:normal}@media only screen and (max-width: 124px){.reply__to-author .icon{margin-top:-3px}}.reply__publish-time{font-size:.812rem}.reply__publish-time a{color:#aaa}.reply__publish-time a:active,.reply__publish-time a:focus,.reply__publish-time a:hover{color:#aaa;text-decoration:underline}.reply__pending-label{color:#;text-transform:uppercase;font-size:14px;display:none;float:right;margin-right:5px}@media only screen and (max-width: 37.438em){.reply__pending-label{float:none;margin:;position:absolute;right:;top:22px}}.reply--unapproved .reply__publish-time .reply__pending-label{display:none}@media only screen and (max-width: 37.438em){.reply--unapproved .reply__publish-time .reply__pending-label{color:black;position:static;font-size:13px;margin-left:5px;display:inline-block}}.reply__content{-webkit-box-flex:1;-moz-flex:1 1 1px;-ms-flex:1 1 1px;flex:1 1 1px;-webkit-box-ordinal-group:2;-moz-order:1;-ms-flex-order:1;order:1;max-width:636px;position:relative;padding-left:5px}@media only screen and (max-width: 37.438em){.reply__content{-ms-flex-preferred-size:1%;flex-basis:1%;padding-left:}}.reply__content blockquote,.reply__content ol,.reply__content p,.reply__content ul{font-size:15px;line-height:28px;padding-bottom:.625rem}.reply__content>:last-child{padding-bottom:}@media only screen and (max-width: 37.438em){.reply__content{width:1%}}@media only screen and (max-width: 53.125em){.reply__content .has-video.has-video.media-large{margin:}}a.reply__count,a.reply__link{line-height:1;color:#aaa}a.reply__count span,a.reply__link span{color:#}a.reply__count .icon,a.reply__link .icon{margin-left:5px}a.reply__count:active,a.reply__count:focus,a.reply__count:hover,a.reply__link:active,a.reply__link:focus,a.reply__link:hover{color:#aaa;text-decoration:none}.reply__link{margin-left:6.5px;position:relative}@media only screen and (max-width: 37.438em){.reply-disabled,.reply__content p,.reply__header{padding-left:1.125rem;padding-right:1.125rem}}@-webkit-keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}@keyframes kinja-slide-wiggle{5%{-webkit-transform:translate3d(-1%, , );transform:translate3d(-1%, , )}8%{-webkit-transform:translate3d(%, , );transform:translate3d(%, , )}}.kinja-slide{-webkit-transition-timing-function:cubic-bezier(.25, .1, .25, 1);transition-timing-function:cubic-bezier(.25, .1, .25, 1)}.kinja-slide__container{width:1%;padding-bottom:66.6666%;position:relative}.kinja-slide__container--wide{padding-bottom:56.25%}@media only screen and (max-width: 37.438em){.kinja-slide--ad .kinja-slide__container{padding-bottom:18px}}.kinja-slide__image-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;background:#;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}@media only screen and (max-width: 37.438em){.kinja-slide__image-container{background:#333}}.kinja-slide__image{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-sizing:border-box;box-sizing:border-box;position:absolute;left:;top:;right:;bottom:;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden}.kinja-slide__image,.kinja-slide__image img{-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none}.kinja-slide__image img{max-width:1%;max-height:1%;-ms-flex-item-align:center;align-self:center;position:relative;-o-object-fit:contain;object-fit:contain}.kinja-slide__image.kinja-slide__image.kinja-slide__image.kinja-slide__image{width:auto}.kinja-slide__image--hidden{display:none}.kinja-slide__blur-background{background-size:cover;background-position:center center;-webkit-filter:blur(3px);filter:blur(3px);position:absolute;width:12%;height:12%;opacity:.6}.kinja-slide__blur-background--hidden{display:none}@media only screen and (max-width: 37.438em){.kinja-slide__blur-background{display:none}}.kinja-slide__caption{color:#333;font-size:16px;line-height:21px;margin: auto;padding:18px;max-width:636px}@media only screen and (min-width: 37.5em){.kinja-slide__caption{padding:18px ;margin: 82px}}.kinja-slide .loading .container{background:#f5f5f5}.kinja-slide__ad-container{-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-sizing:border-box;box-sizing:border-box;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;overflow:hidden;-webkit-user-select:none;-moz-user-select:none;-ms-user-select:none;user-select:none;color:#aaa;font-size:14px;font-weight:bold;line-height:17px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-container{background:#333;position:absolute;left:;top:;right:;bottom:}}.kinja-slide__ad-container .ad-container{width:3px;height:25px;background-color:#fff}.kinja-slide__ad-label{margin-bottom:5px;margin-top:15px;text-transform:uppercase}.kinja-slide__ad-buttons{display:-webkit-box;display:-ms-flexbox;display:flex;margin-top:1px;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;width:3px}@media only screen and (min-width: 37.5em){.kinja-slide__ad-buttons{display:none}}.kinja-slide.wiggle .kinja-slide__caption,.kinja-slide.wiggle .kinja-slide__container{-webkit-animation:kinja-slide-wiggle .6s ease-in-out both;animation:kinja-slide-wiggle .6s ease-in-out both}.kinja-slideshow{margin-bottom:2px;position:relative;overflow:hidden;background-color:#f5f5f5;font-family:"ProximaNovaCond",sans-serif}.kinja-slideshow__deck{display:-webkit-box;display:-ms-flexbox;display:flex}.kinja-slideshow .kinja-slide{width:1%;position:relative;-webkit-box-flex:;-ms-flex: 1%;flex: 1%}.kinja-slideshow__navigate-left.button{display:none;position:absolute;top:2px;margin-top:66.6666%;left:2px}.kinja-slideshow__navigate-left.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-left.button{display:inherit}}.kinja-slideshow__navigate-right.button{display:none;position:absolute;top:2px;margin-top:66.6666%;right:2px}.kinja-slideshow__navigate-right.button .svg-icon{stroke:#666}@media only screen and (min-width: 37.5em){.kinja-slideshow__navigate-right.button{display:inherit}}.kinja-slideshow--wide .kinja-slideshow__navigate-left,.kinja-slideshow--wide .kinja-slideshow__navigate-right{margin-top:56.25%}.kinja-slideshow__index{padding: 18px 15px;max-width:636px;margin: auto;font-size:16px;line-height:21px;font-weight:normal;color:#aaa}.kinja-slideshow__index .svg-icon{margin-right:3px}@media only screen and (min-width: 37.5em){.kinja-slideshow__index{padding: 15px;margin: 82px}}.reviewbox-inset{clear:left}.reviewbox-inset .review-box__head-content-wrapper{display:none}@media only screen and (min-width: 37.5em){.reviewbox-inset.align--left .review-box{width:32px;margin:}}.reviewbox-inset.align--left .review-box__head-content{display:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box{max-width:1%}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head{position:relative;display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:left;-ms-flex-align:left;align-items:left;padding-left:64%}}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{position:relative;display:block;width:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:before{content:"";width:1px;margin-left:-1px;float:left;height:;padding-top:1%}.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper:after{content:"";display:table;clear:both}@media only screen and (max-width: 53.125em){.reviewbox-inset.align--fullbleed .review-box__head-content-wrapper{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__head-content{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-flex:1;-ms-flex-positive:1;flex-grow:1;-webkit-box-orient:vertical;-webkit-box-direction:normal;-ms-flex-direction:column;flex-direction:column;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;max-width:1%;padding:15px}.reviewbox-inset.align--fullbleed .review-box__head-content .review-score{position:unset;margin: auto;background:#fff;border-color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content .review-box__title{color:#fff}.reviewbox-inset.align--fullbleed .review-box__head-content:not(.review-box__head-content--visually-hidden){position:absolute;top:;right:;bottom:;left:}.reviewbox-inset.align--fullbleed .review-box__head-content--visually-hidden{visibility:hidden}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image-wrapper{-ms-flex-preferred-size:64%;flex-basis:64%;padding-top:36%;padding:;position:absolute;width:64%;top:;left:;right:36%;bottom:;height:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__image{position:absolute;top:-9999px;right:-9999px;bottom:-9999px;left:-9999px;min-height:1%;max-width:none;width:auto;margin:auto}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__content .review-box__title,.reviewbox-inset.align--fullbleed .review-box__content .review-score,.reviewbox-inset.align--fullbleed .review-box__content--nodata{display:none}}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .review-box__data-wrapper:not(.review-box__data-wrapper--single){-webkit-column-count:2;column-count:2;-webkit-column-gap:3px;column-gap:3px}}.reviewbox-inset.align--fullbleed .review-box__data-item{-webkit-column-break-inside:avoid;break-inside:avoid;page-break-inside:avoid}.reviewbox-inset.align--fullbleed .review-box__data-label,.reviewbox-inset.align--fullbleed .review-box__data-value{max-width:none}@media only screen and (min-width: 53.126em){.reviewbox-inset.align--fullbleed .storytype-label-wrapper--top{display:none}}.reviewbox-inset.align--fullbleed .storytype-label-wrapper--head{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;margin-bottom:2px}.review-box{margin:3px auto;max-width:47px;width:1%}.review-inset-editor .review-box{width:32px}.review-box__tag-wrapper{max-width:1%;height:26px;margin-bottom:1px}.review-box__tag-wrapper,.review-box__tag{display:-webkit-box;display:-ms-flexbox;display:flex}.review-box__tag{height:1%;padding:5px 5px 5px 7px;-webkit-box-flex:;-ms-flex: auto;flex: auto;overflow:hidden;font-family:"ProximaNovaCond",sans-serif;font-size:15px;line-height:18px;background-color:#93ec;-webkit-transition:background-color .1s ease-out;transition:background-color .1s ease-out}.review-box__tag:first-child{-webkit-box-flex:;-ms-flex: 1 auto;flex: 1 auto}.review-box__tag:first-child .review-box__text{white-space:nowrap;overflow:hidden;text-overflow:ellipsis}.review-box__tag:hover{text-decoration:none;background-color:#73b9}.review-box__tag:not:)last-child){margin-right:1px}.review-box__tag .svg-icon.small{min-width:1px;height:1%;-ms-flex-item-align:end;align-self:flex-end;stroke:#fff;opacity:1}.review-box__text{margin-right:5px;color:#fff;text-transform:uppercase}.review-box__image-wrapper{position:relative;height:;padding-top:56.25%}.review-box__image-container{width:1%;overflow:hidden;position:absolute;top:;right:;bottom:;left:}.review-box__image-container .spinner.bounce{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;-webkit-box-align:center;-ms-flex-align:center;align-items:center;width:1%;height:1%;background-color:#e5e5e5}.review-box__image{width:1%}.review-box__head-content-wrapper{display:none}.review-box__content{position:relative;padding:15px 15px 15px;background-color:#f5f5f5}.review-box__content--nodata{padding:15px}.review-box__content--nodata .review-box__title{margin-bottom:}.review-box__content--nodata .review-box__data-wrapper{display:none}.review-box__title{margin-bottom:15px;font-size:24px;line-height:28px;text-align:center}.review-box__title:last-child{margin-bottom:}.review-box__data-item{padding-bottom:15px}.review-box__data-label{margin-bottom:;font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:normal;line-height:28px;color:#666;text-transform:uppercase}.review-box__data-value{font-family:"ElizabethSerif",Georgia,serif;color:#222;margin-bottom:}.post-content .review-box__data-value,.dui-modal .review-box__data-value{font-size:15px;line-height:28px}.review-score{display:-webkit-box;display:-ms-flexbox;display:flex;-webkit-box-align:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;width:48px;height:48px;margin: auto 15px;border:2px solid #f5f5f5;border-radius:5%;font-family:"ProximaNovaCond",sans-serif;font-size:24px;line-height:24px;color:#fff;background-color:#333}.review-score--img{margin:;position:absolute;top:-38px;left:calc(5% - 24px)}.review-score--small{font-size:19px;line-height:19px;height:36px;width:36px}@media only screen and (min-width: 37.5em){.review-score--small-on-medium-up{font-size:19px;line-height:19px;height:36px;width:36px}}.postlist__item--compact .asset,.postlist__item .asset,.storytype--section .item__image{position:relative}.postlist__item--compact .asset .review-score,.postlist__item .asset .review-score,.storytype--section .item__image .review-score{margin:;position:absolute;left:1px;top:1px;z-index:1}@media only screen and (min-width: 37.5em){.postlist__item .asset .review-score{left:28px}}.branded-item .headline a{color:# !important}.branded-item .inset--story__thumb figure,.branded-item.item .image__wrapper{border-bottom:5px solid transparent}.branded-item .gmg-avatar{width:2px;position:absolute;bottom:-5px;left:}.branded-item .inset--story__readmore{display:inline-block}.branded-item--deadspin .inset--story__thumb figure,.branded-item--deadspin.item .image__wrapper{border-bottom-color:#1b3a4d}.branded-item--deadspin .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #3d84af;box-shadow:inset -2px #3d84af;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--deadspin .inset--story__readmore:hover{color:#1b3a4d;text-decoration:none}.branded-item--earther .inset--story__thumb figure,.branded-item--earther.item .image__wrapper{border-bottom-color:#75b2}.branded-item--earther .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--earther .inset--story__readmore:hover{color:#75b2;text-decoration:none}.branded-item--fusion .inset--story__thumb figure,.branded-item--fusion.item .image__wrapper{border-bottom-color:#4e}.branded-item--fusion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #7ae8ff;box-shadow:inset -2px #7ae8ff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--fusion .inset--story__readmore:hover{color:#caf4;text-decoration:none}.branded-item--gizmodo .inset--story__thumb figure,.branded-item--gizmodo.item .image__wrapper{border-bottom-color:#18afed}.branded-item--gizmodo .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #93daf7;box-shadow:inset -2px #93daf7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--gizmodo .inset--story__readmore:hover{color:#18afed;text-decoration:none}.branded-item--jalopnik .inset--story__thumb figure,.branded-item--jalopnik.item .image__wrapper{border-bottom-color:#ff4d}.branded-item--jalopnik .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffaa85;box-shadow:inset -2px #ffaa85;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jalopnik .inset--story__readmore:hover{color:#ff4d;text-decoration:none}.branded-item--jezebel .inset--story__thumb figure,.branded-item--jezebel.item .image__wrapper{border-bottom-color:#ec1238}.branded-item--jezebel .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--jezebel .inset--story__readmore:hover{color:#ec1238;text-decoration:none}.branded-item--kotaku .inset--story__thumb figure,.branded-item--kotaku.item .image__wrapper{border-bottom-color:#fbc}.branded-item--kotaku .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--kotaku .inset--story__readmore:hover{color:#fbc;text-decoration:none}.branded-item--lifehacker .inset--story__thumb figure,.branded-item--lifehacker.item .image__wrapper{border-bottom-color:#94b33}.branded-item--lifehacker .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #cbdf88;box-shadow:inset -2px #cbdf88;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--lifehacker .inset--story__readmore:hover{color:#94b33;text-decoration:none}.branded-item--theonion .inset--story__thumb figure,.branded-item--theonion.item .image__wrapper{border-bottom-color:#6b3a}.branded-item--theonion .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #f82;box-shadow:inset -2px #f82;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theonion .inset--story__readmore:hover{color:#6b3a;text-decoration:none}.branded-item--theroot .inset--story__thumb figure,.branded-item--theroot.item .image__wrapper{border-bottom-color:#59b22}.branded-item--theroot .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--theroot .inset--story__readmore:hover{color:#59b22;text-decoration:none}.branded-item--splinter .inset--story__thumb figure,.branded-item--splinter.item .image__wrapper{border-bottom-color:#f85637}.branded-item--splinter .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--splinter .inset--story__readmore:hover{color:#f85637;text-decoration:none}.branded-item--avclub .inset--story__thumb figure,.branded-item--avclub.item .image__wrapper{border-bottom-color:#1c263c}.branded-item--avclub .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #465f96;box-shadow:inset -2px #465f96;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--avclub .inset--story__readmore:hover{color:#1c263c;text-decoration:none}.branded-item--thetakeout .inset--story__thumb figure,.branded-item--thetakeout.item .image__wrapper{border-bottom-color:#E5371A}.branded-item--thetakeout .inset--story__readmore{color:#;-webkit-box-shadow:inset -2px #fef7dd;box-shadow:inset -2px #fef7dd;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;line-height:18px}.branded-item--thetakeout .inset--story__readmore:hover{color:#F9DB5D;text-decoration:none}.f_branding_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on .post-content .quotable a,.f_branding_on .post-content footer a,.f_branding_on .post-content h1 a,.f_branding_on .post-content h2 a,.f_branding_on .post-content h3 a,.f_branding_on .post-content h4 a,.f_branding_on .post-content h5 a,.f_branding_on .post-content h6 a,.f_branding_on .post-content li a,.f_branding_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on .post-content .quotable a:hover,.f_branding_on .post-content footer a:hover,.f_branding_on .post-content h1 a:hover,.f_branding_on .post-content h2 a:hover,.f_branding_on .post-content h3 a:hover,.f_branding_on .post-content h4 a:hover,.f_branding_on .post-content h5 a:hover,.f_branding_on .post-content h6 a:hover,.f_branding_on .post-content li a:hover,.f_branding_on .post-content p a:hover,.f_branding_on figcaption a{color:#93ec}.f_branding_on figcaption a:hover{color:#73b9}.f_branding_on .editor-inner.post-content blockquote,.f_branding_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on .editor-inner.post-content blockquote p,.f_branding_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on .editor-inner.post-content .pullquote:before,.f_branding_on .entry-content .pullquote:before,.f_branding_on .editor-inner.post-content .pullquote:after,.f_branding_on .entry-content .pullquote:after{border:}.f_branding_on .editor-inner.post-content .pullquote__content,.f_branding_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on .editor-inner.post-content .pullquote.align--center,.f_branding_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on .storybreak-branded-a,.f_branding_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on .review-score,.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#333}.f_branding_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#333}.f_branding_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on .author-bio__name{color:#222}.f_branding_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-deadspin.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_deadspin_on.f_article_split_on .scroll-list-break{border-top:3px solid #2d9d92}.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#1b3a4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-deadspin .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_deadspin_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-deadspin .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_deadspin_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-deadspin .post-content .quotable a,.f_branding_on .blog-group-deadspin .post-content .quotable a,.f_branding_on.blog-group-deadspin .post-content footer a,.f_branding_on .blog-group-deadspin .post-content footer a,.f_branding_on.blog-group-deadspin .post-content h1 a,.f_branding_on .blog-group-deadspin .post-content h1 a,.f_branding_on.blog-group-deadspin .post-content h2 a,.f_branding_on .blog-group-deadspin .post-content h2 a,.f_branding_on.blog-group-deadspin .post-content h3 a,.f_branding_on .blog-group-deadspin .post-content h3 a,.f_branding_on.blog-group-deadspin .post-content h4 a,.f_branding_on .blog-group-deadspin .post-content h4 a,.f_branding_on.blog-group-deadspin .post-content h5 a,.f_branding_on .blog-group-deadspin .post-content h5 a,.f_branding_on.blog-group-deadspin .post-content h6 a,.f_branding_on .blog-group-deadspin .post-content h6 a,.f_branding_on.blog-group-deadspin .post-content li a,.f_branding_on .blog-group-deadspin .post-content li a,.f_branding_on.blog-group-deadspin .post-content p a,.f_branding_on .blog-group-deadspin .post-content p a,.f_branding_on.f_branding_deadspin_on .post-content .quotable a,.f_branding_on.f_branding_deadspin_on .post-content footer a,.f_branding_on.f_branding_deadspin_on .post-content h1 a,.f_branding_on.f_branding_deadspin_on .post-content h2 a,.f_branding_on.f_branding_deadspin_on .post-content h3 a,.f_branding_on.f_branding_deadspin_on .post-content h4 a,.f_branding_on.f_branding_deadspin_on .post-content h5 a,.f_branding_on.f_branding_deadspin_on .post-content h6 a,.f_branding_on.f_branding_deadspin_on .post-content li a,.f_branding_on.f_branding_deadspin_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #77d8ce;box-shadow:inset -2px #77d8ce;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-deadspin .post-content .quotable a:hover,.f_branding_on .blog-group-deadspin .post-content .quotable a:hover,.f_branding_on.blog-group-deadspin .post-content footer a:hover,.f_branding_on .blog-group-deadspin .post-content footer a:hover,.f_branding_on.blog-group-deadspin .post-content h1 a:hover,.f_branding_on .blog-group-deadspin .post-content h1 a:hover,.f_branding_on.blog-group-deadspin .post-content h2 a:hover,.f_branding_on .blog-group-deadspin .post-content h2 a:hover,.f_branding_on.blog-group-deadspin .post-content h3 a:hover,.f_branding_on .blog-group-deadspin .post-content h3 a:hover,.f_branding_on.blog-group-deadspin .post-content h4 a:hover,.f_branding_on .blog-group-deadspin .post-content h4 a:hover,.f_branding_on.blog-group-deadspin .post-content h5 a:hover,.f_branding_on .blog-group-deadspin .post-content h5 a:hover,.f_branding_on.blog-group-deadspin .post-content h6 a:hover,.f_branding_on .blog-group-deadspin .post-content h6 a:hover,.f_branding_on.blog-group-deadspin .post-content li a:hover,.f_branding_on .blog-group-deadspin .post-content li a:hover,.f_branding_on.blog-group-deadspin .post-content p a:hover,.f_branding_on .blog-group-deadspin .post-content p a:hover,.f_branding_on.f_branding_deadspin_on .post-content .quotable a:hover,.f_branding_on.f_branding_deadspin_on .post-content footer a:hover,.f_branding_on.f_branding_deadspin_on .post-content h1 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h2 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h3 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h4 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h5 a:hover,.f_branding_on.f_branding_deadspin_on .post-content h6 a:hover,.f_branding_on.f_branding_deadspin_on .post-content li a:hover,.f_branding_on.f_branding_deadspin_on .post-content p a:hover,.f_branding_on.blog-group-deadspin figcaption a,.f_branding_on .blog-group-deadspin figcaption a,.f_branding_on.f_branding_deadspin_on figcaption a{color:#2d9d92}.f_branding_on.blog-group-deadspin figcaption a:hover,.f_branding_on .blog-group-deadspin figcaption a:hover,.f_branding_on.f_branding_deadspin_on figcaption a:hover{color:#22756d}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote,.f_branding_on.blog-group-deadspin .entry-content blockquote,.f_branding_on .blog-group-deadspin .entry-content blockquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_deadspin_on .entry-content blockquote{border-radius:;border-left:5px solid #1b3a4d;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on .blog-group-deadspin .editor-inner.post-content blockquote p,.f_branding_on.blog-group-deadspin .entry-content blockquote p,.f_branding_on .blog-group-deadspin .entry-content blockquote p,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_deadspin_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-deadspin .entry-content .pullquote__content,.f_branding_on .blog-group-deadspin .entry-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-deadspin .review-score,.f_branding_on .blog-group-deadspin .review-score,.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_deadspin_on .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1b3a4d}.f_branding_on.blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-deadspin .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_deadspin_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1b3a4d}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white){color:#2d9d92;border-color:#2d9d92}.f_branding_on.blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-deadspin .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_deadspin_on .storytype-label:not(.storytype-label--white):hover{color:#22756d;border-color:#22756d}.f_branding_on.blog-group-deadspin .author-bio__name,.f_branding_on .blog-group-deadspin .author-bio__name,.f_branding_on.f_branding_deadspin_on .author-bio__name{color:#222}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name){color:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#2d9d92}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover{color:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#22756d}.f_branding_on.blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-deadspin .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_deadspin_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#22756d}.f_branding_on.blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-deadspin .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_deadspin_on .sidebar-content .newsletter-subscribe{border-color:#1b3a4d}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote,.f_branding_on.blog-group-deadspin .entry-content .pullquote,.f_branding_on .blog-group-deadspin .entry-content .pullquote,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote{border-top:1px solid #1b3a4d;border-bottom:1px solid #1b3a4d;padding:3px ;position:relative;color:#1b3a4d;font-size:22px;line-height:32px;font-weight:bold;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on .blog-group-deadspin .entry-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{height:4px;width:26px;position:absolute;left:calc(5% - 13px);background-image:url('data:image/svg+xml;utf8,<svg xmlns="http://www.w3.org/2/svg" width="26" height="4" viewBox=" 26 4"><title>deadspin-quote-carrot-aligned-w-bgr-2<\/title><path d="M1,3.5l3-3,3,3Z" style="fill:%23fff;stroke:%23fff"/><path d="M,3.5H1l3-3,3,3H26" style="fill:none;stroke:%231b3a4d"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:before{top:-4px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote:after{bottom:-4px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;width:1%}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child{top:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child{bottom:6px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{display:block;content:'';height:9px;width:18px;position:absolute;top:-1px;background-color:#fff}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:before{left:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:after{right:}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{top:-2px}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{background-image:url('data:image/svg+xml;utf8,<svg width="19" height="9" viewBox=" 19 9" xmlns="http://www.w3.org/2/svg"><title>deadspin-quote-topleft<\/title><path d="M.5 8.5c-4.43 3.655-8.54 8-8h1" stroke="%231B3A4D" fill="none" stroke-linecap="square" stroke-linejoin="round"/><\/svg>')}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:first-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:first-child:after{-webkit-transform:scaleX(-1);transform:scaleX(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:before,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:before{-webkit-transform:scaleY(-1);transform:scaleY(-1)}.f_branding_on.blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on .blog-group-deadspin .entry-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .editor-inner.post-content .pullquote .pullquote__helper:last-child:after,.f_branding_on.f_branding_deadspin_on .entry-content .pullquote .pullquote__helper:last-child:after{-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-deadspin .storybreak-branded-a,.f_branding_on .blog-group-deadspin .storybreak-branded-a,.f_branding_on.f_branding_deadspin_on .storybreak-branded-a{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>diamond-blue<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%231B3A4D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-deadspin .storybreak-branded-b,.f_branding_on .blog-group-deadspin .storybreak-branded-b,.f_branding_on.f_branding_deadspin_on .storybreak-branded-b{min-width:49px;height:14px;background-image:url('data:image/svg+xml;utf8,<svg width="49" height="14" viewBox=" 49 14" xmlns="http://www.w3.org/2/svg"><title>deadspin-diamond-teal<\/title><path d="M 6.75l3.914 4.13 3.96-4.6L3.96 2.69M24.282 l-6.6 6.767 6.523 6.688 6.6-6.767m9.882.62l3.914 4.13 3.96-4.6-3.91-4.13" fill="%23249D9D" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote,.f_branding_on.blog-group-earther .entry-content .pullquote,.f_branding_on .blog-group-earther .entry-content .pullquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_earther_on .entry-content .pullquote{border-top:none;border-bottom:none;padding:3px;position:relative;font-size:22px;line-height:32px;text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-earther .entry-content .pullquote.align--left,.f_branding_on .blog-group-earther .entry-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{height:3px;width:3px;position:absolute;background-image:url('data:image/svg+xml;utf8,<svg width="3" height="3" viewBox=" 4 4" xmlns="http://www.w3.org/2/svg"><title>pq-earther<\/title><path d="M4 h36v8H8v32HVh4z" fill="%2375B2" fill-rule="evenodd"/><\/svg>');margin:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before{top:;left:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{bottom:;right:;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-a{min-width:26px;height:26px;background-image:url('data:image/svg+xml;utf8,<svg width="26" height="26" viewBox=" 26 26" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-a<\/title><g stroke="%2375B2" fill="none" fill-rule="evenodd" stroke-linejoin="round"><path d="M21.292 21.292c-4.757 4.757-12.47 4.756-17.225 -4.756-4.757-4.756-12.47 -17.225 4.757-4.756 12.47-4.756 17.225 4.756 4.757 4.756 12.47 17.225z"/><path d="M21.69 2.988c-3.98 2.526-1.537 1.65-14.767-2.578C2.69 14.177 1.857 8.238 4.67 3.655"/><path d="M22.75 14.657c-2.53 2.5-7.226 1.83-1.55-1.494C8.88 9.84 8.215 5.117 1.718 2.617c2.54-2.5 7.227-1.83 1.55 1.494 3.323 3.33 3.987 8.5 1.484 1.55z" stroke-width="1.77"/><path d="M2.294 9.234c-.793.793-2.37.5-3.524-.654s-1.447-2.732-.654-3.525c.792-.793 2.37-.5 3.524.654 1.154 1.15 1.446 2.73.654 3.52zm-.2.17c2.69 4.38 1.677 1.43-1.856 13.964M2.14 6.963c3.567-3.566 9.973-5.35 13.926-2.225m4.456 2.548c1.473.93 2.75.523 3.745 1.32m-6.7-3.77c-.11-1.416-.534-2.646-1.31-3.61"/><path d="M18.852 9.85c-.55 2.345-2.5 6.53-4.95 8.998-2.427 2.428-4.818 3.666-6.967 4.52m-4.512-4.512c.846-2.16 1.646-4.94 4.98-7.39 2.95-2.945 6.66-3.93 9.1-4.478"/><\/g><\/svg>')}.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-b{min-width:25px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="25" height="25" viewBox=" 25 25" xmlns="http://www.w3.org/2/svg"><title>earther-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path d="M24.398 12.438c 6.63-5.374 12.4-12.4 12.4S.39 19.68.39 12.438 5.765.434 12.394.434c6.63 12.4 5.375 12.4 12.4" fill="%2375B2"/><path d="M 12.32h24.64M12.32 v24.42m8.74-2.818L3.73 2.932M3.727 3.596l17.336 17.34m-1.358-8.67c 4.37-3.273 7.31-7.31 7.31-4.37 -7.31-3.273-7.31-7.31 -4.37 3.273-7.31 7.31-7.31 4.37 7.31 3.273 7.31 7.31z" stroke="%23FFF" stroke-width=".88"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-gizmodo.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_gizmodo_on.f_article_split_on .scroll-list-break{border-top:3px solid #93ec}.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#93ec;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-gizmodo .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_gizmodo_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-gizmodo .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-gizmodo .post-content .quotable a,.f_branding_on .blog-group-gizmodo .post-content .quotable a,.f_branding_on.blog-group-gizmodo .post-content footer a,.f_branding_on .blog-group-gizmodo .post-content footer a,.f_branding_on.blog-group-gizmodo .post-content h1 a,.f_branding_on .blog-group-gizmodo .post-content h1 a,.f_branding_on.blog-group-gizmodo .post-content h2 a,.f_branding_on .blog-group-gizmodo .post-content h2 a,.f_branding_on.blog-group-gizmodo .post-content h3 a,.f_branding_on .blog-group-gizmodo .post-content h3 a,.f_branding_on.blog-group-gizmodo .post-content h4 a,.f_branding_on .blog-group-gizmodo .post-content h4 a,.f_branding_on.blog-group-gizmodo .post-content h5 a,.f_branding_on .blog-group-gizmodo .post-content h5 a,.f_branding_on.blog-group-gizmodo .post-content h6 a,.f_branding_on .blog-group-gizmodo .post-content h6 a,.f_branding_on.blog-group-gizmodo .post-content li a,.f_branding_on .blog-group-gizmodo .post-content li a,.f_branding_on.blog-group-gizmodo .post-content p a,.f_branding_on .blog-group-gizmodo .post-content p a,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a,.f_branding_on.f_branding_gizmodo_on .post-content footer a,.f_branding_on.f_branding_gizmodo_on .post-content h1 a,.f_branding_on.f_branding_gizmodo_on .post-content h2 a,.f_branding_on.f_branding_gizmodo_on .post-content h3 a,.f_branding_on.f_branding_gizmodo_on .post-content h4 a,.f_branding_on.f_branding_gizmodo_on .post-content h5 a,.f_branding_on.f_branding_gizmodo_on .post-content h6 a,.f_branding_on.f_branding_gizmodo_on .post-content li a,.f_branding_on.f_branding_gizmodo_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #72caff;box-shadow:inset -2px #72caff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on .blog-group-gizmodo .post-content .quotable a:hover,.f_branding_on.blog-group-gizmodo .post-content footer a:hover,.f_branding_on .blog-group-gizmodo .post-content footer a:hover,.f_branding_on.blog-group-gizmodo .post-content h1 a:hover,.f_branding_on .blog-group-gizmodo .post-content h1 a:hover,.f_branding_on.blog-group-gizmodo .post-content h2 a:hover,.f_branding_on .blog-group-gizmodo .post-content h2 a:hover,.f_branding_on.blog-group-gizmodo .post-content h3 a:hover,.f_branding_on .blog-group-gizmodo .post-content h3 a:hover,.f_branding_on.blog-group-gizmodo .post-content h4 a:hover,.f_branding_on .blog-group-gizmodo .post-content h4 a:hover,.f_branding_on.blog-group-gizmodo .post-content h5 a:hover,.f_branding_on .blog-group-gizmodo .post-content h5 a:hover,.f_branding_on.blog-group-gizmodo .post-content h6 a:hover,.f_branding_on .blog-group-gizmodo .post-content h6 a:hover,.f_branding_on.blog-group-gizmodo .post-content li a:hover,.f_branding_on .blog-group-gizmodo .post-content li a:hover,.f_branding_on.blog-group-gizmodo .post-content p a:hover,.f_branding_on .blog-group-gizmodo .post-content p a:hover,.f_branding_on.f_branding_gizmodo_on .post-content .quotable a:hover,.f_branding_on.f_branding_gizmodo_on .post-content footer a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h1 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h2 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h3 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h4 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h5 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content h6 a:hover,.f_branding_on.f_branding_gizmodo_on .post-content li a:hover,.f_branding_on.f_branding_gizmodo_on .post-content p a:hover,.f_branding_on.blog-group-gizmodo figcaption a,.f_branding_on .blog-group-gizmodo figcaption a,.f_branding_on.f_branding_gizmodo_on figcaption a{color:#93ec}.f_branding_on.blog-group-gizmodo figcaption a:hover,.f_branding_on .blog-group-gizmodo figcaption a:hover,.f_branding_on.f_branding_gizmodo_on figcaption a:hover{color:#73b9}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote,.f_branding_on.blog-group-gizmodo .entry-content blockquote,.f_branding_on .blog-group-gizmodo .entry-content blockquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote{border-radius:;border-left:5px solid #93ec;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on .blog-group-gizmodo .editor-inner.post-content blockquote p,.f_branding_on.blog-group-gizmodo .entry-content blockquote p,.f_branding_on .blog-group-gizmodo .entry-content blockquote p,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_gizmodo_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before,.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on .blog-group-gizmodo .entry-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-gizmodo .review-score,.f_branding_on .blog-group-gizmodo .review-score,.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_gizmodo_on .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#93ec}.f_branding_on.blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-gizmodo .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_gizmodo_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white){color:#93ec;border-color:#93ec}.f_branding_on.blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-gizmodo .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_gizmodo_on .storytype-label:not(.storytype-label--white):hover{color:#73b9;border-color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio__name,.f_branding_on .blog-group-gizmodo .author-bio__name,.f_branding_on.f_branding_gizmodo_on .author-bio__name{color:#222}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name){color:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#93ec}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover{color:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#73b9}.f_branding_on.blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-gizmodo .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_gizmodo_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#73b9}.f_branding_on.blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-gizmodo .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_gizmodo_on .sidebar-content .newsletter-subscribe{border-color:#93ec}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote,.f_branding_on.blog-group-gizmodo .entry-content .pullquote,.f_branding_on .blog-group-gizmodo .entry-content .pullquote,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote{border-top:2px solid #18afed;border-bottom:2px solid #18afed;padding-top:3px;padding-bottom:3px;position:relative}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:before{height:42px;width:42px;position:absolute;left:calc(5% - 21px);top:-21px;background-image:url('data:image/svg+xml;utf8,<svg width="42" height="42" viewBox=" 42 42" xmlns="http://www.w3.org/2/svg"><title>gizmodo-quote<\/title><g fill="none" fill-rule="evenodd"><path d="M41.95 2.974c 11.583-9.392 2.974-2.976 2.974S 32.558 2.974 9.39 2.974 41.95 9.39 41.95 2.974" fill="%2318AFED"/><path d="M21.8 21.422c-6.874 3.744-9.434 9.622-9.623l.76 3.46c-3.178.38-4.74 1.894-4.647 4.453h3.51l-.2 9.245H21.8v-7.54zm-12.562 c-6.874 3.697-9.434 9.622-9.623l.71 3.46c-3.175.38-4.74 1.894-4.597 4.453h3.58l.4 9.245H9.238v-7.54z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on .blog-group-gizmodo .entry-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on .blog-group-gizmodo .entry-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_gizmodo_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-gizmodo .storybreak-branded-a,.f_branding_on .blog-group-gizmodo .storybreak-branded-a,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-a{min-width:33px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="12" viewBox=" 33 12" xmlns="http://www.w3.org/2/svg"><title>gizmodo-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2318AFED" d="M11 12h11VH11"/><path fill="%23" d="M 12h11VHm22 12h11VH22"/><\/g><\/svg>')}.f_branding_on.blog-group-gizmodo .storybreak-branded-b,.f_branding_on .blog-group-gizmodo .storybreak-branded-b,.f_branding_on.f_branding_gizmodo_on .storybreak-branded-b{min-width:111px;height:25px;background-image:url('data:image/svg+xml;utf8,<svg width="111" height="25" viewBox=" 111 25" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>gizmodo-plots<\/title><defs><path id="a" d="M 5V.324h4.676V5Hz"/><path id="c" d="M4.985.26v4.8H.977V.26h4.8z"/><path id="e" d="M.398.842H3.7v2.672H.398V.842z"/><\/defs><g fill="none" fill-rule="evenodd"><path stroke="%2318AFED" stroke-width=".445" d="M34.61 19.42L1.762 21.857l9.583-18.2 22.69 15.63L44.157 1.372l1.73 1.52 18.44 9.124 3.855-14.23"/><g transform="translate( 19.158)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M4.67 2.516c.84 1.29-.896 2.4-2.184 2.48-1.29.8-2.4-.9-2.48-2.188-.8-1.29.898-2.4 2.188-2.48C3.48.25 4.59 1.23 4.67 2.518" fill="%2318AFED" mask="url(%23b)"/><\/g><path d="M13.587 3.714c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m43.543 8.38c.6.92-.64 1.713-1.56 1.77-.922.6-1.715-.64-1.772-1.56-.58-.922.64-1.715 1.562-1.772.92-.58 1.713.64 1.77 1.562m42.882-7.84c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562m-25.368 16.46c.58.92-.642 1.713-1.562 1.77-.92.6-1.714-.64-1.77-1.56-.6-.922.64-1.715 1.56-1.772.92-.58 1.714.64 1.772 1.562M79.36 6.625c.7 1.15-.77 2.56-1.874 2.125-1.15.7-2.56-.77-2.125-1.875-.66-1.14.77-2.56 1.878-2.125 1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED"/><g transform="translate(16 18.158)"><mask id="d" fill="%23fff"><use xlink-underline:href="%23c"/><\/mask><path d="M4.98 2.14c.7 1.14-.77 2.55-1.874 2.124C2 4.334 1.5 3.494.98 2.39.91 1.284 1.75.332 2.857.263c1.14-.7 2.56.77 2.125 1.875" fill="%2318AFED" mask="url(%23d)"/><\/g><path d="M36.61 19.296c.7 1.15-.77 2.56-1.875 2.125-1.15.7-2.56-.77-2.125-1.872-.7-1.14.77-2.56 1.875-2.125 1.14-.68 2.56.77 2.125 1.876" fill="%2318AFED"/><g transform="translate(43 -.842)"><mask id="f" fill="%23fff"><use xlink-underline:href="%23e"/><\/mask><path d="M3.67 2.95c.46.735-.514 1.37-1.25 1.416C1.8 3.56.447 3 .4 2.265.354 1.524.914.89 1.65.844c.737-.46 1.37.514 1.417 1.25" fill="%2318AFED" mask="url(%23f)"/><\/g><path d="M55.464 11.856L34.61 19.42m-32.272 2.4L44.734 1.336 77.36 6.75l32.24 13.83L97.985 3.574 72.977 2.512" stroke="%2318AFED" stroke-width=".445"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jalopnik.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jalopnik_on.f_article_split_on .scroll-list-break{border-top:3px solid #ff4d}.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ff4d;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jalopnik .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jalopnik_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jalopnik .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jalopnik .post-content .quotable a,.f_branding_on .blog-group-jalopnik .post-content .quotable a,.f_branding_on.blog-group-jalopnik .post-content footer a,.f_branding_on .blog-group-jalopnik .post-content footer a,.f_branding_on.blog-group-jalopnik .post-content h1 a,.f_branding_on .blog-group-jalopnik .post-content h1 a,.f_branding_on.blog-group-jalopnik .post-content h2 a,.f_branding_on .blog-group-jalopnik .post-content h2 a,.f_branding_on.blog-group-jalopnik .post-content h3 a,.f_branding_on .blog-group-jalopnik .post-content h3 a,.f_branding_on.blog-group-jalopnik .post-content h4 a,.f_branding_on .blog-group-jalopnik .post-content h4 a,.f_branding_on.blog-group-jalopnik .post-content h5 a,.f_branding_on .blog-group-jalopnik .post-content h5 a,.f_branding_on.blog-group-jalopnik .post-content h6 a,.f_branding_on .blog-group-jalopnik .post-content h6 a,.f_branding_on.blog-group-jalopnik .post-content li a,.f_branding_on .blog-group-jalopnik .post-content li a,.f_branding_on.blog-group-jalopnik .post-content p a,.f_branding_on .blog-group-jalopnik .post-content p a,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a,.f_branding_on.f_branding_jalopnik_on .post-content footer a,.f_branding_on.f_branding_jalopnik_on .post-content h1 a,.f_branding_on.f_branding_jalopnik_on .post-content h2 a,.f_branding_on.f_branding_jalopnik_on .post-content h3 a,.f_branding_on.f_branding_jalopnik_on .post-content h4 a,.f_branding_on.f_branding_jalopnik_on .post-content h5 a,.f_branding_on.f_branding_jalopnik_on .post-content h6 a,.f_branding_on.f_branding_jalopnik_on .post-content li a,.f_branding_on.f_branding_jalopnik_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #a1cde;box-shadow:inset -2px #a1cde;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on .blog-group-jalopnik .post-content .quotable a:hover,.f_branding_on.blog-group-jalopnik .post-content footer a:hover,.f_branding_on .blog-group-jalopnik .post-content footer a:hover,.f_branding_on.blog-group-jalopnik .post-content h1 a:hover,.f_branding_on .blog-group-jalopnik .post-content h1 a:hover,.f_branding_on.blog-group-jalopnik .post-content h2 a:hover,.f_branding_on .blog-group-jalopnik .post-content h2 a:hover,.f_branding_on.blog-group-jalopnik .post-content h3 a:hover,.f_branding_on .blog-group-jalopnik .post-content h3 a:hover,.f_branding_on.blog-group-jalopnik .post-content h4 a:hover,.f_branding_on .blog-group-jalopnik .post-content h4 a:hover,.f_branding_on.blog-group-jalopnik .post-content h5 a:hover,.f_branding_on .blog-group-jalopnik .post-content h5 a:hover,.f_branding_on.blog-group-jalopnik .post-content h6 a:hover,.f_branding_on .blog-group-jalopnik .post-content h6 a:hover,.f_branding_on.blog-group-jalopnik .post-content li a:hover,.f_branding_on .blog-group-jalopnik .post-content li a:hover,.f_branding_on.blog-group-jalopnik .post-content p a:hover,.f_branding_on .blog-group-jalopnik .post-content p a:hover,.f_branding_on.f_branding_jalopnik_on .post-content .quotable a:hover,.f_branding_on.f_branding_jalopnik_on .post-content footer a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h1 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h2 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h3 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h4 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h5 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content h6 a:hover,.f_branding_on.f_branding_jalopnik_on .post-content li a:hover,.f_branding_on.f_branding_jalopnik_on .post-content p a:hover,.f_branding_on.blog-group-jalopnik figcaption a,.f_branding_on .blog-group-jalopnik figcaption a,.f_branding_on.f_branding_jalopnik_on figcaption a{color:#417eb9}.f_branding_on.blog-group-jalopnik figcaption a:hover,.f_branding_on .blog-group-jalopnik figcaption a:hover,.f_branding_on.f_branding_jalopnik_on figcaption a:hover{color:#346493}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote,.f_branding_on.blog-group-jalopnik .entry-content blockquote,.f_branding_on .blog-group-jalopnik .entry-content blockquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote{border-radius:;border-left:5px solid #417eb9;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jalopnik .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jalopnik .entry-content blockquote p,.f_branding_on .blog-group-jalopnik .entry-content blockquote p,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jalopnik_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before,.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on .blog-group-jalopnik .entry-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on .blog-group-jalopnik .entry-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jalopnik .review-score,.f_branding_on .blog-group-jalopnik .review-score,.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jalopnik_on .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ff4d}.f_branding_on.blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jalopnik .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jalopnik_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ff4d}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white){color:#417eb9;border-color:#417eb9}.f_branding_on.blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jalopnik .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jalopnik_on .storytype-label:not(.storytype-label--white):hover{color:#346493;border-color:#346493}.f_branding_on.blog-group-jalopnik .author-bio__name,.f_branding_on .blog-group-jalopnik .author-bio__name,.f_branding_on.f_branding_jalopnik_on .author-bio__name{color:#222}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name){color:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#417eb9}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover{color:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#346493}.f_branding_on.blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jalopnik .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jalopnik_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#346493}.f_branding_on.blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jalopnik .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jalopnik_on .sidebar-content .newsletter-subscribe{border-color:#417eb9}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jalopnik .entry-content .pullquote,.f_branding_on .blog-group-jalopnik .entry-content .pullquote,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:before{height:8px;width:219px;background-image:url('data:image/svg+xml;utf8,<svg width="219" height="8" viewBox=" 219 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-top<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" transform="matrix(-1 1 265 )" d="M46 h17l3 4H49"/><path fill="%23FF4D" d="M116 4H2L 8h114"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jalopnik .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on .blog-group-jalopnik .entry-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jalopnik_on .entry-content .pullquote:after{height:8px;width:116px;background-image:url('data:image/svg+xml;utf8,<svg width="116" height="8" viewBox=" 116 8" xmlns="http://www.w3.org/2/svg"><title>%23-quote-bottom<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="%23FF4D" d="M116 H48l-1 4h68"/><path fill="url(%23a)" transform="matrix(-1 1 84 )" d="M 4h83l1 4H1"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-a,.f_branding_on .blog-group-jalopnik .storybreak-branded-a,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-a{min-width:77px;height:1px;background-image:url('data:image/svg+xml;utf8,<svg width="77" height="1" viewBox=" 77 1" xmlns="http://www.w3.org/2/svg"><title>%23-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%23CCC" d="M12.423 4L1 1h64.577L77 4"/><path fill="%23FF4D" d="M2.423 L 6h64.577L67 "/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .storybreak-branded-b,.f_branding_on .blog-group-jalopnik .storybreak-branded-b,.f_branding_on.f_branding_jalopnik_on .storybreak-branded-b{min-width:8px;height:12px;background-image:url('data:image/svg+xml;utf8,<svg width="8" height="12" viewBox=" 8 12" xmlns="http://www.w3.org/2/svg"><title>%23-gradient<\/title><defs><linearGradient x1="%" y1="5%" y2="5%" id="a"><stop stop-color="%23FFB2" offset="%"/><stop stop-color="%23FF4E" offset="1%"/><\/linearGradient><\/defs><g fill="none" fill-rule="evenodd"><path fill="url(%23a)" d="M75.1 5.982L78.82 12H3L4.185 H8"/><path d="M3.517 11.977c-.194 -.696.23-.96.23Hl.5-5.86h2.585c.264 .5-.22.527-.49L4.242 H9l-.665 6.92c-.26.27-.15.75-.175.965 -.532 4.68-4.643 4.92z" fill="%23FF4D"/><\/g><\/svg>')}.f_branding_on.blog-group-jalopnik .pullquote__content,.f_branding_on .blog-group-jalopnik .pullquote__content,.f_branding_on.f_branding_jalopnik_on .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-jezebel.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_jezebel_on.f_article_split_on .scroll-list-break{border-top:3px solid #ec1238}.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#ec1238;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-jezebel .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_jezebel_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-jezebel .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_jezebel_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-jezebel .post-content .quotable a,.f_branding_on .blog-group-jezebel .post-content .quotable a,.f_branding_on.blog-group-jezebel .post-content footer a,.f_branding_on .blog-group-jezebel .post-content footer a,.f_branding_on.blog-group-jezebel .post-content h1 a,.f_branding_on .blog-group-jezebel .post-content h1 a,.f_branding_on.blog-group-jezebel .post-content h2 a,.f_branding_on .blog-group-jezebel .post-content h2 a,.f_branding_on.blog-group-jezebel .post-content h3 a,.f_branding_on .blog-group-jezebel .post-content h3 a,.f_branding_on.blog-group-jezebel .post-content h4 a,.f_branding_on .blog-group-jezebel .post-content h4 a,.f_branding_on.blog-group-jezebel .post-content h5 a,.f_branding_on .blog-group-jezebel .post-content h5 a,.f_branding_on.blog-group-jezebel .post-content h6 a,.f_branding_on .blog-group-jezebel .post-content h6 a,.f_branding_on.blog-group-jezebel .post-content li a,.f_branding_on .blog-group-jezebel .post-content li a,.f_branding_on.blog-group-jezebel .post-content p a,.f_branding_on .blog-group-jezebel .post-content p a,.f_branding_on.f_branding_jezebel_on .post-content .quotable a,.f_branding_on.f_branding_jezebel_on .post-content footer a,.f_branding_on.f_branding_jezebel_on .post-content h1 a,.f_branding_on.f_branding_jezebel_on .post-content h2 a,.f_branding_on.f_branding_jezebel_on .post-content h3 a,.f_branding_on.f_branding_jezebel_on .post-content h4 a,.f_branding_on.f_branding_jezebel_on .post-content h5 a,.f_branding_on.f_branding_jezebel_on .post-content h6 a,.f_branding_on.f_branding_jezebel_on .post-content li a,.f_branding_on.f_branding_jezebel_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f68c9f;box-shadow:inset -2px #f68c9f;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-jezebel .post-content .quotable a:hover,.f_branding_on .blog-group-jezebel .post-content .quotable a:hover,.f_branding_on.blog-group-jezebel .post-content footer a:hover,.f_branding_on .blog-group-jezebel .post-content footer a:hover,.f_branding_on.blog-group-jezebel .post-content h1 a:hover,.f_branding_on .blog-group-jezebel .post-content h1 a:hover,.f_branding_on.blog-group-jezebel .post-content h2 a:hover,.f_branding_on .blog-group-jezebel .post-content h2 a:hover,.f_branding_on.blog-group-jezebel .post-content h3 a:hover,.f_branding_on .blog-group-jezebel .post-content h3 a:hover,.f_branding_on.blog-group-jezebel .post-content h4 a:hover,.f_branding_on .blog-group-jezebel .post-content h4 a:hover,.f_branding_on.blog-group-jezebel .post-content h5 a:hover,.f_branding_on .blog-group-jezebel .post-content h5 a:hover,.f_branding_on.blog-group-jezebel .post-content h6 a:hover,.f_branding_on .blog-group-jezebel .post-content h6 a:hover,.f_branding_on.blog-group-jezebel .post-content li a:hover,.f_branding_on .blog-group-jezebel .post-content li a:hover,.f_branding_on.blog-group-jezebel .post-content p a:hover,.f_branding_on .blog-group-jezebel .post-content p a:hover,.f_branding_on.f_branding_jezebel_on .post-content .quotable a:hover,.f_branding_on.f_branding_jezebel_on .post-content footer a:hover,.f_branding_on.f_branding_jezebel_on .post-content h1 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h2 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h3 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h4 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h5 a:hover,.f_branding_on.f_branding_jezebel_on .post-content h6 a:hover,.f_branding_on.f_branding_jezebel_on .post-content li a:hover,.f_branding_on.f_branding_jezebel_on .post-content p a:hover,.f_branding_on.blog-group-jezebel figcaption a,.f_branding_on .blog-group-jezebel figcaption a,.f_branding_on.f_branding_jezebel_on figcaption a{color:#ec1238}.f_branding_on.blog-group-jezebel figcaption a:hover,.f_branding_on .blog-group-jezebel figcaption a:hover,.f_branding_on.f_branding_jezebel_on figcaption a:hover{color:#bde2d}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote,.f_branding_on.blog-group-jezebel .entry-content blockquote,.f_branding_on .blog-group-jezebel .entry-content blockquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_jezebel_on .entry-content blockquote{border-radius:;border-left:5px solid #ec1238;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on .blog-group-jezebel .editor-inner.post-content blockquote p,.f_branding_on.blog-group-jezebel .entry-content blockquote p,.f_branding_on .blog-group-jezebel .entry-content blockquote p,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_jezebel_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-jezebel .review-score,.f_branding_on .blog-group-jezebel .review-score,.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_jezebel_on .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#ec1238}.f_branding_on.blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-jezebel .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_jezebel_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white){color:#ec1238;border-color:#ec1238}.f_branding_on.blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-jezebel .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_jezebel_on .storytype-label:not(.storytype-label--white):hover{color:#bde2d;border-color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio__name,.f_branding_on .blog-group-jezebel .author-bio__name,.f_branding_on.f_branding_jezebel_on .author-bio__name{color:#222}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name){color:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#ec1238}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover{color:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#bde2d}.f_branding_on.blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-jezebel .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_jezebel_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#bde2d}.f_branding_on.blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-jezebel .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_jezebel_on .sidebar-content .newsletter-subscribe{border-color:#ec1238}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote,.f_branding_on.blog-group-jezebel .entry-content .pullquote,.f_branding_on .blog-group-jezebel .entry-content .pullquote,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold;position:relative;padding:36px ;text-transform:uppercase;font-weight:1;color:#ec1238;font-size:31px;line-height:33px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{display:block;content:'';position:absolute;width:23px;height:18px;left:calc(5% - 12px);background-image:url('data:image/svg+xml;utf8,<svg width="23" height="18" viewBox=" 23 18" xmlns="http://www.w3.org/2/svg"><title>jezbel-quote<\/title><path d="M23 13.46c 1.253-.45 2.323-1.345 3.21-.897.887-1.977 1.33-3.243 1.33-1.69 -2.968-.548-3.837-1.644-.87-1.95-1.36-2.426-1.36-3.99 -2.192.76-4.435 2.29-6.73C17.9 3.338 19.252 1.46 22.5 L23 1.41c-1.32 1.147-2.36 2.347-3.125 3.598-.765 1.253-1.358 2.48-1.78 3.68 1.53.14 2.73.613 3.6 1.525.87.913 1.35 1.995 1.35 3.248m-12.385 c 1.258-.457 2.328-1.373 3.21-.915.89-2 1.33-3.256 1.33-1.622 -2.878-.543-3.767-1.64-.89-1.1-1.34-2.43-1.34-3.99 -2.194.756-4.437 2.273-6.73C4.677 3.335 6.85 1.46 9.673 l.86 1.41c-1.35 1.147-2.34 2.347-3.1 3.598-.755 1.253-1.344 2.48-1.762 3.68 1.52.14 2.72.613 3.61 1.525.89.913 1.338 1.995 1.338 3.248" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:before{top:-6px}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote:after{bottom:-6px;-webkit-transform:rotate(18deg);transform:rotate(18deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper{display:block;position:absolute;height:7px;width:calc(5% - 2px);background-color:#ec1238;-webkit-transform:skewX(-7deg);transform:skewX(-7deg)}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:first-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:first-child{top:;left:}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote .pullquote__helper:last-child{bottom:;right:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left{padding:31px ;text-align:left;margin-bottom:1rem}.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:after,.f_branding_on.blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-jezebel .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left .pullquote__helper:last-child,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_jezebel_on .entry-content .pullquote.align--left:before{display:none}}.f_branding_on.blog-group-jezebel .storybreak-branded-a,.f_branding_on .blog-group-jezebel .storybreak-branded-a,.f_branding_on.f_branding_jezebel_on .storybreak-branded-a{min-width:31px;height:31px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="31" viewBox=" 31 31" xmlns="http://www.w3.org/2/svg"><title>jezebel-wheel<\/title><path d="M18.53.852h2.96v7.85c 1-.852 2.643-1.91 3.39-.392.275-.855.582-1.42.738v-.613c.29-.284.425-1.11.425-1.762V.852zM8.46 2.337L1.684.5l5.13 6.14c.652.765 1.72 2.563.75 3.84-.12.46-.274.986-.67 1.465l-.398-.472c.3-.4-.41-1.11-.83-1.61L8.46 2.34M1.713 9.844L2.22 7.3l7.858 1.362c1 .173 2.497 1.285 3.6 2.44.27.427.434.928.492 1.54l-.613-.18c-.234-.33-1.4-.63-1.69-.716-.96-.157-6.215-1.8-9.612-1.668M1.453 19.86C.963 19.23.49 18.22 17.384l6.91-3.925c.88-.5 2.752-.6 3.938-.7.438.19.94.43 1.36.84-.63.3-.334.19-.54.3-.394-.16-1.19.193-1.763.52l-8.452 4.8m6.342 7.84l-2.73-.978 2.73-7.376c.347-.94 1.72-2.197 2.972-2.54.464-.13 1.6-.26 1.593-.218-.26.7-.135.354-.216.574-.37.17-.784.93-1.1 1.515l-3.34 9.3m9.98 1.99l-2.73.978-2.73-7.38c-.345-.94-.116-2.77.62-3.83.272-.39.6-.837 1.8-1.175.23.7.127.357.21.576-.175.364-.13 1.186.213 1.8.315.85 2.16 5.833 3.338 9.22m8.948-4.785c-.49.837-.962 1.64-1.453 2.476l-6.91-3.926c-.88-.5-1.9-2.48-2.27-3.32-.47-.474-.86-1.2.6-1.58l.537.36c.16.39.767.917 1.34 1.243l8.453 4.8m3.727-9.32l.55 2.815-7.858 1.36c-1 .175-2.792-.366-3.722-1.262-.345-.332-.732-.727-.987-1.25.73-.1.38-.62.614-.13.334.23 1.185.22 1.837.17l9.61-1.667m-3.24-9.5l2.222 1.84c-1.756 2.6-3.37 3.953-5.13 6.13-.652.765-2.38 1.485-3.676 1.387-.48-.37-1.35-.94-1.57-.33.46-.6.25-.29.4-.47.41-.36 1.52-.584 1.477-1.8l6.274-7.36" fill="%23EC1238" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-jezebel .storybreak-branded-b,.f_branding_on .blog-group-jezebel .storybreak-branded-b,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b{border:;font-family:"ElizabethSerif",Georgia,serif;letter-spacing:7px;margin-top:4px;margin-bottom:6px;overflow:visible;text-align:center}.f_branding_on.blog-group-jezebel .storybreak-branded-b:before,.f_branding_on .blog-group-jezebel .storybreak-branded-b:before,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b:before{color:#ec1238;content:'***';display:inline-block;font-size:17px}.f_branding_on.blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on .blog-group-jezebel .storybreak-branded-b.storybreak-variant--branded,.f_branding_on.f_branding_jezebel_on .storybreak-branded-b.storybreak-variant--branded{margin:;padding:4px}.f_branding_on.blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-kotaku.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_kotaku_on.f_article_split_on .scroll-list-break{border-top:3px solid #fbc}.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#b1246;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-kotaku .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_kotaku_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-kotaku .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_kotaku_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-kotaku .post-content .quotable a,.f_branding_on .blog-group-kotaku .post-content .quotable a,.f_branding_on.blog-group-kotaku .post-content footer a,.f_branding_on .blog-group-kotaku .post-content footer a,.f_branding_on.blog-group-kotaku .post-content h1 a,.f_branding_on .blog-group-kotaku .post-content h1 a,.f_branding_on.blog-group-kotaku .post-content h2 a,.f_branding_on .blog-group-kotaku .post-content h2 a,.f_branding_on.blog-group-kotaku .post-content h3 a,.f_branding_on .blog-group-kotaku .post-content h3 a,.f_branding_on.blog-group-kotaku .post-content h4 a,.f_branding_on .blog-group-kotaku .post-content h4 a,.f_branding_on.blog-group-kotaku .post-content h5 a,.f_branding_on .blog-group-kotaku .post-content h5 a,.f_branding_on.blog-group-kotaku .post-content h6 a,.f_branding_on .blog-group-kotaku .post-content h6 a,.f_branding_on.blog-group-kotaku .post-content li a,.f_branding_on .blog-group-kotaku .post-content li a,.f_branding_on.blog-group-kotaku .post-content p a,.f_branding_on .blog-group-kotaku .post-content p a,.f_branding_on.f_branding_kotaku_on .post-content .quotable a,.f_branding_on.f_branding_kotaku_on .post-content footer a,.f_branding_on.f_branding_kotaku_on .post-content h1 a,.f_branding_on.f_branding_kotaku_on .post-content h2 a,.f_branding_on.f_branding_kotaku_on .post-content h3 a,.f_branding_on.f_branding_kotaku_on .post-content h4 a,.f_branding_on.f_branding_kotaku_on .post-content h5 a,.f_branding_on.f_branding_kotaku_on .post-content h6 a,.f_branding_on.f_branding_kotaku_on .post-content li a,.f_branding_on.f_branding_kotaku_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #ffe181;box-shadow:inset -2px #ffe181;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-kotaku .post-content .quotable a:hover,.f_branding_on .blog-group-kotaku .post-content .quotable a:hover,.f_branding_on.blog-group-kotaku .post-content footer a:hover,.f_branding_on .blog-group-kotaku .post-content footer a:hover,.f_branding_on.blog-group-kotaku .post-content h1 a:hover,.f_branding_on .blog-group-kotaku .post-content h1 a:hover,.f_branding_on.blog-group-kotaku .post-content h2 a:hover,.f_branding_on .blog-group-kotaku .post-content h2 a:hover,.f_branding_on.blog-group-kotaku .post-content h3 a:hover,.f_branding_on .blog-group-kotaku .post-content h3 a:hover,.f_branding_on.blog-group-kotaku .post-content h4 a:hover,.f_branding_on .blog-group-kotaku .post-content h4 a:hover,.f_branding_on.blog-group-kotaku .post-content h5 a:hover,.f_branding_on .blog-group-kotaku .post-content h5 a:hover,.f_branding_on.blog-group-kotaku .post-content h6 a:hover,.f_branding_on .blog-group-kotaku .post-content h6 a:hover,.f_branding_on.blog-group-kotaku .post-content li a:hover,.f_branding_on .blog-group-kotaku .post-content li a:hover,.f_branding_on.blog-group-kotaku .post-content p a:hover,.f_branding_on .blog-group-kotaku .post-content p a:hover,.f_branding_on.f_branding_kotaku_on .post-content .quotable a:hover,.f_branding_on.f_branding_kotaku_on .post-content footer a:hover,.f_branding_on.f_branding_kotaku_on .post-content h1 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h2 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h3 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h4 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h5 a:hover,.f_branding_on.f_branding_kotaku_on .post-content h6 a:hover,.f_branding_on.f_branding_kotaku_on .post-content li a:hover,.f_branding_on.f_branding_kotaku_on .post-content p a:hover{color:#fbc}.f_branding_on.blog-group-kotaku figcaption a,.f_branding_on .blog-group-kotaku figcaption a,.f_branding_on.f_branding_kotaku_on figcaption a{color:#b1246}.f_branding_on.blog-group-kotaku figcaption a:hover,.f_branding_on .blog-group-kotaku figcaption a:hover,.f_branding_on.f_branding_kotaku_on figcaption a:hover{color:#871b49}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote,.f_branding_on.blog-group-kotaku .entry-content blockquote,.f_branding_on .blog-group-kotaku .entry-content blockquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_kotaku_on .entry-content blockquote{border-radius:;border-left:5px solid #fbc;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on .blog-group-kotaku .editor-inner.post-content blockquote p,.f_branding_on.blog-group-kotaku .entry-content blockquote p,.f_branding_on .blog-group-kotaku .entry-content blockquote p,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_kotaku_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before,.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-kotaku .review-score,.f_branding_on .blog-group-kotaku .review-score,.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_kotaku_on .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#b1246}.f_branding_on.blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-kotaku .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_kotaku_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white){color:#b1246;border-color:#b1246}.f_branding_on.blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-kotaku .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_kotaku_on .storytype-label:not(.storytype-label--white):hover{color:#871b49;border-color:#871b49}.f_branding_on.blog-group-kotaku .author-bio__name,.f_branding_on .blog-group-kotaku .author-bio__name,.f_branding_on.f_branding_kotaku_on .author-bio__name{color:#222}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name){color:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#b1246}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover{color:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#871b49}.f_branding_on.blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-kotaku .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_kotaku_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#871b49}.f_branding_on.blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-kotaku .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_kotaku_on .sidebar-content .newsletter-subscribe{border-color:#fbc}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote,.f_branding_on.blog-group-kotaku .entry-content .pullquote,.f_branding_on .blog-group-kotaku .entry-content .pullquote,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote{font-size:22px;line-height:32px;font-weight:bold}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:before{height:7px;width:244px;background-image:url('data:image/svg+xml;utf8,<svg width="244" height="7" viewBox=" 244 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-top<\/title><g fill="none" fill-rule="evenodd"><path d="M243 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M177.167 6.972c2.622.13 5.38-1.883 6.14-4.54L184 .22 64.833.2v.4c-2.622-.13-5.38 1.884-6.14 4.54L58 6.956l.1.44 119.157-.28z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote:after{height:7px;width:129px;background-image:url('data:image/svg+xml;utf8,<svg width="129" height="7" viewBox=" 129 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-bottom<\/title><g fill="none" fill-rule="evenodd"><path d="M128 4H1" stroke="%23B1246" stroke-linecap="round"/><path d="M81.75 6.972c2.657.13 5.452-1.883 6.224-4.54l.7-2.41-4.76-.2v.4c-2.657-.13-5.452 1.884-6.224 4.54l-.7 2.41.1.44 4.65-.28z" fill="%23FBC"/><\/g><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:before,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:before{background-image:url('data:image/svg+xml;utf8,<svg width="243" height="7" viewBox=" 243 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-lefttop<\/title><g fill="none" fill-rule="evenodd"><path d="M242.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M157.912 6.845c2.375.128 4.872-1.85 5.562-4.457L164.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 122.896-.27z" fill="%23FBC"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on .blog-group-kotaku .entry-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote.align--left:after,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote.align--left:after{background-image:url('data:image/svg+xml;utf8,<svg width="117" height="7" viewBox=" 117 7" xmlns="http://www.w3.org/2/svg"><title>kotaku-quote-leftbottom<\/title><g fill="none" fill-rule="evenodd"><path d="M116.5 3.688H.5" stroke="%23B1246" stroke-linecap="round"/><path d="M74.912 6.845c2.375.128 4.872-1.85 5.562-4.457L81.1.2 41.194.4v.3c-2.374-.128-4.87 1.85-5.56 4.457l-.628 2.367.1.43 39.896-.27z" fill="%23FBC"/><\/g><\/svg>')}}.f_branding_on.blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-kotaku .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_kotaku_on .entry-content .pullquote .pullquote__content{padding-left:;padding-right:}.f_branding_on.blog-group-kotaku .storybreak-branded-a,.f_branding_on .blog-group-kotaku .storybreak-branded-a,.f_branding_on.f_branding_kotaku_on .storybreak-branded-a{min-width:75px;height:16px;background-image:url('data:image/svg+xml;utf8,<svg width="75" height="16" viewBox=" 75 16" xmlns="http://www.w3.org/2/svg"><title>kotaku-bars<\/title><g fill="none" fill-rule="evenodd"><path fill="%23B1246" d="M 16h5VHm7 16h5VH7m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><path fill="%23FBC" d="M49 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5m7 16h5Vh-5"/><\/g><\/svg>')}.f_branding_on.blog-group-kotaku .storybreak-branded-b,.f_branding_on .blog-group-kotaku .storybreak-branded-b,.f_branding_on.f_branding_kotaku_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-lifehacker.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_lifehacker_on.f_article_split_on .scroll-list-break{border-top:3px solid #94b33}.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94b33;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-lifehacker .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_lifehacker_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-lifehacker .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-lifehacker .post-content .quotable a,.f_branding_on .blog-group-lifehacker .post-content .quotable a,.f_branding_on.blog-group-lifehacker .post-content footer a,.f_branding_on .blog-group-lifehacker .post-content footer a,.f_branding_on.blog-group-lifehacker .post-content h1 a,.f_branding_on .blog-group-lifehacker .post-content h1 a,.f_branding_on.blog-group-lifehacker .post-content h2 a,.f_branding_on .blog-group-lifehacker .post-content h2 a,.f_branding_on.blog-group-lifehacker .post-content h3 a,.f_branding_on .blog-group-lifehacker .post-content h3 a,.f_branding_on.blog-group-lifehacker .post-content h4 a,.f_branding_on .blog-group-lifehacker .post-content h4 a,.f_branding_on.blog-group-lifehacker .post-content h5 a,.f_branding_on .blog-group-lifehacker .post-content h5 a,.f_branding_on.blog-group-lifehacker .post-content h6 a,.f_branding_on .blog-group-lifehacker .post-content h6 a,.f_branding_on.blog-group-lifehacker .post-content li a,.f_branding_on .blog-group-lifehacker .post-content li a,.f_branding_on.blog-group-lifehacker .post-content p a,.f_branding_on .blog-group-lifehacker .post-content p a,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a,.f_branding_on.f_branding_lifehacker_on .post-content footer a,.f_branding_on.f_branding_lifehacker_on .post-content h1 a,.f_branding_on.f_branding_lifehacker_on .post-content h2 a,.f_branding_on.f_branding_lifehacker_on .post-content h3 a,.f_branding_on.f_branding_lifehacker_on .post-content h4 a,.f_branding_on.f_branding_lifehacker_on .post-content h5 a,.f_branding_on.f_branding_lifehacker_on .post-content h6 a,.f_branding_on.f_branding_lifehacker_on .post-content li a,.f_branding_on.f_branding_lifehacker_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #9dcee7;box-shadow:inset -2px #9dcee7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on .blog-group-lifehacker .post-content .quotable a:hover,.f_branding_on.blog-group-lifehacker .post-content footer a:hover,.f_branding_on .blog-group-lifehacker .post-content footer a:hover,.f_branding_on.blog-group-lifehacker .post-content h1 a:hover,.f_branding_on .blog-group-lifehacker .post-content h1 a:hover,.f_branding_on.blog-group-lifehacker .post-content h2 a:hover,.f_branding_on .blog-group-lifehacker .post-content h2 a:hover,.f_branding_on.blog-group-lifehacker .post-content h3 a:hover,.f_branding_on .blog-group-lifehacker .post-content h3 a:hover,.f_branding_on.blog-group-lifehacker .post-content h4 a:hover,.f_branding_on .blog-group-lifehacker .post-content h4 a:hover,.f_branding_on.blog-group-lifehacker .post-content h5 a:hover,.f_branding_on .blog-group-lifehacker .post-content h5 a:hover,.f_branding_on.blog-group-lifehacker .post-content h6 a:hover,.f_branding_on .blog-group-lifehacker .post-content h6 a:hover,.f_branding_on.blog-group-lifehacker .post-content li a:hover,.f_branding_on .blog-group-lifehacker .post-content li a:hover,.f_branding_on.blog-group-lifehacker .post-content p a:hover,.f_branding_on .blog-group-lifehacker .post-content p a:hover,.f_branding_on.f_branding_lifehacker_on .post-content .quotable a:hover,.f_branding_on.f_branding_lifehacker_on .post-content footer a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h1 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h2 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h3 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h4 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h5 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content h6 a:hover,.f_branding_on.f_branding_lifehacker_on .post-content li a:hover,.f_branding_on.f_branding_lifehacker_on .post-content p a:hover,.f_branding_on.blog-group-lifehacker figcaption a,.f_branding_on .blog-group-lifehacker figcaption a,.f_branding_on.f_branding_lifehacker_on figcaption a{color:#39c}.f_branding_on.blog-group-lifehacker figcaption a:hover,.f_branding_on .blog-group-lifehacker figcaption a:hover,.f_branding_on.f_branding_lifehacker_on figcaption a:hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote,.f_branding_on.blog-group-lifehacker .entry-content blockquote,.f_branding_on .blog-group-lifehacker .entry-content blockquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote{border-radius:;border-left:5px solid #94b33;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on .blog-group-lifehacker .editor-inner.post-content blockquote p,.f_branding_on.blog-group-lifehacker .entry-content blockquote p,.f_branding_on .blog-group-lifehacker .entry-content blockquote p,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_lifehacker_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-lifehacker .review-score,.f_branding_on .blog-group-lifehacker .review-score,.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_lifehacker_on .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#94b33}.f_branding_on.blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-lifehacker .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_lifehacker_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#94b33}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white){color:#39c;border-color:#39c}.f_branding_on.blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-lifehacker .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_lifehacker_on .storytype-label:not(.storytype-label--white):hover{color:#297aa3;border-color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio__name,.f_branding_on .blog-group-lifehacker .author-bio__name,.f_branding_on.f_branding_lifehacker_on .author-bio__name{color:#222}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name){color:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#39c}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover{color:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#297aa3}.f_branding_on.blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-lifehacker .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_lifehacker_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#297aa3}.f_branding_on.blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-lifehacker .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_lifehacker_on .sidebar-content .newsletter-subscribe{border-color:#94b33}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote,.f_branding_on.blog-group-lifehacker .entry-content .pullquote,.f_branding_on .blog-group-lifehacker .entry-content .pullquote,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote{padding: 23px 61px;text-align:left;max-width:4px}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#39c;-webkit-box-shadow:1px #39c,-1px #39c;box-shadow:1px #39c,-1px #39c;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:4px 3px;line-height:4px;position:relative}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:before{width:46px;height:36px;left:-61px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="36" viewBox=" 46 36" xmlns="http://www.w3.org/2/svg"><title>lifehacker-quote<\/title><path d="M36 L25 18v18h21V17h-8l8-17M11 L 18v18h21V17h-8l8-17" fill="%2394B33" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-lifehacker .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote .pullquote__content:after{width:1px;height:36px;background-color:#94b33;right:-23px;bottom:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on .blog-group-lifehacker .entry-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_lifehacker_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-lifehacker .storybreak-branded-a,.f_branding_on .blog-group-lifehacker .storybreak-branded-a,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-a{min-width:46px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="46" height="11" viewBox=" 46 11" xmlns="http://www.w3.org/2/svg"><title>lifehacker-default<\/title><g fill="none" fill-rule="evenodd"><path fill="%2394B33" d="M 11h11VH"/><path fill="%2339C" d="M18 11h11VH18"/><path fill="%2394B33" d="M35 11h11VH35"/><\/g><\/svg>')}.f_branding_on.blog-group-lifehacker .storybreak-branded-b,.f_branding_on .blog-group-lifehacker .storybreak-branded-b,.f_branding_on.f_branding_lifehacker_on .storybreak-branded-b{min-width:48px;height:47px;background-image:url('data:image/svg+xml;utf8,<svg width="48" height="47" viewBox=" 48 47" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>lifehacker-binder<\/title><defs><path id="a" d="M2.667 3.52H.77V.526h2.59v2.526z"/><\/defs><g fill="none" fill-rule="evenodd"><path d="M18.638 41.243c.347 .348-.568 -.568-.347 -.347.568 .568" fill="%2394B33"/><path d="M18.946 4.75c-1.36-1.347-2.153-2.62-3.35-3.824-.297-.297-.756.167-.46.466 1.2 1.22 2.315 2.477 3.352 3.824.256.334.712-.135.458-.465" fill="%2394B33"/><path d="M15.494 36.886c-1.74-.117-3.66.613-3.115 2.77.28 1.13 1.21 1.998 1.95 2.832.46.523.92 1.5 1.4 1.57.24.272.37.474.74.478.15 .26-.14.31-.24l.2-.75c.13-.4-.49-.57-.63-.17l-.3.8.31-.24c-.33 -1.16-1.26-1.4-1.54-.51-.57-1.5-1.12-1.5-1.74-.55-.76-.98-1.82-.21-2.6.56-.56 1.39-.5 2.12-.45.41.3.41-.63 -.65" fill="%2394B33"/><path d="M18.347 41.227c-.956.2-1.96.457-2.25 1.456-.258.89.197 1.853 1.13 2.3 2.43.386 2.757-4.4.655-3.797-.41.47-.415.76 .657.96-.14.6 1.11.427 1.64-.21.574-.62 1.27-1.28.76-.48-.32-.44-.975-.15-1.41.33-.487.9-.642 1.46-.642.42 .42-.658 -.658m-6.95-6.855c-.92.443-1.23 1.53-1.1 2.49.24 1.55 1.1 1.84 1.99 2.21.39.145.56-.49.17-.636-1.22-.453-2.51-2.692-.84-3.495.37-.18.4-.74-.33-.56" fill="%2394B33"/><path d="M7.78 3.77c1.56 1.365 2.166 2.683 3.33 3.956.283.312.74-.154.458-.464-1.163-1.273-2.273-2.592-3.33-3.957-.257-.333-.713.136-.458.465" fill="%2394B33"/><path d="M7.552 3.174c-.795.645-1.212 1.656-1.17 2.683.42.416.69.42.648 -.9-.877.24-1.667.917-2.218.326-.27-.135-.73-.458-.47" fill="%2394B33"/><path d="M6.338 32.87c1.373 1.997 2.885 3.88 4.54 5.644.29.31.747-.15.46-.46-1.618-1.72-3.1-3.56-4.44-5.51-.236-.34-.8-.1-.56.34M2.32 23.86c1.26 1.41 2.453 2.873 3.578 4.395.247.335.81.8.56-.33-1.157-1.57-2.382-3.8-3.68-4.53-.28-.315-.737.15-.457.464" fill="%2394B33"/><path d="M6.246 27.827c-1.23-.156-2.33.427-2.13 1.547-.11 1.262 1.225 2.29 1.97 3.122.282.315.74-.152.46-.464-.42-.468-.854-.924-1.256-1.45-.27-.246-.44-.533-.51-.86-.17-.82.53-1.422 1.294-1.35.48.62.584-.57.172-.635" fill="%2394B33"/><path d="M2.377 23.144C.73 23.118-.278 24.674.34 26.21c.372.982 1.224 1.835 1.883 2.624.872 1.43 1.786 2.34 2.823 2.91.32.27.78-.194.46-.465-1.138-.96-2.124-2.6-3.72-3.21-.48-.59-1.3-1.16-1.372-1.84-.584-1.17.2-2.45 1.35-2.43.418 .418-.65 -.66" fill="%2394B33"/><path d="M3.83 24.67c2.76-2.947 3.984-6.12 5.69-9.194.57-1.62 1.92-5.88 3.52-4.11.863.527 1.453 1.582 2.46 2.375.585.79 1.17 1.57 1.756 2.36.25.34.812.1.56-.33l-2.132-2.86c-.53-.71-1.4-1.5-1.775-2.1-1.49-1.4-2.423.8-3.74 1.4-2.7 4.2-4.46 8.23-7.15 12.5-.24.35.32.68.56.33m14.97-6.51c.84.83 1.59 1.72 2.34 2.63.27.33.73-.14.46-.46-.75-.91-1.5-1.79-2.33-2.62-.3-.29-.76.17-.46.47m4.52 4.61c1.96 1.96 4 3.81 6.11 5.6.32.27.78-.19.46-.46-2.11-1.79-4.15-3.64-6.11-5.6-.3-.29-.76.17-.46.47" fill="%2394B33"/><path d="M19.263 43.354c1.434-2.52 2.87-5.4 4.33-7.57.718-1.25 1.435-2.52 2.152-3.754.65-1.133 1.243-2.717 2.222-3.596.464-.415 1.8-.428 1.542.62.166.17.242.7.285.94.84.47.97.96.19 1.43.173.87.55 1.7 1.9 2.4.58.75 1.292 1.25 2.12 1.71.5.28 1.7.57 1.36 1.1.62 1.14-.52 1.92-1.44 2.22-.4.13-.23.76.17.63.96-.31 2.3-.99 2.12-2.12.9-1.15-.9-1.83-1.77-2.34-1.41-.83-2.53-1.82-2.95-3.49-.26-1.4-.7-2.52-.96-3.29-.76-.65-1.71-.29-2.32.36-1.13 1.19-1.83 2.94-2.65 4.36L18.7 43.2c-.21.368.35.7.56.332" fill="%2394B33"/><path d="M18.524 44.16l15.417-5.356c.4-.137.23-.772-.17-.634l-15.42 5.357c-.39.136-.22.772.18.634" fill="%2394B33"/><path d="M19.892 43.348c-.897.385-2.5 1.183-1.64 2.35.28.796 1.28 1.75 2.3.76.876-.38 1.28-1.473 1.25-2.385-.68-.846-.927-1.777-1.765-1.12-.326.254-.3.825.327.566.73-.55.836.77.755 1.18-.96.49-.384 1.5-.9 1.19-.46.12-1.76-.13-1.52-.68.3-.72.84-1.7 1.394-1.31.38-.17.5-.73-.33-.57" fill="%2394B33"/><g transform="translate(16.8 43.636)"><mask id="b" fill="%23fff"><use xlink-underline:href="%23a"/><\/mask><path d="M.15 1.16c.573.747 1.26 1.377 2.4 1.892.35.23.676-.338.327-.568C1.78 1.945 1.147 1.344.61.64.353.38-.13.776.15 1.17" fill="%2394B33" mask="url(%23b)"/><\/g><path d="M15.728 37.47c.878-3.268 2.82-6.17 4.473-9.77l5.7-8.95c.79-1.376 1.49-2.88 2.42-4.155.96-1.37 2.33-1.59 3.82-1.865 2.24-.415 4.3-1.36 4.36-3.842.6-4.545-3.33-9.333-7.83-9.613C26.1-.11 24.9.68 23.29 2.59c-1.123 2.695.3 5.637-1.438 8.21-1.1 1.624-2.637 3-3.97 4.424l-3.86 4.116-8.36 8.87c-.287.38.17.774.46.466l13.35-14.253c1.66-1.77 3.612-3.52 3.934-6.6.32-2.54-.724-6.44 2.234-7.324 4.93-2.14 1.68 4.14 9.44 9.3-.755 2.98-3.88 2.4-6.1 3.35-.94.38-1.55 1.5-2.9 1.87-.894 1.35-1.634 2.83-2.436 4.23l-5.17 9.9c-1.583 2.78-3.38 5.55-4.22 8.68-.11.41.515.58.624.17" fill="%2394B33"/><path d="M5.26 31.196c2.932.283 5.2-2.353 6.686-4.398 2.21-2.686 4.27-5.497 6.482-8.18 1.125-1.365 2.29-2.695 3.53-3.955.988-1.4 2.65-1.962 2.818-3.17.757-1.215.942-2.5.82-3.912-.14-1.62-.592-5.74 2.273-5.3.4.1.57-.53.17-.63-1.5-.26-2.9.2-2.69 1.12-.81 1.24-.59 2.79-.45 4.17.21 2.14-.26 3.66-1.69 5.24-1.12 1.25-2.35 2.38-3.47 3.63-2.36 2.65-4.47 5.5-6.67 8.28-1.86 2.36-4.4 6.53-7.83 6.2-.42-.4-.42.62 .66" fill="%2394B33"/><path d="M27.74 2.567c3.7.46 5.95 3.983 5.18 7.12-.733 3.155-4.715.37-6.8 2.546-.226.36.335.69.56.332.543-.868 2-.56 2.847-.526.62-.2 1.267-.8 1.84-.34 1.312-.59 1.66-2.4 1.543-3.38-.274-3.11-2.82-6-5.89-6.42-.41-.6-.47.6 .65" fill="%2394B33"/><path d="M13.184 37.95c.393-2.47 1.518-4.688 2.65-6.885 1.11-2.158 2.278-4.287 3.512-6.376 2.41-4.8 5.83-7.99 7.888-11.8.25-.34-.313-.67-.56-.33-2.878 3.91-5.616 7.92-8.76 12.11-1.232 2.1-2.398 4.24-3.57 6.41-1.9 2.13-2.15 4.29-2.53 6.68-.6.41.56.59.63.17M27.3 26.37c2.16-.15 5.43-.3 6.38-2.67.586-1.45.746-2.91 2.55-3.21 1.525-.252 3.16.267 4.596.745 1.593.53 3.165 1.294 4.32 2.56 1.158 1.27 2.14 3.21 1.476 4.942-1.143 2.974-4.62 1.44-6.82.93-3.265-.72-6.127 1.96-8.715 2.894-.343.24-.2.81.327.57 1.565-1.8 3.19-2.21 5.43-2.72 1.685-.46 3.147-.11 4.78.31 2.22.58 4.92.93 5.977-1.68 1.76-2.67-1.46-5.62-3.163-7.1-1.49-.98-3.24-1.55-4.96-1.96-1.23-.29-2.63-.48-3.84.3-1.47.63-1.62 2.3-2.16 3.37-.82 2.4-3.93 2.14-5.78 2.27-.41.3-.41.69 .66" fill="%2394B33"/><path d="M28.98 27.835c2.463-.212 5.497-.644 6.547-3.298.336-.85.365-1.976 1.42-2.257.866-.23 1.942.194 2.744.5 1.51.576 3.2 1.457 4.29 2.693.78.88 1.27 2.253-.14 2.864-.83.36-1.75.4-2.57-.198-1.28-.38-2.55-.59-3.89-.5-2.7.18-5.24 1.39-7.1 3.38-.29.31.17.77.46.46 2.58-2.76 6.44-3.83 1.5-2.81 1.27.36 2.82.88 3.95-.13.93-.84.76-2.4.11-3.1-.83-1.25-2.28-2.12-3.58-2.78-1.28-.65-3.5-1.51-4.51-1.13-1.57.41-1.4 2.1-2.12 3.18-1.18 1.93-3.68 2.17-5.69 2.34-.42.3-.42.69 .66" fill="%2394B33"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion .headline,.f_branding_on .blog-group-theonion .headline,.f_branding_on.blog-group-theonion .inset-headline,.f_branding_on .blog-group-theonion .inset-headline,.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .headline,.f_branding_on.f_branding_theonion_on .inset-headline,.f_branding_on.f_branding_theonion_on .kinja-slide__caption,.f_branding_on.blog-group-theonion .post-content h1,.f_branding_on .blog-group-theonion .post-content h1,.f_branding_on.blog-group-theonion .post-content h2,.f_branding_on .blog-group-theonion .post-content h2,.f_branding_on.blog-group-theonion .post-content h3,.f_branding_on .blog-group-theonion .post-content h3,.f_branding_on.blog-group-theonion .post-content h4,.f_branding_on .blog-group-theonion .post-content h4,.f_branding_on.blog-group-theonion .post-content h5,.f_branding_on .blog-group-theonion .post-content h5,.f_branding_on.blog-group-theonion .post-content h6,.f_branding_on .blog-group-theonion .post-content h6,.f_branding_on.f_branding_theonion_on .post-content h1,.f_branding_on.f_branding_theonion_on .post-content h2,.f_branding_on.f_branding_theonion_on .post-content h3,.f_branding_on.f_branding_theonion_on .post-content h4,.f_branding_on.f_branding_theonion_on .post-content h5,.f_branding_on.f_branding_theonion_on .post-content h6{font-family:"ElizabethSerif",Georgia,serif}.f_branding_on.blog-group-theonion.permalink .post .entry-title,.f_branding_on .blog-group-theonion.permalink .post .entry-title,.f_branding_on.f_branding_theonion_on.permalink .post .entry-title{font-size:34px;line-height:1.3}.f_branding_on.blog-group-theonion .postlist__item .headline,.f_branding_on .blog-group-theonion .postlist__item .headline,.f_branding_on.f_branding_theonion_on .postlist__item .headline{font-size:22px;line-height:1.4}.f_branding_on.blog-group-theonion .thumb-inset .inset-headline,.f_branding_on .blog-group-theonion .thumb-inset .inset-headline,.f_branding_on.f_branding_theonion_on .thumb-inset .inset-headline{font-size:14px;line-height:1.4}.f_branding_on.blog-group-theonion .kinja-slide__caption,.f_branding_on .blog-group-theonion .kinja-slide__caption,.f_branding_on.f_branding_theonion_on .kinja-slide__caption{font-size:13px;line-height:1.5}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theonion .entry-content .pullquote,.f_branding_on .blog-group-theonion .entry-content .pullquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theonion_on .entry-content .pullquote{border-top:none;border-bottom:8px solid #6b3a;padding: 3px;position:relative;font-size:28px;line-height:1.3;text-align:left;font-family:"ElizabethSerif",Georgia,serif;font-weight:bold;color:#6b3a}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--left{margin-top:}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote .pullquote__content{padding:}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-a{min-width:6px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="6" height="5" viewBox=" 6 5" xmlns="http://www.w3.org/2/svg"><title>onion-storybreak<\/title><path d="M h6v1Hzm 4h6v1Hz" fill="%2391D8B6" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{display:none !important}.f_branding_on .networknav__hovernav-wrapper.theonion .hovernav__post-list h4{font-family:"ElizabethSerif",Georgia,serif;font-size:15px;line-height:1.4}.f_branding_on.blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theroot.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theroot_on.f_article_split_on .scroll-list-break{border-top:3px solid #59b22}.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#59b22;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theroot .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theroot_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theroot .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theroot_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theroot .post-content .quotable a,.f_branding_on .blog-group-theroot .post-content .quotable a,.f_branding_on.blog-group-theroot .post-content footer a,.f_branding_on .blog-group-theroot .post-content footer a,.f_branding_on.blog-group-theroot .post-content h1 a,.f_branding_on .blog-group-theroot .post-content h1 a,.f_branding_on.blog-group-theroot .post-content h2 a,.f_branding_on .blog-group-theroot .post-content h2 a,.f_branding_on.blog-group-theroot .post-content h3 a,.f_branding_on .blog-group-theroot .post-content h3 a,.f_branding_on.blog-group-theroot .post-content h4 a,.f_branding_on .blog-group-theroot .post-content h4 a,.f_branding_on.blog-group-theroot .post-content h5 a,.f_branding_on .blog-group-theroot .post-content h5 a,.f_branding_on.blog-group-theroot .post-content h6 a,.f_branding_on .blog-group-theroot .post-content h6 a,.f_branding_on.blog-group-theroot .post-content li a,.f_branding_on .blog-group-theroot .post-content li a,.f_branding_on.blog-group-theroot .post-content p a,.f_branding_on .blog-group-theroot .post-content p a,.f_branding_on.f_branding_theroot_on .post-content .quotable a,.f_branding_on.f_branding_theroot_on .post-content footer a,.f_branding_on.f_branding_theroot_on .post-content h1 a,.f_branding_on.f_branding_theroot_on .post-content h2 a,.f_branding_on.f_branding_theroot_on .post-content h3 a,.f_branding_on.f_branding_theroot_on .post-content h4 a,.f_branding_on.f_branding_theroot_on .post-content h5 a,.f_branding_on.f_branding_theroot_on .post-content h6 a,.f_branding_on.f_branding_theroot_on .post-content li a,.f_branding_on.f_branding_theroot_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #92dd64;box-shadow:inset -2px #92dd64;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theroot .post-content .quotable a:hover,.f_branding_on .blog-group-theroot .post-content .quotable a:hover,.f_branding_on.blog-group-theroot .post-content footer a:hover,.f_branding_on .blog-group-theroot .post-content footer a:hover,.f_branding_on.blog-group-theroot .post-content h1 a:hover,.f_branding_on .blog-group-theroot .post-content h1 a:hover,.f_branding_on.blog-group-theroot .post-content h2 a:hover,.f_branding_on .blog-group-theroot .post-content h2 a:hover,.f_branding_on.blog-group-theroot .post-content h3 a:hover,.f_branding_on .blog-group-theroot .post-content h3 a:hover,.f_branding_on.blog-group-theroot .post-content h4 a:hover,.f_branding_on .blog-group-theroot .post-content h4 a:hover,.f_branding_on.blog-group-theroot .post-content h5 a:hover,.f_branding_on .blog-group-theroot .post-content h5 a:hover,.f_branding_on.blog-group-theroot .post-content h6 a:hover,.f_branding_on .blog-group-theroot .post-content h6 a:hover,.f_branding_on.blog-group-theroot .post-content li a:hover,.f_branding_on .blog-group-theroot .post-content li a:hover,.f_branding_on.blog-group-theroot .post-content p a:hover,.f_branding_on .blog-group-theroot .post-content p a:hover,.f_branding_on.f_branding_theroot_on .post-content .quotable a:hover,.f_branding_on.f_branding_theroot_on .post-content footer a:hover,.f_branding_on.f_branding_theroot_on .post-content h1 a:hover,.f_branding_on.f_branding_theroot_on .post-content h2 a:hover,.f_branding_on.f_branding_theroot_on .post-content h3 a:hover,.f_branding_on.f_branding_theroot_on .post-content h4 a:hover,.f_branding_on.f_branding_theroot_on .post-content h5 a:hover,.f_branding_on.f_branding_theroot_on .post-content h6 a:hover,.f_branding_on.f_branding_theroot_on .post-content li a:hover,.f_branding_on.f_branding_theroot_on .post-content p a:hover,.f_branding_on.blog-group-theroot figcaption a,.f_branding_on .blog-group-theroot figcaption a,.f_branding_on.f_branding_theroot_on figcaption a{color:#59b22}.f_branding_on.blog-group-theroot figcaption a:hover,.f_branding_on .blog-group-theroot figcaption a:hover,.f_branding_on.f_branding_theroot_on figcaption a:hover{color:#3a7119}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote,.f_branding_on.blog-group-theroot .entry-content blockquote,.f_branding_on .blog-group-theroot .entry-content blockquote,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theroot_on .entry-content blockquote{border-radius:;border-left:5px solid #dd6634;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theroot .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theroot .entry-content blockquote p,.f_branding_on .blog-group-theroot .entry-content blockquote p,.f_branding_on.f_branding_theroot_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theroot_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before,.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theroot .entry-content .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote__content,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theroot .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theroot .review-score,.f_branding_on .blog-group-theroot .review-score,.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theroot_on .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#dd6634}.f_branding_on.blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theroot .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theroot_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#dd6634}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white){color:#59b22;border-color:#59b22}.f_branding_on.blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theroot .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theroot_on .storytype-label:not(.storytype-label--white):hover{color:#3a7119;border-color:#3a7119}.f_branding_on.blog-group-theroot .author-bio__name,.f_branding_on .blog-group-theroot .author-bio__name,.f_branding_on.f_branding_theroot_on .author-bio__name{color:#222}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name){color:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#59b22}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover{color:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#3a7119}.f_branding_on.blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theroot .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theroot_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#3a7119}.f_branding_on.blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theroot .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theroot_on .sidebar-content .newsletter-subscribe{border-color:#dd6634}.f_branding_on.blog-group-theroot .entry-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote{padding: 2px;max-width:4px}.f_branding_on.blog-group-theroot .entry-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote:before{display:none}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content{display:inline;background-color:#;-webkit-box-shadow:2px #,-2px #;box-shadow:2px #,-2px #;-webkit-box-decoration-break:clone;box-decoration-break:clone;color:white;padding:1px ;line-height:37px;font-size:26px;font-weight:normal;font-style:normal;position:relative}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{display:block;content:'';position:absolute}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:before{width:15px;height:32px;left:-2px;top:;background-image:url('data:image/svg+xml;utf8,<svg width="15" height="32" viewBox=" 15 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-green<\/title><path d="M14.345 Hv32h3.627" fill="%2359B22" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on .blog-group-theroot .entry-content .pullquote .pullquote__content:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theroot_on .entry-content .pullquote .pullquote__content:after{width:14px;height:32px;right:-2px;bottom:;background-image:url('data:image/svg+xml;utf8,<svg width="14" height="32" viewBox=" 14 32" xmlns="http://www.w3.org/2/svg"><title>theroot-quote-red<\/title><path d="M 32h14Vh-4" fill="%23DD6634" fill-rule="evenodd"/><\/svg>')}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on .blog-group-theroot .entry-content .pullquote.align--left,.f_branding_on.f_branding_theroot_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-theroot .storybreak-branded-a,.f_branding_on .blog-group-theroot .storybreak-branded-a,.f_branding_on.f_branding_theroot_on .storybreak-branded-a{min-width:24px;height:55px;background-image:url('data:image/svg+xml;utf8,<svg width="24" height="55" viewBox=" 24 55" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-afropicker<\/title><g fill-rule="evenodd"><path d="M23.32 27.59l-6.346-4.574-.475-4.45-2.83.42 2.79-1.39 2.3-3.49 2.393-2.87.14-1.63-2.347-5.31-1.22-.328-2.66.42-2.856-.66-1.62.74v1.68l2.13 1.7s2.638.54 2.83.44c.19-.1 2.686-1.2 2.686-1.2L16.2 9.17l1.73 3.3-3.3-2.74-1.162.66-1.258.233-.28.838-.852 4.264-.218-3.655-.76.343-.766-.19-1.625.81-2.3-.643L3.63 8.84l-.29.91.62 1.384.96 3.87.664.67 1.38 2.44.128 1.336-.364 3.56L 27.586v7.69h1.243V54.54c .258.21.467.467.467s.466-.21.466-.468V35.27H3.73v19.27c .26.21.468.467.468.258 .467-.21.467-.47v-19.26h1.554v19.265c .258.21.467.467.467.258 .467-.21.467-.47V35.278h1.554v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.55v19.265c .258.21.467.46.467s.463-.21.463-.47V35.278h1.554v19.265c .258.21.467.47.467.255 .464-.21.464-.47V35.278h1.555v19.265c .258.25.467.462.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.467.467s.466-.21.466-.47V35.278h1.555v19.265c .258.21.467.47.467s.466-.21.466-.47V35.278h1.246V27.59z"/><path d="M1.515 11.187c.144-.48.956-.526.956-.526l.43-1.9s-1.29-3.39-1.29-3.54c-.14-1.25-2.49-1.25-2.49l-.8-.325-1.29.56-.47 1.162 2.91 6.16s.67.144.81.96m-2.77.57l1.1-.813-2.59-5.4-.91-.336-1.48 1.484-.24 1.387 2.87 3.2m7.26-1.95l.82-.53-1.44-.39-1.4-1.246.776 1.73m2.38-8.9l-.998 1.242.562 2.8 1.46.29 1.89-.19V1.44L16.51.98m-5.938 3.62l1.84-.84 1.314.28-.46-1.58L12.32.98l-1.714.56-.643 1.56.61 2.285"/><\/g><\/svg>')}.f_branding_on.blog-group-theroot .storybreak-branded-b,.f_branding_on .blog-group-theroot .storybreak-branded-b,.f_branding_on.f_branding_theroot_on .storybreak-branded-b{min-width:32px;height:41px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="41" viewBox=" 32 41" xmlns="http://www.w3.org/2/svg"><title>storybreak-theroot-fist<\/title><g fill-rule="evenodd"><path d="M2.474 L18.62 2.18l1.2 3.524 2.85.53 3.698-.335V2.517l-2.51-2.35m-5.22 5.37l-.848-2.77-1.693-1.47-3.48.985-.75 1.85 1.466 4.1V6.52l2.868-1.473m-1.3 11.73S12.87 1.82 12.87 1.57c-.252-2.22-4.378-2.22-4.378L9.228 5.62l-2.296.982-.825 2.46L11.26 19.46s1.185.252 1.44.17c.253-.85 1.693-.924 1.693-.924l.762-1.93zM4.994 9.73l4.58 9.475-1.786 1.43-2.37-.84-5.8-5.62.422-2.432 2.625-2.6m11.313 3.433l1.376 3.34 2.22.755 1.46-.925-2.55-.677"/><path d="M6.266 4.37L6.66 34.1l-.283-2.328-2.47-4.27-1.192-1.168-1.612-6.792L 17.112l.57-1.594L4.62 21.25l3.592 1.13 2.88-1.426 1.353.336 1.347-.63.388 6.47 1.51-7.48.495-1.474 2.23-.48 2.66-1.64 5.37 4.746-3.54-5.32 4.472-3.174s-4.38 1.616-4.72 1.784c-.34.167-4.664-.78-4.664-.78l-3.15-2.985V7.99l2.462-1.31 4.783 1.64 3.587-.736 2.125.574 4.145 9.32-.257 2.81-4.24 5.35-4.74 6.124-4.933 2.44 5.4-.78 1.133 7.773H6.266z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-thetakeout.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_thetakeout_on.f_article_split_on .scroll-list-break{border-top:3px solid #E5371A}.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#E5371A;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-thetakeout .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_thetakeout_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-thetakeout .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-thetakeout .post-content .quotable a,.f_branding_on .blog-group-thetakeout .post-content .quotable a,.f_branding_on.blog-group-thetakeout .post-content footer a,.f_branding_on .blog-group-thetakeout .post-content footer a,.f_branding_on.blog-group-thetakeout .post-content h1 a,.f_branding_on .blog-group-thetakeout .post-content h1 a,.f_branding_on.blog-group-thetakeout .post-content h2 a,.f_branding_on .blog-group-thetakeout .post-content h2 a,.f_branding_on.blog-group-thetakeout .post-content h3 a,.f_branding_on .blog-group-thetakeout .post-content h3 a,.f_branding_on.blog-group-thetakeout .post-content h4 a,.f_branding_on .blog-group-thetakeout .post-content h4 a,.f_branding_on.blog-group-thetakeout .post-content h5 a,.f_branding_on .blog-group-thetakeout .post-content h5 a,.f_branding_on.blog-group-thetakeout .post-content h6 a,.f_branding_on .blog-group-thetakeout .post-content h6 a,.f_branding_on.blog-group-thetakeout .post-content li a,.f_branding_on .blog-group-thetakeout .post-content li a,.f_branding_on.blog-group-thetakeout .post-content p a,.f_branding_on .blog-group-thetakeout .post-content p a,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a,.f_branding_on.f_branding_thetakeout_on .post-content footer a,.f_branding_on.f_branding_thetakeout_on .post-content h1 a,.f_branding_on.f_branding_thetakeout_on .post-content h2 a,.f_branding_on.f_branding_thetakeout_on .post-content h3 a,.f_branding_on.f_branding_thetakeout_on .post-content h4 a,.f_branding_on.f_branding_thetakeout_on .post-content h5 a,.f_branding_on.f_branding_thetakeout_on .post-content h6 a,.f_branding_on.f_branding_thetakeout_on .post-content li a,.f_branding_on.f_branding_thetakeout_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #f9db5d;box-shadow:inset -2px #f9db5d;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on .blog-group-thetakeout .post-content .quotable a:hover,.f_branding_on.blog-group-thetakeout .post-content footer a:hover,.f_branding_on .blog-group-thetakeout .post-content footer a:hover,.f_branding_on.blog-group-thetakeout .post-content h1 a:hover,.f_branding_on .blog-group-thetakeout .post-content h1 a:hover,.f_branding_on.blog-group-thetakeout .post-content h2 a:hover,.f_branding_on .blog-group-thetakeout .post-content h2 a:hover,.f_branding_on.blog-group-thetakeout .post-content h3 a:hover,.f_branding_on .blog-group-thetakeout .post-content h3 a:hover,.f_branding_on.blog-group-thetakeout .post-content h4 a:hover,.f_branding_on .blog-group-thetakeout .post-content h4 a:hover,.f_branding_on.blog-group-thetakeout .post-content h5 a:hover,.f_branding_on .blog-group-thetakeout .post-content h5 a:hover,.f_branding_on.blog-group-thetakeout .post-content h6 a:hover,.f_branding_on .blog-group-thetakeout .post-content h6 a:hover,.f_branding_on.blog-group-thetakeout .post-content li a:hover,.f_branding_on .blog-group-thetakeout .post-content li a:hover,.f_branding_on.blog-group-thetakeout .post-content p a:hover,.f_branding_on .blog-group-thetakeout .post-content p a:hover,.f_branding_on.f_branding_thetakeout_on .post-content .quotable a:hover,.f_branding_on.f_branding_thetakeout_on .post-content footer a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h1 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h2 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h3 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h4 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h5 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content h6 a:hover,.f_branding_on.f_branding_thetakeout_on .post-content li a:hover,.f_branding_on.f_branding_thetakeout_on .post-content p a:hover{color:#F9DB5D}.f_branding_on.blog-group-thetakeout figcaption a,.f_branding_on .blog-group-thetakeout figcaption a,.f_branding_on.f_branding_thetakeout_on figcaption a{color:#E5371A}.f_branding_on.blog-group-thetakeout figcaption a:hover,.f_branding_on .blog-group-thetakeout figcaption a:hover,.f_branding_on.f_branding_thetakeout_on figcaption a:hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote,.f_branding_on.blog-group-thetakeout .entry-content blockquote,.f_branding_on .blog-group-thetakeout .entry-content blockquote,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote{border-radius:;border-left:5px solid #17466;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on .blog-group-thetakeout .editor-inner.post-content blockquote p,.f_branding_on.blog-group-thetakeout .entry-content blockquote p,.f_branding_on .blog-group-thetakeout .entry-content blockquote p,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_thetakeout_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before,.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-thetakeout .review-score,.f_branding_on .blog-group-thetakeout .review-score,.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_thetakeout_on .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#E5371A}.f_branding_on.blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-thetakeout .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_thetakeout_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white){color:#E5371A;border-color:#E5371A}.f_branding_on.blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-thetakeout .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_thetakeout_on .storytype-label:not(.storytype-label--white):hover{color:#b72c15;border-color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio__name,.f_branding_on .blog-group-thetakeout .author-bio__name,.f_branding_on.f_branding_thetakeout_on .author-bio__name{color:#222}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name){color:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#E5371A}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover{color:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#b72c15}.f_branding_on.blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-thetakeout .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_thetakeout_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#b72c15}.f_branding_on.blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-thetakeout .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_thetakeout_on .sidebar-content .newsletter-subscribe{border-color:#17466}.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{padding:3px;max-width:4px;border:1px solid #F9DB5D;border-radius:5px;font-style:normal;text-align:left;position:relative;margin-top:3rem}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote,.f_branding_on .blog-group-thetakeout .entry-content .pullquote,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:before,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:before{display:block;content:'';position:absolute;margin:;width:79px;height:33px;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="79" height="33" viewBox=" 79 33" xmlns="http://www.w3.org/2/svg" xmlns:xlink="http://www.w3.org/1999/xlink"><title>pq-thetakeout<\/title><defs><path id="a" d="M334.76 H.5v136.817h334.26z"/><path id="c" d="M22.72 v18.41HVh22.72z"/><\/defs><g fill="none" fill-rule="evenodd"><g transform="translate(-3)"><mask id="b" fill="%23fff"><use xlink:href="%23a"/><\/mask><path d="M16.262 21.627l-.775-14.652c-.27-3.65-3.31-6.475-6.972-6.475H4.28c-3.662 -6.74 2.825-6.974 6.474l-.775 14.652c-.8 1.95-.99 1.944-2.9 1.944H3.998C2.67 23.57.5 25.134.5 27.64v16.258c 1.93 1.565 3.495 3.496 3.495H331.21c1.93 3.496-1.565 3.496-3.495V27.64c-1.93-1.565-3.494-3.496-3.494H18.354c-1.1 -2.1-.85-2.92-1.944z" stroke="%23F9DB5D" mask="url(#b)"/><\/g><g transform="translate(28 14)"><mask id="d" fill="%23fff"><use xlink:href="%23c"/><\/mask><path d="M12.243 11.274c-6.46 4.37-9.844 5.722-11.13.43-.33.86-.43 1.353.127l.923.923c.435.49.31 1.45-.6 1.353-.674.493-4.34 3.2-4.37 7.384 1.5-.43 2.465-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43-2.338 -5.6-1.783-5.6-7.136M 11.274C 4.814 4.36 1.43 5.722.26c.43-.36.86-.43 1.353.124l.923.923c.43.492.37 1.46-.62 1.354-.676.496-4.36 3.2-4.368 7.387 1.46-.43 2.46-.43 2.4 4.43 1.96 4.43 4.367 2.4-2.3 4.43-4.86 4.43C3.26 18.41 16.628 11.274" fill="%23F9DB5D" mask="url(#d)"/><\/g><\/g><\/svg>');left:3px;top:-24px}.f_branding_on.blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on .blog-group-thetakeout .entry-content .pullquote:after,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on .blog-group-thetakeout .entry-content .pullquote .pullquote__content,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote .pullquote__content{padding:}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:1.5rem;margin-bottom:1rem}}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on .blog-group-thetakeout .entry-content .pullquote.align--left,.f_branding_on.f_branding_thetakeout_on .entry-content .pullquote.align--left{margin-top:3rem}}.f_branding_on.blog-group-thetakeout .storybreak-branded-a,.f_branding_on .blog-group-thetakeout .storybreak-branded-a,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-a{min-width:19px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="19" height="13" viewBox=" 19 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-a<\/title><g stroke="%23F9DB5D" fill="none" fill-rule="evenodd"><path d="M3.35 5.733c-.28.17-.47.345-.47.523v2.18c 1.728 1.413 3.14 3.14 3.14H22.77c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M26.96.5H3.116C1.676.5.5 1.677.5 3.117s1.177 2.616 2.616 2.616h.235c.255-1.48 1.548-2.616 3.96-2.616H22.77c1.548 2.84 1.136 3.92 2.616h.234c1.44 2.617-1.177 2.617-2.616 -1.44-1.178-2.617-2.617-2.617zM43.9 5.733c-.3.17-.5.345-.5.523v2.18c 1.728 1.414 3.14 3.14 3.14h16.33c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M65.834.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.54-2.616 3.9-2.616h16.324c1.55 2.84 1.136 3.93 2.616h.233c1.44 2.617-1.177 2.618-2.616C68.45 1.677 67.274.5 65.835.5zm16.993 5.233c-.3.17-.48.345-.48.523v2.18c 1.728 1.41 3.14 3.14 3.14h16.323c1.727 3.14-1.412 3.14-3.14v-2.18c-.178-.2-.352-.48-.523"/><path d="M15.572.5h-22.98c-1.44 -2.616 1.177-2.616 2.617s1.177 2.616 2.616 2.616h.235c.25-1.48 1.544-2.616 3.92-2.616h16.322c1.55 2.84 1.136 3.93 2.616h.234c1.44 2.616-1.177 2.616-2.616 -1.44-1.177-2.617-2.616-2.617z"/><\/g><\/svg>')}.f_branding_on.blog-group-thetakeout .storybreak-branded-b,.f_branding_on .blog-group-thetakeout .storybreak-branded-b,.f_branding_on.f_branding_thetakeout_on .storybreak-branded-b{min-width:43px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="43" height="13" viewBox=" 43 13" xmlns="http://www.w3.org/2/svg"><title>storybreak-thetakeout-b<\/title><path d="M7 1.38L36.154 1M7 12.38L36.154 12M.5 6.735l42.11-.445" stroke="%23E5371A" fill="none" stroke-linecap="round"/><\/svg>')}.f_branding_on.blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-splinter.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_splinter_on.f_article_split_on .scroll-list-break{border-top:3px solid #f85637}.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#f85637;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-splinter .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_splinter_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-splinter .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_splinter_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-splinter .post-content .quotable a,.f_branding_on .blog-group-splinter .post-content .quotable a,.f_branding_on.blog-group-splinter .post-content footer a,.f_branding_on .blog-group-splinter .post-content footer a,.f_branding_on.blog-group-splinter .post-content h1 a,.f_branding_on .blog-group-splinter .post-content h1 a,.f_branding_on.blog-group-splinter .post-content h2 a,.f_branding_on .blog-group-splinter .post-content h2 a,.f_branding_on.blog-group-splinter .post-content h3 a,.f_branding_on .blog-group-splinter .post-content h3 a,.f_branding_on.blog-group-splinter .post-content h4 a,.f_branding_on .blog-group-splinter .post-content h4 a,.f_branding_on.blog-group-splinter .post-content h5 a,.f_branding_on .blog-group-splinter .post-content h5 a,.f_branding_on.blog-group-splinter .post-content h6 a,.f_branding_on .blog-group-splinter .post-content h6 a,.f_branding_on.blog-group-splinter .post-content li a,.f_branding_on .blog-group-splinter .post-content li a,.f_branding_on.blog-group-splinter .post-content p a,.f_branding_on .blog-group-splinter .post-content p a,.f_branding_on.f_branding_splinter_on .post-content .quotable a,.f_branding_on.f_branding_splinter_on .post-content footer a,.f_branding_on.f_branding_splinter_on .post-content h1 a,.f_branding_on.f_branding_splinter_on .post-content h2 a,.f_branding_on.f_branding_splinter_on .post-content h3 a,.f_branding_on.f_branding_splinter_on .post-content h4 a,.f_branding_on.f_branding_splinter_on .post-content h5 a,.f_branding_on.f_branding_splinter_on .post-content h6 a,.f_branding_on.f_branding_splinter_on .post-content li a,.f_branding_on.f_branding_splinter_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #fcc2b7;box-shadow:inset -2px #fcc2b7;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-splinter .post-content .quotable a:hover,.f_branding_on .blog-group-splinter .post-content .quotable a:hover,.f_branding_on.blog-group-splinter .post-content footer a:hover,.f_branding_on .blog-group-splinter .post-content footer a:hover,.f_branding_on.blog-group-splinter .post-content h1 a:hover,.f_branding_on .blog-group-splinter .post-content h1 a:hover,.f_branding_on.blog-group-splinter .post-content h2 a:hover,.f_branding_on .blog-group-splinter .post-content h2 a:hover,.f_branding_on.blog-group-splinter .post-content h3 a:hover,.f_branding_on .blog-group-splinter .post-content h3 a:hover,.f_branding_on.blog-group-splinter .post-content h4 a:hover,.f_branding_on .blog-group-splinter .post-content h4 a:hover,.f_branding_on.blog-group-splinter .post-content h5 a:hover,.f_branding_on .blog-group-splinter .post-content h5 a:hover,.f_branding_on.blog-group-splinter .post-content h6 a:hover,.f_branding_on .blog-group-splinter .post-content h6 a:hover,.f_branding_on.blog-group-splinter .post-content li a:hover,.f_branding_on .blog-group-splinter .post-content li a:hover,.f_branding_on.blog-group-splinter .post-content p a:hover,.f_branding_on .blog-group-splinter .post-content p a:hover,.f_branding_on.f_branding_splinter_on .post-content .quotable a:hover,.f_branding_on.f_branding_splinter_on .post-content footer a:hover,.f_branding_on.f_branding_splinter_on .post-content h1 a:hover,.f_branding_on.f_branding_splinter_on .post-content h2 a:hover,.f_branding_on.f_branding_splinter_on .post-content h3 a:hover,.f_branding_on.f_branding_splinter_on .post-content h4 a:hover,.f_branding_on.f_branding_splinter_on .post-content h5 a:hover,.f_branding_on.f_branding_splinter_on .post-content h6 a:hover,.f_branding_on.f_branding_splinter_on .post-content li a:hover,.f_branding_on.f_branding_splinter_on .post-content p a:hover,.f_branding_on.blog-group-splinter figcaption a,.f_branding_on .blog-group-splinter figcaption a,.f_branding_on.f_branding_splinter_on figcaption a{color:#f85637}.f_branding_on.blog-group-splinter figcaption a:hover,.f_branding_on .blog-group-splinter figcaption a:hover,.f_branding_on.f_branding_splinter_on figcaption a:hover{color:#f32e9}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote,.f_branding_on.blog-group-splinter .entry-content blockquote,.f_branding_on .blog-group-splinter .entry-content blockquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_splinter_on .entry-content blockquote{border-radius:;border-left:5px solid #f85637;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on .blog-group-splinter .editor-inner.post-content blockquote p,.f_branding_on.blog-group-splinter .entry-content blockquote p,.f_branding_on .blog-group-splinter .entry-content blockquote p,.f_branding_on.f_branding_splinter_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_splinter_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before,.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-splinter .entry-content .pullquote__content,.f_branding_on .blog-group-splinter .entry-content .pullquote__content,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_splinter_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-splinter .review-score,.f_branding_on .blog-group-splinter .review-score,.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_splinter_on .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#f85637}.f_branding_on.blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-splinter .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_splinter_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white){color:#f85637;border-color:#f85637}.f_branding_on.blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-splinter .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_splinter_on .storytype-label:not(.storytype-label--white):hover{color:#f32e9;border-color:#f32e9}.f_branding_on.blog-group-splinter .author-bio__name,.f_branding_on .blog-group-splinter .author-bio__name,.f_branding_on.f_branding_splinter_on .author-bio__name{color:#222}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name){color:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#f85637}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover{color:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#f32e9}.f_branding_on.blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-splinter .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_splinter_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#f32e9}.f_branding_on.blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-splinter .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_splinter_on .sidebar-content .newsletter-subscribe{border-color:#f85637}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote,.f_branding_on.blog-group-splinter .entry-content .pullquote,.f_branding_on .blog-group-splinter .entry-content .pullquote,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_splinter_on .entry-content .pullquote{border-top:4px solid #f85637;padding-top:3px;padding-bottom:;position:relative;font-weight:bold;font-style:normal}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-splinter .entry-content .pullquote:before,.f_branding_on .blog-group-splinter .entry-content .pullquote:before,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:before{height:32px;width:32px;position:absolute;left:calc(5% - 18px);top:-18px;background-image:url('data:image/svg+xml;utf8,<svg width="32" height="32" viewBox=" 32 32" xmlns="http://www.w3.org/2/svg"><title>splinter-pq<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M 32h32VH"/><path d="M14 7.466c-.15-.227.162-.42.39-.423L17.657 7c.233-.2.417.195.398.427C17.82 1.26 16.49 26.6 15.94 26.6c-.547 -1.735-15.85-1.94-18.593z" fill="%23FFF"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-splinter .entry-content .pullquote:after,.f_branding_on .blog-group-splinter .entry-content .pullquote:after,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_splinter_on .entry-content .pullquote:after{display:none}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-splinter .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on .blog-group-splinter .entry-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_splinter_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-splinter .storybreak-branded-a,.f_branding_on .blog-group-splinter .storybreak-branded-a,.f_branding_on.f_branding_splinter_on .storybreak-branded-a{min-width:31px;height:5px;background-image:url('data:image/svg+xml;utf8,<svg width="31" height="5" viewBox=" 31 5" xmlns="http://www.w3.org/2/svg"><title>storybreak-1-splinter<\/title><g fill="none" fill-rule="evenodd"><path fill="%23F85637" d="M1.47 9.33l6.696-3.54v7.495l-6.696 3.6"/><path d="M9.167 24.32H7.223V5.27c-1.455-1.183-2.637-2.637-2.637S1.95 3.572 1.95 5.27V24.32H.5V5.27C.5 2.5 2.6.447 4.585.447c2.527 4.58 2.54 4.58 4.58V24.32z" fill="%23"/><path d="M11.84 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.637-1.18 2.637-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.81c 2.53-2.5 4.58-4.58 4.58" fill="%23"/><path d="M19.2 17.935c-1.454 -2.637 1.183-2.637 2.638v6.8c 1.455 1.183 2.638 2.637 2.638s2.638-1.18 2.638-2.63v-6.8c-1.45-1.184-2.64-2.638-2.64m 14.2c-2.525 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.55-4.58 4.58-4.58 2.526 4.58 2.6 4.58 4.58v6.8c 2.53-2.54 4.58-4.58 4.58" fill="%23"/><path d="M26.2 17.935c-1.453 -2.636 1.183-2.636 2.638v6.8c 1.455 1.183 2.638 2.637 2.638 1.46 2.64-1.18 2.64-2.63v-6.8c-1.45-1.18-2.64-2.63-2.64m 14.2c-2.52 -4.58-2.5-4.58-4.58v-6.8c-2.52 2.6-4.58 4.58-4.58 2.53 4.58 2.6 4.58 4.58v6.8c 2.53-2.5 4.58-4.58 4.58m-1.65 7.36h-5.14v-1.95h5.14c1.46 2.64-1.18 2.64-2.63s-1.18-2.633-2.64-2.633H4.59c-1.454 -2.637 1.183-2.637 2.637H.1c-2.524 2.55-4.58 4.58-4.58h1.96c2.526 4.58 2.56 4.58 4.58 2.527-2.54 4.58-4.58 4.58" fill="%23"/><path d="M15.36 49.895c-4.86 -7.94-1.62-1.85-4.51C1.63 42.475 38.62 34.535V2.99h1.955v13.545c 3.564 1.4 6.926 3.94 9.466 2.538 2.54 5.9 3.94 9.466 3.94 3.57 6.93-1.4 9.47-3.94s3.94-5.9 3.94-9.46V2.99h1.96v13.545c 4.87-1.6 7.94-4.51 1.85-2.91 2.98-6.76 4.51-1.85 4.51" fill="%23"/><\/g><\/svg>')}.f_branding_on.blog-group-splinter .storybreak-branded-b,.f_branding_on .blog-group-splinter .storybreak-branded-b,.f_branding_on.f_branding_splinter_on .storybreak-branded-b{display:none !important}.f_branding_on.blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-avclub.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_avclub_on.f_article_split_on .scroll-list-break{border-top:3px solid #1c263c}.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#91dbd9;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-avclub .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_avclub_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-avclub .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_avclub_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-avclub .post-content .quotable a,.f_branding_on .blog-group-avclub .post-content .quotable a,.f_branding_on.blog-group-avclub .post-content footer a,.f_branding_on .blog-group-avclub .post-content footer a,.f_branding_on.blog-group-avclub .post-content h1 a,.f_branding_on .blog-group-avclub .post-content h1 a,.f_branding_on.blog-group-avclub .post-content h2 a,.f_branding_on .blog-group-avclub .post-content h2 a,.f_branding_on.blog-group-avclub .post-content h3 a,.f_branding_on .blog-group-avclub .post-content h3 a,.f_branding_on.blog-group-avclub .post-content h4 a,.f_branding_on .blog-group-avclub .post-content h4 a,.f_branding_on.blog-group-avclub .post-content h5 a,.f_branding_on .blog-group-avclub .post-content h5 a,.f_branding_on.blog-group-avclub .post-content h6 a,.f_branding_on .blog-group-avclub .post-content h6 a,.f_branding_on.blog-group-avclub .post-content li a,.f_branding_on .blog-group-avclub .post-content li a,.f_branding_on.blog-group-avclub .post-content p a,.f_branding_on .blog-group-avclub .post-content p a,.f_branding_on.f_branding_avclub_on .post-content .quotable a,.f_branding_on.f_branding_avclub_on .post-content footer a,.f_branding_on.f_branding_avclub_on .post-content h1 a,.f_branding_on.f_branding_avclub_on .post-content h2 a,.f_branding_on.f_branding_avclub_on .post-content h3 a,.f_branding_on.f_branding_avclub_on .post-content h4 a,.f_branding_on.f_branding_avclub_on .post-content h5 a,.f_branding_on.f_branding_avclub_on .post-content h6 a,.f_branding_on.f_branding_avclub_on .post-content li a,.f_branding_on.f_branding_avclub_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #e33af5;box-shadow:inset -2px #e33af5;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-avclub .post-content .quotable a:hover,.f_branding_on .blog-group-avclub .post-content .quotable a:hover,.f_branding_on.blog-group-avclub .post-content footer a:hover,.f_branding_on .blog-group-avclub .post-content footer a:hover,.f_branding_on.blog-group-avclub .post-content h1 a:hover,.f_branding_on .blog-group-avclub .post-content h1 a:hover,.f_branding_on.blog-group-avclub .post-content h2 a:hover,.f_branding_on .blog-group-avclub .post-content h2 a:hover,.f_branding_on.blog-group-avclub .post-content h3 a:hover,.f_branding_on .blog-group-avclub .post-content h3 a:hover,.f_branding_on.blog-group-avclub .post-content h4 a:hover,.f_branding_on .blog-group-avclub .post-content h4 a:hover,.f_branding_on.blog-group-avclub .post-content h5 a:hover,.f_branding_on .blog-group-avclub .post-content h5 a:hover,.f_branding_on.blog-group-avclub .post-content h6 a:hover,.f_branding_on .blog-group-avclub .post-content h6 a:hover,.f_branding_on.blog-group-avclub .post-content li a:hover,.f_branding_on .blog-group-avclub .post-content li a:hover,.f_branding_on.blog-group-avclub .post-content p a:hover,.f_branding_on .blog-group-avclub .post-content p a:hover,.f_branding_on.f_branding_avclub_on .post-content .quotable a:hover,.f_branding_on.f_branding_avclub_on .post-content footer a:hover,.f_branding_on.f_branding_avclub_on .post-content h1 a:hover,.f_branding_on.f_branding_avclub_on .post-content h2 a:hover,.f_branding_on.f_branding_avclub_on .post-content h3 a:hover,.f_branding_on.f_branding_avclub_on .post-content h4 a:hover,.f_branding_on.f_branding_avclub_on .post-content h5 a:hover,.f_branding_on.f_branding_avclub_on .post-content h6 a:hover,.f_branding_on.f_branding_avclub_on .post-content li a:hover,.f_branding_on.f_branding_avclub_on .post-content p a:hover,.f_branding_on.blog-group-avclub figcaption a,.f_branding_on .blog-group-avclub figcaption a,.f_branding_on.f_branding_avclub_on figcaption a{color:#948a3}.f_branding_on.blog-group-avclub figcaption a:hover,.f_branding_on .blog-group-avclub figcaption a:hover,.f_branding_on.f_branding_avclub_on figcaption a:hover{color:#68672}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote,.f_branding_on.blog-group-avclub .entry-content blockquote,.f_branding_on .blog-group-avclub .entry-content blockquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_avclub_on .entry-content blockquote{border-radius:;border-left:5px solid #1c263c;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on .blog-group-avclub .editor-inner.post-content blockquote p,.f_branding_on.blog-group-avclub .entry-content blockquote p,.f_branding_on .blog-group-avclub .entry-content blockquote p,.f_branding_on.f_branding_avclub_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_avclub_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before,.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-avclub .entry-content .pullquote__content,.f_branding_on .blog-group-avclub .entry-content .pullquote__content,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_avclub_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-avclub .review-score,.f_branding_on .blog-group-avclub .review-score,.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_avclub_on .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#1c263c}.f_branding_on.blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-avclub .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_avclub_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#1c263c}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white){color:#948a3;border-color:#948a3}.f_branding_on.blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-avclub .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_avclub_on .storytype-label:not(.storytype-label--white):hover{color:#68672;border-color:#68672}.f_branding_on.blog-group-avclub .author-bio__name,.f_branding_on .blog-group-avclub .author-bio__name,.f_branding_on.f_branding_avclub_on .author-bio__name{color:#222}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name){color:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#948a3}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover{color:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#68672}.f_branding_on.blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-avclub .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_avclub_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#68672}.f_branding_on.blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-avclub .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_avclub_on .sidebar-content .newsletter-subscribe{border-color:#1c263c}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote,.f_branding_on.blog-group-avclub .entry-content .pullquote,.f_branding_on .blog-group-avclub .entry-content .pullquote,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote,.f_branding_on.f_branding_avclub_on .entry-content .pullquote{border:2px solid #91dbd9;padding:3px;position:relative;font-weight:normal;font-style:normal}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-avclub .entry-content .pullquote:before,.f_branding_on .blog-group-avclub .entry-content .pullquote:before,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:before{height:3px;width:4px;position:absolute;left:-14px;top:-14px;background-repeat:no-repeat;background-color:#fff;background-image:url('data:image/svg+xml;utf8,<svg width="33" height="23" viewBox=" 33 23" xmlns="http://www.w3.org/2/svg"><title>avc-pq<\/title><path d="M22.725 4.39c-1.4 1.14-1.763 2.345-2.157 3.61-.274.894-.41 1.736-.41 2.53 .496.6 1.55.186 1.674 1.362-1.586 3.223-2.38 5.58-2.38 2.3 3.657.577 4.872 1.727 1.213 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.38 1.86-5.17 1.86-1.34 -2.53-.243-3.57-.723-1.43-.487-1.86-1.187-2.455-2.13-.573-.745-1.3-1.76-1.377-3.5-.348-1.29-.52-2.69-.52-4.24 -2.652.682-5.94 2.44-7.326 1.362-2.23 3.37-3.956 6.25-5.17l.67 1.376c-1.34.62-2.53 1.52-3.57 2.64m-17.518 C4.165 5.53 3.447 6.734 3.5 8c-.274.894-.41 1.736-.41 2.53 .496.62 1.55.188 1.674 1.362-1.586 3.22-2.38 5.578-2.38 2.32 3.66.577 4.872 1.727 1.215 1.16 1.822 2.76 1.822 4.82 1.987-.656 3.58-1.97 4.78-1.316 1.24-3.5 1.86-5.28 1.86-1.315 -2.492-.243-3.533-.723-1.48-.487-1.86-1.187-2.46-2.13-.57-.77-1.35-1.795-1.395-3.7C.18 15.78 14.382 12.87c-2.653.69-5.95 2.62-7.327 1.38-2.23 3.392-3.956 6.47-5.17l.66 1.377c-1.338.62-2.53 1.5-3.57 2.64" fill="%231C263C" fill-rule="evenodd"/><\/svg>')}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-avclub .entry-content .pullquote:after,.f_branding_on .blog-group-avclub .entry-content .pullquote:after,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_avclub_on .entry-content .pullquote:after{display:none}.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{text-align:center}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on .blog-group-avclub .editor-inner.post-content .pullquote.align--left,.f_branding_on.blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on .blog-group-avclub .entry-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .editor-inner.post-content .pullquote.align--left,.f_branding_on.f_branding_avclub_on .entry-content .pullquote.align--left{margin-bottom:1rem}}.f_branding_on.blog-group-avclub .storybreak-branded-a,.f_branding_on .blog-group-avclub .storybreak-branded-a,.f_branding_on.f_branding_avclub_on .storybreak-branded-a{min-width:18px;height:11px;background-image:url('data:image/svg+xml;utf8,<svg width="18" height="11" viewBox=" 18 11" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-a<\/title><g fill="none" fill-rule="evenodd"><path fill="%231C263C" d="M4.63 L 1.56h9.59"/><path fill="%2391DBD9" d="M7.8 l4.784 1.56L17.658.3"/><\/g><\/svg>')}.f_branding_on.blog-group-avclub .storybreak-branded-b,.f_branding_on .blog-group-avclub .storybreak-branded-b,.f_branding_on.f_branding_avclub_on .storybreak-branded-b{min-width:162px;height:13px;background-image:url('data:image/svg+xml;utf8,<svg width="162" height="13" viewBox=" 162 13" xmlns="http://www.w3.org/2/svg"><title>avc-storybreak-b<\/title><g fill="none" fill-rule="evenodd"><path fill="%23948A3" d="M93.427 6.925h67.595V6.14H93.427M 6.925h67.595V6.14H"/><path d="M86.664 6.216c 3.433-2.783 6.216-6.216 6.215-3.433 -6.216-2.78-6.216-6.213S77.15 8.448 c3.433 6.216 2.783 6.216 6.216" fill="%23E6E6E6"/><\/g><\/svg>')}.f_branding_on.blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-theonion.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_theonion_on.f_article_split_on .scroll-list-break{border-top:3px solid #6b3a}.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#94d1b4;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-theonion .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_theonion_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-theonion .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_theonion_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-theonion .post-content .quotable a,.f_branding_on .blog-group-theonion .post-content .quotable a,.f_branding_on.blog-group-theonion .post-content footer a,.f_branding_on .blog-group-theonion .post-content footer a,.f_branding_on.blog-group-theonion .post-content h1 a,.f_branding_on .blog-group-theonion .post-content h1 a,.f_branding_on.blog-group-theonion .post-content h2 a,.f_branding_on .blog-group-theonion .post-content h2 a,.f_branding_on.blog-group-theonion .post-content h3 a,.f_branding_on .blog-group-theonion .post-content h3 a,.f_branding_on.blog-group-theonion .post-content h4 a,.f_branding_on .blog-group-theonion .post-content h4 a,.f_branding_on.blog-group-theonion .post-content h5 a,.f_branding_on .blog-group-theonion .post-content h5 a,.f_branding_on.blog-group-theonion .post-content h6 a,.f_branding_on .blog-group-theonion .post-content h6 a,.f_branding_on.blog-group-theonion .post-content li a,.f_branding_on .blog-group-theonion .post-content li a,.f_branding_on.blog-group-theonion .post-content p a,.f_branding_on .blog-group-theonion .post-content p a,.f_branding_on.f_branding_theonion_on .post-content .quotable a,.f_branding_on.f_branding_theonion_on .post-content footer a,.f_branding_on.f_branding_theonion_on .post-content h1 a,.f_branding_on.f_branding_theonion_on .post-content h2 a,.f_branding_on.f_branding_theonion_on .post-content h3 a,.f_branding_on.f_branding_theonion_on .post-content h4 a,.f_branding_on.f_branding_theonion_on .post-content h5 a,.f_branding_on.f_branding_theonion_on .post-content h6 a,.f_branding_on.f_branding_theonion_on .post-content li a,.f_branding_on.f_branding_theonion_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #94d1b4;box-shadow:inset -2px #94d1b4;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-theonion .post-content .quotable a:hover,.f_branding_on .blog-group-theonion .post-content .quotable a:hover,.f_branding_on.blog-group-theonion .post-content footer a:hover,.f_branding_on .blog-group-theonion .post-content footer a:hover,.f_branding_on.blog-group-theonion .post-content h1 a:hover,.f_branding_on .blog-group-theonion .post-content h1 a:hover,.f_branding_on.blog-group-theonion .post-content h2 a:hover,.f_branding_on .blog-group-theonion .post-content h2 a:hover,.f_branding_on.blog-group-theonion .post-content h3 a:hover,.f_branding_on .blog-group-theonion .post-content h3 a:hover,.f_branding_on.blog-group-theonion .post-content h4 a:hover,.f_branding_on .blog-group-theonion .post-content h4 a:hover,.f_branding_on.blog-group-theonion .post-content h5 a:hover,.f_branding_on .blog-group-theonion .post-content h5 a:hover,.f_branding_on.blog-group-theonion .post-content h6 a:hover,.f_branding_on .blog-group-theonion .post-content h6 a:hover,.f_branding_on.blog-group-theonion .post-content li a:hover,.f_branding_on .blog-group-theonion .post-content li a:hover,.f_branding_on.blog-group-theonion .post-content p a:hover,.f_branding_on .blog-group-theonion .post-content p a:hover,.f_branding_on.f_branding_theonion_on .post-content .quotable a:hover,.f_branding_on.f_branding_theonion_on .post-content footer a:hover,.f_branding_on.f_branding_theonion_on .post-content h1 a:hover,.f_branding_on.f_branding_theonion_on .post-content h2 a:hover,.f_branding_on.f_branding_theonion_on .post-content h3 a:hover,.f_branding_on.f_branding_theonion_on .post-content h4 a:hover,.f_branding_on.f_branding_theonion_on .post-content h5 a:hover,.f_branding_on.f_branding_theonion_on .post-content h6 a:hover,.f_branding_on.f_branding_theonion_on .post-content li a:hover,.f_branding_on.f_branding_theonion_on .post-content p a:hover{color:#94d1b4}.f_branding_on.blog-group-theonion figcaption a,.f_branding_on .blog-group-theonion figcaption a,.f_branding_on.f_branding_theonion_on figcaption a{color:#6b3a}.f_branding_on.blog-group-theonion figcaption a:hover,.f_branding_on .blog-group-theonion figcaption a:hover,.f_branding_on.f_branding_theonion_on figcaption a:hover{color:#381e}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote,.f_branding_on.blog-group-theonion .entry-content blockquote,.f_branding_on .blog-group-theonion .entry-content blockquote,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_theonion_on .entry-content blockquote{border-radius:;border-left:5px solid #94d1b4;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on .blog-group-theonion .editor-inner.post-content blockquote p,.f_branding_on.blog-group-theonion .entry-content blockquote p,.f_branding_on .blog-group-theonion .entry-content blockquote p,.f_branding_on.f_branding_theonion_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_theonion_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-theonion .entry-content .pullquote:before,.f_branding_on .blog-group-theonion .entry-content .pullquote:before,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:before,.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-theonion .entry-content .pullquote:after,.f_branding_on .blog-group-theonion .entry-content .pullquote:after,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_theonion_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-theonion .entry-content .pullquote__content,.f_branding_on .blog-group-theonion .entry-content .pullquote__content,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_theonion_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-theonion .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on .blog-group-theonion .entry-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_theonion_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-theonion .storybreak-branded-a,.f_branding_on .blog-group-theonion .storybreak-branded-a,.f_branding_on.blog-group-theonion .storybreak-branded-b,.f_branding_on .blog-group-theonion .storybreak-branded-b,.f_branding_on.f_branding_theonion_on .storybreak-branded-a,.f_branding_on.f_branding_theonion_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-theonion .review-score,.f_branding_on .blog-group-theonion .review-score,.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_theonion_on .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#6b3a}.f_branding_on.blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-theonion .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_theonion_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white){color:#6b3a;border-color:#6b3a}.f_branding_on.blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-theonion .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_theonion_on .storytype-label:not(.storytype-label--white):hover{color:#381e;border-color:#381e}.f_branding_on.blog-group-theonion .author-bio__name,.f_branding_on .blog-group-theonion .author-bio__name,.f_branding_on.f_branding_theonion_on .author-bio__name{color:#222}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name){color:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#6b3a}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover{color:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#381e}.f_branding_on.blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-theonion .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_theonion_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#381e}.f_branding_on.blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-theonion .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_theonion_on .sidebar-content .newsletter-subscribe{border-color:#94d1b4}.f_branding_on.blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on .blog-group-earther.f_article_split_on .scroll-list-break,.f_branding_on.f_branding_earther_on.f_article_split_on .scroll-list-break{border-top:3px solid #75b2}.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{margin:13px 1px -5px;float:left;color:#75b2;font-family:"ProximaNovaCond",sans-serif;font-weight:bold;font-size:1px;line-height:7px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{line-height:65px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on .blog-group-earther.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on .blog-group-earther .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on.f_dropcap_on .post-item-permalink .post-content:not(.reply__content)>p:first-of-type:first-letter,.f_branding_on.f_branding_earther_on .post-item-permalink .post-content.dropcap--on>p:first-of-type:first-letter{font-size:117px;line-height:8px}}.f_branding_on.blog-group-earther .post-content .inset--story__headline a,.f_branding_on .blog-group-earther .post-content .inset--story__headline a,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a{color:#;-webkit-box-shadow:none;box-shadow:none}.f_branding_on.blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on .blog-group-earther .post-content .inset--story__headline a:hover,.f_branding_on.f_branding_earther_on .post-content .inset--story__headline a:hover{text-decoration:underline;color:#}.f_branding_on.blog-group-earther .post-content .quotable a,.f_branding_on .blog-group-earther .post-content .quotable a,.f_branding_on.blog-group-earther .post-content footer a,.f_branding_on .blog-group-earther .post-content footer a,.f_branding_on.blog-group-earther .post-content h1 a,.f_branding_on .blog-group-earther .post-content h1 a,.f_branding_on.blog-group-earther .post-content h2 a,.f_branding_on .blog-group-earther .post-content h2 a,.f_branding_on.blog-group-earther .post-content h3 a,.f_branding_on .blog-group-earther .post-content h3 a,.f_branding_on.blog-group-earther .post-content h4 a,.f_branding_on .blog-group-earther .post-content h4 a,.f_branding_on.blog-group-earther .post-content h5 a,.f_branding_on .blog-group-earther .post-content h5 a,.f_branding_on.blog-group-earther .post-content h6 a,.f_branding_on .blog-group-earther .post-content h6 a,.f_branding_on.blog-group-earther .post-content li a,.f_branding_on .blog-group-earther .post-content li a,.f_branding_on.blog-group-earther .post-content p a,.f_branding_on .blog-group-earther .post-content p a,.f_branding_on.f_branding_earther_on .post-content .quotable a,.f_branding_on.f_branding_earther_on .post-content footer a,.f_branding_on.f_branding_earther_on .post-content h1 a,.f_branding_on.f_branding_earther_on .post-content h2 a,.f_branding_on.f_branding_earther_on .post-content h3 a,.f_branding_on.f_branding_earther_on .post-content h4 a,.f_branding_on.f_branding_earther_on .post-content h5 a,.f_branding_on.f_branding_earther_on .post-content h6 a,.f_branding_on.f_branding_earther_on .post-content li a,.f_branding_on.f_branding_earther_on .post-content p a{color:#222;-webkit-box-shadow:inset -2px #38bbff;box-shadow:inset -2px #38bbff;-webkit-transition:color .1s ease-out;transition:color .1s ease-out;text-decoration:none}.f_branding_on.blog-group-earther .post-content .quotable a:hover,.f_branding_on .blog-group-earther .post-content .quotable a:hover,.f_branding_on.blog-group-earther .post-content footer a:hover,.f_branding_on .blog-group-earther .post-content footer a:hover,.f_branding_on.blog-group-earther .post-content h1 a:hover,.f_branding_on .blog-group-earther .post-content h1 a:hover,.f_branding_on.blog-group-earther .post-content h2 a:hover,.f_branding_on .blog-group-earther .post-content h2 a:hover,.f_branding_on.blog-group-earther .post-content h3 a:hover,.f_branding_on .blog-group-earther .post-content h3 a:hover,.f_branding_on.blog-group-earther .post-content h4 a:hover,.f_branding_on .blog-group-earther .post-content h4 a:hover,.f_branding_on.blog-group-earther .post-content h5 a:hover,.f_branding_on .blog-group-earther .post-content h5 a:hover,.f_branding_on.blog-group-earther .post-content h6 a:hover,.f_branding_on .blog-group-earther .post-content h6 a:hover,.f_branding_on.blog-group-earther .post-content li a:hover,.f_branding_on .blog-group-earther .post-content li a:hover,.f_branding_on.blog-group-earther .post-content p a:hover,.f_branding_on .blog-group-earther .post-content p a:hover,.f_branding_on.f_branding_earther_on .post-content .quotable a:hover,.f_branding_on.f_branding_earther_on .post-content footer a:hover,.f_branding_on.f_branding_earther_on .post-content h1 a:hover,.f_branding_on.f_branding_earther_on .post-content h2 a:hover,.f_branding_on.f_branding_earther_on .post-content h3 a:hover,.f_branding_on.f_branding_earther_on .post-content h4 a:hover,.f_branding_on.f_branding_earther_on .post-content h5 a:hover,.f_branding_on.f_branding_earther_on .post-content h6 a:hover,.f_branding_on.f_branding_earther_on .post-content li a:hover,.f_branding_on.f_branding_earther_on .post-content p a:hover,.f_branding_on.blog-group-earther figcaption a,.f_branding_on .blog-group-earther figcaption a,.f_branding_on.f_branding_earther_on figcaption a{color:#75b2}.f_branding_on.blog-group-earther figcaption a:hover,.f_branding_on .blog-group-earther figcaption a:hover,.f_branding_on.f_branding_earther_on figcaption a:hover{color:#537f}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote,.f_branding_on.blog-group-earther .entry-content blockquote,.f_branding_on .blog-group-earther .entry-content blockquote,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote,.f_branding_on.f_branding_earther_on .entry-content blockquote{border-radius:;border-left:5px solid #75b2;padding: 1.125rem;background-color:transparent;margin-top:2rem;margin-bottom:2rem}.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:15px;line-height:28px}@media only screen and (max-width: 37.438em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:14px;line-height:26px}}@media only screen and (min-width: 9.62em){.f_branding_on.blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on .blog-group-earther .editor-inner.post-content blockquote p,.f_branding_on.blog-group-earther .entry-content blockquote p,.f_branding_on .blog-group-earther .entry-content blockquote p,.f_branding_on.f_branding_earther_on .editor-inner.post-content blockquote p,.f_branding_on.f_branding_earther_on .entry-content blockquote p{font-size:16px;line-height:29px}}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:before,.f_branding_on.blog-group-earther .entry-content .pullquote:before,.f_branding_on .blog-group-earther .entry-content .pullquote:before,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:before,.f_branding_on.f_branding_earther_on .entry-content .pullquote:before,.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote:after,.f_branding_on.blog-group-earther .entry-content .pullquote:after,.f_branding_on .blog-group-earther .entry-content .pullquote:after,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote:after,.f_branding_on.f_branding_earther_on .entry-content .pullquote:after{border:}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote__content,.f_branding_on.blog-group-earther .entry-content .pullquote__content,.f_branding_on .blog-group-earther .entry-content .pullquote__content,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote__content,.f_branding_on.f_branding_earther_on .entry-content .pullquote__content{display:block;padding-left:1.125rem;padding-right:1.125rem}.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{margin-top:2.5rem;margin-bottom:2.5rem}@media only screen and (min-width: 37.5em){.f_branding_on.blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on .blog-group-earther .editor-inner.post-content .pullquote.align--center,.f_branding_on.blog-group-earther .entry-content .pullquote.align--center,.f_branding_on .blog-group-earther .entry-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .editor-inner.post-content .pullquote.align--center,.f_branding_on.f_branding_earther_on .entry-content .pullquote.align--center{max-width:66%}}.f_branding_on.blog-group-earther .storybreak-branded-a,.f_branding_on .blog-group-earther .storybreak-branded-a,.f_branding_on.blog-group-earther .storybreak-branded-b,.f_branding_on .blog-group-earther .storybreak-branded-b,.f_branding_on.f_branding_earther_on .storybreak-branded-a,.f_branding_on.f_branding_earther_on .storybreak-branded-b{border:;background-position:center;background-repeat:no-repeat}.f_branding_on.blog-group-earther .review-score,.f_branding_on .blog-group-earther .review-score,.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head,.f_branding_on.f_branding_earther_on .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head{background-color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label{color:#fff;border-color:#fff}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .storytype-label-wrapper--head .storytype-label:hover{background-color:#fff;color:#75b2}.f_branding_on.blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on .blog-group-earther .reviewbox-inset.align--fullbleed .review-box__head-content .review-score,.f_branding_on.f_branding_earther_on .reviewbox-inset.align--fullbleed .review-box__head-content .review-score{color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white),.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white){color:#75b2;border-color:#75b2}.f_branding_on.blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on .blog-group-earther .storytype-label:not(.storytype-label--white):hover,.f_branding_on.f_branding_earther_on .storytype-label:not(.storytype-label--white):hover{color:#537f;border-color:#537f}.f_branding_on.blog-group-earther .author-bio__name,.f_branding_on .blog-group-earther .author-bio__name,.f_branding_on.f_branding_earther_on .author-bio__name{color:#222}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name){color:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon--filled{fill:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name) .svg-icon:not(.svg-icon--filled){stroke:#75b2}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover{color:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon--filled,.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon--filled{fill:#537f}.f_branding_on.blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on .blog-group-earther .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled),.f_branding_on.f_branding_earther_on .author-bio a:not(.author-bio__name):hover .svg-icon:not(.svg-icon--filled){stroke:#537f}.f_branding_on.blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on .blog-group-earther .sidebar-content .newsletter-subscribe,.f_branding_on.f_branding_earther_on .sidebar-content .newsletter-subscribe{border-color:#75b2}.storytype--box{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;margin-bottom:1.5rem}.storytype--box__text{padding:}.storytype--box__title{margin:}.storytype--box__description{font-family:"ElizabethSerif",Georgia,serif;font-size:14px;line-height:1.5;color:#666;margin-top:.5rem}@media only screen and (max-width: 37.438em){.storytype--box__description{margin-bottom:1.5rem}}.storytype--box__asset img{display:block;width:1%}.storytype--box.storytype--box__wrap{margin-bottom:2.5rem;padding:1.125rem ;background-color:#f5f5f5}.storytype--box.storytype--box__wrap .storytype--box__text{padding: 1.125rem}@media only screen and (min-width: 37.5em){.storytype__content .postlist__item--compact{padding-left:1.125rem}.storytype__content .postlist__item--compact .item__content--thumb .asset{padding-left:}}.storytype--nav{margin: -16px;min-height:calc(36px + 2rem)}@media only screen and (max-width: 37.438em){.storytype--nav{min-height:calc(36px + 2rem)}}@media only screen and (max-width: 37.438em){.storytype--nav--two-dropdowns{min-height:calc(36px * 2 + 1rem + 2rem)}}.storytype--nav__categoryselector,.storytype--nav__subcategoryselector{margin-bottom:2rem}@media only screen and (max-width: 37.438em){.storytype--nav__subcategoryselector{margin-top:-1rem}}.storytype--nav .select-component-list{max-height:3px;overflow-y:scroll}.storytype--nav .select-component-list ul{overflow-y:hidden}@media only screen and (max-width: 37.438em){.storytype--section{margin-left:-1.125rem;margin-right:-1.125rem}}.storytype--section header{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:wrap;flex-wrap:wrap;-webkit-box-pack:justify;-ms-flex-pack:justify;justify-content:space-between;border-bottom:1px solid #e5e5e5;margin-bottom:15px}@media only screen and (max-width: 37.438em){.storytype--section header{margin-left:1.125rem;margin-right:1.125rem}}.storytype--section header h2{margin-bottom:5px}.storytype--section header h2 a{color:#}.storytype--section__viewall{text-transform:uppercase;display:inline-block;-ms-flex-item-align:center;align-self:center}.storytype--section__wrapper{margin-bottom:3rem}@media only screen and (max-width: 37.438em){.storytype--section__wrapper{width:1%;overflow-x:scroll;padding-left:1.125rem}}.storytype--section__items{display:-webkit-box;display:-ms-flexbox;display:flex;-ms-flex-wrap:nowrap;flex-wrap:nowrap;-webkit-box-pack:start;-ms-flex-pack:start;justify-content:flex-start}.storytype--section__item{width:31.8%;position:relative;-ms-flex-negative:;flex-shrink:;margin-right:1.125rem}.storytype--section__item:last-of-type{margin-right:}@media only screen and (max-width: 37.438em){.storytype--section__item{width:2px;margin-right:1.125rem}.storytype--section__item:last-of-type{width:218px;padding-right:1.125rem}}.storytype--section .item__image{display:block;margin-bottom:1px}.storytype--section .headline{margin-bottom:}.storytype-label{font-family:"ProximaNovaCond",sans-serif;font-size:15px;font-weight:bold;padding-right:1px;text-transform:uppercase;color:#93ec}.storytype-label:hover{color:#73b9;text-decoration:none}.storytype-label:hover.storytype-label--white{background-color:#ffffff;color:#}.storytype-label--white{color:#ffffff}.storytype-label--outlined{border:1px solid #93ec;line-height:27px;margin-right:5px;height:27px;padding: 8px}.storytype-label--outlined.storytype-label--white{border-color:#ffffff;color:white}.storytype-label-wrapper{display:-webkit-box;display:-ms-flexbox;display:flex;max-width:1%;overflow:hidden}.storytype-label-wrapper--small-margin{margin-bottom:5px}.storytype-label-wrapper--medium-margin{margin-bottom:1px}.storytype-label-wrapper--large-margin{margin-bottom:15px}.storytype-label-wrapper--huge-margin{margin-bottom:2px}@media only screen and (max-width: 53.125em){.storytype-label-wrapper--curation{-webkit-box-pack:center;-ms-flex-pack:center;justify-content:center;padding: 18px}}.storytype-label-wrapper .storytype-label{overflow:hidden;text-overflow:ellipsis;white-space:nowrap}.storytype-label-wrapper :last-child{margin-right:}.postlist__item--compact{margin-bottom:3px;padding-bottom:3px;border-bottom:1px solid #e5e5e5}.postlist__item--compact:last-of-type{border-bottom:;margin-bottom:}.postlist__item--compact .item__content{margin: -1.125rem;max-width:none;width:auto}.postlist__item--compact .item__content:after,.postlist__item--compact .item__content:before{content:" ";display:table}.postlist__item--compact .item__content:after{clear:both}.postlist__item--compact .item__text{padding-left:1.125rem;padding-right:1.125rem;float:left}@media only screen and (min-width: 37.5em){.postlist__item--compact .item__content--thumb .asset{padding-left:1.125rem;padding-right:1.125rem;width:33.333%;float:left;margin-bottom:}.postlist__item--compact .item__content--thumb .item__text{padding-left:1.125rem;padding-right:1.125rem;width:66.667%;float:left;padding-left:}}.postlist__item--compact .asset{width:1%;position:relative;margin: 2px}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{padding:}}.postlist__item--compact .asset img{width:1%}.postlist__item--compact .asset img[data-sizes=auto],.postlist__item--compact .asset video[data-sizes=auto]{display:block;width:1%}@media only screen and (max-width: 37.438em){.postlist__item--compact .asset{float:none}}.postlist__item--compact .headline{font-size:24px;margin-bottom:5px}html.fallback-fonts .postlist__item--compact .headline{font-family:"Arial Narrow",Arial,sans-serif;font-size:22.68px;line-height:1.349;letter-spacing:.5px}.postlist__item--compact .meta--pe{display:block;margin-bottom:7px}.postlist__item--compact .meta__container{font-size:15px}.postlist__item--compact .meta__byline,.postlist__item--compact .meta__time{display:inline-block}.postlist__item--compact .meta__byline:after{display:inline-block;content:'*';color:#aaa;padding: 5px}.postlist__item--compact .meta__right{display:none}.postlist__item--compact .excerpt{font-family:"ElizabethSerif",Georgia,serif}.postlist__item--compact .excerpt p{margin-bottom:}</style><script>window._K_MSGS = []; window._K_MSG_L = function (e) {_K_MSGS.push(e);}; window.addEventListener('message', window._K_MSG_L);</script><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/blog-2545d75c35bc9d9491eb61d4b29724.css" as="style" onload="this.rel='stylesheet'"><link rel="preload" href="//x.kinja-static.com/assets/stylesheets/insets-13541366ddfac4e8eca127496e.css" as="style" onload="this.rel='stylesheet'"><script src="https://kinja.com/api/profile/accountwithtoken?jsonp=_fasttoken&newFollows=true" async defer></script><meta name="dynamic-stylesheet" id="editor-css-url" content="//x.kinja-static.com/assets/stylesheets/editor-7ed31791155c6bedc63fda5ded339b2.css"><meta name="google-site-verification" content="P13oAn8o8LB6FVCJWKsHWXvxfbR-SJrmvox6EgULpUs" /><meta name="viewport" content="width=device-width, initial-scale=1., minimum-scale=1.,maximum-scale=1." /><meta name="ROBOTS" content="INDEX, FOLLOW" /><title>The 218 Ford F-15 Gets A New Engine And More Horsepower
/ 2.7EB vs 3.5EB? #35
I don't think your link(s) worked.haha I get your apprehensiveness over the AFM, it has had many problems. You really won't go wrong with the 2.7 ecoboost if that's the engine you end up choosing. It's also the engine Ford ran in the Baja race I believe.
/ 2.7EB vs 3.5EB? #37
Whoever said the 5.0L is a close second to the 3.5EB for towing has never towed with a 3.5EB. Big difference in low end torque.
Agree. We had a Ford E250 van, Express 2500, replaced with a Transit with 3.5EB.
The EcoBoost got much better mileage unloaded, and had much more power towing 5-7,000 lbs.
The van Market is mostly work truck and fleet trucks (you don’t see any “King Ranch” vans!) and the 3.5EB has become the engine of choice for towing. They are selling very few diesels in the T250/350 market.
/ 2.7EB vs 3.5EB? #39
On a straight, flat road, for 23 seconds?
Here’s a guy who towed 11,700 and got called out, so he responded in detail.
Umm....the truck receiver hitch is only rated that much if WEIGHT DISTRIBUTION is used? **** even my old 7.3 F250 was only rated 500/5000 no weight distribution and 1000/10000 with weight distribution. I get the ball and drawbar are he has are rated the right weight. Why didn't he show the sticker on the truck hitch?
/ 2.7EB vs 3.5EB? #40
He missed a bunch of critical points. He is no doubt illegal on total weight towed with a weight carrying hitch, tongue weight with a weight carrying hitch, and likely illegal on RGAWR and GVWR of the truck. He said the trailer is around ~10K but indicated he doesn't go over 11.7K. So he likely runs tongue weights up to 1,200 pounds or more. 1,200 pounds with a weight carrying hitch adds about 1,700 to the rear axle. He doesn't even know what a weight distribution hitch is! Not the guy I would take advice from for towing.
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
7x16 Enclosed Spray Foam Trailer (A65563)
7x16 Enclosed...
Engine knock
Engine knock
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
1996 International Paystar 5000 Log Truck (A62679)
1996 International...
