1996 JD 670 wiring help needed
/ 1996 JD 670 wiring help needed #1
Kcorey
North Madison, CT
Hello all i recently purchased a 1996 JD 670 tractor with loader that was sitting for approx 1 1/2 years. i went threw it and got her running. I did not have any fuel at first when i cracked injector lines to bleed system ( yes i know it is a self bleeding system but i always bleed small diesels like this). Well i had no fuel at all , i suspected fuel shutdown solenoid and sure enough when i manually pull solenoid back she fired right up. Now i checked for power at the solenoid plug and found no power at any of the 3 wires. does anyone have a wiring diagram or schematic for this machine? Also i checked fuses and i have a blown 3 amp fuse but not sure what it is for... anyone have a fuse diagram also? thanks
/ 1996 JD 670 wiring help needed #2
I have a PDF of the Deere technical manual, you are more than welcome to it. Shoot me your email if you want it. All the wiring schematics are in it.
Joe
/ 1996 JD 670 wiring help needed #3
3 amp fuse sounds about right for the solenoid shut off, if it keeps blowing after a change, check all the wires going to the solenoid, one of them is probably shorting to ground, check especially where they have been "tied" to something.
Yeah I checked the wires and there was a frayed wire where it was ties together right by the plug. All fixed thanks for the help
