1994 Jeep
/ 1994 Jeep #1
Daryl
Southwest Virginia
New Holland TC30,, Kubota Bx2360
My jeep runs at a temp of about 200-210 F. While setting in traffic it gets close to red mark in temp gauge. Question is should I change thermostats.
What is normal running temp supposed to be?
Not sure what temp thermostat I have but was thinking of going to 180F.
Thanks
daryl
/ 1994 Jeep #2
Could be many things. Radiator could be plugged or reduced flow, thermostat could be bad, could have an air bubble in the line. Best bet is to clean and flush the system and put in a new thermostat.
/ 1994 Jeep #3
</font><font color="blue" class="small">( While setting in traffic it gets close to red mark in temp gauge. )</font>
Check to make sure your fan is working.
/ 1994 Jeep
I am sure it does need flushing but have always been told if you do not flush it regularly, which I have not, it will cause it to leak. Thought maybe just changing the thermostat would help.
Thanks Daryl
/ 1994 Jeep
Thanks. Fan is working. It has 2 fans and both kick on and off.
daryl
/ 1994 Jeep #7
I don't remember if they had pressure radiator caps or not but that's a possible fix as well. A system that doesn't maintain pressure is going to overheat sooner or later.
2019 FOREST RIVER WILDWOOD (A67714)
2019 FOREST RIVER...
PAIR OF TRACTOR TIRES AND RIMS (A67714)
PAIR OF TRACTOR...
2008 MISSISSIPPI BOTTLE TRAILER (A67714)
2008 MISSISSIPPI...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A66736)
2017 Volvo VNL T/A...
Generator (A64553)
Generator (A64553)
