1989 110 loader/backhoe
/ 1989 110 loader/backhoe #1
sotocon71
1989 john deer 110 loader
Hello i have a john deere 110 that has been a nightmare, tractor operates fine until the engine is up to temp. then i lose forward pedal on the hydrostatic transmission. it wont let me do a manual recalibration until it cools down, things that have been repaired or replaced are.
repaired corroded orange wire (673c) at junction. also inspected complete harness from pedals to hst controller. replaced forward pedal potentiometer and adjusted to spec at BOT and TOT, adjusted reverse pedal also, split the tractor in two and replaced both forward and reverse proportional solenoids. the only thing that has not been replaced is the HST controller. local john deere dealership said that they have never sold a controller.
HST service code flashes forward pedal potentiometer when it stops working.
any help would be appreciated if anyone has run into a similar situation?
/ 1989 110 loader/backhoe #2
sotocon71
Welcome to TBN
This work being done by the dealer? or yourself? Do you have the service tech manual? Assume you have it, as deep as you have explained the efforts so far.
hello thanks for the quick reply, I've been doing all the work myself i have the service manual but it seems very limited on the info.
/ 1989 110 loader/backhoe #4
have you tried searching on here? I have seen several posts on similar problems from the past on here.
/ 1989 110 loader/backhoe #5
try these 2. there are more but I have to get back to work.
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2017 Versatile 260 (A64126)
2017 Versatile 260...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
