1979 John deere 301a not going into forward
   / 1979 John deere 301a not going into forward #1
Mach1mike
Bridgetown nj
1979 John Deere 301a, PTO, single stage clutch w/ reverser
tractor details
single stage clutch
PTO
REVERSER
3pt hitch
ok, I bought the tractor 3 weeks ago the guy told me the charge pump was bad, within an hour I concluded the clutch was bad. He said, the tractor had just stopped moving and the hydro's had died. he had already changed the front hydro pump and all of the filters. when I replaced the clutch and started the tractor back up, I regained the use of the Hydro's but not the trans (at all) the next night I was able to hook a pressure gauge to the bottom of the reverser valve, the gauge read 150lbs in reverse and neutral (the strange part is, now reverse started working) the gauge went to 24lbs or so in forward. I am looking to verify my suspisions. possibilty A) cracked supply/return line or failed seal to forwared clutch pack? I guess my real questions are because this seems to be a "pressure thing" my clutch pack should be ok? and since I removed the 2 inspection ports on top the reverser valve w/ the tractor running ((not recommended :laughing:) (I had already returned the gauge I had borrowed)when shifting into forward or reverse there was plenty of pressure they both shot to the celling of my garage, lesson learned! lol. that being said, since there is obviosly pressure being sent to the forward clutch pack, the failure has to be between the valve and clutch pack or the return line, correct?
on a side note: I found it very frustrating that hardly anyone ever posted how they resolved there similar issues.
   / 1979 John deere 301a not going into forward #2
Welcome to the hands-on school for JD closed-center hyd's with reverser. I think you need to buy you a 300 psi gauge from Surplus center for about $15. Have you checked the reverser valve control linkage for loose/sheared pins?
lol I will be picking another gauge up tonight.. all of the linkage is tight and working.thx
   / 1979 John deere 301a not going into forward #4
The forward clutch is weak when hot on our 1983 JD backhoe. I expect it is the seals in it but one guy with the issue found one on the linkage pins worn through so Tx Jim post is right on. Best of luck. Did the seller mention the forward clutch being weak for years before the loss of forward motion?
I had also read about the linkage and the pins, prior to starting the "project" so I new to check them. no, there was no mention of a weak clutch. he said they were loading sand last winter and the machine just went limp.
by the way it runs great in reverse. The neighbors think I'm nuts! lol
   / 1979 John deere 301a not going into forward #7
Seems like the most likely problem area would be the sealing rings for the forward clutch. That is what I have found most often. Check key #2 and 2a in drawing. Also the bushing the seal rings ride in wears often also. Key#1. While the clutch pack is out, replace seals #7 & 9 also. This clutch pack is accessed from the same split you had apart for the main clutch. If any of the oil lines need replaced, that is done at the split between clutch housing and trans housing.
So once I open the clutch pack housing should that be a wet or dry area? I am assuming dry unless the seals are bad. Is there any way to check the tubes w/o disassembling the trans? Air maybe?
Thanks for your help
Ok got the clutch pack out, I haft to admit
Ok, I got the clutch pack out, I haft to admit so do the seals ( to the naked and untrained eye) thoughts on the pictures of the discs?
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
2013 Ford Edge (A54815)
2013 Ford Edge...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
17307 (A55853)
17307 (A55853)
